Wyze Chime Controller: Install, Upgrade & Fix Mechanical Doorbells
Wyze Chime Controller Wiring Installation Upgrade and Troubleshooting for Mechanical Doorbells
Upgrading your mechanical doorbell system with the Wyze Chime Controller and compatible Wyze Video Doorbells can enhance your home security and convenience. This guide covers the installation, wiring upgrades, and troubleshooting tips specifically for mechanical doorbells using Wyze products.
Wyze Video Doorbell v2 with Chime Controller: Features and Installation
Advanced Wired Video Doorbell with Chime Controller
The Wyze Video Doorbell v2 is a wired video doorbell designed to work seamlessly with your existing mechanical doorbell chime system when paired with the included Wyze Doorbell Chime Controller. It offers:
  • 2K video resolution (2048 x 1536) for crystal-clear video.
  • Wide 166.8° diagonal field of view to capture more of your porch.
  • Two-way audio with noise and echo cancellation.
  • Local microSD storage up to 256GB plus optional cloud storage.
  • Weather resistance rated IP65, suitable for outdoor use.
  • Compatibility with Alexa, Google Assistant, and IFTTT.
Installation Overview for Mechanical Doorbells
Installing the Wyze Chime Controller is essential for integrating the Wyze Video Doorbell v2 with your existing mechanical chime. The controller ensures proper power delivery and protects your doorbell from power surges, even if your chime is broken. Key installation steps: 1. Power off your existing doorbell circuit at the electrical panel. 2. Open your mechanical chime box and photograph the current wiring for reference. 3. Follow the Wyze app instructions to connect the chime controller wires to the correct terminals in your chime box. 4. Use the included wire caps and extension wires as needed to secure connections. 5. Mount the Wyze Video Doorbell v2 on the wall plate or wedge for optimal viewing angle. 6. Restore power and test the doorbell and chime functionality. 7. In the Wyze app, set your chime type to Mechanical under the doorbell settings.
Tip: If your home has multiple doorbells or more than two wires in the chime box, the app provides guidance for selecting the correct wiring configuration.
Power Requirements and Troubleshooting
  • The Wyze Video Doorbell v2 requires a transformer supplying 16V-24V AC with at least 10VA power.
  • If your chime does not ring after installation, it may be due to insufficient transformer power or wiring issues.
  • Wyze recommends upgrading to a 20-30VA transformer for reliable chime operation.
  • Alternate wiring instructions are available for users comfortable with electrical work.
  • If unsure, always consult a licensed electrician to avoid damage or safety hazards.
Why install the Chime Controller if your chime is broken?
The controller protects your doorbell from power surges and ensures proper power flow, even if the mechanical chime is non-functional.
The Front Porch Security Bundle: Comprehensive Home Entry Solution
For those seeking an all-in-one smart home entry system, the Front Porch Security Bundle combines:
  • Wyze Video Doorbell (1080p HD resolution)
  • Wyze Chime (wireless chime with multiple sound options)
  • Wyze Lock (remote door locking and unlocking)
Bundle Highlights
  • View your front porch in crisp 1080p HD with two-way audio.
  • Lock and unlock your door remotely via the Wyze app.
  • Receive motion alerts and view lock history for enhanced security.
  • Compatible with Alexa and Google Assistant for voice control.
  • Includes all necessary mounting hardware, wire caps, and extension wires.
This bundle is ideal for users who want a smart, integrated solution that works with existing mechanical chimes or replaces them with the Wyze Chime for wireless convenience.
Best Practices for Mechanical Doorbell Wiring Upgrade
Preparing for Installation
  • Always turn off power at the breaker before handling doorbell wiring.
  • Take clear photos of your existing chime wiring to reference during installation.
  • Identify the number of wires in your chime box:
  • 2 wires: Typically one doorbell, connect using jump wire instructions.
  • 3 or more wires: Follow app guidance to select the correct door and wiring.
Wiring Tips
  • Use the included wire caps to secure wire connections safely.
  • If space is limited, connect wires directly to the doorbell screw terminals.
  • Use the wedge (30º angle) or wall plate to mount the doorbell for optimal camera view.
  • Test the doorbell button and chime after wiring before closing the chime box.
Troubleshooting Common Issues
  • Chime not ringing: Check transformer voltage and wiring connections. Consider upgrading transformer if below 20VA.
  • Doorbell not powering on: Verify wiring polarity and secure connections.
  • Multiple doorbells with one chime: Use multiple chime controllers as shown in Wyze app photos for proper operation.
Summary
Upgrading your mechanical doorbell system with the Wyze Video Doorbell v2 and Wyze Doorbell Chime Controller offers enhanced video quality, smart alerts, and reliable chime integration. For a complete smart home entry solution, the Front Porch Security Bundle adds remote locking and wireless chime options. Proper wiring and installation are critical for optimal performance. Always follow the Wyze app instructions carefully and consult a professional electrician if you are unsure about your home's wiring.
