How to Install & Pair Wyze Chime with Wired Doorbell
How to Install and Pair Wyze Chime with Wired Doorbell
If you have a Wyze Video Doorbell v2 or the Front Porch Security Bundle, pairing your Wyze Chime with your wired doorbell is a straightforward process that enhances your home security and convenience. This guide will walk you through the installation and pairing steps, highlighting the features of the Wyze products involved.
Wyze Video Doorbell v2: Your Wired Doorbell Solution
Key Features
  • 2K Video Resolution: Capture clear, detailed video at 2048 x 1536 resolution.
  • Wide Field of View: 166.8° diagonal view to cover your porch area.
  • Two-Way Audio: Communicate with visitors via built-in microphone and speaker.
  • Motion-Activated Voice Deterrence: Automatically warns unwanted guests.
  • Local and Cloud Storage: Supports microSD cards up to 256GB and cloud storage with subscription.
  • Weather Resistant: IP65 rating ensures durability in all weather conditions.
  • Power Requirements: Works with 16V-24V AC wired doorbell systems.
What’s Included for Installation
  • Wyze Video Doorbell v2
  • Wyze Chime Controller
  • Wall Plate and Wedge for angled mounting
  • Installation Kit with wire caps, screws, and extension wires
  • Quick Start Guide
Installation Overview
1. Turn off power to your existing doorbell at the breaker. 2. Remove your old doorbell and disconnect the wires. 3. Mount the Wyze Chime Controller near your existing chime inside your home. 4. Connect the wires from your doorbell transformer to the chime controller. 5. Attach the Wyze Video Doorbell v2 to your doorframe using the included mounting hardware. 6. Turn power back on and follow the Wyze app instructions to complete setup.
The Wyze Chime Controller bridges your wired doorbell system with the Wyze app, enabling customizable chime sounds and volume control.
Pairing Wyze Chime with Your Wired Doorbell
Step-by-Step Pairing Guide
  • Download and open the Wyze app on your smartphone (compatible with Android 9.0+ and iOS 15.0+).
  • Add the Wyze Video Doorbell v2 to your device list by following the in-app prompts.
  • Power on the Wyze Chime Controller and ensure it is connected to your home Wi-Fi network.
  • In the app, navigate to the Doorbell settings and select “Pair Chime.”
  • Follow the app’s instructions to sync the chime controller with your doorbell.
  • Test the chime by pressing the doorbell button to confirm sound and notification functionality.
Chime Sound Options
Wyze Chime offers a variety of sounds including:
  • 5 modern tones
  • 4 classic doorbell sounds
  • 3 animal sounds
  • 6 automation sounds
  • 1 intruder alarm
This variety allows you to personalize your home’s alert system.
The Front Porch Security Bundle: Complete Smart Home Security
For those looking for an all-in-one solution, the Wyze Front Porch Security Bundle combines the Wyze Video Doorbell, Wyze Chime, and Wyze Lock for seamless front door security.
Bundle Highlights
  • 1080p HD Video Doorbell: View your porch with crisp video and two-way audio.
  • Wyze Chime: Connects easily to your wired doorbell system with multiple sound options.
  • Wyze Lock: Control your door lock remotely and monitor lock history via the Wyze app.
  • Smart Home Integration: Works with Alexa and Google Assistant for voice control.
  • Weather Resistant: All devices are built to withstand outdoor conditions.
This bundle simplifies installation and ensures all components work harmoniously for enhanced security.
Additional Wyze Cameras for Home Security
While the Wyze Video Doorbell v2 and Chime are perfect for your entryway, consider complementing your system with other Wyze cameras for full home coverage:
Wyze Cam Pan v3
  • 360° Pan and 180° Tilt: Covers every angle indoors or outdoors.
  • 1080p HD Video: Clear day and night vision with 4 IR LEDs.
  • IP65 Weather Resistant: Durable for outdoor use with optional power adapter.
  • Two-Way Audio: Built-in speaker and microphone with noise cancellation.
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 providing weather-resistant outdoor security
Wyze Cam v4
  • 2.5K QHD Resolution: Ultra-clear video with enhanced color night vision.
  • Motion-Activated Spotlight: Illuminates and alerts on movement.
  • Wi-Fi 6 Support: Faster and more reliable connectivity.
  • Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts.
Wyze Cam OG Telephoto
  • 3x Telephoto Lens: Zoom in on details with sharp clarity.
  • 1080p HD Video: Crisp video with night vision.
  • Compact and Weather Resistant: Ideal for indoor or outdoor use.
Summary
Installing and pairing your Wyze Chime with a wired doorbell like the Wyze Video Doorbell v2 is simple and enhances your home’s security and convenience. The Wyze Chime Controller integrates seamlessly with your existing wired system, offering customizable sounds and easy app control. For a comprehensive security setup, the Front Porch Security Bundle provides video, audio, and smart lock capabilities in one package. Enhance your home security further with Wyze’s range of cameras, including the versatile Wyze Cam Pan v3 and the high-resolution Wyze Cam v4.
