Wyze Outdoor Floodlight Cameras with Customizable Motion Detection and Scheduling
When it comes to securing your home’s exterior, Wyze offers a range of outdoor floodlight cameras designed to provide powerful illumination, crystal-clear video, and intelligent motion detection with customizable scheduling. Whether you want to brighten your driveway, monitor your yard, or deter unwanted visitors, Wyze’s floodlight cameras combine advanced technology with user-friendly features to keep your property safe day and night.
Wyze Cam Floodlight v2: Bright, Smart, and Reliable Outdoor Security
Experience powerful lighting and wide-angle security with Wyze Cam Floodlight v2.
Wyze Cam Floodlight v2 is a standout choice for those seeking a floodlight camera with exceptional brightness and smart features:
- 2800 Lumens LED Brightness: Two powerful adjustable floodlight heads illuminate your outdoor space with intense light, turning night into day.
- 2K Video with Color Night Vision: Capture sharp, detailed video footage even in low light, ensuring you never miss a moment.
- 160° Wide-Angle View: Covers a broad area, reducing blind spots and increasing your field of vision.
- Customizable Motion Detection: Set custom detection zones and receive alerts only for the areas you care about.
- AI-Powered Light Control & Ambient Light Mode: Lights stay on low-level ambient mode and brighten automatically when motion is detected.
- Dusk-to-Dawn Automation: Automatically turns lights on at sunset and off at sunrise for effortless security.
- 24/7 Local Recording: Supports continuous recording to a microSD card (up to 256GB) without subscription fees.
- Two-Way Talk & Loud Siren: Communicate with visitors or deter intruders with a 105dB siren.
- IP65 Weather Resistance: Built to withstand rain, snow, and harsh outdoor conditions.
- Smart Assistant Integration: Works seamlessly with Alexa and Google Assistant for voice control and smart home automation.
This floodlight camera is perfect for illuminating large outdoor areas like driveways, backyards, and porches while providing intelligent motion detection and scheduling to fit your lifestyle.
Wyze Cam Floodlight Pro: Advanced AI and Ultra-Wide Coverage
Wyze Cam Floodlight Pro offers premium security with AI-powered detection and ultra-wide lighting.
For those who want the ultimate in outdoor floodlight camera technology, the Wyze Cam Floodlight Pro delivers:
- 3,000 Lumens from Three Dimmable Light Panels: Provides bright, customizable lighting with a natural 5000K color temperature.
- 2.5K QHD Video Resolution: Ultra-clear video quality with color night vision for detailed monitoring.
- 180° Wide-Angle Lens: Covers an expansive field of view, ensuring no corner of your yard is left unseen.
- Onboard AI Computer Vision: Detects and distinguishes people, vehicles, and other objects, triggering lights and alerts only for selected targets.
- Dual-Band WiFi (2.4 & 5 GHz): Ensures stable connectivity even in crowded wireless environments.
- Hardwired Power Supply: Reliable 110-120V AC power for continuous operation.
- Customizable Motion Detection & Scheduling: Tailor detection zones and set schedules to avoid false alarms and optimize security.
- 105dB Siren: Loud alarm to scare off intruders.
- IP65 Weatherproof Rating: Built tough for all weather conditions from -4°F to 140°F (-20°C to 60°C).
- Smart Home Integrations: Compatible with Alexa, Google Assistant, and IFTTT for seamless automation.
The Floodlight Pro is ideal for homeowners who want a high-performance security system with intelligent lighting and precise motion detection that adapts to their needs.
Wyze Cam Pan v3: Versatile Outdoor Camera with Motion Tracking
Wyze Cam Pan v3 offers 360° coverage and customizable motion detection for outdoor security.
While not a floodlight camera, the Wyze Cam Pan v3 is a versatile outdoor security camera that complements floodlight models with its unique features:
- 360° Pan and 180° Tilt: Covers every angle of your property with smooth, quiet motorized movement.
- IP65 Weather Resistance: Designed for outdoor use with the Wyze Outdoor Power Adapter (sold separately).
- Automatic Motion Tracking: Detects motion and follows moving objects automatically, capturing every detail.
- Color Night Vision: See clear, colorful video even in the dark.
- Custom Detection Zones & Scheduling: Focus on specific areas and set active times to reduce false alerts.
- Two-Way Audio: Communicate through the camera using the Wyze app.
- Privacy Mode: Easily disable the camera’s view when privacy is needed.
- Supports Local and Cloud Storage: Save footage on microSD cards or via Cam Plus subscription.
The Pan v3 is perfect for users who want dynamic coverage and customizable motion detection in an outdoor camera that can be paired with floodlight cameras for comprehensive home security.
Why Choose Wyze Outdoor Floodlight Cameras?
Wyze outdoor floodlight cameras combine powerful illumination, advanced AI motion detection, and flexible scheduling to provide smart, reliable security for your home. With IP65 weather resistance, these cameras are built to withstand the elements while delivering crisp video and customizable alerts that fit your lifestyle.
