Wyze Floodlight Cam: Bright, Smart Security for Your Home
Ultimate Guide to Wyze Floodlight Cams for Smart Home Security
When it comes to securing your home with bright, intelligent lighting and crystal-clear video, Wyze offers a range of floodlight cameras designed to meet diverse needs. Whether you want a powerful 2K camera with color night vision or a pro-level 2.5K QHD camera with AI-powered motion detection, Wyze has you covered. This guide highlights the key features and specs of the Wyze Cam Floodlight lineup, including convenient plug-in mounts and bundled options for easy installation.
Wyze Cam Floodlight v2: Bright, Clear, and Smart
Experience superior home security with the
Wyze Cam Floodlight v2, a perfect blend of powerful lighting and high-definition video.
Key Features:
- 2800 Lumens Brightness: Two dimmable LED light panels deliver bright, clear illumination with a daylight color temperature of 5000K.
- 2K Video Quality: Capture sharp 2304 x 1296 resolution video with vibrant color night vision for clear images even in low light.
- Wide 160° Field of View: Covers a broad area to monitor your porch, driveway, or backyard effectively.
- AI-Powered Light Control: Automatically adjusts lighting based on detected motion and ambient light.
- Two-Way Audio: Built-in speaker and microphone allow you to communicate directly through the camera.
- Weather Resistant: Rated IP65 for reliable outdoor use in temperatures from -4°F to 140°F.
- Local Storage Support: Compatible with up to 256GB microSD cards for continuous local recording.
- Smart Assistant Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Hardwired Power Supply: Connects to standard 110-120V AC wiring for consistent power.
Dominate the dark with smart lighting and crystal-clear video that keeps your home safe day and night.
Wyze Cam Floodlight v2 lighting up a driveway with motion detection
Wyze Cam Floodlight Pro: Advanced AI and Ultra-Wide Coverage
For those seeking the ultimate in floodlight camera technology, the
Wyze Cam Floodlight Pro offers enhanced video quality and intelligent detection.
Standout Specifications:
- 2.5K QHD Video Resolution: Ultra-clear 2560 x 1440 video with color night vision captures every detail.
- 180° Ultra-Wide Field of View: Panoramic coverage ensures no blind spots around your property.
- 3,000 Lumens Brightness: Three dimmable LED panels provide powerful illumination with 5000K color temperature.
- AI Computer Vision: Detects and distinguishes people, vehicles, and other objects to reduce false alerts.
- Dual-Band WiFi Support: Connects via 2.4 GHz and 5 GHz networks for stable streaming.
- 105dB Siren: Loud built-in siren to deter intruders effectively.
- Weatherproof IP65 Rating: Durable for outdoor use in extreme weather conditions.
- Two-Way Audio: Communicate with visitors or delivery personnel remotely.
- Local Storage: Supports up to 256GB microSD cards for continuous recording.
- Smart Home Compatibility: Integrates with Alexa, Google Assistant, and IFTTT.
Think of it as your personal home security guard with bright lights and smart eyes.
Wyze Cam Floodlight Pro providing security and communication at home
Easy Installation with Wyze Cam Floodlight Plug-In Mount
Installing floodlight cameras can be complicated, but Wyze simplifies it with the
Plug-In Mount accessory.
Benefits:
- No Junction Box Needed: Avoid costly and complex electrical work.
- Plug-n-Play Setup: Simply plug into a standard outdoor outlet with a 20-foot power cord.
- Compatible with All Wyze Floodlights: Works with Wyze Cam Floodlight v1, v2, and Floodlight Pro.
- Outdoor Safe and Durable: Rated for outdoor use with robust cable and weather resistance.
- Complete Mounting Kit Included: Comes with screws, silicone ring, foam tape, and quick start guide for hassle-free installation.
Perfect for renters or anyone wanting a quick, flexible floodlight camera setup.
Convenient Bundles: Wyze Cam Floodlight Pro + Plug-In Mount & v2 + Plug-In Mount
Wyze offers bundled options combining the power of their floodlight cams with the ease of plug-in mounts.
Wyze Cam Floodlight Pro + Plug-In Mount Bundle:
- Includes the advanced Floodlight Pro camera and the plug-in mount for easy installation.
