Wyze Cam Floodlight Kit Including Cam v3 for Smart Home Setup
Enhance your smart home security with the Wyze Cam Floodlight Kit featuring the versatile Wyze Cam v3. This combination offers powerful lighting, crystal-clear video, and intelligent features designed to keep your home safe day and night. Whether you want to monitor your front porch, driveway, or backyard, these products provide seamless integration, weather resistance, and smart automation to fit your lifestyle.
Wyze Cam v3 Spotlight Bundle: The Perfect Smart Home Starter Kit
Key Features
- 1080p Full HD Video with Color Night Vision powered by a CMOS Starlight Sensor for clear images in any lighting.
- IP65 Weatherproof Rating ensures reliable outdoor use rain or shine.
- 120° Diagonal Viewing Angle captures wide areas around your home.
- Motion-Activated 70 Lumen Spotlight enhances visibility and deters unwanted visitors.
- Two-Way Audio & Siren for real-time communication and alerts.
- Easy Installation with included wall mount plate, screws, and power adapter.
- Smartphone Compatibility with Android 5.0+ and iOS 9.0+.
What’s Included
- Wyze Cam v3 camera
- Spotlight Kit (motion-activated, IP65 rated)
- Wall mount plate and tape
- Indoor USB power adapter and cables
This bundle is ideal for those looking to add a reliable camera with integrated lighting to their smart home setup. The spotlight activates automatically with motion, illuminating your property while the camera records in vivid color day and night.
Wyze Cam v3 with spotlight installed outdoors, showcasing weatherproof design and smart lighting.
Wyze Cam Floodlight v2: Brighten and Secure Your Outdoor Spaces
Outstanding Specifications
- 2800 Lumens of Brightness from two dimmable LED light panels, providing powerful illumination.
- 2K Video Resolution (2304 x 1296) with Color Night Vision for detailed monitoring.
- 160° Wide-Angle Field of View covers large outdoor areas.
- Ambient Light Mode & Dusk-to-Dawn Automation for energy-efficient lighting.
- IP65 Weather Resistance for durability in harsh weather conditions.
- Two-Way Talk & 105dB Siren for active deterrence.
- Supports up to 256GB microSD Local Storage for continuous recording.
- Smart Assistant Integration with Alexa, Google Assistant, and IFTTT.
Ideal Use Cases
Perfect for front porches, driveways, and backyards, the Floodlight v2 combines high-powered lighting with advanced security features. Its AI-powered light control intelligently adjusts brightness and activates only when needed, saving energy while keeping your home safe.
Wyze Cam Floodlight v2 lighting up a driveway with motion detection and smart automation.
Wyze Cam Floodlight Pro: Next-Level Security and Illumination
Premium Features
- 2.5K QHD Video (2560 x 1440) with Color Night Vision for ultra-clear footage.
- 3000 Lumens from Three Dimmable LED Panels for maximum brightness.
- 180° Wide-Angle Lens captures an expansive view of your property.
- Onboard AI Computer Vision detects people, vehicles, and other objects with precision.
- Adjustable Light Activation based on selected motion triggers.
- Dual-Band WiFi (2.4 & 5 GHz) for reliable connectivity.
- Built-in 105dB Siren and two-way audio for immediate response.
- IP65 Water Resistance and robust build for all-weather protection.
- Smart Home Compatibility with Alexa, Google Assistant, and IFTTT.
Why Choose Floodlight Pro?
For homeowners seeking the ultimate in outdoor security, the Floodlight Pro offers unmatched video clarity and intelligent lighting control. Its AI-powered detection reduces false alarms and ensures your floodlights only activate for relevant events, making it a smart and efficient security solution.
Wyze Cam Floodlight Pro providing bright, smart lighting with two-way communication.
Additional Accessories and Replacement Parts
Wyze Cam v3 Spotlight Kit
- Motion-activated spotlight with 70 lumens brightness.
- IP65 rated for outdoor durability.
- Connects via Micro USB with included USB cable splitter.
- Dimensions: 21.5 x 55.8 x 34.4 mm.
- Perfect for enhancing your existing Wyze Cam v3 setup with added illumination.
Wyze Cam v3 Replacement Part Kit
- Compatible with both Wyze Cam v2 and v3.
- Ideal for replacing lost or damaged parts.
- Affordable and easy to install with a 30-day hassle-free return policy.
Why Choose Wyze for Your Smart Home Security?
