Wyze Floodlight Cameras with Two-Way Audio and PIR Sensor
When it comes to securing your home with smart lighting and surveillance, Wyze offers top-tier floodlight cameras equipped with two-way audio and advanced PIR (Passive Infrared) motion sensors. These features ensure you not only see what’s happening around your property but also communicate in real-time and get precise motion alerts. Below, we explore the best Wyze floodlight cameras that meet these criteria, highlighting their specs and unique benefits.
Wyze Cam Floodlight v2: Bright, Smart, and Responsive
Powerful Illumination and Crisp 2K Video
The Wyze Cam Floodlight v2 dominates the dark with two 2800-lumen LEDs that provide bright, adjustable lighting to illuminate your outdoor spaces. Coupled with a 2K resolution camera and a 160° wide-angle lens, it captures crystal-clear video with vibrant color night vision, ensuring you never miss a detail—even in low light.
Advanced PIR Motion Detection
Equipped with a 270° PIR motion detection area, this floodlight camera detects movement faster and more accurately than traditional sensors. This wide detection range helps eliminate blind spots, triggering the floodlights and alerts promptly when motion is sensed.
Two-Way Audio and Loud Siren
Communicate directly through the Wyze app with two-way talk functionality. Whether greeting guests or warning off intruders, the built-in microphone and speaker make interaction seamless. For added security, a 105dB siren can be activated remotely to deter unwanted visitors.
Smart Features and Weather Resistance
- Ambient Light Mode: Provides a constant low-level light that brightens automatically upon motion detection.
- Dusk-to-Dawn Automation: Automatically turns the floodlight on at sunset and off at sunrise.
- IP65 Weatherproof: Built to withstand rain, snow, and extreme temperatures.
- Local 24/7 Recording: Supports continuous recording to a microSD card (up to 256GB) without subscription fees.
- Smart Assistant Integration: Compatible with Alexa and Google Home for voice control and live feed viewing.
Flexible Installation with Plug-In Mount Option
For those without hardwired floodlight setups, the Wyze Cam Floodlight Plug-In Mount offers an easy DIY installation using a standard outdoor outlet—no electrician needed.
Bright and smart floodlight camera securing your driveway
Wyze Cam Floodlight Pro: The Ultimate Outdoor Security Solution
Ultra-Wide 180° Field of View with 2.5K QHD Video
The Floodlight Pro steps up the game with a massive 180° viewing angle and stunning 2.5K Quad HD resolution. This means you can monitor your entire yard with fewer blind spots and enjoy sharper, more detailed video footage day or night.
AI-Powered Motion Detection and Lighting
Unlike traditional PIR sensors, the Floodlight Pro uses onboard AI computer vision to detect motion intelligently. It activates the 3000-lumen LED lights only for selected objects such as people and vehicles, reducing false alarms and unnecessary lighting.
Enhanced Two-Way Communication and Deterrence
- Motion-Activated Voice Deterrence: Plays a custom voice prompt when a person is detected to warn off intruders.
- Built-in 105dB Siren: Adds an extra layer of security by sounding a loud alarm remotely.
- Two-Way Audio: Talk to visitors or delivery personnel directly through the Wyze app.
Robust Features for Reliable Security
- Dual-Band Wi-Fi Support: Connects seamlessly to both 2.4 GHz and 5 GHz networks for faster, more stable streaming.
- Ambient Light Mode & Dusk-to-Dawn Automation: Provides consistent lighting and automatic operation based on natural light.
- IP65 Weather Resistance: Durable against harsh weather conditions.
- 24/7 Local Recording: Supports microSD cards up to 256GB for continuous video storage.
- Easy DIY Installation: Replace your existing floodlight in under 20 minutes with no professional help.
Wyze Cam Floodlight Pro providing smart security with two-way talk
Wyze Cam Floodlight v2 + Plug-In Mount Bundle: Convenience Meets Security
For users seeking the flexibility of plug-in power without sacrificing features, the Wyze Cam Floodlight v2 + Plug-In Mount bundle is the perfect choice. It combines all the advanced features of the Floodlight v2 with a 20-foot power cord and easy plug-in installation, eliminating the need for junction boxes or complex wiring.
Key Benefits:
- Same 2K HD video with vibrant color night vision and 160° wide-angle view.
- Advanced motion detection with 2800-lumen LEDs and 105dB siren.
- Plug-and-play installation ideal for renters or homes with outdoor outlets.
- Cable management with included Velcro strap for neat setup.
Why Choose Wyze Floodlight Cameras with Two-Way Audio and PIR Sensor?
Wyze floodlight cameras offer a perfect blend of powerful illumination, intelligent motion detection, and interactive communication. Whether you want to keep an eye on your front porch, driveway, or backyard, these cameras provide peace of mind with smart features designed for real-world security needs.
- Two-Way Audio: Stay connected and respond instantly to visitors or intruders.
- PIR Sensor: Accurate motion detection reduces false alerts and triggers lights promptly.
- High-Quality Video: From 2K to 2.5K QHD, see every detail clearly.
