How to Install Wyze Chime Controller for Doorbell v2
How to Install Wyze Chime Controller for Wyze Doorbell v2
Installing the Wyze Doorbell Chime Controller is a crucial step to ensure your Wyze Video Doorbell v2 works seamlessly with your existing mechanical chime. This guide will walk you through the installation process, helping you keep the classic doorbell sound while enjoying the advanced features of the Wyze Video Doorbell v2.
About Wyze Video Doorbell v2 and Chime Controller
The Wyze Video Doorbell v2 is a wired smart doorbell offering crystal-clear 2K video resolution, local microSD storage, and essential smart features like two-way audio, real-time alerts, and motion-activated voice deterrence. It works with your home's existing mechanical chime, thanks to the included Wyze Doorbell Chime Controller.
Key Features of Wyze Video Doorbell v2
  • 2K HD Video: Capture every detail on your porch with high-resolution video.
  • Local microSD Storage: Continuous 24/7 recording without relying solely on cloud storage.
  • Two-Way Audio: Speak directly to visitors through the Wyze app.
  • Motion-Activated Voice Deterrence: Automatically warn visitors they are being recorded.
  • Works with Existing Chime: Keep your traditional doorbell sound with the chime controller.
  • Weatherproof (IP65): Durable for all weather conditions.
  • Smart Home Integration: Compatible with Alexa and Google Home.
The chime controller protects your doorbell from power surges and ensures your mechanical chime rings properly, even if your chime is broken or non-functional.
Step-by-Step Installation Guide for Wyze Doorbell Chime Controller
Before installing the Wyze Video Doorbell v2, you must install the Wyze Doorbell Chime Controller inside your existing chime box.
What You Need
  • Phillips screwdriver
  • Your existing wired mechanical doorbell and chime
  • Wyze Doorbell Chime Controller (included with the doorbell)
  • Wyze app installed on your smartphone
Installation Steps
1. Prepare for Installation
  • In the Wyze app, tap Home, then tap the + icon.
  • Select Device > Cameras > Video Doorbells > Wyze Video Doorbell v2.
  • Check the box confirming you have a screwdriver and an existing wired doorbell.
  • Follow the prompts to verify you have all necessary items.
2. Power Off Your Doorbell Circuit
  • Turn off power to your existing mechanical doorbell at your electrical panel.
  • Press your doorbell button to confirm power is off.
3. Open Your Chime Box
  • Remove the cover of your chime box.
  • Take a photo of the current wiring for reference.
4. Connect the Chime Controller
  • In the Wyze app, select your chime wiring configuration (usually 2 or 3 wires).
  • Follow the app’s wiring instructions to connect the chime controller to the correct terminals.
  • For 2-wire setups, connect the jump wire as instructed.
  • For 3-wire setups, select the correct door and connect wires accordingly.
  • Use the wire caps included to secure connections.
5. Close the Chime Box
  • After wiring, close the chime box securely.
6. Install the Doorbell
  • Proceed to mount the Wyze Video Doorbell v2 on your wall using the included wall plate or wedge for angled mounting.
  • Connect the doorbell wires to the terminals or use the extension wires if needed.
  • Slide the doorbell onto the wall plate until it clicks into place.
7. Power On and Test
  • Turn the power back on at the electrical panel.
  • The doorbell should flash orange, indicating it is powered.
  • Press the doorbell button to test if the chime rings.
  • If the chime does not ring, check wiring or consider transformer power (recommended 20-30VA).
Note: If you do not have an existing mechanical chime or are unsure about wiring, contact a licensed electrician for assistance.
Tips for a Smooth Installation
  • Transformer Check: Ensure your transformer provides 16-24V AC and at least 10VA power output. A 20-30VA transformer is recommended for reliable chime operation.
  • Chime Compatibility: Wyze Video Doorbell v2 supports most mechanical chimes but is not compatible with integrated or chip-controlled chimes.
  • Use the Wyze App: The app provides detailed wiring diagrams and step-by-step instructions tailored to your chime setup.
  • Safety First: Always turn off power before working with electrical wiring.
  • Mounting Height: Install the doorbell approximately 4.3 feet (1.2 meters) from the ground for optimal viewing angle.
Why Install the Wyze Doorbell Chime Controller?
Installing the chime controller is essential even if your existing chime is broken. It protects your Wyze Video Doorbell v2 from power surges and ensures proper power flow, preventing damage and unexpected chime sounds.
