DIY Wyze Refurbished Pro V2 Doorbell Installation Guide
DIY Installation of Wyze Refurbished Pro V2 Doorbell for Smart Home
Upgrading your home security with a Wyze Video Doorbell is a smart and affordable choice. Whether you choose the Wyze Video Doorbell v2 or the Wyze Video Doorbell Pro, both offer excellent features and straightforward DIY installation options that fit perfectly into any smart home setup. This guide will walk you through the key specs and installation steps for the Wyze refurbished Pro V2 doorbell, helping you enhance your home’s safety and convenience.
Overview of Wyze Video Doorbell Options
Wyze Video Doorbell v2 (Refurbished)
The Wyze Video Doorbell v2 is a budget-friendly, wired doorbell solution designed for easy integration with your existing mechanical doorbell system. It offers:
  • 2K Resolution (2048 x 1536) for clear video quality.
  • Wide Field of View: 135° horizontal and 103° vertical.
  • Power Requirements: Requires an existing wired mechanical doorbell with 16V-24V and 10VA power output.
  • Included Accessories: Doorbell, chime controller, wall plate, wedge for angled mounting, wire caps, extension wires, screws, and anchors.
  • Local and Cloud Storage: Supports both for video recordings.
  • DIY Friendly: No technician needed if you are comfortable turning off power and handling basic wiring.
The Wyze Video Doorbell Pro is a premium option with enhanced features and flexible installation options:
  • 1440 x 1440 Resolution with a 150° horizontal and vertical field of view for broader coverage.
  • Power Options: Wired installation with battery backup, allowing for more flexible placement.
  • Auxiliary Chime Support: Comes with the Wyze Chime Pro for enhanced chime functionality.
  • Wireless or Wired Installation: Can be mounted using screws or 3M tape for no-drill installation.
  • Cloud Storage Only: Supports cloud video storage.
  • Included Tools and Accessories: Back plates for screw or tape mounting, extension wires, wire nuts, screwdriver, USB charging cable, and quick start guide.
  • No Technician Required: Designed for easy DIY installation with detailed app guidance.
Step-by-Step DIY Installation Guide for Wyze Refurbished Pro V2 Doorbell
Preparation Before Installation
Ensure you have an existing wired mechanical doorbell and chime with a power supply of 16V-24V and at least 10VA output. If unsure about wiring, consult a licensed electrician.
  • Turn off power at your electrical panel to avoid any risk.
  • Gather the included tools and accessories from the box.
  • Download and open the Wyze app on your smartphone.
  • Follow the initial setup steps in the app to prepare your doorbell for installation.
Installing the Wyze Doorbell Chime Controller
The chime controller is essential for integrating the Wyze doorbell with your existing mechanical chime.
  • Open your chime box and take a photo of the current wiring for reference.
  • Follow the app’s wiring instructions to connect the chime controller wires to the correct terminals.
  • For homes with 1 doorbell, typically 2 wires are involved; for 2 doorbells, 3 wires may be present.
  • After wiring, close the chime box and confirm the chime controller installation is complete.
Mounting the Doorbell
  • Remove your old doorbell and disconnect the wires.
  • Decide on the mounting style: flat against the wall using the wall plate or angled using the wedge (30º).
  • Mark screw holes at approximately 4.3 feet (1.2 meters) from the ground for optimal visitor access.
  • Drill holes and insert wall anchors.
  • Pass the wires through the wall plate and secure it to the wall.
  • Attach extension wires to the doorbell terminals if needed, securing with wire caps.
  • Mount the doorbell onto the wall plate by sliding it down until it clicks into place.
  • Turn power back on and wait for the doorbell’s status light to flash orange, indicating it’s ready to connect.
Final Setup in the Wyze App
  • Return to the Wyze app to complete the setup.
  • Connect the doorbell to your 2.4 GHz Wi-Fi network.
  • Customize detection settings and notifications.
  • Test the doorbell button and chime functionality.
Tips for a Successful Installation
  • Always double-check that power is off before handling wiring.
  • Use the app’s step-by-step tutorial and wiring diagrams for guidance.
  • If your chime does not ring after installation, try the alternate wiring method provided by Wyze or consider upgrading your transformer.
