Hardwired Outdoor Security Floodlight Camera with Wyze Cam v4
When it comes to securing your home with a reliable, high-quality outdoor security camera, the Wyze Cam v4 and its compatible accessories offer an unbeatable combination of advanced features, wired power options, and smart home integration. Whether you want a standalone hardwired camera or a complete floodlight security solution, Wyze has you covered with products designed for durability, clarity, and convenience.
Wyze Cam v4: The Core of Outdoor Security
Crystal-Clear 2.5K QHD Resolution
Wyze Cam v4 delivers stunning 2.5K QHD video quality, ensuring every detail is captured with crystal clarity. This high resolution is perfect for identifying faces, license plates, and other critical details around your property.
Enhanced Color Night Vision & Motion-Activated Spotlight
Unlike traditional infrared night vision, Wyze Cam v4 features enhanced color night vision combined with a motion-activated spotlight. This means you get full-color video even in low-light conditions, improving security and visibility during nighttime hours.
Wired Power Source for Continuous Operation
The Wyze Cam v4 supports a wired power source, making it ideal for hardwired outdoor installations. This eliminates the need for frequent battery changes and ensures your camera stays powered 24/7.
Smart Home Compatibility & Connectivity
Wyze Cam v4 supports Wi-Fi 6 for faster, more reliable connections and integrates seamlessly with Alexa and Google Assistant. You can control your camera and receive alerts through voice commands or your smartphone.
Robust Outdoor Durability
With an IP65 weather resistance rating, the Wyze Cam v4 is built to withstand harsh outdoor conditions, from rain to extreme temperatures (-4ºF to 122ºF).
Additional Features
  • 24/7 local recording with microSD card support (up to 512GB)
  • Two-way audio with a waterproof 99dB speaker and built-in siren
  • Wide Dynamic Range (WDR) for balanced lighting in challenging environments
  • Motion detection zones and sound detection for precise alerts
Power Your Wyze Cam v4 with the Lamp Socket v2 Bundle
Convenient Hardwired Power Solution
The Cam v4 + Lamp Socket v2 Bundle offers a smart way to power your Wyze Cam v4 without needing a traditional outlet. This lamp socket adapter fits into any standard E26 light socket, providing continuous power to your camera.
Motion-Activated Lighting
This lamp socket not only powers your camera but also features motion-activated lights with dusk-to-dawn scheduling, enhancing your outdoor security lighting automatically.
Easy Installation & Compatibility
  • Compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3
  • Simple screw-in installation into existing lamp sockets
  • Supports CFL or LED bulbs up to 20W (incandescent bulbs not recommended)
This bundle is perfect for those looking to hardwire their Wyze Cam v4 in outdoor locations where power outlets are not readily available.
Enhanced Security with the Whole Home Security Enhanced Kit
For a comprehensive outdoor security solution, consider the Whole Home Security Enhanced Kit which pairs the Wyze Cam v4 with the Wyze Cam Floodlight v2.
Integrated Floodlight and Camera System
This kit combines the high-resolution Wyze Cam v4 with a powerful floodlight camera, providing both bright illumination and detailed video surveillance.
Features of the Floodlight Camera
  • Hardwired power for continuous operation
  • Bright floodlights to deter intruders and illuminate large areas
  • Motion detection and smart alerts integrated with Wyze app
Benefits of the Kit
  • Simplifies installation with bundled components
  • Offers multi-angle security coverage
  • Compatible with Alexa and Google Assistant for voice control
Why Choose Wyze for Your Hardwired Outdoor Security?
Wyze products stand out for their balance of affordability, advanced technology, and ease of use. The Wyze Cam v4 and its accessories provide:
  • Reliable wired power options for uninterrupted security
  • Superior video quality with 2.5K resolution and color night vision
  • Smart home integration for seamless control and monitoring
  • Weatherproof design built for outdoor environments
  • Expandable ecosystem with bundles and accessories like lamp sockets and floodlights
Protect your home day and night with Wyze’s hardwired outdoor security solutions that combine cutting-edge features with practical installation options.
Outdoor Security Camera in Use Enhance your home security with hardwired Wyze Cam v4 outdoor cameras.
Summary of Relevant Products
Wyze Cam v4 Outdoor Bundle Includes Wyze Cam v4, outdoor power adapter, and 128GB microSD card. Features 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, and wired power source. Wyze Cam v4 Standalone camera with wired power option, 2.5K QHD video, color night vision, two-way talk, built-in siren, and Wi-Fi 6 support. Cam v4 + Lamp Socket v2 Bundle Provides a hardwired power solution via lamp socket, motion-activated lighting, and compatibility with multiple Wyze Cam models. Whole Home Security Enhanced Kit Combines Wyze Cam v4 with Wyze Cam Floodlight v2 for a complete hardwired floodlight camera security system.
Secure your home with Wyze’s hardwired outdoor security cameras and accessories — the smart choice for reliable, high-quality surveillance.