- Customizable Motion Detection: Define detection zones and schedules to avoid false alarms and focus on what matters.
- Smart Lighting Automation: Lights adjust automatically based on ambient light and motion, enhancing security and energy efficiency.
- High-Resolution Video: From 2K to 2.5K QHD, Wyze cameras capture clear, detailed footage day and night.
- Two-Way Audio & Sirens: Communicate with visitors or deter intruders instantly.
- Easy Integration: Compatible with Alexa, Google Assistant, and IFTTT for smart home control.
- Local and Cloud Storage Options: Choose between free local recording or enhanced cloud storage with Cam Plus.
Summary of Wyze Outdoor Floodlight Cameras
Model | Video Resolution | Lighting (Lumens) | Field of View | Motion Detection | Weatherproof | Price Range |
Wyze Cam Floodlight v2 | 2K | 2800 | 160° | Custom Zones, AI | IP65 | $89.98 |
Wyze Cam Floodlight Pro | 2.5K QHD | 3000 (3 panels) | 180° | AI-Powered | IP65 | $149.98 |
Wyze Cam Pan v3 | 1080p | N/A | 360° pan/180° tilt | Motion Tracking | IP65 | $39.98 |
Enhance your home security with Wyze’s outdoor floodlight cameras featuring customizable motion detection and scheduling. Whether you want bright, AI-powered floodlights or versatile pan-and-tilt coverage, Wyze has the perfect solution to keep your property safe and well-lit.
What are the main features of Wyze outdoor floodlight cameras?
Wyze outdoor floodlight cameras offer powerful LED illumination, high-resolution video (up to 2.5K QHD), customizable motion detection zones, AI-powered alerts, two-way audio, loud sirens, IP65 weather resistance, and smart home integration with Alexa, Google Assistant, and IFTTT.How does customizable motion detection work on Wyze floodlight cameras?
Customizable motion detection allows you to set specific detection zones and schedules, so you only receive alerts for the areas and times that matter most. Advanced models like the Wyze Cam Floodlight Pro use AI to distinguish between people, vehicles, and other objects, reducing false alarms.What is the difference between Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro?
Wyze Cam Floodlight v2 features 2K video, 2800 lumens of brightness, a 160° field of view, and customizable motion detection. The Floodlight Pro offers 2.5K QHD video, 3000 lumens from three dimmable panels, a 180° field of view, onboard AI computer vision, and dual-band WiFi for enhanced performance.Can Wyze outdoor floodlight cameras record video locally without a subscription?
Yes, Wyze outdoor floodlight cameras support 24/7 local recording to a microSD card (up to 256GB), allowing you to store footage without any subscription fees. Cloud storage is also available through the Cam Plus subscription.Are Wyze outdoor floodlight cameras weatherproof?
Yes, all Wyze outdoor floodlight cameras have an IP65 weather resistance rating, making them suitable for use in rain, snow, and harsh outdoor conditions.Do Wyze floodlight cameras work with Alexa and Google Assistant?
Yes, Wyze floodlight cameras are compatible with Alexa and Google Assistant, allowing for voice control and integration with your smart home devices. The Floodlight Pro also supports IFTTT for advanced automation.What is the field of view for Wyze outdoor floodlight cameras?
The Wyze Cam Floodlight v2 offers a 160° wide-angle view, while the Wyze Cam Floodlight Pro provides an even broader 180° field of view. The Wyze Cam Pan v3 features 360° pan and 180° tilt for complete coverage.How does the AI-powered detection on Wyze Cam Floodlight Pro work?
The Wyze Cam Floodlight Pro uses onboard AI computer vision to detect and distinguish between people, vehicles, and other objects. This ensures that lights and alerts are triggered only for selected targets, reducing unnecessary notifications.Can I schedule when the Wyze floodlight cameras are active?
Yes, Wyze floodlight cameras allow you to set custom schedules for motion detection and lighting, so you can optimize security and avoid false alarms during certain times of the day or night.What storage options are available for Wyze outdoor cameras?
Wyze outdoor cameras support both local storage via microSD cards and cloud storage through the Cam Plus subscription, giving you flexibility in how you save and access your video footage.Is the Wyze Cam Pan v3 suitable for outdoor use?
Yes, the Wyze Cam Pan v3 is IP65 weather resistant and designed for outdoor use when paired with the Wyze Outdoor Power Adapter (sold separately). It offers 360° pan, 180° tilt, motion tracking, and customizable detection zones.How loud is the siren on Wyze floodlight cameras?
Both the Wyze Cam Floodlight v2 and Floodlight Pro feature a 105dB siren, which can be used to deter intruders and alert you to suspicious activity.What is the price range for Wyze outdoor floodlight cameras?
The Wyze Cam Floodlight v2 is priced at $89.98, the Wyze Cam Floodlight Pro at $149.98, and the Wyze Cam Pan v3 at $39.98.
