Upgrade Your Short Term Rental with Wireless Keypad Smart Locks
Managing short term rentals demands seamless, secure, and convenient access control for guests. A wireless keypad smart lock upgrade not only enhances security but also simplifies guest check-ins and check-outs without the hassle of physical keys. Discover how Wyze’s smart lock solutions can transform your rental property with advanced features tailored for effortless access management.
Wyze Lock Bolt: The Ultimate Wireless Keypad Smart Lock
Ultra-Fast Fingerprint & Keypad Access
The Wyze Lock Bolt replaces your existing deadbolt with a sleek, connected home device featuring a
backlit keypad and an
ultra-fast fingerprint sensor. Guests can unlock the door in less than a second using their fingerprint or a simple tap on the keypad, eliminating the need for physical keys.
Smart Features for Rental Hosts
- Auto-lock function ensures your rental is always secured if guests forget to lock the door.
- Lock and unlock history is accessible via the Wyze app, giving you real-time insights into who accessed your property and when.
- Emergency one-time codes can be generated for guests, perfect for short stays without sharing permanent access.
- Built-in alarm detects jam attempts, adding an extra layer of security.
Durable & Weather-Resistant Design
Designed to withstand outdoor conditions, the Wyze Lock Bolt boasts an
IPX5 weather resistance rating and operates reliably in temperatures from
-13°F to 122°F. It fits standard door thicknesses and backsets, making installation straightforward.
Power & Connectivity
Powered by 4 AA batteries (included) with a battery life of
10-12 months, the lock communicates via
Bluetooth 5.0 with a range of up to 16 feet, ensuring smooth operation with your smartphone or keypad.
“Upgrade your rental’s security with a smart lock that guests love for its speed and hosts trust for its reliability.”
Experience seamless access with Wyze Lock Bolt on your rental’s front door.
Enhance Security with The Front Porch Security Bundle
Comprehensive Access & Surveillance Solution
For short term rentals, combining smart locks with video doorbells enhances security and guest experience. The
Front Porch Security Bundle includes:
- Wyze Lock for remote locking/unlocking and access history.
- Wyze Video Doorbell with 1080p HD video and two-way audio to see and speak with visitors.
- Wyze Chime for audible alerts inside the property.
Key Features
- View your porch in crisp 1080p HD with night vision and motion detection.
- Remote control of your door lock and video doorbell via the Wyze app.
- Works with Alexa and Google Assistant for voice control convenience.
- Weather-resistant components ensure durability in various climates.
This bundle is ideal for hosts who want to monitor their rental’s entryway and provide guests with a secure, welcoming environment.
Keep an eye on your rental’s front porch with Wyze Video Doorbell and Lock.
Replacement Parts for Wyze Lock Bolt: Maintain Your Smart Lock Effortlessly
Keep Your Smart Lock in Top Shape
For long-term reliability, Wyze offers essential replacement parts compatible with the Wyze Lock Bolt:
- Replacement Part Kit and Adapter Replacement Kit for quick fixes.
- Wyze Lock Bolt Screws to secure your lock firmly.
- Interior Assembly Battery Cover and Metal Plate to maintain the lock’s internal components.
These parts ensure your smart lock continues to function flawlessly, minimizing downtime and maintenance hassle for your rental property.
Why Choose Wyze Wireless Keypad Smart Locks for Short Term Rentals?
- Keyless convenience for guests and hosts alike.
- Enhanced security with fingerprint, keypad, and app control.
- Remote management to monitor and control access anytime, anywhere.
- Easy installation replacing existing deadbolts without complex wiring.
- Long battery life reduces frequent maintenance.
- Weather-resistant and durable for various rental property types.
Investing in Wyze smart locks and security bundles elevates your short term rental’s appeal, providing peace of mind and a modern guest experience.
What are the benefits of upgrading my short term rental with a wireless keypad smart lock?
Upgrading your short term rental with a wireless keypad smart lock, such as the Wyze Lock Bolt, enhances security, simplifies guest check-ins and check-outs, and eliminates the need for physical keys. It provides keyless convenience, real-time access management, and a modern guest experience.How does the Wyze Lock Bolt improve guest access for short term rentals?
The Wyze Lock Bolt offers ultra-fast fingerprint and keypad access, allowing guests to unlock the door in less than a second. Hosts can generate emergency one-time codes for guests, making check-ins and check-outs seamless and secure without sharing permanent access.What security features does the Wyze Lock Bolt offer for rental properties?
The Wyze Lock Bolt includes an auto-lock function, lock and unlock history accessible via the Wyze app, emergency one-time codes, and a built-in alarm that detects jam attempts, providing multiple layers of security for your rental property.Is the Wyze Lock Bolt weather-resistant and suitable for outdoor use?
Yes, the Wyze Lock Bolt is designed with an IPX5 weather resistance rating and operates reliably in temperatures from -13°F to 122°F, making it suitable for various climates and outdoor conditions.How is the Wyze Lock Bolt powered and how long does the battery last?
The Wyze Lock Bolt is powered by 4 AA batteries (included) and offers a battery life of 10-12 months, reducing the need for frequent maintenance.Can I control the Wyze Lock Bolt remotely?
The Wyze Lock Bolt communicates via Bluetooth 5.0 with a range of up to 16 feet, allowing you to control the lock and monitor access history through the Wyze app when you are within Bluetooth range.What is included in the Wyze Front Porch Security Bundle for short term rentals?
The Wyze Front Porch Security Bundle includes a Wyze Lock for remote locking and unlocking, a Wyze Video Doorbell with 1080p HD video and two-way audio, and a Wyze Chime for audible alerts inside the property, providing comprehensive access and surveillance for your rental.Does the Wyze Video Doorbell work with smart home assistants?
Yes, the Wyze Video Doorbell works with Alexa and Google Assistant, allowing for convenient voice control and integration with your smart home ecosystem.Are replacement parts available for the Wyze Lock Bolt?
Yes, Wyze offers essential replacement parts for the Lock Bolt, including a Replacement Part Kit, Adapter Replacement Kit, Wyze Lock Bolt Screws, Interior Assembly Battery Cover, and Metal Plate, ensuring your smart lock remains in top condition.Is the Wyze Lock Bolt easy to install on my rental property?
The Wyze Lock Bolt is designed to fit standard door thicknesses and backsets, making installation straightforward. It replaces your existing deadbolt without the need for complex wiring.Why should I choose Wyze wireless keypad smart locks for my short term rental?
Wyze wireless keypad smart locks offer keyless convenience, enhanced security with fingerprint and keypad access, remote management, easy installation, long battery life, and weather-resistant durability, making them an ideal choice for short term rental properties.
