Wyze Cam Floodlight Pro vs v2: Full Feature & Specs Comparison
Wyze Cam Floodlight Pro vs Wyze Cam Floodlight v2: Detailed Comparison
When choosing the perfect outdoor security camera with floodlight capabilities, Wyze offers two standout models: the Wyze Cam Floodlight Pro and the Wyze Cam Floodlight v2. Both are designed to enhance your home security with bright lighting and smart camera features, but they cater to slightly different needs and budgets. This comparison will help you understand their key differences and decide which one fits your home best.
Wyze Cam Floodlight Pro: Premium Security with AI-Powered Precision
Superior Video Quality and Field of View
The Wyze Cam Floodlight Pro boasts a 2.5K QHD (2560 x 1440) resolution with vibrant color night vision, delivering crystal-clear footage day and night. Its ultra-wide 180° diagonal field of view ensures you can monitor your entire yard or driveway with minimal blind spots.
Intelligent Motion Detection with AI
Equipped with evolutionary onboard AI computer vision, the Floodlight Pro can detect and differentiate between people, vehicles, and other objects. This smart detection triggers the adjustable 3,000 lumen LED lights only when necessary, reducing false alarms and saving energy.
Powerful Lighting and Audio Features
  • 3 dimmable light panels producing a total of 3,000 lumens at 5000K color temperature.
  • A loud 105dB siren to deter intruders.
  • Hardwired power supply (110-120V AC) ensures consistent performance.
  • Supports both 2.4 GHz and 5 GHz dual-band WiFi for reliable connectivity.
Durable and Weather-Resistant Design
With an IP65 water resistance rating, the Floodlight Pro is built to withstand harsh weather conditions, operating efficiently between -4°F and 140°F (-20°C to 60°C).
Smart Home Integration
Compatible with Alexa, Google Assistant, and IFTTT, it fits seamlessly into your smart home ecosystem.
The Wyze Cam Floodlight Pro is ideal for homeowners seeking top-tier video quality, advanced AI detection, and powerful lighting in one robust package.
Wyze Cam Floodlight Pro lifestyle Wyze Cam Floodlight Pro in action with smart lighting and communication
Wyze Cam Floodlight v2: Affordable and Reliable Outdoor Security
Crisp 2K Video with Wide-Angle Coverage
The Floodlight v2 offers 2K HD video (2304 x 1296) with color night vision, providing clear images to keep your property safe. Its 160° diagonal field of view covers a broad area, perfect for typical home security needs.
Bright and Efficient Lighting
  • Features 2 dimmable LED light panels delivering a total of 2800 lumens at 5000K color temperature.
  • Includes AI-powered light control and dusk-to-dawn automation for energy-efficient operation.
Enhanced Security Features
  • Built-in 105dB siren and two-way audio with speaker and microphone for real-time communication.
  • Supports 24/7 local recording with up to 256GB microSD card storage.
  • Hardwired power supply (110-120V AC) ensures steady power.
Weatherproof and Smart Assistant Compatible
Rated IP65 for weather resistance, it performs well in temperatures from -4°F to 140°F (-20°C to 60°C). It also integrates with Alexa, Google Assistant, and IFTTT.
The Wyze Cam Floodlight v2 is a budget-friendly option that doesn’t compromise on essential security features and smart home compatibility.
Wyze Cam Floodlight v2 lifestyle Wyze Cam Floodlight v2 illuminating a driveway with smart motion detection
Key Differences at a Glance
FeatureWyze Cam Floodlight ProWyze Cam Floodlight v2
Video Resolution2.5K QHD (2560 x 1440)2K HD (2304 x 1296)
Field of View180° diagonal, 170° horizontal160° diagonal
Lighting Lumens3,000 lumens (3 dimmable panels)2,800 lumens (2 dimmable panels)
AI Motion DetectionAdvanced AI computer vision (people, vehicles)AI-powered light control, advanced motion detection
WiFi ConnectivityDual-band 2.4 & 5 GHzSingle-band 2.4 GHz
Audio Features105dB siren105dB siren, two-way audio
Power SupplyHardwired 110-120V ACHardwired 110-120V AC
Weather ResistanceIP65IP65
PriceAround $149.98Around $89.98
Optional Plug-In Mount Bundles for Easy Installation
For those who want to avoid complex wiring, Wyze offers Plug-In Mount bundles for both models:
  • Wyze Cam Floodlight Pro + Plug-In Mount: Combines the Pro camera with a convenient plug-in mount for easy setup without a junction box.
  • Wyze Cam Floodlight v2 + Plug-In Mount: Offers the v2 camera with a plug-in mount, simplifying installation and cable management.
These bundles provide flexibility and ease, especially for renters or those who prefer a plug-and-play solution. Wyze Cam Floodlight Pro Plug-In Mount Plug-in mount option for hassle-free installation of Wyze Floodlight cameras
Conclusion: Which Wyze Floodlight Camera Should You Choose?
