DIY Weather Resistant Wyze Floodlight Camera Installation with Plug-In Outdoor Mount
Enhance your home security and outdoor lighting with Wyze’s innovative floodlight cameras and plug-in mounts designed for easy, weather-resistant installation. Whether you want to upgrade your porch, backyard, or driveway, Wyze offers smart, plug-and-play solutions that eliminate the hassle of complex wiring or junction boxes. This guide highlights the best Wyze products for a seamless DIY installation that withstands the elements.
Wyze Plug Outdoor: Power Your Outdoor Devices Rain or Shine
Weather-Resistant Smart Outdoor Plug
The
Wyze Plug Outdoor is a must-have for powering your outdoor floodlight cameras and other devices with confidence. Rated IP64 for weather resistance, this smart plug is built to endure rain, snow, and heat, making it perfect for outdoor use.
- Dimensions: 4.0” x 2.8” x 1.4”
- Weight: 7.2 ounces
- Operating Temperature: -4°F to 120°F
- Connectivity: 2.4GHz WiFi and Bluetooth V4.2
- Output: 15A max with overload protection
- Outlets: 2 outdoor-rated outlets
- Compatibility: Android 5.0+ and iOS 9.0+
- Voice Control: Works with Alexa
- Energy Monitoring: Track your outdoor power usage via the app
With the Wyze app, you can schedule your floodlights or garden lights to turn on/off automatically, monitor energy consumption, and control devices remotely. This plug is ideal for powering your Wyze floodlight cameras without complicated wiring.
Power your outdoor space effortlessly and keep your devices safe from the elements.
Wyze floodlight illuminating a backyard deck at dusk
Wyze Cam Floodlight Plug-In Mount: Simplify Your Installation
Easy Plug-and-Play Mount for Floodlight Cameras
Say goodbye to costly and complex junction box installations with the
Wyze Cam Floodlight Plug-In Mount. This accessory is designed to work seamlessly with all Wyze Cam Floodlight models (v1, v2, and Pro), providing a quick and weather-safe way to power your floodlight camera.
- Power Cord Length: 20 feet (6 meters) for flexible placement
- Operating Temperature: -22°F to 122°F
- Input Voltage: 110-120V AC
- Outdoor Safe: Yes, designed for exterior use
- Cable Wire: 18 AWG SJTW rated for durability
- Colors Available: Black and White
- Included Items: Mount, mounting screws, foam tape, and quick start guide
This mount allows you to plug your floodlight camera directly into an outdoor outlet, eliminating the need for electrical work. It’s perfect for DIY enthusiasts who want a clean, professional-looking installation without the hassle.
Install your Wyze floodlight camera in minutes with no electrician needed.
Wyze Cam Floodlight Pro + Plug-In Mount: Ultimate Security and Lighting Bundle
High-Performance Floodlight Camera with Plug-In Convenience
For those seeking top-tier security and lighting, the
Wyze Cam Floodlight Pro + Plug-In Mount bundle offers a powerful 2.5K QHD camera combined with a 3000-lumen floodlight. This all-in-one solution provides ultra-wide 180° coverage and color night vision to keep your property safe day and night.
- Resolution: 2.5K QHD (2560 x 1440)
- Field of View: 180° ultra-wide angle
- Light Output: 3000 lumens for bright illumination
- Night Vision: Full-color night vision capability
- Water Resistance: IP65 rated for outdoor durability
- Compatibility: Android 9.0+ and iOS 15.0+
- Integrations: Alexa, Google Assistant, IFTTT
- Mount Type: Wall or ceiling mount with included plug-in mount
This bundle is perfect for homeowners who want a professional-grade floodlight camera with the convenience of plug-in installation. The included mount and long power cord make setup straightforward and flexible.
Experience crystal-clear security footage and powerful lighting without complicated wiring.
Wyze Cam Floodlight v2 + Plug-In Mount: Reliable and Affordable Outdoor Security
Bright, Smart, and Easy to Install
The
Wyze Cam Floodlight v2 + Plug-In Mount bundle offers a great balance of features and value. With 2K HD video, vibrant color night vision, and a 160° wide-angle view, this floodlight camera keeps your outdoor areas well-lit and monitored.
