Wyze Cam Floodlight Pro: Top Features, AI Security & 2.5K Video
Wyze Cam Floodlight Pro Features Overview
Wyze Cam Floodlight Pro is a cutting-edge security camera designed to provide comprehensive outdoor protection with advanced lighting and AI technology. Combining a 180° wide-angle lens with 2.5K QHD video resolution, it offers crystal-clear, end-to-end coverage of your yard or property. This smart floodlight camera uses evolutionary onboard AI computer vision to detect motion intelligently, activating its powerful 3,000 lumen LED lights only for selected objects like people and vehicles. It’s like having a personal home security guard that thinks and reacts in real-time. With support for both 2.4 GHz and 5 GHz Wi-Fi, the Floodlight Pro ensures fast and reliable connectivity. Available in sleek black or white, it fits seamlessly into any home exterior.
"A high-powered security camera with bright lights that thinks and responds like a personal home security guard—no donuts required."
Wyze Cam Floodlight Pro in action with outdoor lighting Wyze Cam Floodlight Pro securing a home’s side door with bright floodlight
Key Features of Wyze Cam Floodlight Pro
1. Industry-Leading 180° Field of View
The Floodlight Pro offers one of the widest views in its category, covering your property with fewer blind spots. This expansive field of view means you can monitor large outdoor areas with a single device, reducing the need for multiple cameras.
2. Stunning 2.5K QHD Video + Color Night Vision
Capture every detail with Quad High Definition clarity. Whether it’s day or night, the camera delivers crisp, vibrant video that makes it easy to identify people, vehicles, and other important details.
3. AI-Powered Motion Detection & Lighting
Unlike traditional PIR sensors, the Floodlight Pro uses onboard AI computer vision to detect motion from specific objects you choose—such as people or cars. This smart detection triggers the adjustable LED lights only when necessary, reducing false alarms and saving energy.
4. Ultra-Bright, Adjustable 3,000 Lumen LEDs
The camera features three independently articulating light panels that blast up to 3,000 lumens. You can customize the light coverage and brightness to suit your needs, whether you want a gentle guiding light or a powerful deterrent to unwanted visitors.
5. Ambient Light Mode & Voice Deterrence
Ambient Light Mode provides constant low-level lighting that brightens automatically when motion is detected, acting like a reverse night light for intruders. Additionally, motion-activated voice deterrence and a built-in 105 dB siren help scare off unwanted guests with customizable voice prompts.
6. Dual-Band Wi-Fi Support
Connect easily and reliably with support for both 2.4 GHz and 5 GHz Wi-Fi networks, ensuring smooth video streaming and quick notifications.
7. Weatherproof & Easy Installation
Rated IP65 for weather resistance, the Floodlight Pro withstands rain, snow, and extreme temperatures. Installation is DIY-friendly, replacing your existing floodlight in under 20 minutes.
Wyze Cam Floodlight Pro + Plug-In Mount: Hassle-Free Setup
For those who want to avoid the complexity and cost of installing a junction box, the Wyze Cam Floodlight Pro + Plug-In Mount bundle offers a perfect solution. This combo includes the Floodlight Pro and a plug-n-play mount that connects to any outdoor power outlet.
Benefits of the Plug-In Mount Bundle:
  • No electrician needed: Avoid costly and complicated wiring jobs.
  • Flexible placement: The 20-foot durable cable lets you position the floodlight exactly where you need it.
  • Clean cable management: Includes a velcro strap for neat installation.
  • Same powerful features: Enjoy all the Floodlight Pro’s advanced specs with the convenience of plug-in power.
Wyze Cam Floodlight Pro with Plug-In Mount installed outdoors Easy plug-in installation for flexible outdoor security
Why Choose Wyze Cam Floodlight Pro?
  • Comprehensive security coverage with a wide 180° view and high-resolution video.
  • Smart AI detection reduces false alerts and activates lights only when needed.
  • Powerful lighting with 3,000 lumens and customizable panels.
  • Voice deterrence and siren for active protection.
  • Dual-band Wi-Fi for reliable connectivity.
  • Weatherproof design for year-round outdoor use.
  • Simple DIY installation with optional plug-in mount for no-hassle setup.
Whether you want to secure your front porch, backyard, or driveway, Wyze Cam Floodlight Pro offers professional-grade security lighting and surveillance in one sleek package.
Related Wyze Floodlight Cameras
Wyze Cam Floodlight v2
  • 2K video resolution with color night vision
160° wide-angle view
  • 2800 lumens LED lighting with dimmable panels
AI-powered light control and two-way talk Dusk-to-dawn automation and IP65 weather resistance Compatible with Alexa, Google Assistant, and IFTTT
  • Price: $89.98
This model is a great option if you want solid floodlight security with slightly less wide coverage and a lower price point.
Summary
Wyze Cam Floodlight Pro stands out as a top-tier outdoor security camera with floodlight capabilities. Its combination of AI-powered motion detection, ultra-bright adjustable LEDs, and crisp 2.5K video makes it an excellent choice for homeowners seeking smart, reliable, and easy-to-install security lighting. For even easier installation, the Plug-In Mount bundle removes the need for electrical work, making professional-grade floodlight security accessible to everyone. Protect your home day and night with Wyze Cam Floodlight Pro — the smart floodlight camera that watches over your property with intelligence and power.