  • For homes without an existing chime, installation may require additional equipment or professional help.
  • Keep the doorbell firmware and app updated for the best performance.
Why Choose Wyze Refurbished Pro V2 Doorbell for Your Smart Home?
  • Cost-Effective: Refurbished units offer premium features at a lower price.
  • High-Quality Video: Crisp 2K resolution ensures you never miss a detail.
  • Easy DIY Installation: Designed for homeowners with basic electrical knowledge.
  • Smart Home Integration: Works seamlessly with Wyze app and other Wyze devices.
  • Reliable Power and Chime Compatibility: Works with most existing mechanical doorbell systems.
Smart Home Doorbell Installation Enhance your home security with easy DIY installation of Wyze Video Doorbell.
Conclusion
Installing the Wyze refurbished Pro V2 doorbell yourself is a straightforward process that can significantly boost your home’s security and convenience. With clear app instructions, included accessories, and compatibility with existing wiring, you can enjoy smart home benefits without the need for a technician. Whether you opt for the Wyze Video Doorbell v2 or the Pro model, both provide excellent value and performance for your smart home setup.
What are the main features of the Wyze Refurbished Pro V2 Doorbell?The Wyze Refurbished Pro V2 Doorbell offers 2K video resolution (2048 x 1536), a wide 135° horizontal and 103° vertical field of view, compatibility with existing wired mechanical doorbell systems (16V-24V, 10VA), local and cloud storage options, and easy DIY installation with included accessories.
Is the Wyze Refurbished Pro V2 Doorbell easy to install by myself?Yes, the Wyze Refurbished Pro V2 Doorbell is designed for DIY installation. If you are comfortable turning off power and handling basic wiring, you can install it without a technician by following the step-by-step instructions provided in the Wyze app and the included installation guide.
What do I need before installing the Wyze Refurbished Pro V2 Doorbell?Before installing, ensure you have an existing wired mechanical doorbell and chime with a power supply of 16V-24V and at least 10VA output. Gather the included tools and accessories, turn off power at your electrical panel, and download the Wyze app to your smartphone.
How do I install the Wyze doorbell chime controller?To install the chime controller, open your chime box and take a photo of the current wiring. Follow the Wyze app’s wiring instructions to connect the chime controller wires to the correct terminals. After wiring, close the chime box and confirm the installation in the app.
What mounting options are available for the Wyze Refurbished Pro V2 Doorbell?You can mount the Wyze Refurbished Pro V2 Doorbell flat against the wall using the wall plate or at a 30º angle using the included wedge. Mark screw holes at about 4.3 feet (1.2 meters) from the ground for optimal access, drill holes, insert wall anchors, and secure the doorbell.
Does the Wyze Refurbished Pro V2 Doorbell work with my existing chime?Yes, the Wyze Refurbished Pro V2 Doorbell is designed to work with most existing wired mechanical chimes. If your chime does not ring after installation, try the alternate wiring method provided by Wyze or consider upgrading your transformer.
What should I do if my home does not have an existing chime?If your home does not have an existing chime, installation may require additional equipment or professional assistance. Consult the Wyze support resources or a licensed electrician for guidance.
How do I complete the setup of my Wyze Refurbished Pro V2 Doorbell in the app?After mounting the doorbell and restoring power, open the Wyze app, connect the doorbell to your 2.4 GHz Wi-Fi network, customize detection settings and notifications, and test the doorbell button and chime functionality.
What are the benefits of choosing a refurbished Wyze Pro V2 Doorbell?Refurbished Wyze Pro V2 Doorbells offer premium features at a lower price, including high-quality 2K video, easy DIY installation, smart home integration, and reliable compatibility with most existing mechanical doorbell systems.
What tips can help ensure a successful Wyze doorbell installation?Always double-check that power is off before handling wiring, use the app’s step-by-step tutorial and wiring diagrams, keep the doorbell firmware and app updated, and consult a licensed electrician if you are unsure about any part of the installation.
What are the key specifications of the Wyze Video Doorbell Pro?Can you explain the differences between the Wyze Video Doorbell v2 and the Pro model?What tools and accessories are included with the Wyze refurbished Pro V2 doorbell?
