Wyze Doorbell Pro Kit with Smart Lock Bolt Home Installation Instructions
Enhance your home security and convenience with the Wyze Doorbell Pro Kit paired with the Wyze Lock Bolt. This powerful combination offers seamless smart home access management and front door monitoring, all controllable via the Wyze app. Whether you’re upgrading your existing deadbolt or installing a new video doorbell, this guide will walk you through the essentials for a smooth home installation.
Wyze Lock Bolt: The Ultimate Smart Deadbolt Replacement
Key Features and Benefits
- Ultra-Fast Fingerprint Reader: Unlock your door in less than a second with a simple fingerprint scan, eliminating the need for keys.
- Backlit Keypad with Anti-Peep Technology: Enter your access code securely even at night, with the ability to add extra digits before or after your code to prevent code spying.
- Auto-Lock Function: Never worry about leaving your door unlocked. Set a timer in the Wyze app, and the lock will automatically secure your door after the delay.
- Robust Security and Durability: Crafted from solid metal, the Wyze Lock Bolt is fully pick-proof and weatherproof with an IPX5 rating, built to withstand outdoor elements.
- Long Battery Life: Powered by 4 AA batteries lasting up to 12 months, with a USB-C port for emergency charging if batteries run out.
- Local Bluetooth Control: Manage lock/unlock history, create and store up to 20 access codes and 50 fingerprints, and generate emergency one-time codes—all through the Wyze app without cloud dependency.
- Elegant Design: Available in Matte Black and Satin Nickel finishes, designed to blend beautifully with your door’s exterior.
Installation Overview
Replacing your existing deadbolt with the Wyze Lock Bolt is straightforward and typically takes about 20 minutes. The lock is compatible with most exterior doors and comes with all necessary hardware for installation.
“Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans.”
For added security and ease, the lock pairs perfectly with the Wyze Video Doorbell Pro, creating a comprehensive front door security system.
Secure your home with Wyze Lock Bolt’s smart fingerprint access.
Wyze Video Doorbell Pro: Smart Front Door Monitoring
Why Choose Wyze Video Doorbell Pro?
- High-Resolution Video: Capture clear 2K video with a wide 120° vertical and 88° horizontal field of view.
- Two-Way Audio: Communicate with visitors or delivery personnel directly from your smartphone.
- Weather-Resistant Design: Rated IP65, it withstands rain, snow, and extreme temperatures.
- Motion Detection & Alerts: Receive real-time notifications when motion is detected at your front door.
- Easy Integration: Works seamlessly with Wyze Lock Bolt for a unified smart home experience.
Installation Tips
The Wyze Video Doorbell Pro requires a standard doorbell wiring (16V-24V AC) and can be installed on most front doors or porches. The package includes mounting hardware and a chime for indoor alerts.
Essential Accessories for Wyze Lock Bolt Installation
To ensure a secure and lasting installation of your Wyze Lock Bolt, consider these replacement parts and accessories:
- Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly firmly to your door for enhanced stability.
- Wyze Lock Bolt Interior Assembly Battery Cover: Protects the battery compartment inside the lock.
- Wyze Lock Bolt Screws: Replacement screws set to secure the lock components properly.
These parts are available separately to maintain or repair your smart lock as needed.
Comprehensive Security with Wyze Bundles
For those looking to maximize home security, Wyze offers bundles that combine the Lock Bolt and Video Doorbell Pro with additional cameras and accessories:
- Essential Security Bundle: Includes Wyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, and two Wyze Cam OG cameras for full home coverage.
- Front Porch Security Bundle: Combines Wyze Lock Bolt with Wyze Video Doorbell Pro or v2, plus chime and app integration for remote monitoring and control.
These bundles provide an all-in-one solution for protecting your home’s entry points with smart technology.
Control your Wyze Lock Bolt remotely via the Wyze app.
Final Installation Tips and Recommendations
- Prepare Your Door: Ensure your door’s deadbolt is compatible and remove the existing lock hardware.
- Follow the Quick Start Guides: Both Wyze Lock Bolt and Video Doorbell Pro come with detailed instructions and videos to guide you step-by-step.
- Use the Wyze App: Set up your devices, configure access codes, fingerprints, and customize auto-lock settings.
- Test Before Finalizing: Confirm the lock and doorbell function correctly before securing all screws and plates.
With Wyze’s smart lock and video doorbell, you gain peace of mind and convenience, knowing your home is protected and accessible with just a tap or a glance.
Summary of Products Mentioned
By following these installation instructions and leveraging the powerful features of the Wyze Lock Bolt and Video Doorbell Pro, you can transform your front door into a smart, secure, and convenient entry point for your home.
What is included in the Wyze Doorbell Pro Kit with Smart Lock Bolt?
The Wyze Doorbell Pro Kit includes the Wyze Video Doorbell Pro and the Wyze Lock Bolt. This combination provides smart front door monitoring and secure, keyless entry, all manageable through the Wyze app.How does the Wyze Lock Bolt enhance home security?
The Wyze Lock Bolt features an ultra-fast fingerprint reader, a backlit keypad with anti-peep technology, auto-lock functionality, and robust, weatherproof construction. It is pick-proof and allows you to manage access codes and fingerprints locally via Bluetooth for enhanced security.Is the Wyze Lock Bolt easy to install?
Yes, the Wyze Lock Bolt is designed for straightforward installation, typically taking about 20 minutes. It is compatible with most exterior doors and comes with all necessary hardware and detailed instructions.What are the key features of the Wyze Video Doorbell Pro?
The Wyze Video Doorbell Pro offers high-resolution 2K video, a wide field of view, two-way audio, weather-resistant design (IP65), motion detection with real-time alerts, and seamless integration with the Wyze Lock Bolt.Can I control the Wyze Lock Bolt and Video Doorbell Pro remotely?
Yes, both devices can be controlled and monitored remotely through the Wyze app. You can manage access codes, view lock/unlock history, receive doorbell notifications, and communicate with visitors from your smartphone.What accessories are available for the Wyze Lock Bolt installation?
Essential accessories include the Wyze Lock Bolt Interior Assembly Metal Plate, Interior Assembly Battery Cover, and replacement screws. These parts help ensure a secure installation and are available separately for maintenance or repair.What is the battery life of the Wyze Lock Bolt, and how is it powered?
The Wyze Lock Bolt is powered by 4 AA batteries, which can last up to 12 months. It also features a USB-C port for emergency charging if the batteries run out.Are there security bundles available with Wyze products?
Yes, Wyze offers security bundles such as the Essential Security Bundle and the Front Porch Security Bundle. These combine the Wyze Lock Bolt, Video Doorbell Pro or v2, and additional cameras for comprehensive home security.What should I do before installing the Wyze Lock Bolt or Video Doorbell Pro?
Before installation, ensure your door’s deadbolt is compatible, remove existing lock hardware, and review the included quick start guides and instructional videos. Test the devices before finalizing the installation to ensure proper functionality.Does the Wyze Lock Bolt require an internet connection to operate?
No, the Wyze Lock Bolt operates locally via Bluetooth, allowing you to manage access codes, fingerprints, and lock history without relying on a cloud connection.
