Wyze Cam Floodlight v2 Ambient Light Mode: Smart Outdoor Security
Wyze Cam Floodlight v2 Ambient Light Mode: Illuminate and Secure Your Home
When it comes to outdoor security cameras with powerful lighting and smart features, the Wyze Cam Floodlight v2 stands out as a top choice. Designed to dominate the dark, this camera combines bright illumination with intelligent automation, including the innovative Ambient Light Mode that enhances your home’s security and convenience.
What is Ambient Light Mode on Wyze Cam Floodlight v2?
The Ambient Light Mode on the Wyze Cam Floodlight v2 allows the floodlight to emit a soft, dimmable glow that provides subtle illumination without the harshness of full brightness. This mode is perfect for creating a welcoming atmosphere around your home during the evening hours while still maintaining security awareness. It automatically adjusts based on the environment, ensuring your outdoor space is gently lit from dusk to dawn.
This feature is ideal for those who want continuous lighting that is not overpowering but still deters unwanted visitors and improves visibility.
Key Features of Wyze Cam Floodlight v2
  • 2800 Lumens of Brightness: Two dimmable LED light panels deliver powerful illumination with a crisp 5000K color temperature.
  • 2K Video with Color Night Vision: Capture clear, vibrant footage day and night with a 160° wide-angle lens.
  • AI-Powered Light Control: The floodlight intelligently adjusts brightness and activates based on motion detection and ambient light conditions.
  • Dusk-to-Dawn Automation: Automatically turns on at sunset and off at sunrise, providing hassle-free lighting.
  • Two-Way Audio: Built-in speaker and microphone allow you to communicate through the camera remotely.
  • Weather Resistant: Rated IP65 for reliable outdoor performance in rain, snow, or shine.
  • Local Storage Support: Save up to 256GB on a microSD card for continuous 24/7 recording.
  • Smart Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control.
  • Hardwired Power Supply: Ensures consistent power without the need for battery changes.
Dimensions and Design
The Wyze Cam Floodlight v2 measures 9.5in x 7.7in x 7.0in and weighs 2.76 lbs, featuring a matte polycarbonate body available in Black or White. It can be mounted on walls or ceilings, making it versatile for various outdoor locations. Wyze Cam Floodlight v2 in action illuminating a driveway at night Bright and smart outdoor lighting with Wyze Cam Floodlight v2
Wyze Cam Floodlight v2 + Plug-In Mount: Flexible Installation and Power
For those who prefer a non-hardwired option, the Wyze Cam Floodlight v2 + Plug-In Mount bundle offers the same powerful features with added installation flexibility.
Highlights of the Plug-In Mount Bundle
  • Easy Installation: No junction box needed; simply plug into a standard outlet.
  • 20ft Cable with Velcro Strap: Manage cable length neatly for a clean setup.
  • Same 2K HD Video and 2800-Lumen LEDs: Enjoy vibrant color night vision and wide 160° field of view.
  • Advanced Motion Detection and 105dB Siren: Enhance your home security with smart alerts and deterrents.
This bundle is perfect for renters or homeowners who want the power of the Wyze Cam Floodlight v2 without the complexity of hardwiring.
Wyze Cam Floodlight Pro: Next-Level Security and Lighting
If you want to upgrade your outdoor security lighting, the Wyze Cam Floodlight Pro offers enhanced features and brighter illumination.
Why Choose Wyze Cam Floodlight Pro?
  • 3,000 Lumens Brightness: Three dimmable LED panels provide even more powerful lighting.
  • 2.5K QHD Video Quality: Higher resolution (2560 x 1440) for crystal-clear footage.
  • 180° Wide-Angle Lens: Covers a broader area with 170° horizontal and 95° vertical views.
  • AI-Powered Object Detection: Onboard AI distinguishes people, vehicles, and more to reduce false alerts.
  • Dual-Band WiFi (2.4 & 5 GHz): Ensures stable connectivity even in crowded networks.
  • Hardwired Power with IP65 Weather Resistance: Built to withstand harsh outdoor conditions.
  • 105dB Siren and Two-Way Audio: Loud siren and communication features for active deterrence.
The Floodlight Pro is ideal for those who want a high-powered, intelligent security camera that acts like a personal home security guard. Wyze Cam Floodlight Pro providing bright security lighting with a woman and dog Advanced security lighting with Wyze Cam Floodlight Pro
Summary: Which Wyze Floodlight is Right for You?