Finalizing Your Setup
After installing the chime controller and mounting your doorbell:
  • Return to the Wyze app to complete the doorbell setup.
  • Scan the QR code on your phone to pair the doorbell.
  • Configure your preferences such as motion detection zones, quick responses, and voice deterrence.
  • Enjoy smart notifications and crystal-clear video from anywhere.
Smart Home Doorbell Installation Alt text: Person installing smart doorbell on home exterior
Summary
The Wyze Video Doorbell v2 combined with the Wyze Doorbell Chime Controller offers a perfect blend of modern smart home technology and traditional doorbell functionality. By following the installation steps carefully, you can enjoy enhanced security, clear video, and the familiar chime sound without hassle.
What is the Wyze Doorbell Chime Controller and why do I need it for Wyze Video Doorbell v2?The Wyze Doorbell Chime Controller is a device included with the Wyze Video Doorbell v2 that allows your smart doorbell to work seamlessly with your existing mechanical chime. It protects your doorbell from power surges and ensures your mechanical chime rings properly, even if the chime is broken or non-functional. Installing the chime controller is essential for proper operation and to prevent damage to your doorbell.
Is the Wyze Video Doorbell v2 compatible with my existing mechanical chime?Yes, the Wyze Video Doorbell v2 is designed to work with most traditional wired mechanical chimes when installed with the included Wyze Doorbell Chime Controller. However, it is not compatible with integrated or chip-controlled chimes.
What tools and materials do I need to install the Wyze Doorbell Chime Controller?To install the Wyze Doorbell Chime Controller, you will need a Phillips screwdriver, your existing wired mechanical doorbell and chime, the Wyze Doorbell Chime Controller (included with the doorbell), and the Wyze app installed on your smartphone.
How do I install the Wyze Doorbell Chime Controller for my Wyze Video Doorbell v2?To install the Wyze Doorbell Chime Controller: 1) Turn off power to your doorbell at the electrical panel. 2) Open your chime box and take a photo of the wiring. 3) Use the Wyze app to select your wiring configuration and follow the step-by-step instructions to connect the chime controller. 4) Secure the connections with the included wire caps, close the chime box, and proceed to mount the doorbell. 5) Restore power and test the chime. For detailed guidance, refer to the Wyze app during installation.
What should I do if my mechanical chime does not ring after installing the Wyze Doorbell Chime Controller?If your mechanical chime does not ring after installation, double-check your wiring connections and ensure the transformer provides adequate power (recommended 20-30VA). If issues persist, consult the Wyze app for troubleshooting or consider contacting a licensed electrician.
Can I install the Wyze Video Doorbell v2 if I don’t have an existing mechanical chime?Yes, you can install the Wyze Video Doorbell v2 even if you don’t have an existing mechanical chime. However, installing the chime controller is still recommended to protect your doorbell from power surges and ensure proper power flow.
What are the key features of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 offers 2K HD video resolution, local microSD storage for continuous 24/7 recording, two-way audio, motion-activated voice deterrence, weatherproof (IP65) design, and smart home integration with Alexa and Google Home. It also works with your existing mechanical chime using the included chime controller.
What transformer specifications are recommended for the Wyze Video Doorbell v2 and Chime Controller?For optimal performance, your transformer should provide 16-24V AC and at least 10VA power output. A 20-30VA transformer is recommended to ensure reliable chime operation with the Wyze Video Doorbell v2 and Chime Controller.
How do I complete the setup of my Wyze Video Doorbell v2 after installation?After installing the chime controller and mounting your doorbell, return to the Wyze app to complete the setup. Scan the QR code on your phone to pair the doorbell, then configure preferences such as motion detection zones, quick responses, and voice deterrence. You can then enjoy smart notifications and clear video from anywhere.
Is it safe to install the Wyze Doorbell Chime Controller myself?Yes, you can install the Wyze Doorbell Chime Controller yourself by following the step-by-step instructions in the Wyze app. Always turn off power at the electrical panel before working with wiring. If you are unsure about any step or do not have an existing mechanical chime, it is recommended to contact a licensed electrician for assistance.
What tools do I need to install the Wyze Doorbell Chime Controller?Can you explain the steps to power off my doorbell circuit?How do I ensure my transformer is compatible with the Wyze Video Doorbell v2?