FeatureWyze Cam Floodlight ProWyze Cam Floodlight Pro + Plug-In MountWyze Cam Floodlight v2Wyze Cam v4
Price$149.98$169.96$89.98$35.98 - $107.94 (varies by pack)
Video Resolution2.5K QHD2K HD2K HD2.5K QHD
Field of View180° wide-angle180° wide-angle160° wide-angleDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
LED Brightness (Lumens)3000 lumens (adjustable, dimmable)3000 lumens (adjustable, dimmable)2800 lumens (2 dimmable panels)Spotlight LEDs 72 lumens
Night VisionColor Night VisionColor Night VisionColor Night VisionEnhanced Color Night Vision
AI Motion DetectionOnboard AI computer vision (people, vehicles)Same as Floodlight ProAI-Powered Light ControlPerson detection, motion detection
Motion-Activated LightsYesYesYesMotion-activated spotlight
Voice Deterrence & Siren105 dB siren, motion-activated voice deterrenceSame as Floodlight Pro105 dB sirenBuilt-in siren, 99 dB speaker
Wi-Fi SupportDual-band 2.4 & 5 GHzDual-band 2.4 & 5 GHz2.4 GHz2.4 GHz & Wi-Fi 6
Power SupplyHardwiredPlug-in Mount (no junction box needed)HardwiredWired (requires power adapter)
Weather ResistanceIP65IP65IP65IP65
Local StorageSupports up to 256GB microSD (sold separately)Same as Floodlight ProSupports up to 256GB microSD (sold separately)microSD card up to 512GB (sold separately)
InstallationDIY hardwired, easy installDIY plug-n-play with 20ft cableDIY hardwired, easy installMultiple mounting options, easy install
DimensionsNot specifiedNot specified9.5" x 7.7" x 7.0"2" x 2" x 2 3/8"
WeightNot specifiedNot specified2.76 lbs (1.25 kg)0.49 lb (222 g)
Additional FeaturesAmbient Light Mode, Dusk to Dawn Automation, 3 adjustable light panelsIncludes Plug-in Mount for flexible powerAmbient Light Mode, Two-way talkTwo-way audio, Wide Dynamic Range (WDR), Alexa & Google Assistant integration
WarrantyNot specifiedNot specified1 year1 year
What is the Wyze Cam Floodlight Pro?The Wyze Cam Floodlight Pro is an advanced outdoor security camera that combines a 180° wide-angle lens, 2.5K QHD video resolution, and powerful 3,000 lumen LED floodlights. It uses onboard AI computer vision for intelligent motion detection, providing comprehensive security coverage for your property.
What are the key features of Wyze Cam Floodlight Pro?Key features of the Wyze Cam Floodlight Pro include a 180° field of view, 2.5K QHD video with color night vision, AI-powered motion detection, ultra-bright adjustable 3,000 lumen LEDs, ambient light mode, voice deterrence with a 105 dB siren, dual-band Wi-Fi support (2.4 GHz and 5 GHz), and IP65 weatherproof rating for outdoor use.
How does the AI-powered motion detection work on Wyze Cam Floodlight Pro?Wyze Cam Floodlight Pro uses onboard AI computer vision to intelligently detect motion from specific objects, such as people or vehicles. This smart detection triggers the floodlight and notifications only when necessary, reducing false alarms and saving energy.
Does Wyze Cam Floodlight Pro support both 2.4 GHz and 5 GHz Wi-Fi?Yes, Wyze Cam Floodlight Pro supports both 2.4 GHz and 5 GHz Wi-Fi networks, ensuring fast, reliable connectivity and smooth video streaming.
Is Wyze Cam Floodlight Pro weatherproof?Yes, the Wyze Cam Floodlight Pro is rated IP65 for weather resistance, making it suitable for outdoor use in rain, snow, and extreme temperatures.
How bright are the floodlights on Wyze Cam Floodlight Pro?The Wyze Cam Floodlight Pro features three independently adjustable LED panels that provide up to 3,000 lumens of ultra-bright light, which can be customized for coverage and brightness.
What is the Ambient Light Mode on Wyze Cam Floodlight Pro?Ambient Light Mode provides constant low-level lighting that automatically brightens when motion is detected, acting as a reverse night light to deter intruders.
Does Wyze Cam Floodlight Pro have a siren or voice deterrence?Yes, the Wyze Cam Floodlight Pro includes a built-in 105 dB siren and motion-activated voice deterrence with customizable voice prompts to help scare off unwanted guests.
How easy is it to install Wyze Cam Floodlight Pro?Wyze Cam Floodlight Pro is designed for easy DIY installation, replacing your existing floodlight in under 20 minutes. For even easier setup, the Plug-In Mount bundle allows you to connect the camera to any outdoor power outlet without the need for electrical work.
What is the Wyze Cam Floodlight Pro + Plug-In Mount bundle?The Wyze Cam Floodlight Pro + Plug-In Mount bundle includes the Floodlight Pro camera and a plug-n-play mount with a 20-foot cable, allowing for flexible placement and easy installation without the need for an electrician or complex wiring.
What are the benefits of the Plug-In Mount for Wyze Cam Floodlight Pro?The Plug-In Mount offers hassle-free installation, flexible placement with a 20-foot cable, clean cable management with a velcro strap, and all the advanced features of the Floodlight Pro without requiring electrical work.
How does Wyze Cam Floodlight Pro compare to Wyze Cam Floodlight v2?Wyze Cam Floodlight Pro offers a wider 180° field of view, higher 2.5K QHD video resolution, and brighter 3,000 lumen LEDs compared to the Wyze Cam Floodlight v2, which has a 160° view, 2K resolution, and 2,800 lumens. Both models feature AI-powered detection, color night vision, and weather resistance.
Can I use Wyze Cam Floodlight Pro to secure different areas of my property?Yes, the Wyze Cam Floodlight Pro is ideal for securing front porches, backyards, driveways, and other outdoor areas, providing professional-grade security lighting and surveillance in one device.
What are the installation requirements for the Wyze Cam Floodlight Pro?Can you explain how the AI-powered motion detection works in the Wyze Cam Floodlight Pro?Are there any ongoing promotions or discounts for the Wyze Cam Floodlight Pro?