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight v2 + Plug-In MountWyze Cam Floodlight Pro
Video Resolution2K (2304 x 1296)2K (2304 x 1296)2.5K QHD (2560 x 1440)
Brightness (Lumens)280028003000
Field of View160°160°180°
Power SupplyHardwired 110-120V ACPlug-in Mount (20ft cable)Hardwired 110-120V AC
Ambient Light ModeYesYesYes
AI-Powered Light ControlYesYesAdvanced AI Object Detection
Weather ResistanceIP65IP65IP65
Two-Way AudioYesYesYes
Siren105dB105dB105dB
Enhance Your Home Security with Wyze Cam Floodlight v2 Ambient Light Mode
The Ambient Light Mode on the Wyze Cam Floodlight v2 is a standout feature that balances security and ambiance. Whether you choose the hardwired model, the plug-in mount for easy installation, or the advanced Floodlight Pro, Wyze offers smart, bright, and reliable outdoor lighting solutions that keep your home safe and well-lit. Wyze Cam Floodlight v2 lifestyle image showing two-way talk feature Communicate easily with visitors using two-way audio
Price$89.98$109.96$149.98
Color VariantsBlack, WhiteBlack, White (both Floodlight and Plug-In Mount)Black, White
Video Resolution2K (2560x1440)2K (2560x1440)2.5K QHD (2560x1440)
Field of View160° wide-angle160° wide-angle180° diagonal, 170° horizontal, 95° vertical
Lighting2 floodlight heads, 2800 lumens2 floodlight heads, 2800 lumens3 dimmable light panels, 3000 lumens total
Night VisionColor Night VisionColor Night VisionColor Night Vision
Motion Detection270° PIR motion detection area270° PIR motion detection areaAI computer vision with selectable object detection
AI Detection (with Cam Plus)People, Pets, Vehicle, PackagePeople, Pets, Vehicle, PackagePeople, Pets, Vehicle, Package + quicker Edge AI detections
Local Recording24/7 local recording, microSD up to 256 GB24/7 local recording, microSD up to 256 GBUp to 256 GB microSD card
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscription
Two-Way Talk + SirenYes, 105 dB sirenYes, 105 dB sirenYes, 105 dB siren
Dusk-to-Dawn AutomationYesYesYes
Power SupplyHardwiredHardwired + Plug-In Mount (20 ft cable)Hardwired 110-120V AC
Wi-Fi Compatibility2.4 GHz2.4 GHz2.4 & 5 GHz dual-band
SetupAccess Point Wi-Fi setup, no QR codeAccess Point Wi-Fi setup, no QR codeStandard Wi-Fi setup
Mounting OptionsWall or ceiling mountWall or ceiling mount + plug-in mount for outletWall or ceiling mount
DimensionsNot specifiedNot specified10.2" x 9.1" x 7.8" (25.91 x 23.11 x 19.81 cm)
WeightNot specifiedNot specified2.9 lbs (1.32 kg)
IntegrationsAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTT
WarrantyNot specifiedNot specified1 Year
What is Ambient Light Mode on the Wyze Cam Floodlight v2?Ambient Light Mode on the Wyze Cam Floodlight v2 allows the floodlight to emit a soft, dimmable glow that gently illuminates your outdoor space from dusk to dawn. This feature provides subtle lighting for a welcoming atmosphere while maintaining security, automatically adjusting based on environmental conditions.
How bright is the Wyze Cam Floodlight v2?The Wyze Cam Floodlight v2 delivers up to 2800 lumens of brightness through two dimmable LED panels with a crisp 5000K color temperature, ensuring powerful illumination for your outdoor areas.
Does the Wyze Cam Floodlight v2 support color night vision?Yes, the Wyze Cam Floodlight v2 features 2K video resolution with color night vision, allowing you to capture clear, vibrant footage both day and night with a wide 160° field of view.
What smart features does the Wyze Cam Floodlight v2 offer?The Wyze Cam Floodlight v2 includes AI-powered light control that adjusts brightness and activates the floodlight based on motion detection and ambient light. It also offers dusk-to-dawn automation, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT for smart home integration.
Is the Wyze Cam Floodlight v2 weather resistant?Yes, the Wyze Cam Floodlight v2 is rated IP65, making it weather resistant and suitable for reliable outdoor use in rain, snow, or shine.
Can I install the Wyze Cam Floodlight v2 without hardwiring?Yes, the Wyze Cam Floodlight v2 + Plug-In Mount bundle allows for easy installation without hardwiring. It comes with a 20ft cable and Velcro strap, so you can simply plug it into a standard outlet—ideal for renters or those seeking installation flexibility.
What is the difference between Wyze Cam Floodlight v2 and Floodlight Pro?The Wyze Cam Floodlight Pro offers enhanced features, including 3,000 lumens of brightness, 2.5K QHD video quality, a 180° wide-angle lens, advanced AI-powered object detection, and dual-band WiFi. The Floodlight v2 provides 2K video, 2,800 lumens, and a 160° field of view, making the Pro model ideal for those seeking higher resolution and broader coverage.
Does the Wyze Cam Floodlight v2 support local video storage?Yes, the Wyze Cam Floodlight v2 supports local storage with a microSD card of up to 256GB, enabling continuous 24/7 video recording.
What are the dimensions and design options for the Wyze Cam Floodlight v2?The Wyze Cam Floodlight v2 measures 9.5in x 7.7in x 7.0in and weighs 2.76 lbs. It features a matte polycarbonate body available in Black or White and can be mounted on walls or ceilings for versatile outdoor placement.
Does the Wyze Cam Floodlight v2 have two-way audio?Yes, the Wyze Cam Floodlight v2 is equipped with a built-in speaker and microphone, allowing you to communicate with visitors remotely using two-way audio.
Is the Wyze Cam Floodlight v2 compatible with smart home assistants?Yes, the Wyze Cam Floodlight v2 works with Alexa, Google Assistant, and IFTTT, enabling seamless integration with your smart home ecosystem.
What security features are included with the Wyze Cam Floodlight v2?The Wyze Cam Floodlight v2 includes advanced motion detection, a 105dB siren for active deterrence, AI-powered light control, and two-way audio to enhance your home security.
Can you explain how the AI-Powered Light Control works on the Wyze Cam Floodlight v2?What are the dimensions of the Wyze Cam Floodlight v2?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam Floodlight v2?
