Where to Find a Tune Doorbell Chime That Pairs with Wyze
If you're looking for a reliable and easy-to-use doorbell chime that pairs seamlessly with your Wyze smart doorbell system, you've come to the right place. Wyze offers a range of compatible chimes and doorbell products designed to enhance your home security and convenience. Below, we explore the best Wyze doorbell chimes and compatible doorbell systems that deliver clear alerts, customizable tones, and smart home integration.
Wyze Universal Wi-Fi Chime: The Perfect Tune Doorbell Chime for Wyze Devices
The
Wyze Universal Wi-Fi Chime is the ideal accessory for anyone wanting a fuss-free, tune-enabled chime that works flawlessly with all Wyze cameras and doorbells.
Key Features:
- Compatibility: Works with all Wyze Cams and doorbells, ensuring broad usability.
- Multiple Tones: Choose from 17 different chime tones to customize your doorbell sound.
- Easy Installation: No complicated wiring needed — simply plug it in and connect via Wi-Fi.
- Smart Automations: Set the chime to ring not only when the doorbell is pressed but also when your Wyze camera detects a person, such as at your kitchen or porch.
- Connectivity: Supports IEEE 802.11 b/g/n 2.4 GHz Wi-Fi and Bluetooth BLE 5.0.
- Indoor Use: Designed for indoor placement with a compact size of 81 x 53 x 38 mm.
This chime ensures you never miss a visitor or delivery with clear, customizable alerts that integrate smoothly into your Wyze smart home ecosystem.
Wyze Video Doorbell v2: Wired Doorbell with Built-In Chime Controller
For those seeking a complete wired doorbell solution with an integrated chime, the
Wyze Video Doorbell v2 is a top choice.
Experience smart doorbell convenience with Wyze Video Doorbell v2.
Highlights:
- 2K Video Quality: Crystal-clear 2048 x 1536 resolution with a wide 135° horizontal field of view.
- Chime Controller Included: Comes with a Wyze Chime Controller that powers the chime and integrates with nearly every mechanical chime.
- Two-Way Audio & Alerts: Communicate with visitors and receive real-time notifications on your phone.
- Weather Resistant: Rated IP65 for durability in various weather conditions.
- Smart Integrations: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Easy Installation: Includes wall plate, wedge mount, wire caps, and all necessary hardware.
The bundled chime controller ensures your existing mechanical chime can be used or replaced with the Wyze chime for a customizable tune experience.
Wyze Chime Controller: Standalone Unit for Advanced Compatibility
If you already own a Wyze Video Doorbell v2 or Wyze Duo Cam Doorbell but need a dedicated chime controller, the
Wyze Chime Controller is the perfect add-on.
Features:
- Compatibility: Designed exclusively for Wyze Video Doorbell v2 and Duo Cam Doorbell.
- Mechanical Chime Support: Compatible with nearly every mechanical chime, allowing you to keep your existing doorbell sound system.
- Compact Design: Small footprint (47mm x 32mm x 15mm) fits easily behind your chime.
- Easy Wiring: Simple installation process with included wiring.
- Power: Operates on AC16V/AC24V, ≥10VA power input.
- Durability: Works reliably in temperatures from -20°C to 50°C.
This controller bridges your Wyze doorbell with traditional chimes, enabling you to enjoy tune options without replacing your entire chime system.
Wyze Duo Cam Battery Doorbell: Advanced Battery-Powered Doorbell with Included Wi-Fi Chime
For a wireless option with advanced features, the
Wyze Duo Cam Battery Doorbell comes bundled with the Wyze Wi-Fi Chime, offering a complete tune doorbell solution.
Wireless convenience with Wyze Duo Cam Doorbell and included Wi-Fi Chime.
Why Choose Wyze Duo Cam Doorbell?
- Dual Cameras: Front 2K camera plus bottom 1080p camera for people and package detection.
- Included Wi-Fi Chime: Comes with the Wyze Universal Wi-Fi Chime for customizable tones and smart alerts.
- Battery Powered: Rechargeable lithium-ion battery with USB-C charging and optional hardwired power.
- Smart Alerts: Real-time AI detections, two-way audio, and motion-activated voice deterrence.
- Weather Resistant: IP65 rating for outdoor durability.
- Local & Cloud Storage: Supports microSD cards up to 256GB and cloud storage options.
This battery doorbell is perfect for homes without existing doorbell wiring but still wanting a tune chime that pairs perfectly with Wyze devices.
The Front Porch Security Bundle: Complete Smart Home Doorbell and Chime Package
For a comprehensive smart home security upgrade, the
Front Porch Security Bundle combines a Wyze Video Doorbell, Wyze Chime, and Wyze Lock for total front door control.
Bundle Benefits:
- 1080p HD Video: Monitor your porch with clear video and two-way audio.