- Available in black or white.
- Price: $169.96
- Features all Pro-level specs with the convenience of plug-and-play power.
Wyze Cam Floodlight v2 + Plug-In Mount Bundle:
- Combines the popular Floodlight v2 with the plug-in mount.
- Price: $109.96
- Ideal for those wanting 2K video and bright lighting without hardwiring.
These bundles make upgrading your home security simple and affordable.
Why Choose Wyze Floodlight Cameras?
Wyze floodlight cams stand out for their combination of bright, adjustable lighting, high-resolution video, and smart features like AI detection and voice assistant integration. Whether you want a budget-friendly 2K camera or a pro-grade 2.5K QHD model, Wyze offers reliable, weatherproof solutions that keep your home safe and well-lit.
Bright light, sharp video, smart security — all in one floodlight camera.
Summary of Wyze Floodlight Cam Products
Product Name | Video Resolution | Brightness (Lumens) | Field of View | AI Motion Detection | Power Supply | Price (USD) |
Wyze Cam Floodlight v2 | 2K (2304x1296) | 2800 | 160° | Yes | Hardwired | 89.98 |
Wyze Cam Floodlight Pro | 2.5K QHD (2560x1440) | 3000 | 180° | Advanced AI | Hardwired | 149.98 |
Wyze Cam Floodlight Plug-In Mount | N/A | N/A | N/A | N/A | Plug-in | 19.98 |
Wyze Cam Floodlight Pro + Plug-In Mount | 2.5K QHD | 3000 | 180° | Advanced AI | Plug-in | 169.96 |
Wyze Cam Floodlight v2 + Plug-In Mount | 2K | 2800 | 160° | Yes | Plug-in | 109.96 |
Enhance your home security today with Wyze floodlight cameras — powerful lighting, smart detection, and easy installation all in one.
Feature | Wyze Cam Floodlight v2 | Wyze Cam Floodlight Pro | Wyze Cam Floodlight Plug-In Mount | Wyze Cam Floodlight Pro + Plug-In Mount | Wyze Cam Floodlight v2 + Plug-In Mount |
Price (USD) | $89.98 | $149.98 | $19.98 | $169.96 | $109.96 |
Camera Resolution | 2K HD | 2.5K QHD | N/A | 2.5K QHD | 2K HD |
Field of View | 160° | 180° Ultra-Wide | N/A | 180° Ultra-Wide | 160° |
LED Brightness (Lumens) | 2800 | 3000 | N/A | 3000 | 2800 |
Color Night Vision | Yes | Yes | N/A | Yes | Yes |
AI-Powered Motion Detection | Yes (with Cam Plus for advanced) | Yes (onboard AI computer vision) | N/A | Yes (onboard AI computer vision) | Yes (with Cam Plus for advanced) |
Motion Warning | Yes (with Cam Plus) | Yes | N/A | Yes | Yes |
Two-Way Talk + Siren | Yes (105 dB siren) | Yes (105 dB siren + voice deterrence) | N/A | Yes (105 dB siren + voice deterrence) | Yes (105 dB siren) |
Local Recording | 24/7 local recording (microSD up to 256GB) | 24/7 local recording (microSD up to 256GB) | N/A | 24/7 local recording (microSD up to 256GB) | 24/7 local recording (microSD up to 256GB) |
Wi-Fi Compatibility | 2.4 GHz | 2.4 & 5 GHz Dual-Band | N/A | 2.4 GHz (listed), likely dual-band | 2.4 GHz |
Weather Resistance | IP65 | IP65 | Yes (Outdoor safe) | IP65 | IP65 |
Power Solution | Hardwired | Hardwired | Plug-in mount (20 ft cord) | Floodlight Pro + Plug-in Mount (20 ft cord) | Floodlight v2 + Plug-in Mount (20 ft cord) |
Installation | Hardwired, DIY install possible | Hardwired, DIY install possible | Plug-n-play, no junction box needed | Plug-n-play, no junction box needed | Plug-n-play, no junction box needed |
Ambient Light Mode | Yes | Yes | N/A | Yes | Yes |
Dusk-to-Dawn Automation | Yes | Yes | N/A | Yes | Yes |
Bundle Includes | Camera only | Camera only | Plug-In Mount only | Floodlight Pro + Plug-In Mount | Floodlight v2 + Plug-In Mount |
Compatible With | N/A | N/A | Wyze Cam Floodlight v1, v2, Pro | N/A | N/A |
Cable Length | N/A | N/A | 20 ft (6m) | 20 ft (6m) | 20 ft (6m) |
Additional Features | AI-Powered Light Control, Two-way talk | Motion-Activated Voice Deterrence, 3 adjustable LED panels | UL certified, outdoor safe | All Pro features + plug-in convenience | All v2 features + plug-in convenience |
What are the main features of the Wyze Cam Floodlight v2?
