Wyze Video Doorbell Replacement Kits: Enhanced Mounting, Screws, and Cables
Looking for a reliable Wyze video doorbell replacement kit that includes screws, cables, and enhanced mounting stability? Discover the best Wyze solutions designed for easy installation, secure mounting, and superior performance. Whether you need a wired or battery-powered option, Wyze has you covered with advanced features and all the essential hardware for a seamless upgrade.
Wyze Video Doorbell v2: The Ultimate Wired Replacement Kit
Key Features & Specs
- 2K Video Resolution: Capture every detail at your doorstep with crystal-clear 2K video.
- 24/7 Local Recording: Supports microSD cards up to 256GB for continuous, local video storage.
- Enhanced Mounting Stability: Includes a wall plate, 30° angled wedge, and a comprehensive screw kit (long and short screws, wall anchors) for secure installation on any surface.
- Complete Installation Kit: Comes with extension wires, wire caps, and a quick start guide for a hassle-free setup.
- Works with Existing Chime: No need to bypass your home’s chime—keep your familiar doorbell sound.
- Weatherproof Design: IP65-rated to withstand rain, snow, and extreme temperatures.
- Smart Features: Two-way audio, motion-activated voice deterrence, and compatibility with Alexa and Google Assistant.
“Enjoy head-to-toe viewing, immaculate 2K resolution, and the peace of mind that comes with a secure, stable installation.”
Wyze Duo Cam Battery Doorbell: Flexible, Screw-In or Adhesive Mounting
Dual-Camera Innovation & Easy Installation
- Dual Cameras: One camera for visitors, one for packages—double the coverage, double the security.
- 2K HD Video + Color Night Vision: See every detail, day or night.
- All-Inclusive Mounting Kit: Includes long and short screws, expansion tubes, wire nuts, extension wires, and a 30° corner kit for perfect viewing angles and enhanced mounting stability.
- Flexible Power: Use the removable battery pack for wire-free installation or hardwire for continuous power and 24/7 recording.
- Wi-Fi Chime Included: Get alerts anywhere in your home.
- Weather Resistant: IP65-rated for reliable outdoor use.
- Quick, Tool-Free Option: Mount with included 3M adhesive for renters or temporary setups.
“Mount it in two shakes of a dog’s tail with the included adhesive strips. No wires or screws. You can also wire it if you really want to.”
Wyze Video Doorbell v2 Wedge Kit: Perfect Your Viewing Angle
Accessory for Enhanced Mounting Stability
- 30° Angled Wedge: Ideal for angled door frames or porches with stairs, ensuring you never miss a visitor or package.
- Easy Installation: Designed to work seamlessly with the Wyze Video Doorbell v2, the wedge kit comes with all necessary screws and hardware.
- Eliminate Blind Spots: Adjust your doorbell’s field of view for maximum security coverage.
“Goodbye to blind spots, hello to a superior home security experience.”
Why Choose Wyze for Your Video Doorbell Replacement?
- Comprehensive Kits: Every Wyze doorbell kit includes the screws, cables, and mounting accessories you need for a secure, stable installation.
- Enhanced Security: Advanced features like 2K video, dual cameras, and AI-powered alerts keep your home protected.
- Flexible Installation: Whether you prefer wired or battery-powered, Wyze offers solutions for every home and entryway.
In Summary
Upgrade your home’s security and convenience with Wyze’s video doorbell replacement kits. Enjoy enhanced mounting stability, all necessary installation hardware, and cutting-edge smart features—everything you need for a seamless, secure, and reliable doorbell experience.
