Wyze Cam Floodlight v2 Field of View and Features
When it comes to securing your home with bright, intelligent lighting and crystal-clear video, the
Wyze Cam Floodlight v2 stands out with its impressive
160° wide-angle field of view. This wide perspective doubles the visibility compared to the previous generation, allowing you to see more of your property and eliminate blind spots effectively.
Expansive 160° Wide-Angle View
The Wyze Cam Floodlight v2 offers a
160° diagonal field of view, providing a broad coverage area that captures more detail and activity around your home. This wide lens ensures you don’t miss any movement or suspicious activity, making it ideal for front porches, driveways, and backyards.
- 2K HD video resolution enhances the clarity of the footage, especially useful for identifying faces or objects.
- Color Night Vision keeps your property illuminated with vibrant colors even in low-light conditions.
- The wide-angle lens combined with AI-powered motion detection helps reduce false alarms and focuses on relevant events.
"See more, worry less" perfectly sums up the advantage of the 160° field of view on the Wyze Cam Floodlight v2.
Bright security lighting with wide-angle detection
Powerful Lighting and Smart Features
The floodlight is equipped with
two 2800 lumen LEDs that are adjustable and motion-activated, turning night into day to deter intruders effectively. The
Ambient Light Mode provides a constant low-level glow that brightens automatically when motion is detected, acting like a reverse night light for added security.
Additional features include:
- 24/7 local recording with microSD card support up to 256GB, no subscription required.
- Two-way talk with a built-in microphone and speaker lets you communicate with visitors or warn off unwanted guests.
- A loud 105dB siren can be triggered remotely for extra deterrence.
- 270° PIR motion detection area to eliminate blind spots and trigger lights faster.
- Dusk-to-dawn automation turns the floodlight on and off automatically based on ambient light.
- IP65 weather resistance ensures reliable performance in all weather conditions.
- Seamless integration with Alexa, Google Assistant, and IFTTT for smart home control.
Two-way talk feature for real-time communication
Wyze Cam Floodlight v2 + Plug-In Mount: Easy Installation and Flexibility
For those who want the convenience of a plug-and-play setup without the hassle of electrical work, the
Wyze Cam Floodlight v2 + Plug-In Mount bundle is the perfect solution.
Plug-In Mount Benefits
- No need for a junction box or electrician.
- Includes a durable 20-foot outdoor-rated power cable.
- Velcro strap for clean cable management.
- Allows you to place the floodlight exactly where you need it, using any outdoor power outlet.
This bundle combines all the features of the Wyze Cam Floodlight v2 with the flexibility of easy installation, making it ideal for renters or anyone looking to avoid complex wiring.
Comparing Wyze Floodlight Models: Field of View and Features
Model | Field of View | Resolution | Lighting Lumens | Motion Detection | Special Features |
Wyze Cam Floodlight v1 | 121° | 1080p | 2600 | 270° PIR | Color Night Vision, Two-way Audio |
Wyze Cam Floodlight v2 | 160° | 2K | 2800 | 270° PIR | Ambient Light Mode, AI Light Control |
Wyze Cam Floodlight Pro | 180° | 2.5K QHD | 3000 | Advanced AI | Dual-band WiFi, 3 floodlight heads |
The
Wyze Cam Floodlight v2 strikes a balance between wide coverage and high-quality video, making it a top choice for most home security needs. Its 160° field of view offers significantly more visibility than the v1 model, while the Pro model extends coverage even further with 180° and enhanced AI features.
Smart home integration with Alexa and Google Assistant
Why Choose Wyze Cam Floodlight v2?
- Wide 160° field of view for comprehensive coverage.
- 2K video with color night vision for clear, detailed footage day and night.
- Powerful 2800 lumen LEDs with motion-activated and ambient light modes.
- Robust weatherproof design (IP65 rating) for year-round outdoor use.
- Flexible installation options including plug-in mount for easy setup.
- Smart home compatibility with Alexa, Google Assistant, and IFTTT.
- Affordable price point with no mandatory subscription for local recording.
The Wyze Cam Floodlight v2 is lighting the way to smarter, safer home security with its expansive field of view and intelligent features.
Product Summary
Whole Home Security Enhanced Kit (includes Wyze Cam Floodlight v2)
Wyze Cam Floodlight Plug-In Mount
Secure your home with the Wyze Cam Floodlight v2 and enjoy a wide field of view, powerful lighting, and smart features designed to keep your property safe and well-lit around the clock.
What is the field of view of the Wyze Cam Floodlight v2?
The Wyze Cam Floodlight v2 features a 160° wide-angle diagonal field of view, providing expansive coverage to help eliminate blind spots and monitor more of your property compared to previous models.How does the Wyze Cam Floodlight v2 improve night vision?
The Wyze Cam Floodlight v2 is equipped with 2K HD video resolution and color night vision, allowing you to see clear, vibrant footage even in low-light conditions for enhanced security at night.What are the lighting capabilities of the Wyze Cam Floodlight v2?
The Wyze Cam Floodlight v2 comes with two powerful 2800 lumen LEDs that are adjustable and motion-activated. It also features an Ambient Light Mode, which provides a constant low-level glow that brightens when motion is detected.Does the Wyze Cam Floodlight v2 support local video recording?
Yes, the Wyze Cam Floodlight v2 supports 24/7 local recording with a microSD card (up to 256GB), so you can store footage without a subscription.What smart features does the Wyze Cam Floodlight v2 offer?
The Wyze Cam Floodlight v2 includes AI-powered motion detection, two-way talk, a 105dB siren, dusk-to-dawn automation, and seamless integration with Alexa, Google Assistant, and IFTTT for smart home control.Is the Wyze Cam Floodlight v2 weatherproof?
Yes, the Wyze Cam Floodlight v2 is IP65 weather resistant, ensuring reliable performance in all weather conditions for year-round outdoor use.What is the Wyze Cam Floodlight v2 + Plug-In Mount bundle?
The Wyze Cam Floodlight v2 + Plug-In Mount bundle offers easy, plug-and-play installation without the need for a junction box or electrician. It includes a 20-foot outdoor-rated power cable and a Velcro strap for cable management, making it ideal for renters or those seeking flexible placement.How does the Wyze Cam Floodlight v2 compare to other Wyze floodlight models?
The Wyze Cam Floodlight v2 offers a 160° field of view and 2K resolution, which is wider and clearer than the v1 model (121°, 1080p) but slightly less than the Pro model (180°, 2.5K QHD). The v2 also features Ambient Light Mode and AI Light Control, striking a balance between coverage, video quality, and smart features.Does the Wyze Cam Floodlight v2 require a subscription for full functionality?
No, the Wyze Cam Floodlight v2 does not require a subscription for local video recording. You can use a microSD card for 24/7 recording without any ongoing fees.What motion detection features are included with the Wyze Cam Floodlight v2?
The Wyze Cam Floodlight v2 features a 270° PIR motion detection area, AI-powered motion detection to reduce false alarms, and the ability to trigger lights and alerts when motion is detected.
