Wyze Outdoor Floodlights with Wide Field View and Color Night Vision
When it comes to securing your home with outdoor floodlights that offer a wide field of view and vibrant color night vision, Wyze provides some of the most innovative and reliable smart security cameras on the market. Whether you want a 2-in-1 lighting and camera solution or a dedicated outdoor camera with advanced features, Wyze has you covered.
Explore the top Wyze products designed to enhance your outdoor security with wide-angle coverage and stunning color night vision.
Wyze Bulb Cam: 2-in-1 Outdoor Security and Smart Lighting
Bright, Wide-Angle Coverage with 160° Field of View
The Wyze Bulb Cam transforms any standard light fixture into a powerful security camera and smart LED light bulb. It offers a super-wide 160° field of view, ensuring you capture more of your outdoor space with fewer blind spots.
Crystal Clear 2K HD Video with Color Night Vision
Equipped with 2K HD resolution and advanced color night vision, the Bulb Cam lets you see vibrant, detailed footage even in low-light conditions. This means you can monitor your porch, driveway, or backyard clearly at night without relying on traditional infrared black-and-white night vision.
Smart Lighting Features
The built-in 800 lumen LED bulb is dimmable and customizable, allowing you to set the perfect lighting ambiance. You can also connect up to 5 Wyze Accessory Bulbs for full coverage smart lighting that can be motion-activated or scheduled via the Wyze app.
Easy Installation and Local Storage
Installation is as simple as screwing in a light bulb. The Bulb Cam fits most fixtures and supports local video storage on a microSD card up to 256 GB—no subscription required.
Additional Security Features
- Instant motion alerts to your smartphone
- Two-way audio to communicate remotely
- Built-in siren and flashing lights to deter intruders
- Compatible with Alexa, Google Assistant, and IFTTT
Wyze Bulb Cam: Smart lighting and security in one
Wyze Bulb Cam + Accessory Bulbs Bundle: Enhanced Outdoor Lighting and Security
Complete Outdoor Lighting Setup
This bundle pairs the Wyze Bulb Cam with one or more Wyze Accessory Bulbs, each delivering up to 800 lumens of bright, dimmable light. The accessory bulbs sync automatically with the Bulb Cam, providing seamless, motion-activated lighting coverage across your outdoor area.
Advanced Color Night Vision and 2K Video
Enjoy the same crystal-clear 2K HD video and color night vision as the Bulb Cam alone, but with expanded lighting control and coverage for larger spaces.
Smart Controls and Scheduling
Control all bulbs from the Wyze app, set schedules, and customize motion-activated lighting to enhance security and convenience.
Wyze Cam v4 Outdoor Bundle: Superior Clarity and Color Night Vision
Stunning 2.5K QHD Resolution
The Wyze Cam v4 Outdoor Bundle offers unmatched video clarity with 2.5K Quad HD resolution, capturing every detail with precision.
Enhanced Color Night Vision with Motion-Activated Spotlight
Unlike traditional night vision, the v4’s enhanced color night vision reveals vibrant colors even in darkness. The built-in motion-activated spotlight further illuminates your property when activity is detected, improving visibility and deterrence.
Wide Field of View and Smart Features
While the v4 has a slightly narrower field of view than the Bulb Cam (115.8° diagonal), it still covers a broad area with excellent image quality. Additional features include:
- 24/7 local recording with included 128GB microSD card
- Wi-Fi 6 support for stronger, more reliable connections
- Compatibility with Alexa and Google Assistant
- Motion and sound detection with customizable zones
- Smoke and CO alarm alerts
The Wyze Cam v4 is designed to withstand rain, snow, and harsh outdoor conditions, making it a durable choice for year-round security.
Wyze Duo Cam Pan: Dual 2K Cameras with Pan, Tilt, and Color Night Vision
Two Cameras in One for Complete Coverage
The Wyze Duo Cam Pan features two 2K cameras: one fixed on your priority area and another that pans 360° horizontally and tilts 180° vertically to track motion automatically.
Wide Field of View and Auto Motion Tracking
With a wide dynamic range and enhanced color night vision, this camera captures vibrant footage day and night. The pan-and-tilt camera ensures no movement goes unnoticed by following activity in real time.
Integrated Spotlights and Siren
Built-in spotlights brighten the scene on demand, while a siren helps deter unwanted visitors.
Outdoor Ready and Smart Assistant Compatible
Rated IP65 for weather resistance, the Duo Cam Pan works outdoors with the Wyze Universal Outdoor Power Adapter (available Sept. 2025). It supports Alexa, Google Assistant, and IFTTT for smart home integration.
Why Choose Wyze Outdoor Floodlights with Color Night Vision?
