Refurbished Wyze Smart Lock: Auto-Lock, Keyless Entry & Security
Features of the Refurbished Wyze Smart Lock with Auto Lock/Unlock
If you're looking for a reliable, secure, and convenient smart lock solution, the Wyze Lock Bolt stands out as an excellent choice. This refurbished smart lock offers advanced features including auto-lock and auto-unlock capabilities, making your home entry seamless and secure. Below, we explore the key features and benefits of the Wyze Lock Bolt, designed to replace your traditional deadbolt with smart technology.
Keyless Entry with Ultra-Fast Fingerprint Reader
Say goodbye to fumbling for keys. The Wyze Lock Bolt allows you to unlock your door in less than a second using its ultra-fast fingerprint sensor. This biometric access ensures that only authorized users can enter, providing both convenience and enhanced security.
  • Fingerprint Unlock: Store up to 50 fingerprints for family and frequent users.
  • Backlit Keypad: The lock features a luxurious, solid metal exterior with a backlit keypad for easy nighttime use.
  • Anti-Peep Technology: Enter your code with extra digits before or after to prevent onlookers from guessing your passcode.
Unlock your door with just a touch or a tap in the Wyze app, making keyless entry effortless.
Wyze Lock Bolt Lifestyle Experience seamless keyless entry with Wyze Lock Bolt at your front door.
Auto-Lock and Auto-Unlock for Ultimate Convenience
One of the standout features of the Wyze Lock Bolt is its auto-lock functionality. If you forget to lock your door, the lock will automatically secure itself after a set delay, which you can customize in the Wyze app. This feature eliminates the worry of leaving your home unsecured.
  • Auto-Lock Timer: Set your preferred delay time for automatic locking.
  • Auto-Unlock: When paired with the Wyze Lock (not the Bolt), auto-unlock is available, but the Bolt focuses on auto-lock for simplicity and security.
  • One-Touch Locking: Easily lock your door with a single press on the keypad or via the app when within Bluetooth range.
Never stress about whether your door is locked again — Wyze Lock Bolt has you covered.
Robust Security and Weatherproof Design
Security is paramount with the Wyze Lock Bolt. It is designed to be fully pick-proof by eliminating the need for physical keys. The lock is also weatherproof with an IPX5 rating, ensuring durability against rain and other elements.
  • Hardware Encryption: All fingerprint and code data is encrypted locally, so no one, including Wyze, can access your personal information.
  • Two-Factor Authentication: The Wyze app uses 2FA to ensure only authorized users can control the lock.
  • Battery Life: Powered by 4 AA batteries, the lock can last up to 12 months. A low battery indicator and USB-C emergency charging port ensure you’re never locked out.
Wyze Lock Bolt Keypad Secure your home with Wyze Lock Bolt’s encrypted fingerprint and keypad access.
Easy Installation and App Integration
The Wyze Lock Bolt replaces your existing deadbolt and installs in about 20 minutes, compatible with most exterior doors. The Wyze app acts as your command center, allowing you to:
  • View lock/unlock history and failed attempts.
  • Create and manage up to 20 access codes for family and guests.
  • Generate emergency one-time codes remotely, even without Bluetooth connection.
  • Set auto-expiring codes and access schedules for temporary guests.
The app ensures you have full control and visibility over your home’s access at all times.
Wyze Lock Bolt Installation Simple installation replaces your deadbolt in minutes.
Summary
The refurbished Wyze Lock Bolt is a smart, secure, and user-friendly lock solution with standout features like ultra-fast fingerprint unlocking, auto-lock timer, and robust security protocols. Its weatherproof design and long battery life make it ideal for any home, while the Wyze app integration offers comprehensive control and peace of mind.
Product Details at a Glance
FeatureDescription
TypeBluetooth Smart Lock replacing deadbolt
Fingerprint CapacityUp to 50 fingerprints
Access CodesUp to 20 codes
Auto-LockYes, customizable timer
Auto-UnlockNo (available on Wyze Lock, not Bolt)
Battery LifeUp to 12 months (4 AA batteries)
Weatherproof RatingIPX5
SecurityHardware encryption, 2FA, pick-proof design
Installation TimeApprox. 20 minutes
Replacement Parts and Accessories
For maintenance or upgrades, Wyze offers replacement parts compatible with the Lock Bolt, including:
  • Wyze Lock Bolt Interior Assembly Metal Plate – Anchors the interior assembly securely.
