Upgrade Your Outdated Mechanical Doorbell with Wyze Refurbished Wired Solutions
If you're looking to replace your old mechanical doorbell with a modern, smart, and reliable wired doorbell system, Wyze offers excellent refurbished options that integrate seamlessly with your home. These products not only bring smart features but also provide easy installation and compatibility with existing wiring setups, making your upgrade hassle-free.
Wyze Video Doorbell v2: The Smart Wired Doorbell Replacement
Crisp 2K Video and Wide Field of View
The Wyze Video Doorbell v2 is the perfect wired doorbell replacement for outdated mechanical bells. It delivers stunning 2K (2048 x 1536) video resolution, ensuring you never miss a detail at your doorstep. With a wide 135° horizontal and 103° vertical field of view, you get comprehensive coverage of your porch area.
Smart Features for Enhanced Security
- Two-way audio with built-in microphone and speaker lets you communicate with visitors remotely.
- Motion-activated voice deterrence helps keep unwanted guests away.
- Real-time alerts notify you instantly when someone approaches your door.
- Local microSD storage (up to 256GB) and optional cloud storage with Wyze Security Plan ensure your footage is safely recorded.
Durable and Weather-Resistant
Designed with an IP65 rating, this doorbell withstands rain, snow, and extreme temperatures (-4°F to 122°F), making it ideal for all climates.
Easy Installation with Included Accessories
The package includes a Wyze Chime Controller, wall plate, wedge for angled mounting, wire caps, and installation kit, simplifying the upgrade from your mechanical bell to a smart wired doorbell.
Replace your outdated mechanical doorbell with a smart, high-definition video doorbell that keeps you connected and secure.
Alt text: Modern home entrance featuring a Wyze wired video doorbell installation
Wyze Universal Wi-Fi Chime: Smart Chime Replacement Without Complex Wiring
Plug-and-Play Convenience
The Wyze Universal Wi-Fi Chime is an ideal accessory for those who want to keep their existing wired doorbell but upgrade the chime sound. It requires no complicated wiring—simply plug it into a standard power outlet indoors.
Features That Enhance Your Doorbell Experience
- Compatible with all Wyze Cams and doorbells, making it a versatile choice.
- Offers 17 different chime tones, from classic to modern sounds, customizable to your preference.
- Supports smart automations, such as chiming when a Wyze camera detects a person, even if the doorbell isn't pressed.
- Connect multiple chimes throughout your home for full coverage.
Compact and Stylish Design
Measuring just 81 x 53 x 38 mm, the chime fits discreetly in any room and blends with your home décor.
Enjoy the familiar doorbell sound with a smart twist—no rewiring needed.
Wyze Chime Controller: Seamless Integration with Wyze Video Doorbell v2
Essential for Wired Doorbell Setup
The Wyze Chime Controller is a standalone unit designed specifically for the Wyze Video Doorbell v2 and Duo Cam Doorbell. It enables your wired doorbell to work with Wyze’s smart system while allowing you to keep your existing mechanical chime.
Key Specifications
- Easy wiring installation compatible with nearly every mechanical chime.
- Compact size (47mm x 32mm x 15mm) fits neatly behind your existing chime.
- Operates on AC16V/AC24V power, supporting standard doorbell wiring.
- Works reliably in temperatures from -20°C to 50°C (-4°F to 122°F).
Upgrade your wired doorbell system without replacing your mechanical chime hardware.
Standalone Wyze Chime: Compatible with Wyze Wired Doorbell v1
If you have an earlier Wyze Wired Doorbell or Video Doorbell v1, the standalone Wyze Chime offers a simple replacement for your mechanical chime. Note that it is not compatible with the newer Wyze Video Doorbell Pro or v2 models.
Features
- Designed exclusively for Wyze Wired Doorbell v1 and Wyze Wired Doorbell.
- Provides clear, reliable chime sounds to alert you when visitors arrive.
A straightforward chime replacement for older Wyze wired doorbell models.
Why Choose Wyze Refurbished Wired Doorbell Solutions?
- Cost-Effective: Refurbished products offer smart home upgrades at a fraction of the cost.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Easy Installation: Designed to work with existing wiring and mechanical chimes, minimizing installation hassle.
- Reliable Performance: Weather-resistant and built to last, ensuring your doorbell works flawlessly year-round.
Upgrade your home’s entryway with Wyze’s smart wired doorbell and chime replacements—modern convenience meets classic reliability.
What are the benefits of upgrading to a Wyze refurbished wired doorbell?
Upgrading to a Wyze refurbished wired doorbell provides smart features like 2K video resolution, two-way audio, motion-activated alerts, and seamless integration with your existing wiring. Refurbished options are cost-effective, reliable, and compatible with smart home systems like Alexa, Google Assistant, and IFTTT.How does the Wyze Video Doorbell v2 improve home security?
The Wyze Video Doorbell v2 enhances home security with crisp 2K video, a wide 135° horizontal and 103° vertical field of view, two-way audio, motion-activated voice deterrence, and instant real-time alerts. It also offers local microSD storage and optional cloud storage for secure video recording.Is the Wyze Video Doorbell v2 weather-resistant?
Yes, the Wyze Video Doorbell v2 is designed with an IP65 weather-resistant rating, allowing it to withstand rain, snow, and extreme temperatures ranging from -4°F to 122°F, making it suitable for all climates.What is included with the Wyze Video Doorbell v2 package?
The Wyze Video Doorbell v2 package includes the doorbell unit, Wyze Chime Controller, wall plate, wedge for angled mounting, wire caps, and a complete installation kit for easy setup.Can I keep my existing mechanical chime with Wyze Video Doorbell v2?
Yes, with the Wyze Chime Controller, you can integrate the Wyze Video Doorbell v2 with your existing mechanical chime, allowing you to retain your current chime hardware while upgrading to a smart doorbell system.What is the Wyze Universal Wi-Fi Chime and how does it work?
The Wyze Universal Wi-Fi Chime is a plug-and-play accessory that upgrades your doorbell chime sound without complex wiring. Simply plug it into a standard indoor outlet, and it works with all Wyze Cams and doorbells, offering 17 customizable chime tones and smart automation features.Is the Wyze Universal Wi-Fi Chime compatible with all Wyze doorbells?
Yes, the Wyze Universal Wi-Fi Chime is compatible with all Wyze Cams and doorbells, making it a versatile choice for enhancing your doorbell experience.What is the difference between the Wyze Chime Controller and the Standalone Wyze Chime?
The Wyze Chime Controller is designed for the Wyze Video Doorbell v2 and Duo Cam Doorbell, enabling integration with existing mechanical chimes. The Standalone Wyze Chime is specifically for Wyze Wired Doorbell v1 and provides a direct chime replacement for older models.Can I use the Standalone Wyze Chime with the Wyze Video Doorbell v2?
No, the Standalone Wyze Chime is only compatible with Wyze Wired Doorbell v1 and is not supported by the Wyze Video Doorbell v2 or Wyze Video Doorbell Pro.Are Wyze refurbished wired doorbells easy to install?
Yes, Wyze refurbished wired doorbells are designed for easy installation with included accessories and compatibility with existing wiring and mechanical chimes, making the upgrade process hassle-free.Do Wyze wired doorbells support smart home integration?
Yes, Wyze wired doorbells are compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What storage options are available for Wyze Video Doorbell v2 recordings?
The Wyze Video Doorbell v2 supports local microSD storage up to 256GB and offers optional cloud storage through the Wyze Security Plan, ensuring your video footage is securely recorded.