Wyze’s outdoor security cameras and floodlights combine wide-angle views, vibrant color night vision, and smart lighting to provide comprehensive home protection. Whether you want a discreet bulb cam or a powerful pan-and-tilt camera, Wyze offers flexible solutions that are easy to install and packed with features.
Summary of Key Features
Product | Field of View | Video Resolution | Color Night Vision | Lighting Type | Weather Resistance | Special Features |
Wyze Bulb Cam | 160° wide | 2K HD | Yes | 800 lumen LED bulb | IP65 | Two-way audio, siren, local storage |
Wyze Bulb Cam + Accessory Bulbs | 160° wide | 2K HD | Yes | Multiple 800 lumen bulbs | IP65 | Group light control, motion-activated |
Wyze Cam v4 Outdoor Bundle | 115.8° diagonal | 2.5K QHD | Enhanced color | Motion-activated spotlight | IP65 | Wi-Fi 6, 24/7 recording, smart alerts |
Wyze Duo Cam Pan | Dual cameras, pan 360° | 2K HD | Yes | Integrated spotlights | IP65 | Auto motion tracking, siren, pan & tilt |
Wyze Cam Pan v3: Weather-resistant outdoor security
Conclusion
For outdoor floodlights with a wide field of view and color night vision, Wyze offers versatile options tailored to your security needs. The Wyze Bulb Cam and its accessory bulbs provide an elegant lighting and camera combo with a broad 160° view, while the Wyze Cam v4 Outdoor Bundle delivers superior 2.5K clarity and enhanced night vision. For dynamic coverage, the Wyze Duo Cam Pan’s dual cameras and pan-tilt capabilities ensure no corner is left unmonitored.
Choose Wyze for smart, reliable, and easy-to-install outdoor security lighting solutions that keep your home safe day and night.
What are the key features of Wyze outdoor floodlights with color night vision?
Wyze outdoor floodlights offer a wide field of view, vibrant color night vision, smart lighting, and easy installation. Key features include 2K or 2.5K HD video resolution, motion-activated lighting, two-way audio, built-in sirens, local storage, and compatibility with Alexa, Google Assistant, and IFTTT.How does the Wyze Bulb Cam enhance outdoor security?
The Wyze Bulb Cam combines a 2K HD security camera with an 800 lumen smart LED bulb, providing a 160° wide field of view and advanced color night vision. It offers instant motion alerts, two-way audio, a built-in siren, and supports local video storage on a microSD card up to 256GB.What is included in the Wyze Bulb Cam + Accessory Bulbs Bundle?
The Wyze Bulb Cam + Accessory Bulbs Bundle includes the Wyze Bulb Cam and one or more Wyze Accessory Bulbs. Each bulb delivers up to 800 lumens of dimmable light, and the accessory bulbs sync with the Bulb Cam for seamless, motion-activated lighting and expanded coverage, all controllable via the Wyze app.What makes the Wyze Cam v4 Outdoor Bundle stand out?
The Wyze Cam v4 Outdoor Bundle features 2.5K QHD resolution for superior video clarity, enhanced color night vision, a motion-activated spotlight, and 24/7 local recording with a 128GB microSD card. It also supports Wi-Fi 6, customizable motion and sound detection zones, and is weather-resistant for year-round use.How does the Wyze Duo Cam Pan provide complete outdoor coverage?
The Wyze Duo Cam Pan features two 2K cameras: one fixed and one with 360° pan and 180° tilt capabilities for automatic motion tracking. It offers wide dynamic range, color night vision, integrated spotlights, a built-in siren, and is rated IP65 for outdoor weather resistance.Are Wyze outdoor floodlights easy to install?
Yes, Wyze outdoor floodlights like the Bulb Cam are designed for easy installation. The Bulb Cam simply screws into most standard light fixtures, and all products are compatible with the Wyze app for quick setup and control.Do Wyze outdoor security cameras require a subscription for video storage?
No, Wyze outdoor security cameras such as the Bulb Cam and Cam v4 support local video storage on microSD cards, so you can record and access footage without a subscription.Can Wyze outdoor floodlights and cameras be integrated with smart home systems?
Yes, Wyze outdoor floodlights and cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your smart home ecosystem.Are Wyze outdoor security cameras weather-resistant?
Yes, Wyze outdoor security cameras and floodlights are rated IP65 for weather resistance, making them suitable for use in rain, snow, and harsh outdoor conditions.What is the field of view for Wyze outdoor security cameras?
The Wyze Bulb Cam and Bulb Cam + Accessory Bulbs offer a 160° wide field of view, the Wyze Cam v4 Outdoor Bundle provides a 115.8° diagonal view, and the Wyze Duo Cam Pan features dual cameras with 360° pan and 180° tilt for comprehensive coverage.