Secure your home with Wyze’s smart, reliable, and easy-to-install devices designed for modern living.
FeatureWyze Video Doorbell v2The Front Porch Security BundleWyze Cam OG
TypeWired Video DoorbellBundle: Wyze Video Doorbell + Chime + Wyze LockWired Security Camera
Video Resolution2K (2560 x 1440)1080p HD1080p (1920 x 1080)
Field of ViewHead-to-toe view (exact degrees not specified)Not specified121.4° DFOV / 102.3° HFOV / 54.1° VFOV
Local StoragemicroSD slot for 24/7 local recordingNot specifiedSupports up to 256 GB microSD
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscription
Two-Way AudioYesYesYes
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect)Not specifiedNo
Night VisionColor Night Vision with Starlight sensorNot specifiedColor Night Vision with 4 IR LEDs
Weather ResistanceIP65Not specifiedIP65
Integration with Smart HomeAlexa, Google HomeNot specifiedAlexa, Google Assistant, IFTTT
PowerWiredWiredWired (5V/1A adapter)
Additional FeaturesPre-roll motion recording (3-6 seconds), chime controller includedIncludes Wyze Lock for remote locking/unlocking and lock historyBuilt-in spotlight (40 lumens), faster live streaming, noise & echo cancellation
Price$44.98 (Doorbell + Chime Controller)From $123.99 to $173.97 depending on variantFrom $29.98 (1 pack) to $89.94 (3 pack)
How do I install and pair the Wyze Chime with my wired doorbell?To install and pair the Wyze Chime with your wired doorbell, first turn off the power at the breaker and remove your old doorbell. Mount the Wyze Chime Controller near your existing chime, connect the wires from your doorbell transformer to the chime controller, and attach the Wyze Video Doorbell v2 to your doorframe. Restore power and use the Wyze app to add the doorbell, then follow the in-app instructions to pair the chime. Test the chime by pressing the doorbell button to ensure it works.
What are the key features of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 offers 2K video resolution (2048 x 1536), a 166.8° wide field of view, two-way audio, motion-activated voice deterrence, support for local (microSD up to 256GB) and cloud storage, IP65 weather resistance, and compatibility with 16V-24V AC wired doorbell systems.
What is included in the Wyze Video Doorbell v2 installation kit?The installation kit for the Wyze Video Doorbell v2 includes the doorbell itself, Wyze Chime Controller, wall plate and wedge for angled mounting, installation kit with wire caps, screws, extension wires, and a quick start guide.
How do I pair the Wyze Chime with my Wyze Video Doorbell v2 using the Wyze app?Download and open the Wyze app on your smartphone (Android 9.0+ or iOS 15.0+). Add the Wyze Video Doorbell v2 to your device list, power on the Wyze Chime Controller, and ensure it is connected to your Wi-Fi. In the app, go to Doorbell settings, select 'Pair Chime,' and follow the instructions to sync the chime controller with your doorbell. Test the chime to confirm functionality.
What chime sound options are available with Wyze Chime?Wyze Chime offers a variety of sound options, including 5 modern tones, 4 classic doorbell sounds, 3 animal sounds, 6 automation sounds, and 1 intruder alarm, allowing you to personalize your home’s alert system.
What is the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle is an all-in-one smart home security solution that includes the Wyze Video Doorbell, Wyze Chime, and Wyze Lock. It provides 1080p HD video, two-way audio, customizable chime sounds, remote lock control, and smart home integration with Alexa and Google Assistant. All devices are weather resistant for outdoor use.
Can I use additional Wyze cameras with my Wyze Video Doorbell v2 and Chime?Yes, you can enhance your home security by adding other Wyze cameras such as the Wyze Cam Pan v3 (with 360° pan and 180° tilt, 1080p HD video, and IP65 weather resistance), Wyze Cam v4 (2.5K QHD resolution, motion-activated spotlight, Wi-Fi 6 support), and Wyze Cam OG Telephoto (3x telephoto lens, 1080p HD video, compact and weather resistant).
Is the Wyze Video Doorbell v2 weather resistant?Yes, the Wyze Video Doorbell v2 is IP65 weather resistant, making it suitable for use in all weather conditions.
What are the power requirements for the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 requires a 16V-24V AC wired doorbell system for proper operation.
Does the Wyze Chime Controller allow for customizable chime sounds and volume control?Yes, the Wyze Chime Controller bridges your wired doorbell system with the Wyze app, enabling you to customize chime sounds and adjust the volume to your preference.
Can you explain the features of the Wyze Video Doorbell v2 in more detail?What are the different sound options available for the Wyze Chime?How does the Wyze Chime Controller connect to my home Wi-Fi?