- Weatherproof and Durable: Built to perform in all seasons.
- Easy Installation: Options for hardwired or plug-in setups to fit your home.
Summary of Wyze Floodlight Cameras
Feature | Wyze Cam Floodlight v2 | Wyze Cam Floodlight Pro | Wyze Cam Floodlight v2 + Plug-In Mount |
Video Resolution | 2K HD | 2.5K QHD | 2K HD |
Field of View | 160° | 180° | 160° |
LED Brightness | 2800 lumens | 3000 lumens | 2800 lumens |
Motion Detection | 270° PIR sensor | AI computer vision + PIR | 270° PIR sensor |
Two-Way Audio | Yes | Yes | Yes |
Siren | 105dB | 105dB | 105dB |
Weather Resistance | IP65 | IP65 | IP65 |
Installation | Hardwired or plug-in mount | Hardwired | Plug-in mount included |
Wi-Fi Support | 2.4 GHz | Dual-band 2.4 & 5 GHz | 2.4 GHz |
Protect your home with Wyze floodlight cameras that combine bright, smart lighting with clear video and interactive two-way audio. Whether you choose the versatile Floodlight v2, the advanced Floodlight Pro, or the convenient plug-in bundle, you get reliable security powered by intelligent PIR sensors and user-friendly features.
What are the main features of Wyze Cam Floodlight v2?
Wyze Cam Floodlight v2 offers 2K HD video resolution, 160° wide-angle lens, 2800-lumen adjustable LEDs, advanced 270° PIR motion detection, two-way audio, a 105dB siren, ambient light mode, dusk-to-dawn automation, IP65 weather resistance, local 24/7 recording to microSD card, and compatibility with Alexa and Google Home.How does the PIR motion sensor work on Wyze floodlight cameras?
The PIR (Passive Infrared) motion sensor on Wyze floodlight cameras detects heat signatures from people, animals, or vehicles within a wide 270° area. This allows for faster and more accurate motion detection, reducing false alerts and ensuring the floodlights and notifications are triggered only when real movement is detected.What is the difference between Wyze Cam Floodlight v2 and Floodlight Pro?
Wyze Cam Floodlight v2 features 2K HD video, a 160° field of view, 2800-lumen LEDs, and PIR motion detection. The Floodlight Pro upgrades to 2.5K QHD video, a 180° ultra-wide field of view, 3000-lumen LEDs, and AI-powered motion detection with computer vision for smarter alerts. The Pro model also supports dual-band Wi-Fi (2.4 GHz and 5 GHz) for faster streaming.Can I talk to visitors using Wyze floodlight cameras?
Yes, all Wyze floodlight cameras come with two-way audio. You can communicate directly with visitors, delivery personnel, or even warn off intruders in real-time using the Wyze app on your smartphone.Are Wyze floodlight cameras weatherproof?
Yes, Wyze floodlight cameras are rated IP65 weatherproof, making them suitable for outdoor use in rain, snow, and extreme temperatures.Is professional installation required for Wyze floodlight cameras?
No, Wyze floodlight cameras are designed for easy DIY installation. The Floodlight v2 can be hardwired or used with a plug-in mount, while the Floodlight Pro replaces existing floodlights in under 20 minutes. The v2 + Plug-In Mount bundle is ideal for renters or homes with outdoor outlets, requiring no complex wiring.Do Wyze floodlight cameras support continuous video recording?
Yes, Wyze floodlight cameras support 24/7 local recording to a microSD card (up to 256GB), allowing you to store video footage without subscription fees.What smart home integrations are available with Wyze floodlight cameras?
Wyze floodlight cameras are compatible with Alexa and Google Home, enabling voice control and live video feed viewing through your smart home devices.What is the benefit of the Wyze Cam Floodlight v2 + Plug-In Mount bundle?
The Wyze Cam Floodlight v2 + Plug-In Mount bundle offers all the advanced features of the Floodlight v2 with the added convenience of a 20-foot power cord for easy plug-in installation. This makes it perfect for renters or homes without existing hardwired floodlight setups.How bright are the Wyze floodlight cameras?
The Wyze Cam Floodlight v2 and v2 + Plug-In Mount provide 2800 lumens of adjustable LED brightness, while the Floodlight Pro offers an even brighter 3000 lumens, ensuring excellent illumination for your outdoor spaces.What is ambient light mode on Wyze floodlight cameras?
Ambient light mode provides a constant low-level light that automatically brightens when motion is detected, enhancing security and visibility around your property.Do Wyze floodlight cameras have a siren for security?
Yes, all Wyze floodlight cameras are equipped with a built-in 105dB siren that can be activated remotely to deter unwanted visitors or intruders.What Wi-Fi networks do Wyze floodlight cameras support?
Wyze Cam Floodlight v2 and v2 + Plug-In Mount support 2.4 GHz Wi-Fi networks, while the Floodlight Pro supports both 2.4 GHz and 5 GHz dual-band Wi-Fi for faster and more stable streaming.