  • Wyze Lock Bolt Screws – Replacement screws for installation.
  • Wyze Lock Bolt Interior Assembly Battery Cover – Replacement battery cover for the interior assembly.
These parts ensure your smart lock stays in optimal condition for years to come.
Upgrade your home security with the Wyze Lock Bolt — smart, secure, and effortless.
What is the Wyze Lock Bolt and how does it work?The Wyze Lock Bolt is a Bluetooth-enabled smart lock designed to replace your traditional deadbolt. It offers keyless entry through an ultra-fast fingerprint reader and a backlit keypad, allowing you to unlock your door in less than a second. The lock also features an auto-lock timer, robust security protocols, and easy integration with the Wyze app for full control and monitoring.
What are the key features of the refurbished Wyze Lock Bolt?Key features of the refurbished Wyze Lock Bolt include ultra-fast fingerprint unlocking (up to 50 fingerprints), a backlit keypad with anti-peep technology, customizable auto-lock timer, hardware encryption, two-factor authentication, weatherproof IPX5 rating, up to 12 months of battery life, and easy installation in about 20 minutes.
How does the fingerprint unlock feature work on the Wyze Lock Bolt?The Wyze Lock Bolt uses a biometric fingerprint sensor that allows you to unlock your door in less than a second. You can store up to 50 fingerprints, making it easy for family members and frequent users to access your home securely and conveniently.
Does the Wyze Lock Bolt support auto-lock and auto-unlock?The Wyze Lock Bolt supports a customizable auto-lock feature, which automatically locks your door after a set delay. However, auto-unlock is not available on the Bolt model; it is a feature of the Wyze Lock. The Bolt focuses on auto-lock for enhanced security and simplicity.
Is the Wyze Lock Bolt secure?Yes, the Wyze Lock Bolt is designed with security in mind. It features hardware encryption for all fingerprint and code data, two-factor authentication via the Wyze app, a pick-proof design with no physical keyhole, and anti-peep technology on the keypad to prevent code theft.
How long does the battery last on the Wyze Lock Bolt and what happens if it runs out?The Wyze Lock Bolt is powered by 4 AA batteries, providing up to 12 months of battery life. It includes a low battery indicator and a USB-C emergency charging port, ensuring you can always access your home even if the batteries are depleted.
Is the Wyze Lock Bolt weatherproof?Yes, the Wyze Lock Bolt has an IPX5 weatherproof rating, making it durable and resistant to rain and other outdoor elements. This ensures reliable performance in various weather conditions.
How easy is it to install the Wyze Lock Bolt?The Wyze Lock Bolt is designed for easy installation, replacing your existing deadbolt in about 20 minutes. It is compatible with most exterior doors and comes with all necessary hardware for a straightforward setup.
What can I do with the Wyze app when using the Wyze Lock Bolt?With the Wyze app, you can view lock and unlock history, monitor failed access attempts, create and manage up to 20 access codes, generate emergency one-time codes remotely, set auto-expiring codes, and schedule access for temporary guests. The app also allows you to control the lock when within Bluetooth range.
Are there replacement parts available for the Wyze Lock Bolt?Yes, Wyze offers replacement parts for the Lock Bolt, including the interior assembly metal plate, replacement screws, and the interior assembly battery cover. These accessories help maintain and extend the life of your smart lock.
How many fingerprints and access codes can the Wyze Lock Bolt store?The Wyze Lock Bolt can store up to 50 fingerprints for biometric access and up to 20 unique access codes for family members and guests.
Can you tell me more about the installation process for the Wyze Lock Bolt?What kind of maintenance do I need to perform on the Wyze Lock Bolt?Are there any ongoing sales or discounts for the Wyze Lock Bolt?