- Remote Lock Control: Lock and unlock your door remotely via the Wyze app.
- Multiple Chime Sounds: Includes a Wyze Chime with a variety of tune options.
- Smart Home Integration: Works with Alexa and Google Assistant.
- All-In-One Kit: Comes with all necessary hardware and accessories for easy setup.
This bundle is ideal for those wanting a fully integrated smart doorbell and chime system with added security features.
Why Choose Wyze Doorbell Chimes?
Wyze doorbell chimes are designed to provide clear, customizable alerts that integrate seamlessly with Wyze cameras and doorbells. Whether you prefer a wired or wireless setup, Wyze offers versatile chime options that are easy to install and compatible with smart home assistants like Alexa and Google Assistant.
With multiple tune options, smart automations, and reliable connectivity, Wyze chimes ensure you never miss a visitor or delivery, enhancing your home security and convenience.
Summary of Wyze Doorbell Chime Options
Product | Type | Key Feature | Price (USD) |
Wyze Universal Wi-Fi Chime | Accessory | 17 tones, Wi-Fi, easy plug-in | $19.98 |
Wyze Video Doorbell v2 + Chime | Wired Doorbell | 2K video, chime controller included | $44.98 |
Wyze Chime Controller | Accessory | Compatible with mechanical chimes | $17.99 |
Wyze Duo Cam Battery Doorbell | Battery Doorbell | Dual cameras, included Wi-Fi chime | $109.99 |
Front Porch Security Bundle | Bundle | Doorbell, chime, and smart lock | From $123.99 |
By choosing any of these Wyze doorbell chimes or bundles, you ensure a tune doorbell chime experience that pairs perfectly with your Wyze smart home devices, providing convenience, security, and peace of mind.
Product Tags and Highlights
What is the best doorbell chime that pairs with Wyze devices?
The Wyze Universal Wi-Fi Chime is the top choice for a tune doorbell chime that pairs seamlessly with all Wyze cameras and doorbells. It offers 17 customizable tones, easy plug-in installation, and smart home integration for clear and reliable alerts.Does the Wyze Universal Wi-Fi Chime work with all Wyze doorbells and cameras?
Yes, the Wyze Universal Wi-Fi Chime is compatible with all Wyze Cams and doorbells, making it a versatile accessory for your Wyze smart home system.How do I install the Wyze Universal Wi-Fi Chime?
Installation is simple—just plug the Wyze Universal Wi-Fi Chime into a power outlet, connect it to your Wi-Fi network, and pair it with your Wyze device using the Wyze app. No complicated wiring is required.Can I customize the doorbell chime sound with Wyze products?
Yes, the Wyze Universal Wi-Fi Chime offers 17 different chime tones, allowing you to personalize your doorbell sound to your preference.Is there a Wyze doorbell with a built-in chime controller?
Yes, the Wyze Video Doorbell v2 comes with a built-in chime controller that powers the chime and integrates with nearly every mechanical chime, providing a complete wired doorbell solution.Can I use my existing mechanical chime with Wyze doorbells?
Yes, with the Wyze Chime Controller, you can connect your Wyze Video Doorbell v2 or Wyze Duo Cam Doorbell to almost any existing mechanical chime, allowing you to keep your current doorbell sound system.Is there a wireless Wyze doorbell chime option?
Yes, the Wyze Duo Cam Battery Doorbell is a battery-powered option that comes bundled with the Wyze Universal Wi-Fi Chime, offering wireless convenience and customizable tune options.What smart home integrations are available with Wyze doorbell chimes?
Wyze doorbell chimes and doorbells work with Alexa, Google Assistant, and IFTTT, enabling voice control and smart home automations for enhanced convenience.Are Wyze doorbell chimes weather resistant?
Wyze doorbells such as the Video Doorbell v2 and Duo Cam Battery Doorbell are rated IP65 for weather resistance, making them suitable for outdoor use. The Wyze Universal Wi-Fi Chime is designed for indoor use.What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell, Wyze Chime, and Wyze Lock, providing a complete smart home security solution with HD video, remote lock control, and multiple chime sounds.How much do Wyze doorbell chimes and bundles cost?
Wyze doorbell chimes and bundles are affordably priced: the Wyze Universal Wi-Fi Chime is $19.98, Wyze Video Doorbell v2 with Chime is $44.98, Wyze Chime Controller is $17.99, Wyze Duo Cam Battery Doorbell is $109.99, and the Front Porch Security Bundle starts from $123.99.Why should I choose a Wyze doorbell chime for my home?
Wyze doorbell chimes offer clear, customizable alerts, easy installation, and seamless integration with Wyze cameras and smart home assistants. With both wired and wireless options, Wyze chimes enhance your home security and ensure you never miss a visitor or delivery.
