Best Smart Locks with Door Sensors for Rental Homes
Smart Locks for Rental Homes with Built-in Door Sensors
When managing rental properties, security and convenience are paramount. A smart lock with a built-in door sensor offers landlords and tenants peace of mind by providing keyless entry, real-time door status, and enhanced access control. Below, we explore the top smart lock solution designed specifically for rental homes, featuring integrated door sensors and advanced security features.
Wyze Lock Bolt: The Ultimate Smart Lock for Rental Homes
The Wyze Lock Bolt is a Bluetooth-enabled smart lock that replaces your existing deadbolt, making it an ideal upgrade for rental properties. It combines ease of use, robust security, and smart home integration to ensure your rental home is both secure and accessible.
Key Features and Benefits
  • Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a quick fingerprint scan, eliminating the need for physical keys.
  • Backlit Keypad with Anti-Peep Technology: Enter your access code discreetly, even in low light, while preventing others from guessing your code.
  • Built-in Door Sensor: Know if the door is open or closed at a glance, enhancing security monitoring for rental homes.
  • Auto-Lock Function: The lock automatically secures itself if you forget to lock the door, providing an extra layer of safety.
  • Lock and Unlock History: Track who enters and exits your rental property through the Wyze app, perfect for managing multiple tenants.
  • Emergency One-Time Codes: Generate temporary access codes for guests or maintenance workers without compromising permanent access.
  • Built-in Alarm for Jam Detection: Alerts you immediately if the lock is tampered with or jammed.
  • Weather Resistant (IPX5): Suitable for various climates, ensuring durability and reliability.
  • Easy Installation: Replaces existing deadbolts with standard door compatibility (door thickness 1-3/8” to 1-3/4”).
Technical Specifications
SpecificationDetails
CommunicationBluetooth 5.0
RangeUp to 16 feet
Power Source4x AA Batteries (included)
Battery Life10-12 months
Operating Temperature-13°F to 122°F (keypad)
Door Thickness Compatibility1-3/8” to 1-3/4”
Backset Compatibility2-3/8” and 2-3/4”
Deadbolt Diameter1”
Color OptionsMatte Black, Satin Nickel
Weight2.75 lbs
The Wyze Lock Bolt is designed to provide rental property owners with a seamless, secure, and smart access solution that tenants will appreciate for its convenience and reliability.
Wyze Lock Bolt Lifestyle Secure your rental home with Wyze Lock Bolt
Enhance Rental Home Security with the Essential Security Bundle
For landlords seeking a comprehensive security solution, the Essential Security Bundle offers an all-in-one package that includes the Wyze Lock Bolt along with other smart security devices tailored for rental homes.
Bundle Components
  • Wyze Lock Bolt: Keyless entry with fingerprint sensor and backlit keypad.
  • Wyze Video Doorbell v2: Monitor your front door with 1080p HD video and two-way audio, perfect for screening visitors or deliveries.
  • Wyze Cam Pan v3: Provides 360° horizontal and 180° vertical coverage with motion tracking and color night vision.
  • Two Wyze Cam OG Cameras: Versatile indoor/outdoor cameras with motion-activated spotlights and color night vision.
Why Choose the Essential Security Bundle?
  • Comprehensive Coverage: Monitor entrances, common areas, and outdoor spaces with high-definition cameras.
  • Real-Time Alerts: Receive instant notifications on your smartphone for door activity or motion detection.
  • Easy Integration: All devices work seamlessly within the Wyze app, simplifying management for landlords and tenants.
  • Weather Resistant Devices: Cameras and locks are built to withstand outdoor conditions, ensuring year-round protection.
This bundle is perfect for rental homes where security, convenience, and tenant satisfaction are top priorities.
Wyze Plug-in Cam Outdoor Outdoor security with Wyze Plug-in Cam
Replacement Parts for Wyze Lock Bolt
Maintaining your smart lock is easy with genuine Wyze replacement parts designed specifically for the Wyze Lock Bolt. These parts ensure your lock remains functional and secure over time.
Available Replacement Parts
  • Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly securely to the door.
  • Wyze Lock Bolt Screws: Replacement screw sets compatible with the Wyze Lock Bolt.
  • Wyze Lock Bolt Interior Assembly Battery Cover: Protects the battery compartment inside the lock.
  • Wyze Lock Replacement Part Kit: Includes essential components for repair and maintenance.
These parts come with a 30-day hassle-free return policy, making upkeep straightforward and worry-free.
Why Choose Wyze Lock Bolt for Rental Homes?
Managing rental properties demands smart, reliable, and secure access solutions. The Wyze Lock Bolt stands out with its built-in door sensor, ultra-fast fingerprint access, and comprehensive app control, making it the perfect smart lock for rental homes.
  • Tenant Convenience: Keyless entry and temporary codes simplify access management.
  • Landlord Control: Monitor door status and access history remotely.
  • Enhanced Security: Auto-lock and alarm features protect your property.
  • Durability: Weather-resistant design suitable for various environments.