The Wyze Cam Floodlight v2 offers 2800 lumens of bright, dimmable LED lighting, 2K video resolution (2304 x 1296), a wide 160° field of view, color night vision, AI-powered light control, two-way audio, weather resistance (IP65), support for up to 256GB microSD cards for local storage, and integration with Alexa, Google Assistant, and IFTTT. It requires a hardwired power supply.How does the Wyze Cam Floodlight Pro differ from the v2 model?
The Wyze Cam Floodlight Pro features a higher 2.5K QHD video resolution (2560 x 1440), a wider 180° field of view, 3,000 lumens of brightness from three LED panels, advanced AI computer vision for detecting people, vehicles, and objects, dual-band WiFi (2.4 GHz and 5 GHz), a 105dB siren, weatherproof IP65 rating, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT. It also supports up to 256GB microSD cards for local storage.What is the Wyze Cam Floodlight Plug-In Mount and how does it work?
The Wyze Cam Floodlight Plug-In Mount is an accessory that allows you to install Wyze floodlight cameras without hardwiring. It plugs into a standard outdoor outlet using a 20-foot power cord, making installation quick and easy. The mount is compatible with all Wyze Floodlight models (v1, v2, and Pro), is rated for outdoor use, and comes with a complete mounting kit.Are there bundle options available for Wyze floodlight cameras?
Yes, Wyze offers convenient bundles that pair their floodlight cameras with the Plug-In Mount. The Wyze Cam Floodlight Pro + Plug-In Mount bundle and the Wyze Cam Floodlight v2 + Plug-In Mount bundle are available in black or white, providing easy installation and all the features of their respective cameras. These bundles are ideal for users who want plug-and-play installation without hardwiring.Can Wyze floodlight cameras be used outdoors in extreme weather?
Yes, both the Wyze Cam Floodlight v2 and Floodlight Pro are rated IP65 for weather resistance, making them suitable for outdoor use in a wide range of temperatures and weather conditions.Do Wyze floodlight cameras support local video storage?
Yes, Wyze floodlight cameras support local storage with microSD cards up to 256GB, allowing for continuous recording and easy access to video footage.Are Wyze floodlight cameras compatible with smart home assistants?
Yes, Wyze floodlight cameras integrate seamlessly with Alexa, Google Assistant, and IFTTT, enabling voice control and smart home automation.What is the price range for Wyze floodlight cameras and accessories?
Wyze Cam Floodlight v2 is priced at $89.98, Wyze Cam Floodlight Pro at $149.98, the Plug-In Mount at $19.98, the Floodlight Pro + Plug-In Mount bundle at $169.96, and the Floodlight v2 + Plug-In Mount bundle at $109.96.Is professional installation required for Wyze floodlight cameras?
No, professional installation is not required. Wyze floodlight cameras can be installed by homeowners, especially when using the Plug-In Mount, which eliminates the need for hardwiring and a junction box.What are the benefits of choosing Wyze floodlight cameras for home security?
Wyze floodlight cameras offer a combination of bright, adjustable lighting, high-resolution video, smart AI detection, weatherproof design, local storage, and smart home integration, making them a reliable and affordable choice for enhancing home security.
What are the key features of the Wyze Cam Floodlight v2?How does the AI-powered light control work in the Wyze Cam Floodlight v2?Are there any ongoing sales or discounts for the Wyze Cam Floodlight products?
