Weatherproof 2K Cam Floodlight with Ambient Light Mode & Scheduling
When it comes to securing your outdoor spaces with powerful lighting and crystal-clear video, Wyze offers two standout floodlight cameras designed to meet your needs: the
Wyze Cam Floodlight v2 and the
Wyze Cam Floodlight Pro. Both models combine high-resolution video, weatherproof durability, and smart lighting features including ambient light mode and scheduling to keep your home safe and well-lit around the clock.
Wyze Cam Floodlight v2: Bright, Smart, and Weather-Resistant
Powerful Illumination & Crisp 2K Video
The Wyze Cam Floodlight v2 delivers an impressive
2800 lumens of brightness through two dimmable LED light panels with a daylight color temperature of 5000K. Its
2K (2304 x 1296) resolution camera captures sharp, detailed video with a wide
160° diagonal field of view, ensuring you see more of your property clearly.
This floodlight features an intelligent
Ambient Light Mode that automatically adjusts brightness based on surrounding light conditions, conserving energy while maintaining optimal visibility. You can also schedule the floodlight to turn on or off at specific times, including dusk-to-dawn automation, for hassle-free lighting control.
Robust Weatherproof Design
Built with a durable polycarbonate body and IP65 weather resistance, the Wyze Cam Floodlight v2 is designed to withstand rain, snow, and extreme temperatures from
-4°F to 140°F (-20°C to 60°C), making it perfect for year-round outdoor use.
Smart Home Integration & Features
- Two-way audio with built-in speaker and microphone lets you communicate remotely.
- AI-powered light control and motion detection trigger lights and alerts only when needed.
- Supports local storage up to 256GB microSD card.
- Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home automation.
"Dominate the dark with smart lighting and 2K color night vision."
Alt text: Wyze Cam Floodlight v2 lighting a driveway at night with person detected
Wyze Cam Floodlight Pro: Enhanced Vision and AI-Powered Security
Ultra-Wide 180° View with 2.5K QHD Video
Step up your security with the Wyze Cam Floodlight Pro, featuring a
2.5K QHD (2560 x 1440) camera and an expansive
180° diagonal field of view. This camera captures more detail and covers a wider area, perfect for large yards or multiple entry points.
Brighter Lighting with Intelligent AI Control
Equipped with
3 dimmable LED panels producing
3000 lumens at 5000K color temperature, the Floodlight Pro shines brighter than its predecessor. Its onboard AI computer vision detects specific objects like people and vehicles, activating the lights only when necessary to reduce false alarms and save energy.
Dual-Band WiFi & Weatherproof Durability
Supporting both
2.4 GHz and 5 GHz WiFi, the Floodlight Pro ensures a stable connection for smooth video streaming. Like the v2, it boasts an
IP65 rating for water and dust resistance and operates reliably in temperatures from
-4°F to 140°F (-20°C to 60°C).
Advanced Security Features
- Loud 105dB siren to deter intruders.
- Two-way audio for real-time communication.
- Local storage support up to 256GB microSD card.
- Compatible with Alexa, Google Assistant, and IFTTT.
"A high-powered security camera with bright lights that think and respond."
Alt text: Woman with dog near Wyze Cam Floodlight Pro illuminating side door
Why Choose a Wyze Weatherproof Floodlight Camera?
Both Wyze Cam Floodlight v2 and Floodlight Pro offer:
- Weatherproof reliability with IP65 rating for outdoor use.
- Ambient Light Mode and customizable scheduling for energy-efficient lighting.
- High-resolution video with color night vision to monitor your property day and night.
- Smart integrations with popular voice assistants and automation platforms.
- Two-way audio and siren for interactive security and deterrence.
Whether you want a powerful 2K floodlight camera or the enhanced vision and AI smarts of the 2.5K Floodlight Pro, Wyze provides affordable, feature-rich options to illuminate and protect your home.
Additional Smart Lighting Options
For those looking to expand their smart lighting setup, Wyze also offers lamp socket bundles compatible with various Wyze cameras, enabling motion-activated lights and dusk-to-dawn scheduling without the need for an outlet. These are ideal for customizing your outdoor lighting ecosystem.
Enhance your home security with Wyze’s weatherproof 2K cam floodlights featuring ambient light mode and scheduling — smart, bright, and built to last.
What is the difference between Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro?
The Wyze Cam Floodlight v2 features a 2K (2304 x 1296) camera with a 160° field of view and 2800 lumens of brightness, while the Wyze Cam Floodlight Pro offers a higher 2.5K QHD (2560 x 1440) camera, a wider 180° field of view, and brighter 3000 lumens lighting. The Pro model also includes advanced AI-powered object detection, a 105dB siren, and dual-band WiFi support.Are Wyze Cam Floodlight cameras weatherproof?
Yes, both Wyze Cam Floodlight v2 and Floodlight Pro are IP65 weatherproof, making them suitable for outdoor use in rain, snow, and extreme temperatures ranging from -4°F to 140°F (-20°C to 60°C).What is Ambient Light Mode on Wyze Cam Floodlight cameras?
Ambient Light Mode is an intelligent feature that automatically adjusts the floodlight’s brightness based on surrounding light conditions. This helps conserve energy while maintaining optimal visibility for your outdoor spaces.Can I schedule when the Wyze Cam Floodlight turns on or off?
Yes, both Wyze Cam Floodlight v2 and Pro support customizable scheduling, including dusk-to-dawn automation. You can set specific times for the floodlight to turn on or off for hassle-free lighting control.Do Wyze Cam Floodlight cameras support local video storage?
Yes, both models support local storage with microSD cards up to 256GB, allowing you to record and review footage without a subscription.Are Wyze Cam Floodlight cameras compatible with smart home systems?
Yes, both the v2 and Pro models are compatible with Alexa, Google Assistant, and IFTTT, enabling seamless integration with your smart home devices and automation routines.What security features do Wyze Cam Floodlight cameras offer?
Both models include two-way audio for real-time communication and a loud siren (105dB on the Pro) to deter intruders. The Pro model also features advanced AI-powered detection for people and vehicles.What is the brightness and color temperature of Wyze Cam Floodlight cameras?
The Wyze Cam Floodlight v2 provides 2800 lumens of brightness, while the Floodlight Pro offers 3000 lumens. Both use a daylight color temperature of 5000K for clear, bright illumination.Can I use Wyze Cam Floodlight cameras with both 2.4 GHz and 5 GHz WiFi?
The Wyze Cam Floodlight Pro supports both 2.4 GHz and 5 GHz WiFi for a stable connection. The v2 model supports 2.4 GHz WiFi.Are there additional smart lighting options compatible with Wyze cameras?
Yes, Wyze offers lamp socket bundles that work with various Wyze cameras. These enable motion-activated lighting and dusk-to-dawn scheduling, expanding your smart outdoor lighting setup without the need for an outlet.