Wyze Lock Bolt Keypad Smart keypad and fingerprint access
Conclusion
For rental homes, the Wyze Lock Bolt offers an unbeatable combination of security, convenience, and smart technology. Whether used alone or as part of the Essential Security Bundle, it provides landlords and tenants with peace of mind through advanced features like built-in door sensors, fingerprint access, and real-time monitoring. Upgrade your rental property today with Wyze Lock Bolt — the smart lock designed to keep your home safe and accessible.
Product Tags Summary
FeatureWyze Lock BoltEssential Security Bundle
Product TypeBluetooth Smart LockSecurity Bundle (Multiple Devices)
Price$79.98$199.99
IncludesSmart Lock with fingerprint reader and keypadWyze Lock Bolt, Wyze Video Doorbell v2, Wyze Cam Pan v3, 2× Wyze Cam OG
Lock FeaturesUltra-fast fingerprint sensor, backlit keypad, auto-lock, built-in alarm, emergency codesSame Wyze Lock Bolt features included
Video DoorbellNot includedWyze Video Doorbell v2 with 1080p HD, two-way audio
Cameras IncludedNoneWyze Cam Pan v3 (pan/tilt, motion tracking, color night vision), 2× Wyze Cam OG (motion-activated spotlight, color night vision)
CommunicationBluetooth 5.0Bluetooth 5.0 (Lock), WiFi (Cameras)
Battery Life (Lock)10-12 months (4x AA batteries included)Same for Wyze Lock Bolt
Lock Range16 ftSame for Wyze Lock Bolt
Weather ResistanceIPX5Lock: IPX5; Cameras: IP65 (Video Doorbell)
Operating Temperature (Keypad)-13°F to 122°FSame for Wyze Lock Bolt
App FeaturesLock/unlock history, remote control via appFull app control for all devices included
Additional FeaturesAnti-peep keypad, jam detection alarmAll Wyze Lock Bolt features plus camera monitoring and alerts
Suitable ForReplacing existing deadboltComprehensive home security with entry and video coverage
What makes the Wyze Lock Bolt a good smart lock for rental homes?The Wyze Lock Bolt is designed specifically for rental properties, offering keyless entry, a built-in door sensor, ultra-fast fingerprint access, and real-time monitoring through the Wyze app. Its features provide both landlords and tenants with enhanced security, convenience, and easy access management.
How does the built-in door sensor on the Wyze Lock Bolt improve security?The built-in door sensor lets you know instantly if the door is open or closed, allowing landlords and tenants to monitor door status in real time. This feature enhances security by ensuring doors are properly secured and alerts users to any unauthorized access.
Can I install the Wyze Lock Bolt on any standard door?Yes, the Wyze Lock Bolt is compatible with standard doors that have a thickness between 1-3/8” and 1-3/4”. It replaces your existing deadbolt and supports backset sizes of 2-3/8” and 2-3/4”, making installation easy for most rental properties.
What are the key features of the Wyze Lock Bolt for landlords and tenants?Key features include ultra-fast fingerprint unlocking, a backlit keypad with anti-peep technology, built-in door sensor, auto-lock function, lock and unlock history tracking, emergency one-time codes, jam detection alarm, weather resistance (IPX5), and easy installation.
How does the Wyze Lock Bolt help landlords manage access for multiple tenants?Landlords can generate temporary access codes for guests or maintenance workers, track lock and unlock history through the Wyze app, and monitor door status remotely. This makes managing access for multiple tenants simple and secure.
What is included in the Essential Security Bundle for rental homes?The Essential Security Bundle includes the Wyze Lock Bolt, Wyze Video Doorbell v2, Wyze Cam Pan v3, and two Wyze Cam OG Cameras. This bundle provides comprehensive security coverage for entrances, common areas, and outdoor spaces.
Are Wyze security devices weather resistant?Yes, the Wyze Lock Bolt and Wyze security cameras included in the Essential Security Bundle are weather resistant, making them suitable for both indoor and outdoor use in various climates.
How long does the Wyze Lock Bolt battery last and what type does it use?The Wyze Lock Bolt uses 4 AA batteries (included) and offers a battery life of 10-12 months, depending on usage.
What replacement parts are available for the Wyze Lock Bolt?Available replacement parts include the Wyze Lock Bolt Interior Assembly Metal Plate, Wyze Lock Bolt Screws, Wyze Lock Bolt Interior Assembly Battery Cover, and a Wyze Lock Replacement Part Kit. All parts come with a 30-day hassle-free return policy.
How does the Wyze Lock Bolt enhance tenant convenience?Tenants benefit from keyless entry via fingerprint or keypad, the ability to receive temporary access codes, and the peace of mind provided by real-time door status monitoring and auto-lock features.
Can I monitor my rental property remotely with Wyze devices?Yes, all Wyze devices, including the Lock Bolt and security cameras, can be managed and monitored remotely through the Wyze app, allowing landlords to receive real-time alerts and access history from anywhere.
What are the key features of the Wyze Lock Bolt that make it suitable for rental homes?Can you explain how the built-in door sensor works in the Wyze Lock Bolt?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Lock Bolt?