FeatureWyze Cam v4 Outdoor BundleWyze Cam v4Cam v4 + Lamp Socket v2 BundleWhole Home Security Enhanced Kit
Price$69.99$35.98 (1 Pack)$49.96$256.91
Included Items1x Wyze Cam v4, 1x Wyze Outdoor Power Adapter, 1x Wyze MicroSD Card 128GBWyze Cam v4 onlyWyze Cam v4 + Lamp Socket v21x Wyze Cam v4, 1x Wyze Cam Floodlight v2
Video Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night Vision
SpotlightMotion-activated spotlightMotion-activated spotlightPowered via lamp socket (no outlet needed)Motion-activated spotlight
AudioTwo-way talk, built-in sirenTwo-way talk, built-in sirenTwo-way talk (via Cam v4)Improved two-way audio, built-in siren
Storage128GB microSD card includedmicroSD card required (sold separately)microSD card required (sold separately)128GB microSD card included
PowerWired, includes Outdoor Power AdapterWired, indoor power adapter includedPowered via Lamp Socket v2 (E26 socket)Wired, indoor power adapter included
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6
Weather ResistanceIP65IP65Lamp Socket: Not weatherproof, suitable for damp locationsIP65
CompatibilityAlexa, Google AssistantAlexa, Google AssistantCompatible with Wyze Cam v3, v3 Pro, v4, OG, Pan v3Alexa, Google Assistant
Motion & Sound DetectionYesYesYes (via Cam v4)Yes
Smoke & CO AlertsYesYesYes (via Cam v4)Yes
Mounting OptionsStand, Wall, Ceiling, Magnetic mountStand, Wall, Ceiling, Magnetic mountSame as Cam v4Stand, Wall, Ceiling, Magnetic mount
Dimensions (Camera)Not specified (same as Wyze Cam v4)2in x 2in x 2 3/8inSame as Cam v4Same as Cam v4
Warranty1 Year1 Year1 Year1 Year
What is the Wyze Cam v4 and how does it enhance outdoor security?The Wyze Cam v4 is a high-quality outdoor security camera that offers 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, and a wired power source for continuous operation. It is designed for durability with an IP65 weather resistance rating and integrates seamlessly with smart home systems like Alexa and Google Assistant.
Does the Wyze Cam v4 require batteries or is it hardwired?The Wyze Cam v4 is designed for hardwired installations, supporting a wired power source. This ensures continuous operation without the need for frequent battery changes, making it ideal for reliable outdoor security.
How does the Wyze Cam v4 perform at night?Wyze Cam v4 features enhanced color night vision and a motion-activated spotlight, allowing it to capture full-color video even in low-light conditions. This provides superior visibility and security during nighttime hours compared to traditional infrared night vision cameras.
Is the Wyze Cam v4 weatherproof for outdoor use?Yes, the Wyze Cam v4 is built for outdoor durability with an IP65 weather resistance rating. It can withstand harsh weather conditions, including rain and extreme temperatures ranging from -4ºF to 122ºF.
What smart home systems are compatible with Wyze Cam v4?Wyze Cam v4 is compatible with Alexa and Google Assistant, allowing you to control the camera and receive alerts using voice commands or your smartphone. It also supports Wi-Fi 6 for faster and more reliable connectivity.
Can I record video locally on the Wyze Cam v4?Yes, the Wyze Cam v4 supports 24/7 local recording with a microSD card (up to 512GB), enabling continuous video storage without relying solely on cloud services.
What is the Cam v4 + Lamp Socket v2 Bundle and how does it work?The Cam v4 + Lamp Socket v2 Bundle provides a convenient hardwired power solution for your Wyze Cam v4 by allowing you to power the camera through any standard E26 light socket. The lamp socket also features motion-activated lighting and dusk-to-dawn scheduling, enhancing your outdoor security lighting.
Is the Lamp Socket v2 compatible with other Wyze cameras?Yes, the Lamp Socket v2 is compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3. It supports CFL or LED bulbs up to 20W, but incandescent bulbs are not recommended.
What is included in the Whole Home Security Enhanced Kit?The Whole Home Security Enhanced Kit combines the Wyze Cam v4 with the Wyze Cam Floodlight v2, offering a complete hardwired floodlight camera security system. It provides bright floodlights, high-resolution video surveillance, motion detection, and smart alerts, all integrated with the Wyze app.
What are the main benefits of choosing Wyze hardwired outdoor security cameras?Wyze hardwired outdoor security cameras offer reliable wired power for uninterrupted operation, superior 2.5K video quality with color night vision, smart home integration, weatherproof design, and an expandable ecosystem with accessories like lamp sockets and floodlights. They provide advanced features at an affordable price, making them a smart choice for home security.
How easy is it to install Wyze Cam v4 and its accessories?Wyze Cam v4 and its accessories, such as the Lamp Socket v2, are designed for easy installation. The lamp socket simply screws into existing E26 light sockets, and the camera can be mounted for hardwired power, making setup straightforward even in locations without traditional power outlets.
What are the key features of the Wyze Cam v4 Outdoor Bundle?How does the enhanced color night vision work on the Wyze Cam v4?Are there any ongoing sales or discounts for the Wyze Cam v4?
