Best Extra Chime Options for Wyze Video Doorbell v1 System
If you own the Wyze Video Doorbell v1 system and are looking to enhance your doorbell experience with an extra chime, this guide will help you find the best compatible options. While the original Wyze Video Doorbell v1 does not come with a dedicated extra chime accessory, there are excellent Wyze products designed to work seamlessly with Wyze doorbells, including universal chimes and bundles that improve your home’s alert system.
Wyze Universal Wi-Fi Chime: The Ideal Extra Chime for Wyze Doorbells
Easy Setup and Compatibility
The
Wyze Universal Wi-Fi Chime is the perfect extra chime solution for your Wyze Video Doorbell v1 system. It requires no complicated wiring—simply plug it in and stay informed whenever someone rings your doorbell. This chime works with all Wyze cameras and doorbells, making it a versatile and convenient choice.
Features That Enhance Your Doorbell Experience
- 17 different tones to customize your alert sound
- Smart Automations allow the chime to ring not only when the doorbell is pressed but also when your Wyze cameras detect motion or a person
- Connect multiple devices to cover different areas of your home
- Wi-Fi connectivity ensures reliable notifications without the need for physical wiring
- Compatible with voice assistants like Alexa and Google Assistant for hands-free control
Specifications
- Dimensions: 81 x 53 x 38 mm
- Power Input: 10-24V AC, 10VA 60Hz
- Operating Temperature: -4°F to 122°F (-20°C to 50°C)
- Indoor use only
The Wyze Universal Wi-Fi Chime is a fuss-free, smart way to never miss a visitor or delivery again.
Upgrade Your Doorbell with Wyze Video Doorbell v2 and Included Chime Controller
Why Consider Upgrading to Wyze Video Doorbell v2?
If you are open to upgrading from your v1 system, the
Wyze Video Doorbell v2 offers a significant enhancement in video quality and chime integration. It comes bundled with a
Wyze Chime Controller, which supports an extra chime for your home.
Key Features of Wyze Video Doorbell v2
- 2K video resolution (2048 x 1536) for crystal-clear video
- Local microSD storage up to 256GB for continuous recording
- Two-way audio and motion-activated voice deterrence
- Wide field of view: 135° horizontal, 103° vertical, 166.8° diagonal
- Weather-resistant with IP65 rating, suitable for all seasons
- Includes a Wyze Chime Controller to connect an extra chime easily
What’s Included in the Package?
- Wyze Video Doorbell v2
- Wyze Chime Controller
- Wall Plate and Wedge for angled installation
- Installation kit with wire caps and screws
This bundle ensures you get a high-quality doorbell camera with a compatible chime system that can be expanded with additional chimes if needed.
Alt text: Family using Wyze Video Doorbell with extra chime at home entrance
Additional Considerations: Bundles and Accessories
Front Porch Security Bundle
For those looking for a comprehensive security upgrade, the
Front Porch Security Bundle includes a Wyze Video Doorbell (v1 or v2 depending on the bundle), a Wyze Chime, and a Wyze Lock. This bundle offers:
- 1080p HD video doorbell with two-way audio
- Multiple chime sounds including modern, classic, and animal sounds
- Remote locking/unlocking with Wyze Lock integration
- Alexa and Google Assistant compatibility
This bundle is ideal if you want to enhance your entire front porch security system with a reliable extra chime included.
Wedge Kit for Better Doorbell Placement
If your doorbell installation location requires an angled mount for better coverage, the
Wyze Video Doorbell v2 Wedge Kit is a useful accessory. While it does not add chime functionality, it improves the camera’s field of view, ensuring you don’t miss any visitors.
Summary: Best Extra Chime for Wyze Video Doorbell v1
- Wyze Universal Wi-Fi Chime is the best standalone extra chime compatible with Wyze Video Doorbell v1. It’s easy to install, offers multiple tones, and integrates with your smart home system.
- Consider upgrading to Wyze Video Doorbell v2 for a built-in chime controller and enhanced video features.
- Bundles like the Front Porch Security Bundle provide a complete solution with extra chimes and smart locks for full home security.
Enhance your Wyze doorbell system today with these extra chime options to never miss a visitor or delivery again!
What is the best extra chime option for Wyze Video Doorbell v1?
The best extra chime for Wyze Video Doorbell v1 is the Wyze Universal Wi-Fi Chime. It is easy to install, requires no wiring, and offers 17 different tones. It works seamlessly with all Wyze cameras and doorbells, making it a versatile and reliable choice.Is the Wyze Universal Wi-Fi Chime compatible with Wyze Video Doorbell v1?
Yes, the Wyze Universal Wi-Fi Chime is fully compatible with Wyze Video Doorbell v1. It connects via Wi-Fi and can be set up quickly without any complicated wiring.What features does the Wyze Universal Wi-Fi Chime offer?
The Wyze Universal Wi-Fi Chime offers 17 customizable tones, smart automations for alerts when the doorbell is pressed or when Wyze cameras detect motion, the ability to connect multiple chimes throughout your home, Wi-Fi connectivity, and compatibility with Alexa and Google Assistant for hands-free control.Can I use multiple Wyze Universal Wi-Fi Chimes in my home?
Yes, you can connect multiple Wyze Universal Wi-Fi Chimes to your Wyze Video Doorbell v1 system to ensure you hear alerts in different areas of your home.Does Wyze Video Doorbell v1 come with an extra chime?
No, the Wyze Video Doorbell v1 does not come with a dedicated extra chime accessory. However, you can add the Wyze Universal Wi-Fi Chime for enhanced notifications.Should I upgrade to Wyze Video Doorbell v2 for better chime integration?
Upgrading to Wyze Video Doorbell v2 is a great option if you want enhanced video quality and built-in chime integration. The v2 model comes with a Wyze Chime Controller, making it easy to add extra chimes to your system.What are the key features of Wyze Video Doorbell v2?
Wyze Video Doorbell v2 features 2K video resolution, local microSD storage up to 256GB, two-way audio, motion-activated voice deterrence, a wide field of view, weather resistance (IP65), and includes a Wyze Chime Controller for easy chime expansion.What is included in the Wyze Video Doorbell v2 package?
The Wyze Video Doorbell v2 package includes the doorbell itself, a Wyze Chime Controller, a wall plate and wedge for angled installation, and an installation kit with wire caps and screws.Are there any Wyze bundles that include an extra chime?
Yes, the Front Porch Security Bundle includes a Wyze Video Doorbell (v1 or v2 depending on the bundle), a Wyze Chime, and a Wyze Lock. This bundle provides a complete front porch security solution with extra chime functionality.What is the purpose of the Wyze Video Doorbell v2 Wedge Kit?
The Wyze Video Doorbell v2 Wedge Kit is an accessory that allows you to mount your doorbell at an angle for better coverage. While it does not add chime functionality, it improves the camera’s field of view to ensure you don’t miss any visitors.Can I control the Wyze Universal Wi-Fi Chime with voice assistants?
Yes, the Wyze Universal Wi-Fi Chime is compatible with Alexa and Google Assistant, allowing for hands-free control and integration with your smart home system.