- Video Resolution: 2K HD
- Field of View: 160° wide-angle
- Light Output: 2800 lumens
- Siren: 105dB built-in siren for deterrence
- Power Cord: 20 feet with cable management strap
- Installation: Plug-in mount for easy setup, no junction box required
- Colors: Black and White
This model is ideal for those who want a reliable floodlight camera with advanced motion detection and siren features, all powered through a simple plug-in mount.
Secure your home with bright lighting and smart alerts, installed in minutes.
DIY installation of Wyze Cam Floodlight with plug-in mount
Why Choose Wyze for Your Outdoor Floodlight Camera Setup?
- Weather-Resistant Products: Designed to withstand harsh outdoor conditions.
- Plug-In Convenience: Avoid costly electrical work with easy plug-and-play mounts.
- Smart Home Integration: Control devices via Wyze app, Alexa, Google Assistant, and IFTTT.
- Energy Monitoring: Track power usage with smart plugs.
- Flexible Installation: Long power cords and versatile mounts for any outdoor space.
- Affordable Pricing: High-quality security without breaking the bank.
Conclusion
Installing a weather-resistant Wyze floodlight camera with a plug-in outdoor mount is the smartest way to secure your home with minimal effort. Whether you choose the powerful Floodlight Pro bundle or the versatile Floodlight v2, combined with the Wyze Plug Outdoor for reliable power, you get a seamless, DIY-friendly setup that keeps your property safe and well-lit all year round.
Upgrade your outdoor security today with Wyze’s innovative floodlight cameras and plug-in mounts — the perfect blend of convenience, durability, and smart technology.
What makes Wyze floodlight cameras weather resistant?
Wyze floodlight cameras and accessories are designed with weather resistance in mind, featuring IP64 or IP65 ratings to protect against rain, snow, and heat. This ensures reliable performance in harsh outdoor conditions, making them ideal for year-round use.How do I install a Wyze floodlight camera without a junction box?
Wyze offers plug-in mounts for their floodlight cameras, allowing you to install your camera by simply plugging it into an outdoor outlet. This eliminates the need for complex wiring or a junction box, making installation quick and DIY-friendly.What is the Wyze Plug Outdoor and how does it work?
The Wyze Plug Outdoor is a weather-resistant smart plug rated IP64, designed to power outdoor devices like floodlight cameras. It features two outdoor-rated outlets, energy monitoring, voice control with Alexa, and can be managed remotely via the Wyze app.Can I control Wyze floodlight cameras and plugs with my smartphone?
Yes, you can control Wyze floodlight cameras and smart plugs using the Wyze app on your Android or iOS device. The app allows you to schedule, monitor, and control your devices remotely for added convenience.Are Wyze floodlight cameras compatible with smart home systems?
Wyze floodlight cameras and plugs are compatible with popular smart home platforms, including Alexa, Google Assistant, and IFTTT. This allows for seamless integration and voice control within your smart home ecosystem.What is included with the Wyze Cam Floodlight Plug-In Mount?
The Wyze Cam Floodlight Plug-In Mount includes a 20-foot power cord, mounting screws, foam tape, and a quick start guide. It is available in black and white and is designed for easy, weather-safe installation.What are the main differences between Wyze Cam Floodlight Pro and Floodlight v2?
The Wyze Cam Floodlight Pro offers 2.5K QHD resolution, 180° ultra-wide field of view, 3000 lumens of light output, and full-color night vision. The Floodlight v2 provides 2K HD video, a 160° wide-angle view, 2800 lumens, and a built-in 105dB siren. Both models come with plug-in mounts for easy installation.How long is the power cord for Wyze floodlight camera plug-in mounts?
Wyze floodlight camera plug-in mounts come with a 20-foot (6 meter) power cord, providing flexible placement options for your outdoor security setup.Can I monitor energy usage with Wyze outdoor plugs?
Yes, the Wyze Plug Outdoor features energy monitoring, allowing you to track the power usage of your connected outdoor devices directly from the Wyze app.Is professional installation required for Wyze floodlight cameras?
No, professional installation is not required. Wyze floodlight cameras with plug-in mounts are designed for easy DIY installation, so you can set up your security system in minutes without the need for an electrician.What operating temperatures can Wyze outdoor products withstand?
Wyze outdoor products, including floodlight cameras and plugs, are built to operate in a wide temperature range, typically from -22°F to 122°F, ensuring reliable performance in various climates.Are Wyze floodlight cameras available in different colors?
Yes, Wyze floodlight cameras and plug-in mounts are available in both black and white, allowing you to choose the color that best matches your outdoor decor.
