Wyze Cam Floodlight Pro: Advanced Motion Detection & Customization
Wyze Cam Floodlight Pro is a cutting-edge security camera designed to provide comprehensive outdoor protection with intelligent motion detection customization. Featuring a
180° wide-angle lens and
2.5K QHD video resolution, it captures your entire yard in stunning detail, day or night. The camera’s onboard AI computer vision technology allows you to
customize motion detection by selecting specific objects like people and vehicles to trigger the floodlight and notifications, reducing false alarms from irrelevant movements.
Key Features of Wyze Cam Floodlight Pro
- AI-Powered Motion Detection: Unlike traditional PIR sensors, the Floodlight Pro uses evolutionary AI to detect and differentiate between people, vehicles, and other objects, ensuring your lights and alerts activate only when necessary.
- Adjustable 3,000 Lumen LED Lights: Three independently articulating panels let you customize the light coverage and brightness to suit your outdoor space perfectly.
- Color Night Vision & 2.5K QHD Video: Capture crisp, colorful footage even in low light, providing clear evidence and peace of mind.
- Ambient Light Mode: Provides constant ambient lighting that brightens automatically when motion is detected, deterring unwanted visitors.
- Motion-Activated Voice Deterrence & 105 dB Siren: Scare off intruders with a loud siren and customizable voice prompts triggered only when a person is detected.
- Dual-Band Wi-Fi Support: Connects seamlessly to both 2.4 GHz and 5 GHz networks for reliable streaming and notifications.
- Weather Resistant (IP65): Built to withstand harsh outdoor conditions year-round.
- Easy DIY Installation: Replace your existing floodlight in under 20 minutes with no electrician needed.
Wyze Cam Floodlight Pro in action, providing bright security lighting and smart alerts.
Wyze Cam Floodlight Pro + Plug-In Mount: Simplified Installation with Full Features
For those who want the power of the Wyze Cam Floodlight Pro but without the hassle of hardwiring or installing a junction box, the
Wyze Cam Floodlight Pro + Plug-In Mount bundle is the perfect solution. This plug-and-play setup includes the Floodlight Pro camera and a 20-foot outdoor-rated plug-in mount cable, allowing you to power your floodlight from any outdoor outlet.
Why Choose the Plug-In Mount Bundle?
- No Junction Box Needed: Avoid costly electrician visits and complicated wiring.
- Flexible Placement: The 20-foot cable lets you position the floodlight exactly where you need it.
- All Features of Floodlight Pro Included: Enjoy the same AI motion detection, 3000 lumen brightness, 2.5K video, and voice deterrence.
- Easy DIY Setup: Simply plug it in and connect via Bluetooth for quick installation.
This bundle is ideal for renters or homeowners who want professional-grade security lighting without permanent electrical modifications.
Wyze Cam Floodlight v2: Reliable Motion Detection with Great Value
If you’re looking for a more budget-friendly option with solid motion detection and lighting features, the
Wyze Cam Floodlight v2 offers excellent performance with a
160° wide-angle view and
2K video resolution. It includes color night vision and AI-powered light control to activate the floodlight only when motion is detected.
Highlights of Wyze Cam Floodlight v2
- 2800 Lumens Brightness: Powerful LEDs illuminate your driveway or yard effectively.
- AI-Powered Light Control: Lights activate intelligently based on detected motion.
- Two-Way Audio & 105 dB Siren: Communicate through the built-in speaker and microphone or deter intruders with the siren.
- Dusk-to-Dawn Automation: Automatically turns lights on at sunset and off at sunrise.
- IP65 Weather Resistance: Durable for outdoor use in various weather conditions.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
Wyze Cam Floodlight v2 providing smart lighting and security for your driveway.
Motion Detection Customization: How Wyze Floodlight Cameras Stand Out
Wyze floodlight cameras excel in
motion detection customization by leveraging AI computer vision rather than traditional motion sensors. This means you can:
- Select which objects trigger the floodlight and notifications (e.g., people, vehicles).
- Avoid false alarms caused by animals, shadows, or passing leaves.
- Receive instant alerts on your phone only when relevant motion is detected.
- Use ambient light mode to maintain a low-level light that brightens upon motion detection, enhancing security without wasting energy.
This intelligent approach ensures your outdoor lighting and security system is both effective and user-friendly.
Summary: Which Wyze Floodlight Camera Fits Your Needs?