Wyze products combine affordability, advanced technology, and user-friendly design to deliver smart home security solutions that anyone can install and operate. With features like color night vision, AI-powered detection, and seamless smart assistant integration, Wyze cameras and floodlights provide peace of mind around the clock.
Whether you want a simple spotlight bundle or a high-powered floodlight camera, Wyze offers options tailored to your needs and budget.
Summary of Wyze Floodlight Kit Components
Product | Highlights | Price Range |
Wyze Cam v3 Spotlight Bundle | 1080p HD, spotlight, IP65, two-way audio | $49.98 |
Wyze Cam Floodlight v2 | 2800 lumens, 2K video, AI light control | $89.98 |
Wyze Cam Floodlight Pro | 3000 lumens, 2.5K QHD, AI detection | $149.98 |
Wyze Cam v3 Spotlight Kit | Motion-activated spotlight accessory | $16.98 |
Wyze Cam v3 Replacement Kit | Replacement parts for Wyze Cam v2 & v3 | $7.99 |
Equip your smart home with Wyze’s floodlight kits and cameras to enjoy enhanced security, bright illumination, and smart automation that adapts to your lifestyle.
What is included in the Wyze Cam Floodlight Kit?
The Wyze Cam Floodlight Kit typically includes a Wyze Cam v3 camera, a motion-activated spotlight kit (IP65 rated), a wall mount plate and tape, an indoor USB power adapter, and cables. This kit is designed for easy installation and seamless integration into your smart home security setup.What are the main features of the Wyze Cam v3 Spotlight Bundle?
The Wyze Cam v3 Spotlight Bundle offers 1080p Full HD video with color night vision, a 120° diagonal viewing angle, IP65 weatherproof rating, a motion-activated 70 lumen spotlight, two-way audio, a built-in siren, and compatibility with Android and iOS smartphones. It is easy to install and ideal for monitoring outdoor areas.How bright is the Wyze Cam Floodlight v2 and what areas does it cover?
The Wyze Cam Floodlight v2 provides 2800 lumens of brightness from two dimmable LED panels and covers a wide 160° field of view. It is perfect for illuminating and monitoring large outdoor spaces such as front porches, driveways, and backyards.What video quality does the Wyze Cam Floodlight Pro offer?
The Wyze Cam Floodlight Pro delivers ultra-clear 2.5K QHD video (2560 x 1440) with color night vision, ensuring detailed footage both day and night.Are Wyze floodlight cameras weatherproof?
Yes, all Wyze floodlight cameras, including the Cam v3, Floodlight v2, and Floodlight Pro, have an IP65 weather resistance rating, making them suitable for reliable outdoor use in various weather conditions.Can Wyze floodlight cameras be integrated with smart home assistants?
Yes, Wyze floodlight cameras are compatible with popular smart home assistants such as Amazon Alexa, Google Assistant, and IFTTT, allowing for voice control and smart automation.Does the Wyze Cam Floodlight Pro have AI-powered detection?
Yes, the Wyze Cam Floodlight Pro features onboard AI computer vision that can detect people, vehicles, and other objects, reducing false alarms and ensuring the floodlights activate only for relevant events.What storage options are available for Wyze floodlight cameras?
Wyze floodlight cameras support local storage with microSD cards (up to 256GB for Floodlight v2) for continuous recording. Cloud storage options may also be available through Wyze services.How does the motion-activated spotlight work on the Wyze Cam v3?
The Wyze Cam v3’s motion-activated spotlight automatically turns on when motion is detected, providing 70 lumens of illumination and helping to deter unwanted visitors while the camera records clear video.Are replacement parts available for Wyze Cam v3?
Yes, Wyze offers a Replacement Part Kit compatible with both Wyze Cam v2 and v3. This kit is ideal for replacing lost or damaged parts and comes with a 30-day hassle-free return policy.What is the price range for Wyze floodlight kits and accessories?
Wyze floodlight kits and accessories range in price: Wyze Cam v3 Spotlight Bundle ($49.98), Wyze Cam Floodlight v2 ($89.98), Wyze Cam Floodlight Pro ($149.98), Wyze Cam v3 Spotlight Kit ($16.98), and Wyze Cam v3 Replacement Kit ($7.99).Why should I choose Wyze for my smart home security?
Wyze offers affordable, advanced, and user-friendly smart home security solutions. With features like color night vision, AI-powered detection, weather resistance, and smart assistant integration, Wyze cameras and floodlights provide reliable protection and peace of mind for your home.
