Affordable Refurbished Outdoor Floodlight Cameras with Wide-Angle Views
Looking for an affordable, refurbished outdoor floodlight camera that offers a wide-angle view between 130° and 180°? You’ve come to the right place. We highlight top Wyze floodlight cameras that combine powerful lighting, smart AI features, and expansive viewing angles to keep your home safe and well-lit—all without breaking the bank.
Wyze Cam Floodlight Pro: The Ultimate 180° Wide-Angle Security Solution
Expansive 180° Field of View & Crisp 2.5K QHD Video
The Wyze Cam Floodlight Pro leads the pack with a
180° wide-angle lens, providing the broadest coverage available in its category. This means fewer blind spots and full yard visibility. Coupled with
2.5K Quad High Definition (QHD) video resolution, you get crystal-clear footage day and night, enhanced by color night vision.
Intelligent AI-Powered Motion Detection & Lighting
Forget outdated PIR sensors. This floodlight camera uses
onboard AI computer vision to detect motion from specific objects like people and vehicles, triggering the
adjustable 3,000 lumen LED lights only when needed. This smart lighting saves energy and reduces false alarms.
Bright, Customizable Lighting & Voice Deterrence
With
three independently articulating floodlight panels, you can customize your light coverage to suit your property. The camera also features
motion-activated voice deterrence and a
105 dB siren to ward off unwanted visitors effectively.
Dual-Band Wi-Fi & Easy Installation
Supports both
2.4 GHz and 5 GHz Wi-Fi for faster, more reliable connections. Installation is DIY-friendly, replacing your existing floodlight in under 20 minutes. Plus, a
plug-in mount option is available for renters or those without junction boxes.
"Wyze Cam Floodlight Pro is like having a personal home security guard with bright, smart lights."
Stay connected and secure with Wyze Cam Floodlight Pro, perfect for your yard and driveway.
Wyze Cam Floodlight v2: Affordable 160° Wide-Angle with Powerful Illumination
Wide 160° Field of View & 2K Video Quality
The Wyze Cam Floodlight v2 offers a
160° wide-angle view, ideal for covering large outdoor areas with fewer blind spots. It records in
2K resolution with color night vision, ensuring clear images even in low light.
Bright 2800 Lumen LEDs & Ambient Light Mode
Equipped with
two 2800 lumen adjustable LED floodlights, this camera brightens your outdoor space effectively. The
Ambient Light Mode provides a constant low-level light that brightens when motion is detected, deterring intruders while saving energy.
Smart Features & Weather Resistance
Enjoy
AI-powered light control,
two-way talk, and a
105 dB siren for added security. The floodlight is
IP65 weather-resistant, built to withstand rain, snow, and harsh outdoor conditions.
Easy Setup & Smart Home Integration
Supports
2.4 GHz Wi-Fi and integrates seamlessly with Alexa and Google Assistant. The camera also features
dusk-to-dawn automation for hassle-free operation.
"Wyze Cam Floodlight v2 lights the way to smarter home security at an affordable price."
Illuminate your driveway and keep an eye on visitors with Wyze Cam Floodlight v2.
Why Choose Wyze Floodlight Cameras for Outdoor Security?
- Wide-Angle Views: From 160° to 180°, these cameras cover large outdoor areas with minimal blind spots.
- High-Resolution Video: Crisp 2K to 2.5K QHD video ensures you never miss details.
- Smart AI Detection: Motion-triggered lighting and notifications focus on people and vehicles, reducing false alerts.
- Bright, Adjustable LEDs: Powerful floodlights (up to 3000 lumens) with customizable angles.
- Weatherproof & Durable: IP65 rating means reliable performance in rain, snow, and extreme temperatures.
- Easy DIY Installation: Replace existing floodlights or use plug-in mounts without professional help.
- Smart Home Compatibility: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
Summary Table of Recommended Floodlight Cameras
Model | Field of View | Video Resolution | LED Brightness | Price (Refurbished) | Wi-Fi Support |
Wyze Cam Floodlight Pro | 180° | 2.5K QHD | 3000 lumens | ~$150 | 2.4 & 5 GHz Dual-Band |
Wyze Cam Floodlight v2 | 160° | 2K | 2800 lumens | ~$90 | 2.4 GHz |
Final Thoughts
For those seeking
affordable refurbished outdoor floodlight cameras with wide-angle views between 130° and 180°, the
Wyze Cam Floodlight Pro and
Wyze Cam Floodlight v2 stand out as top choices. Both offer excellent video quality, bright and smart lighting, and robust weather resistance, making them perfect for enhancing your home security without overspending.
What are the benefits of choosing a refurbished Wyze outdoor floodlight camera?
Refurbished Wyze outdoor floodlight cameras offer high-quality security features at a more affordable price. They provide wide-angle views, advanced AI motion detection, bright adjustable LED lighting, and weather resistance, making them a cost-effective solution for enhancing home security.Which Wyze floodlight camera has the widest field of view?
The Wyze Cam Floodlight Pro offers the widest field of view at 180°, providing expansive coverage with minimal blind spots for your outdoor areas.What is the video resolution of Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2?
The Wyze Cam Floodlight Pro records in 2.5K Quad High Definition (QHD) video, while the Wyze Cam Floodlight v2 records in 2K resolution. Both models feature color night vision for clear footage in low-light conditions.How bright are the LED floodlights on Wyze outdoor cameras?
The Wyze Cam Floodlight Pro features three adjustable LED panels with a combined brightness of 3,000 lumens. The Wyze Cam Floodlight v2 is equipped with two adjustable LED floodlights providing 2,800 lumens of brightness.Do Wyze floodlight cameras use AI for motion detection?
Yes, both Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2 use AI-powered motion detection to identify people and vehicles, reducing false alarms and ensuring the lights and notifications are triggered only when necessary.Are Wyze floodlight cameras weatherproof?
Yes, both Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2 are IP65 weather-resistant, ensuring reliable performance in rain, snow, and extreme outdoor conditions.Can I install Wyze floodlight cameras myself?
Yes, Wyze floodlight cameras are designed for easy DIY installation. They can replace your existing floodlight in under 20 minutes, and a plug-in mount option is available for renters or homes without junction boxes.Do Wyze floodlight cameras support smart home integration?
Yes, Wyze floodlight cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What Wi-Fi networks do Wyze floodlight cameras support?
The Wyze Cam Floodlight Pro supports both 2.4 GHz and 5 GHz dual-band Wi-Fi for faster and more reliable connections. The Wyze Cam Floodlight v2 supports 2.4 GHz Wi-Fi.What is the price range for refurbished Wyze floodlight cameras?
Refurbished Wyze Cam Floodlight Pro cameras are typically priced around $150, while refurbished Wyze Cam Floodlight v2 cameras are available for about $90.What makes Wyze floodlight cameras a good choice for outdoor security?
Wyze floodlight cameras offer wide-angle views, high-resolution video, smart AI detection, bright adjustable LEDs, weatherproof durability, easy installation, and smart home compatibility—all at an affordable price, making them an excellent choice for outdoor security.
