Affordable Refurbished Smart Lock with Auto Lock, Auto Unlock, and Backlit Keypad
Looking for a budget-friendly, reliable smart lock that offers advanced features like auto-lock, auto-unlock, and a backlit keypad? The
Wyze Lock Bolt stands out as an excellent choice for anyone wanting to upgrade their home security without breaking the bank. This refurbished smart lock combines convenience, security, and modern technology in a sleek, durable design.
Wyze Lock Bolt: Key Features and Benefits
Ultra-Fast Fingerprint Unlock & Backlit Keypad
Say goodbye to fumbling for keys. The Wyze Lock Bolt replaces your traditional deadbolt with a smart lock featuring an ultra-fast fingerprint reader. Unlock your door in less than a second with just a touch of your finger. The lock also includes a luxurious backlit keypad, making it easy to enter your code even in the dark.
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Auto-Lock for Peace of Mind
Never worry about leaving your door unlocked again. The Wyze Lock Bolt comes with an auto-lock timer that you can customize via the Wyze app. If you forget to lock your door, the smart lock will automatically secure it after your set delay, ensuring your home stays safe.
Anti-Peep Technology
Protect your access codes from prying eyes. The Wyze Lock Bolt’s anti-peep feature allows you to enter extra random digits before or after your actual code, so no one can guess your passcode by watching you enter it.
Durable and Weatherproof Design
Crafted from solid metal, the Wyze Lock Bolt is built to last and withstand the elements with an IPX5 weatherproof rating. It’s fully pick-proof since it eliminates the need for physical keys, enhancing your home’s security.
Long Battery Life with Easy Charging
Powered by 4 AA batteries, the Wyze Lock Bolt can last up to 12 months on a single set. When battery levels run low, a red indicator flashes to remind you to replace them. If the batteries die while you’re away, a USB-C port allows for a quick emergency charge so you can still enter your access code.
Seamless App Control
The Wyze app acts as your command center, allowing you to:
- View lock/unlock history and failed attempts
- Create and store up to 20 access codes and 50 fingerprints
- Generate emergency one-time codes remotely
- Set auto-expiring codes and access schedules
- Lock or unlock remotely within Bluetooth range
Easy Installation
The Wyze Lock Bolt replaces your existing deadbolt and installs in about 20 minutes, compatible with most exterior doors.
Secure your home effortlessly with Wyze Lock Bolt smart lock
Why Choose Wyze Lock Bolt for Your Smart Home?
- Affordable Price: At just $79.98, the Wyze Lock Bolt offers premium features at a fraction of the cost of many competitors.
- Refurbished Quality: A-grade refurbished units ensure you get a like-new product with full functionality and reliability.
- Auto-Lock Feature: Essential for busy households or forgetful moments, this feature adds an extra layer of security.
- Backlit Keypad: Convenient for nighttime use, the keypad is easy to see and use in any lighting condition.
- Fingerprint Access: Fast, secure, and keyless entry that’s perfect for families and frequent users.
Additional Accessories and Replacement Parts
While the Wyze Lock Bolt is a complete smart lock solution, you can also find compatible replacement parts and accessories to keep your lock functioning perfectly:
- Wyze Lock Bolt Screws: Replacement screws to maintain secure installation.
- Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly firmly to your door.
- Wyze Lock Bolt Interior Assembly Battery Cover: Replacement battery cover for the interior assembly.
These parts ensure your smart lock stays in top condition for years to come.
Control your smart lock easily with the Wyze app and backlit keypad
Summary
The
Wyze Lock Bolt is the ideal affordable refurbished smart lock for anyone seeking keyless convenience, enhanced security, and smart home integration. With features like ultra-fast fingerprint unlocking, auto-lock, anti-peep technology, and a backlit keypad, it offers everything you need to secure your home effortlessly. Its durable, weatherproof design and long battery life make it a dependable choice for any exterior door.
Upgrade your home security today with the Wyze Lock Bolt — smart, secure, and budget-friendly.
What is the Wyze Lock Bolt and what features does it offer?
The Wyze Lock Bolt is an affordable, refurbished smart lock designed to replace your traditional deadbolt. It offers advanced features such as ultra-fast fingerprint unlock, a backlit keypad, customizable auto-lock, anti-peep technology, durable weatherproof construction, long battery life, and seamless app control via the Wyze app.How does the fingerprint unlock feature work on the Wyze Lock Bolt?
The Wyze Lock Bolt features an ultra-fast fingerprint reader that allows you to unlock your door in less than a second with just a touch of your finger. It can store up to 50 fingerprints, making it convenient for families and frequent users.What is the auto-lock feature on the Wyze Lock Bolt?
The auto-lock feature on the Wyze Lock Bolt automatically secures your door after a customizable delay, which you can set using the Wyze app. This ensures your home stays safe even if you forget to lock the door manually.How does the anti-peep technology on the Wyze Lock Bolt enhance security?
The anti-peep technology allows you to enter extra random digits before or after your actual access code on the keypad. This prevents others from guessing your passcode by watching you enter it, enhancing your home’s security.Is the Wyze Lock Bolt weatherproof and durable?
Yes, the Wyze Lock Bolt is crafted from solid metal and has an IPX5 weatherproof rating, making it suitable for exterior doors and able to withstand various weather conditions.How long does the battery last on the Wyze Lock Bolt and how do I charge it?
The Wyze Lock Bolt is powered by 4 AA batteries, which can last up to 12 months on a single set. When the battery is low, a red indicator flashes to remind you to replace them. If the batteries die, you can use the USB-C port for a quick emergency charge to enter your access code.What can I control with the Wyze app for the Wyze Lock Bolt?
With the Wyze app, you can view lock and unlock history, monitor failed attempts, create and store up to 20 access codes, generate emergency one-time codes, set auto-expiring codes and access schedules, and lock or unlock the door remotely within Bluetooth range.How easy is it to install the Wyze Lock Bolt?
The Wyze Lock Bolt is designed for easy installation, replacing your existing deadbolt in about 20 minutes. It is compatible with most exterior doors.What is included with a refurbished Wyze Lock Bolt?
A refurbished Wyze Lock Bolt is an A-grade unit that has been tested for full functionality and reliability, offering like-new performance at a lower price.Are there replacement parts and accessories available for the Wyze Lock Bolt?
Yes, you can purchase compatible replacement parts and accessories such as Wyze Lock Bolt screws, interior assembly metal plates, and battery covers to keep your smart lock in top condition.What makes the Wyze Lock Bolt a good choice for smart home security?
The Wyze Lock Bolt is an affordable, feature-rich smart lock that offers keyless convenience, enhanced security with fingerprint and anti-peep technology, a backlit keypad for easy use at night, durable weatherproof construction, and seamless integration with the Wyze app, making it an excellent choice for upgrading your home security.
