Wyze Cam Floodlight Pro: 180° Motion Detection Range & Features
Wyze Cam Floodlight Pro Motion Detection Range and Features
When it comes to securing your home with advanced motion detection and powerful lighting, the Wyze Cam Floodlight Pro stands out as a top choice. Designed to cover wide outdoor areas with precision, this floodlight camera offers a motion detection range and smart features that make it a reliable guardian for your property.
Industry-Leading Motion Detection Range
The Wyze Cam Floodlight Pro features an evolutionary onboard AI computer vision system that detects motion with remarkable accuracy. Unlike traditional PIR sensors, this camera uses AI to identify specific objects such as people and vehicles, reducing false alarms from animals or passing shadows.
  • 180° Wide-Angle Field of View: The camera’s broad 180-degree lens ensures you can monitor your entire yard or driveway with fewer blind spots.
  • Adjustable Motion Detection Zones: Customize which areas trigger alerts, focusing on critical zones for enhanced security.
  • AI-Powered Object Recognition: Detects and distinguishes between people, vehicles, and other objects for smarter notifications.
  • Dual-Band Wi-Fi Support: Connects seamlessly to both 2.4 GHz and 5 GHz networks for reliable, fast communication.
Powerful Lighting to Complement Detection
The floodlight component of the Wyze Cam Floodlight Pro is no less impressive:
  • 3,000 Lumens of Brightness: Adjustable and dimmable LED panels provide intense illumination to deter intruders and light up dark areas.
  • Three Independently Articulating Panels: Customize the direction and coverage of the lights to suit your property’s layout.
  • Ambient Light Mode: Provides a constant low-level light that brightens automatically when motion is detected, acting as a reverse night light to discourage unwanted visitors.
  • Motion-Activated Voice Deterrence: When a person is detected, a voice prompt and a 105 dB siren activate to warn off intruders.
Crisp Video Quality for Clear Identification
  • 2.5K QHD Resolution: Capture detailed video footage with Quad High Definition clarity, day or night.
  • Color Night Vision: See vivid, full-color images even in low-light conditions, improving identification and evidence quality.
  • 24/7 Recording with MicroSD Support: Record continuously with up to 30 days of storage on a 256GB microSD card (sold separately).
“Wyze Cam Floodlight Pro is like having a personal home security guard that thinks and responds intelligently — no donuts required.”
Wyze Cam Floodlight Pro in action with bright outdoor lighting Bright and smart outdoor security lighting
Wyze Cam Floodlight Pro + Plug-In Mount: Easy Installation with Full Features
For those who want the power of the Wyze Cam Floodlight Pro but prefer a hassle-free installation, the Wyze Cam Floodlight Pro + Plug-In Mount bundle is the perfect solution.
Simplified Plug-and-Play Setup
  • No Junction Box Needed: Avoid costly electrician visits and complicated wiring.
  • 20-Foot Outdoor-Rated Cable: Easily reach your outdoor power outlet without rewiring.
  • Velcro Strap for Cable Management: Keeps your installation neat and tidy.
  • Same Powerful Features: Enjoy the full 180° field of view, 2K HD video, 3,000 lumens of LED brightness, and AI motion detection.
This bundle is ideal for renters or anyone who wants professional-grade floodlight security without permanent electrical modifications. Wyze Cam Floodlight Pro with Plug-In Mount installed outdoors Easy plug-in installation for powerful security
Comparing Wyze Cam Floodlight Pro with Wyze Cam Floodlight v2
If you’re exploring options, the Wyze Cam Floodlight v2 is another solid choice, though with some differences in motion detection and lighting:
  • Field of View: 160° diagonal (vs. 180° on Floodlight Pro)
  • Video Resolution: 2K HD (2304 x 1296) with color night vision
  • Lighting: 2,800 lumens from two dimmable LED panels (slightly less bright than Floodlight Pro)
  • Motion Detection: AI-powered light control with PIR sensor assistance
  • Connectivity: 2.4 GHz Wi-Fi only (no 5 GHz support)
  • Additional Features: Two-way audio, 105 dB siren, dusk-to-dawn automation, and IP65 weather resistance
While the Floodlight v2 offers excellent security features and bright lighting, the Floodlight Pro’s wider field of view, higher resolution, and advanced AI motion detection make it the superior choice for comprehensive outdoor security. Wyze Cam Floodlight v2 lifestyle image showing driveway security Reliable driveway monitoring with Wyze Cam Floodlight v2
Summary: Why Choose Wyze Cam Floodlight Pro for Motion Detection?
  • Unmatched 180° wide-angle coverage to monitor large outdoor areas with fewer blind spots.
  • AI-powered motion detection that accurately identifies people and vehicles, minimizing false alerts.
  • Ultra-bright 3,000 lumen LED floodlights with customizable panels for tailored lighting.
  • High-resolution 2.5K QHD video with color night vision for clear, detailed footage.
  • Flexible installation options including plug-in mount for easy setup without electrical work.
  • Dual-band Wi-Fi support for faster, more reliable connectivity.
For homeowners seeking a smart, powerful, and easy-to-install floodlight camera with advanced motion detection range, the Wyze Cam Floodlight Pro and its plug-in mount bundle are the ultimate solutions.