  • Choose the Wyze Cam Floodlight Pro if you want the highest video resolution, wider field of view, and advanced AI detection for precise security monitoring.
  • Opt for the Wyze Cam Floodlight v2 if you prefer a more budget-friendly option that still delivers excellent video quality, bright lighting, and smart features.
Both models offer durable, weather-resistant designs and integrate smoothly with popular smart home platforms, making either a smart choice for enhancing your home security.
Video Resolution2.5K QHD (2560 x 1440)2K HD (1920 x 1080)
Field of View180° Ultra-Wide160° Wide-Angle
LED Brightness3000 lumens, 3 floodlight heads2800 lumens, 2 floodlight heads
Color Night VisionYesYes
Motion Detection TechnologyAI computer visionAI-Powered Light Control + 270° PIR motion detection
Motion-Activated LightsYes, adjustable and dimmableYes, adjustable and motion-activated
Ambient Light ModeYesYes
Two-Way AudioNot specifiedYes
Siren105 dB105 dB
Dusk-to-Dawn AutomationYesYes
Wi-Fi SupportDual-band 2.4 & 5 GHz2.4 GHz only
Local RecordingYes, up to 256 GB microSD (sold separately)Yes, up to 256 GB microSD (sold separately)
Cloud Storage SubscriptionCam Plus availableCam Plus available
InstallationDIY, under 20 minutesDIY, easy install
Additional FeaturesMotion-Activated Voice Deterrence, 3 articulating light panels, Instant Bluetooth setupTwo-way talk, 270° PIR motion detection, Access Point Wi-Fi setup
Price$149.98$89.98
What are the main differences between Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2?The Wyze Cam Floodlight Pro offers 2.5K QHD video resolution, a 180° diagonal field of view, 3,000 lumens from three dimmable panels, advanced AI computer vision for motion detection, and dual-band WiFi (2.4 & 5 GHz). The Wyze Cam Floodlight v2 features 2K HD video, a 160° diagonal field of view, 2,800 lumens from two dimmable panels, AI-powered light control, and single-band 2.4 GHz WiFi. Both are IP65 weather-resistant and have a 105dB siren, but the v2 also includes two-way audio.
Which Wyze floodlight camera has better video quality?The Wyze Cam Floodlight Pro has superior video quality with a 2.5K QHD (2560 x 1440) resolution, compared to the Wyze Cam Floodlight v2's 2K HD (2304 x 1296) resolution. This means the Pro model delivers clearer and more detailed footage.
How does the motion detection differ between Wyze Cam Floodlight Pro and v2?The Wyze Cam Floodlight Pro uses advanced onboard AI computer vision to detect and differentiate between people, vehicles, and other objects, reducing false alarms. The Floodlight v2 features AI-powered light control and advanced motion detection, but its AI capabilities are less advanced than the Pro model.
Are both Wyze Cam Floodlight Pro and v2 weatherproof?Yes, both the Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2 are rated IP65 for water resistance and can operate in temperatures ranging from -4°F to 140°F (-20°C to 60°C), making them suitable for outdoor use in various weather conditions.
Do Wyze Cam Floodlight Pro and v2 support smart home integration?Yes, both models are compatible with Alexa, Google Assistant, and IFTTT, allowing seamless integration into your smart home ecosystem.
What are the lighting capabilities of Wyze Cam Floodlight Pro vs v2?The Wyze Cam Floodlight Pro features three dimmable LED panels producing a total of 3,000 lumens at 5000K color temperature. The Wyze Cam Floodlight v2 has two dimmable LED panels delivering 2,800 lumens at the same color temperature. Both provide bright, adjustable lighting for outdoor security.
Is there a plug-in installation option for Wyze Cam Floodlight Pro and v2?Yes, both the Wyze Cam Floodlight Pro and v2 offer optional Plug-In Mount bundles. These bundles allow for easy installation without the need for hardwiring or a junction box, making them ideal for renters or those seeking a plug-and-play solution.
What audio features are available on Wyze Cam Floodlight Pro and v2?Both models include a loud 105dB siren to deter intruders. The Wyze Cam Floodlight v2 also features two-way audio with a built-in speaker and microphone, enabling real-time communication, while the Pro model does not specify two-way audio.
What is the price difference between Wyze Cam Floodlight Pro and v2?The Wyze Cam Floodlight Pro is priced around $149.98, while the Wyze Cam Floodlight v2 is more budget-friendly at around $89.98.
Which Wyze floodlight camera is best for advanced security needs?The Wyze Cam Floodlight Pro is best for advanced security needs, offering higher video resolution, a wider field of view, advanced AI-powered motion detection, and more powerful lighting.
Does Wyze Cam Floodlight v2 support local video recording?Yes, the Wyze Cam Floodlight v2 supports 24/7 local recording with up to a 256GB microSD card, allowing you to store footage directly on the device.
What are the main features of the Wyze Cam Floodlight Pro?How does the AI motion detection work in the Wyze Cam Floodlight Pro?Are there any ongoing promotions or discounts for the Wyze Cam Floodlight cameras?
