Wyze Video Doorbell v2 Installation Guide & Setup Tips
Wyze Video Doorbell v2 Installation Process
Installing the Wyze Video Doorbell v2 is a straightforward process designed to get your home security up and running quickly. This wired video doorbell offers advanced features such as 2K video resolution, two-way audio, and local microSD storage, making it a top choice for smart home security.
What’s Included in the Box?
When you purchase the Wyze Video Doorbell v2, you receive everything needed for installation:
  • Wyze Video Doorbell v2 unit
  • Wyze Chime Controller
  • Wall Plate
  • 30° Wedge for angled mounting
  • Installation Kit (screws, wire caps, anchors)
  • Extension Wires
  • Quick Start Guide
This comprehensive kit ensures you have all the hardware necessary to mount and connect your doorbell securely.
Step-by-Step Installation Guide
1. Turn Off Power: Before starting, switch off power to your existing doorbell at the breaker to ensure safety. 2. Remove Existing Doorbell: Unscrew and disconnect your current doorbell from the wiring. 3. Mount the Chime Controller: The included Wyze Chime Controller must be installed inside your home near your existing chime to enable sound notifications. 4. Attach the Wall Plate: Use the screws and anchors to mount the wall plate where you want your doorbell installed. 5. Connect Wiring: Attach the existing doorbell wires to the terminals on the Wyze Video Doorbell v2. The device requires 16V-24V AC power with at least 10VA. 6. Mount the Doorbell: Secure the doorbell onto the wall plate. Use the included wedge if your door frame is angled or if you want to adjust the viewing angle. 7. Restore Power: Turn the power back on at the breaker. 8. Set Up in the Wyze App: Follow the in-app instructions to connect your doorbell to Wi-Fi and complete the setup.
The included wedge accessory is especially useful for porches with stairs or angled door frames, allowing you to optimize the camera’s field of view and eliminate blind spots.
Installation Tips for Optimal Performance
  • Use the Wedge Kit: The Wyze Video Doorbell v2 Wedge Kit includes a 15° horizontal bracket and two 7.5° vertical brackets to fine-tune your doorbell’s angle. This accessory is weather-resistant and easy to install, ensuring maximum coverage of your porch or entryway.
  • Check Power Requirements: Ensure your doorbell transformer meets the 16V-24V AC, ≥10VA specification for proper operation.
  • Position for Best View: The doorbell’s 2K camera offers a wide 135° horizontal and 103° vertical field of view, but proper mounting height and angle will maximize coverage.
  • Weatherproof Installation: The doorbell is IP65 rated, so it withstands rain and dust, but mounting under a porch roof can extend its lifespan.
Homeowner installing smart doorbell on porch Enhance your home security with easy installation.
Features of Wyze Video Doorbell v2
  • 2K Video Resolution: Crystal-clear 2048 x 1536 video quality captures every detail.
  • Local and Cloud Storage: Supports microSD cards up to 256GB for local recording, plus optional cloud storage with Wyze Security Plan.
  • Two-Way Audio: Built-in microphone and speaker allow you to communicate with visitors in real time.
  • Motion-Activated Voice Deterrence: Automatically plays a warning message to deter unwanted guests.
  • Wide Field of View: 135° horizontal and 103° vertical coverage ensures you see the entire porch area.
  • Night Vision: Six 940nm IR lights provide clear video even in low light.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Durable Build: Polycarbonate body with resin lens and IP65 weather resistance for all-season reliability.
For those with angled door frames or porches with stairs, the Wyze Video Doorbell v2 Wedge Kit is an essential accessory. It allows you to adjust the doorbell’s viewing angle horizontally and vertically, eliminating blind spots and improving security coverage.
  • Includes 15° horizontal bracket and two 7.5° vertical brackets
  • Quick and easy installation with included screws
  • Weather-resistant plastic construction
  • Compatible exclusively with Wyze Video Doorbell v2
  • 1-year warranty included
Using the wedge kit ensures your doorbell camera captures the best possible view of your entryway, enhancing your home’s security.
Refurbished Wyze Video Doorbell v2 Option
If you’re looking for a budget-friendly alternative, the Refurbished Wyze Video Doorbell v2 offers the same features and performance as the new model but at a reduced price. Each refurbished unit is fully tested and guaranteed to work like new.
  • Same 2K video and two-way audio capabilities
  • Includes all original accessories and installation kit
  • 1-year warranty for peace of mind
  • Environmentally friendly choice
Choosing a refurbished doorbell is a smart way to secure your home without compromising on quality or features.
Enhance your home security today with the Wyze Video Doorbell v2 and its accessories. With easy installation, superior video quality, and smart features, it’s the perfect solution to monitor your front door from anywhere. Smart home front porch with video doorbell Secure your home with Wyze’s smart video doorbell.
Summary of Products Mentioned
  • Wyze Video Doorbell v2: Advanced wired video doorbell with 2K video, two-way audio, and local storage.
  • Wyze Video Doorbell v2 Wedge Kit: Adjustable mounting accessory for optimal camera angles.
  • Refurbished Wyze Video Doorbell v2: Certified pre-owned doorbell with full features at a lower price.