FeatureWyze Cam Floodlight ProWyze Cam Floodlight Pro + Plug-In Mount
Price$149.98$169.96
Color VariantsBlack, WhiteBlack/White combinations (Black/Black, Black/White, White/Black, White/White)
Video Resolution2.5K QHD2K HD
Field of View180° wide-angle lens180° field-of-view
LED BrightnessAdjustable 3,000 lumens LED lights3,000-lumen LEDs with 3 adjustable panels
Motion Detection TechnologyOnboard AI computer visionAI-powered motion detection
Night VisionColor Night VisionColor Night Vision
Wi-Fi SupportDual-band 2.4 & 5 GHzDual-band 2.4 & 5 GHz
Voice DeterrenceMotion-activated voice deterrence + 105 dB sirenIncluded
Ambient Light ModeYesNot specifically mentioned
Weather ResistanceIP65Not specifically mentioned
RecordingSupports microSD card (up to 256GB)Not specified
InstallationHardwired, DIY install under 20 minutesPlug-n-play with 20 ft cable, no junction box needed
Power SourceHardwiredPlug-in mount with 20 ft cable
Included ItemsWyze Cam Floodlight Pro onlyWyze Cam Floodlight Pro + Plug-in Mount
SetupBluetoothⓇ setup, no QR code scanningEasy plug-in installation, no electrician needed
Cable Length (Plug-In Mount)N/A20 ft (6 m)
What is the motion detection range of the Wyze Cam Floodlight Pro?The Wyze Cam Floodlight Pro features a 180° wide-angle field of view, allowing it to monitor large outdoor areas such as yards and driveways with minimal blind spots. Its advanced AI computer vision system accurately detects motion and identifies people and vehicles, providing industry-leading motion detection coverage.
How does the Wyze Cam Floodlight Pro reduce false motion alerts?The Wyze Cam Floodlight Pro uses AI-powered object recognition to distinguish between people, vehicles, and other objects. This technology helps minimize false alarms caused by animals, passing shadows, or other non-threatening movements.
Can I customize motion detection zones with the Wyze Cam Floodlight Pro?Yes, the Wyze Cam Floodlight Pro allows you to set adjustable motion detection zones. This feature lets you focus alerts on specific areas of your property, enhancing security and reducing unnecessary notifications.
What are the lighting features of the Wyze Cam Floodlight Pro?The Wyze Cam Floodlight Pro is equipped with three independently articulating LED panels that deliver up to 3,000 lumens of adjustable, dimmable brightness. It also features an ambient light mode for constant low-level illumination and motion-activated voice deterrence with a 105 dB siren.
Does the Wyze Cam Floodlight Pro support color night vision?Yes, the Wyze Cam Floodlight Pro offers color night vision, allowing you to capture vivid, full-color video footage even in low-light conditions for better identification and evidence quality.
What video resolution does the Wyze Cam Floodlight Pro provide?The Wyze Cam Floodlight Pro records in 2.5K QHD resolution, delivering clear and detailed video footage both day and night.
Is continuous video recording available on the Wyze Cam Floodlight Pro?Yes, the Wyze Cam Floodlight Pro supports 24/7 continuous recording with a microSD card (up to 256GB, sold separately), allowing for up to 30 days of local video storage.
What installation options are available for the Wyze Cam Floodlight Pro?The Wyze Cam Floodlight Pro can be installed using traditional wiring or with the Wyze Cam Floodlight Pro + Plug-In Mount bundle, which offers a plug-and-play setup with a 20-foot outdoor-rated cable and no need for a junction box or electrician.
What is the Wyze Cam Floodlight Pro + Plug-In Mount bundle?The Wyze Cam Floodlight Pro + Plug-In Mount bundle includes the floodlight camera and a plug-in mount for easy installation. It features a 20-foot outdoor-rated cable and a Velcro strap for cable management, making it ideal for renters or those who want to avoid permanent electrical modifications.
How does the Wyze Cam Floodlight Pro compare to the Wyze Cam Floodlight v2?The Wyze Cam Floodlight Pro offers a wider 180° field of view, higher 2.5K QHD video resolution, brighter 3,000 lumen lighting, and advanced AI-powered motion detection with dual-band Wi-Fi support. In contrast, the Wyze Cam Floodlight v2 has a 160° field of view, 2K HD resolution, 2,800 lumens of brightness, and supports only 2.4 GHz Wi-Fi.
Does the Wyze Cam Floodlight Pro support dual-band Wi-Fi?Yes, the Wyze Cam Floodlight Pro supports both 2.4 GHz and 5 GHz Wi-Fi networks, ensuring fast and reliable connectivity for your security system.
What security features are included with the Wyze Cam Floodlight Pro?The Wyze Cam Floodlight Pro includes AI-powered motion detection, customizable detection zones, ultra-bright adjustable LED panels, color night vision, a 105 dB siren, motion-activated voice deterrence, and continuous video recording capabilities.
What are the adjustable motion detection zones for the Wyze Cam Floodlight Pro?Can you explain the AI-powered object recognition feature in more detail?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam Floodlight Pro?