Smart Home Doorbell Installation Enhance your home security with smart doorbell installation Mechanical Doorbell Wiring Proper wiring is key to a successful doorbell upgrade Front Porch Security Complete front porch security with Wyze smart devices
FeatureWyze Video Doorbell v2The Front Porch Security Bundle
Video Resolution2K (2048 x 1536)1080p HD
Local StoragemicroSD card slot for 24/7 local recordingNot specified
Two-Way AudioYesYes
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect subscription)Not specified
Pre-roll Motion Recording3-6 secondsNot specified
Weather ResistanceIP65Not specified
Works with Existing ChimeYes, includes chime controllerIncludes Wyze Video Doorbell and Chime
Smart Lock IncludedNoYes, Wyze Lock included
Video Doorbell ModelWyze Video Doorbell v2Wyze Video Doorbell (1080p HD)
Additional CamerasNoOptional Wyze Cam V3 in some variants
Price$44.98 (Doorbell + Chime Controller)$123.99 - $173.97 depending on variant
Key Bundle VariantsDoorbell + Chime Controller, with or without 128GB microSDMultiple bundles including Wyze Lock + Video Doorbell variants
Cloud Storage SubscriptionOptional Cam Plus for AI detections and cloud storageOptional Cam Plus subscription available
IntegrationAlexa, Google HomeAlexa, Google Home
Night VisionColor Night Vision with starlight sensorNot specified
Field of View135° horizontal, 103° verticalNot specified
Warranty1 yearNot specified
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the Wyze Chime Controller and why do I need it for my mechanical doorbell?The Wyze Chime Controller is a device that integrates your Wyze Video Doorbell v2 with your existing mechanical doorbell chime system. It ensures proper power delivery, protects your doorbell from power surges, and allows your mechanical chime to function correctly—even if the chime is broken.
How do I install the Wyze Video Doorbell v2 with the Chime Controller on a mechanical doorbell system?To install the Wyze Video Doorbell v2 with the Chime Controller, first turn off power at your electrical panel. Open your mechanical chime box and take a photo of the existing wiring. Follow the Wyze app instructions to connect the chime controller wires to the correct terminals, using the included wire caps and extension wires as needed. Mount the doorbell on the wall plate or wedge, restore power, and test the system. Set your chime type to 'Mechanical' in the Wyze app.
What are the power requirements for the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 requires a transformer that supplies 16V-24V AC with at least 10VA of power. For reliable operation, Wyze recommends upgrading to a 20-30VA transformer, especially if your chime does not ring after installation.
What should I do if my mechanical chime does not ring after installing the Wyze Video Doorbell v2?If your mechanical chime does not ring, check the transformer voltage and wiring connections. Insufficient transformer power is a common issue; upgrading to a 20-30VA transformer may resolve the problem. Also, verify that all wires are securely connected and follow the troubleshooting steps in the Wyze app.
Can I use the Wyze Chime Controller if my mechanical chime is broken?Yes, you should still install the Wyze Chime Controller even if your mechanical chime is broken. The controller protects your doorbell from power surges and ensures proper power flow, which is essential for the safe operation of your Wyze Video Doorbell v2.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell (1080p HD resolution), a Wyze Chime (wireless chime with multiple sound options), and a Wyze Lock for remote door locking and unlocking. The bundle also comes with all necessary mounting hardware, wire caps, and extension wires.
Is the Wyze Video Doorbell v2 compatible with smart home assistants?Yes, the Wyze Video Doorbell v2 is compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home integration.
What are the best practices for upgrading mechanical doorbell wiring with Wyze products?Best practices include turning off power at the breaker before starting, taking clear photos of your existing wiring, using the included wire caps for secure connections, and following the Wyze app instructions closely. Test the doorbell and chime before closing the chime box, and consult a licensed electrician if you are unsure about any wiring steps.
How do I handle installation if my chime box has multiple wires or multiple doorbells?If your chime box has more than two wires or multiple doorbells, follow the guidance provided in the Wyze app. The app offers step-by-step instructions and photos to help you select the correct wiring configuration. For multiple doorbells with one chime, use multiple chime controllers as shown in the app.
What should I do if my Wyze Video Doorbell v2 is not powering on after installation?If your Wyze Video Doorbell v2 is not powering on, check the wiring polarity and ensure all connections are secure. Verify that your transformer meets the required voltage and power specifications. If issues persist, consult the troubleshooting section in the Wyze app or contact a licensed electrician.
What are the key features of the Wyze Video Doorbell v2?Can you explain the installation steps for the Wyze Chime Controller in more detail?What should I do if my chime does not ring after installing the Wyze Video Doorbell v2?