Feature | Wyze Cam Floodlight Pro | Wyze Cam Floodlight Pro + Plug-In Mount | Wyze Cam Floodlight v2 |
Video Resolution | 2.5K QHD | 2.5K QHD | 2K HD |
Field of View | 180° | 180° | 160° |
LED Brightness | 3000 lumens | 3000 lumens | 2800 lumens |
Motion Detection | AI Computer Vision | AI Computer Vision | AI-Powered Light Control |
Voice Deterrence & Siren | Yes | Yes | Yes |
Installation | Hardwired | Plug-in Mount (no junction box) | Hardwired |
Wi-Fi Support | Dual-band 2.4 & 5 GHz | Dual-band 2.4 & 5 GHz | 2.4 GHz only |
Price | $149.98 | $169.96 | $89.98 |
Choose the Wyze Cam Floodlight Pro for the most advanced motion detection customization and brightest lighting. Opt for the Plug-In Mount bundle if you want hassle-free installation. The Floodlight v2 is a great value option with reliable features for everyday security needs.
"Wyze Cam Floodlight Pro is like having a personal home security guard that thinks and responds intelligently to motion, lighting your yard only when it matters."
What is the Wyze Cam Floodlight Pro and how does it enhance outdoor security?
The Wyze Cam Floodlight Pro is an advanced outdoor security camera featuring a 180° wide-angle lens and 2.5K QHD video resolution. It uses AI-powered motion detection to differentiate between people, vehicles, and other objects, ensuring that the floodlight and notifications are only triggered by relevant activity. This reduces false alarms and provides comprehensive protection for your yard, day or night.How does AI-powered motion detection work on Wyze Cam Floodlight Pro?
Wyze Cam Floodlight Pro uses onboard AI computer vision technology to detect and differentiate between people, vehicles, and other objects. You can customize which types of motion trigger the floodlight and notifications, minimizing false alarms from irrelevant movements like animals or shadows.What are the main features of the Wyze Cam Floodlight Pro?
Key features of the Wyze Cam Floodlight Pro include a 180° wide-angle lens, 2.5K QHD video resolution, AI-powered motion detection, adjustable 3,000 lumen LED lights, color night vision, ambient light mode, motion-activated voice deterrence, a 105 dB siren, dual-band Wi-Fi support (2.4 GHz and 5 GHz), IP65 weather resistance, and easy DIY installation.What is the Wyze Cam Floodlight Pro + Plug-In Mount bundle?
The Wyze Cam Floodlight Pro + Plug-In Mount bundle includes the Floodlight Pro camera and a 20-foot outdoor-rated plug-in mount cable. This setup allows you to power the floodlight from any outdoor outlet, eliminating the need for hardwiring or a junction box. It offers all the features of the Floodlight Pro with a simple, plug-and-play installation.Who should choose the Wyze Cam Floodlight Pro + Plug-In Mount bundle?
The Plug-In Mount bundle is ideal for renters or homeowners who want professional-grade security lighting without permanent electrical modifications. It’s perfect for those seeking easy, DIY installation without the need for an electrician.What are the differences between Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2?
Wyze Cam Floodlight Pro offers a 180° field of view, 2.5K QHD video resolution, 3,000 lumen brightness, dual-band Wi-Fi, and advanced AI motion detection customization. Wyze Cam Floodlight v2 provides a 160° field of view, 2K video resolution, 2,800 lumen brightness, 2.4 GHz Wi-Fi, and AI-powered light control. Both models feature color night vision, a 105 dB siren, and IP65 weather resistance.Does Wyze Cam Floodlight v2 support smart home integration?
Yes, Wyze Cam Floodlight v2 is compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.How does motion detection customization work on Wyze floodlight cameras?
Wyze floodlight cameras use AI computer vision to let you select which objects—such as people or vehicles—trigger the floodlight and notifications. This reduces false alarms from animals, shadows, or leaves, and ensures you receive instant alerts only for relevant motion.Are Wyze floodlight cameras weather resistant?
Yes, both Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2 are IP65 weather resistant, making them suitable for year-round outdoor use in various weather conditions.How easy is it to install Wyze Cam Floodlight Pro?
Wyze Cam Floodlight Pro is designed for easy DIY installation. You can replace your existing floodlight in under 20 minutes without needing an electrician. The Plug-In Mount bundle offers even simpler installation by plugging into any outdoor outlet.What is ambient light mode on Wyze Cam Floodlight Pro?
Ambient light mode provides constant low-level lighting that automatically brightens when motion is detected. This feature helps deter unwanted visitors while conserving energy.What security features are included in Wyze Cam Floodlight Pro?
Wyze Cam Floodlight Pro includes motion-activated voice deterrence, a 105 dB siren, and customizable voice prompts that are triggered only when a person is detected, helping to scare off intruders effectively.Which Wyze floodlight camera is best for my needs?
Choose Wyze Cam Floodlight Pro for the most advanced motion detection and brightest lighting. Opt for the Plug-In Mount bundle for hassle-free, non-permanent installation. Select Wyze Cam Floodlight v2 for a budget-friendly option with reliable security features and smart home integration.