FeatureWyze Video Doorbell v2Wyze Video Doorbell v2 Wedge Kit(Refurbished) Wyze Video Doorbell v2
TypeWired Video DoorbellAccessory (Wedge Kit for Doorbell v2)Refurbished Wired Video Doorbell
Video Resolution2K (2048 x 1536)N/A2K (2048 x 1536)
Local StoragemicroSD slot for local recordingN/AmicroSD slot for local recording
Cloud StorageOptional with Cam Plus subscriptionN/AOptional with Wyze Security Plan
Two-way AudioYesN/AYes
Motion-activated Voice DeterrenceYes (requires Cam Plus or Cam Protect)N/AYes (requires subscription)
Pre-roll Motion Recording3-6 secondsN/A3-6 seconds
Weather ResistanceIP65Weather-resistant plasticIP65
Night VisionColor Night Vision with Starlight SensorN/AColor Night Vision with Starlight Sensor
Field of View (Horizontal)135°N/A135°
Power16V-24V AC, ≥10VAN/A16V-24V AC, ≥10VA
CompatibilityWorks with existing chime (includes chime controller)N/AWorks with existing chime (includes chime controller)
Included ItemsDoorbell, Chime Controller, Wall Plate, 30° Wedge, Installation Kit, Wire Caps, Extension Wires, Screws, Anchors, Quick Start Guide1x 15° Horizontal + 2x 7.5° Vertical WedgesSame as new version
Dimensions4.3in x 1.7in x 0.9in (110mm x 44mm x 24mm)N/A4.3in x 1.7in x 0.9in (110mm x 44mm x 24mm)
WarrantyStandard (usually 1 year)N/A1 Year
Price$44.98$8.99 (Wedge Kit Only) / $51.97 (Doorbell + Wedge Kit)$29.98 (Refurbished)
MaterialPolycarbonate body, Resin lensThick, weather-resistant plasticPolycarbonate body, Resin lens
Sensor TypeCMOS Starlight SensorN/ACMOS Starlight Sensor
Frame Rate (Day/Night)20 FPS / 15 FPSN/A20 FPS / 15 FPS
ConnectivityWi-Fi 2.4 GHz b/g/nN/AWi-Fi 2.4 GHz b/g/n
Phone CompatibilityAndroid 9.0+, iOS 15.0+N/AAndroid 9.0+, iOS 15.0+
IntegrationsAlexa, Google Assistant, IFTTTN/AAlexa, Google Assistant, IFTTT
What is included in the Wyze Video Doorbell v2 box?The Wyze Video Doorbell v2 package includes the doorbell unit, Wyze Chime Controller, wall plate, 30° wedge for angled mounting, installation kit (screws, wire caps, anchors), extension wires, and a quick start guide. This comprehensive kit provides all the hardware needed for secure installation.
How do I install the Wyze Video Doorbell v2?To install the Wyze Video Doorbell v2, turn off power at the breaker, remove your existing doorbell, mount the Wyze Chime Controller inside your home, attach the wall plate, connect the doorbell wiring (requires 16V-24V AC, ≥10VA), mount the doorbell, restore power, and complete setup in the Wyze app. Detailed step-by-step instructions are included in the quick start guide.
What are the power requirements for the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 requires a doorbell transformer that supplies 16V-24V AC with at least 10VA. Ensure your existing wiring meets these specifications for proper operation.
What features does the Wyze Video Doorbell v2 offer?The Wyze Video Doorbell v2 features 2K video resolution (2048 x 1536), two-way audio, local microSD storage up to 256GB, optional cloud storage, motion-activated voice deterrence, a wide 135° horizontal and 103° vertical field of view, night vision, smart home integration with Alexa, Google Assistant, and IFTTT, and an IP65 weather-resistant build.
How does the Wyze Video Doorbell v2 Wedge Kit improve installation?The Wyze Video Doorbell v2 Wedge Kit includes a 15° horizontal bracket and two 7.5° vertical brackets, allowing you to adjust the doorbell’s viewing angle for optimal coverage. It is weather-resistant, easy to install, and helps eliminate blind spots, especially on angled door frames or porches with stairs.
Is the Wyze Video Doorbell v2 weatherproof?Yes, the Wyze Video Doorbell v2 is IP65 rated, making it resistant to rain and dust. For extended lifespan, it is recommended to mount the doorbell under a porch roof if possible.
Can I use local storage with the Wyze Video Doorbell v2?Yes, the Wyze Video Doorbell v2 supports local storage with microSD cards up to 256GB, allowing you to record and access video footage directly from the device. Cloud storage is also available with a Wyze Security Plan.
Is the Wyze Video Doorbell v2 compatible with smart home systems?The Wyze Video Doorbell v2 is compatible with Alexa, Google Assistant, and IFTTT, enabling voice control and smart home automation.
What is the difference between the new and refurbished Wyze Video Doorbell v2?The refurbished Wyze Video Doorbell v2 offers the same features and performance as the new model, including 2K video and two-way audio. Refurbished units are fully tested, include all original accessories and installation kit, come with a 1-year warranty, and are a more budget-friendly, environmentally conscious option.
Does the Wyze Video Doorbell v2 come with a warranty?Yes, both new and refurbished Wyze Video Doorbell v2 units come with a 1-year warranty for peace of mind.
Can you explain the features of the Wyze Video Doorbell v2 in more detail?What are the power requirements for the Wyze Video Doorbell v2?How does the Wyze Video Doorbell v2 integrate with smart home systems like Alexa or Google Assistant?
