Affordable Matte Black Smart Lock with Encrypted Access
Affordable Matte Black Smart Lock with Encrypted Access Features
Looking for a sleek, secure, and budget-friendly smart lock in matte black? The Wyze Lock Bolt stands out as an excellent choice. Designed to replace your existing deadbolt, this smart lock combines advanced encrypted access technology with a stylish matte black finish, making it perfect for modern homes seeking both security and convenience.
Wyze Lock Bolt: Key Features & Benefits
Stylish Matte Black Design
The Wyze Lock Bolt is crafted from solid metal with a luxurious matte black finish that complements any exterior door. Its modern, minimalist look blends seamlessly with your home’s aesthetic while providing robust security.
Ultra-Fast Fingerprint Access
Say goodbye to fumbling with keys. Unlock your door in less than a second using the ultra-fast fingerprint reader. The backlit keypad also allows for easy code entry at night, featuring anti-peep technology so you can enter your code discreetly by adding extra digits before or after your passcode.
Encrypted and Secure Access
Wyze Lock Bolt uses hardware encryption to protect your fingerprint and passcode data. No cloud connection is required for unlocking, ensuring your access information stays private and secure. Two-factor authentication within the Wyze app adds an extra layer of protection, allowing only authorized users to control the lock.
Convenient Auto-Lock and App Control
Never worry about leaving your door unlocked. The lock auto-locks after a set delay, configurable via the Wyze app. You can also lock or unlock remotely when within Bluetooth range, view access history, and create up to 20 unique access codes and 50 fingerprints for family and guests.
Weatherproof and Pick-Proof
Built tough with IPX5 weatherproofing, the Wyze Lock Bolt withstands rain and outdoor elements. Its keyless design eliminates the risk of lock picking, enhancing your home’s security.
Long Battery Life with Backup Options
Powered by 4 AA batteries, the lock lasts up to 12 months on a single set. Low battery alerts notify you in advance, and if the batteries die, a USB-C port allows a quick emergency charge to regain entry.
Easy Installation
Replacing your existing deadbolt is simple and takes about 20 minutes. The lock fits most exterior doors and comes with all necessary hardware for a hassle-free setup.
Wyze Lock Bolt Lifestyle Secure your home stylishly with Wyze Lock Bolt in matte black.
Why Choose Wyze Lock Bolt for Your Smart Home?
  • Affordable Price: At $79.98, the Wyze Lock Bolt offers premium features without breaking the bank.
  • Local Bluetooth Control: No reliance on cloud services means faster, more secure operation.
  • Fingerprint and Code Access: Multiple convenient ways to enter your home.
  • Auto-Lock Feature: Peace of mind knowing your door locks automatically.
  • Robust Security: Hardware encryption and two-factor authentication protect your data.
  • Weather-Resistant: Suitable for outdoor installation with IPX5 rating.
Additional Wyze Smart Lock Options
While the Wyze Lock Bolt is the best fit for those seeking a matte black smart lock with encrypted access, Wyze also offers the Wyze Lock (not in matte black) for users wanting remote access and smart home integrations like Alexa and Google Assistant. However, it lacks fingerprint unlocking and is designed to attach to your existing deadbolt rather than replace it.
Summary
If you want an affordable matte black smart lock with encrypted access features, the Wyze Lock Bolt is your top pick. It combines style, security, and convenience with advanced fingerprint technology, encrypted local access, and a durable, weatherproof design — all at a wallet-friendly price.
Wyze Lock Bolt App Control Control your Wyze Lock Bolt easily from your smartphone app.
Product Specifications at a Glance
FeatureSpecification
FinishMatte Black
Access MethodsFingerprint, Backlit Keypad, App
EncryptionHardware Encryption
Auto-LockYes, configurable delay
Weather ResistanceIPX5 (water resistant)
Battery LifeUp to 12 months (4 AA batteries)
Emergency PowerUSB-C quick charge port
Max Fingerprints Stored50
Max Access Codes20
Installation Time~20 minutes
Price$79.98
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans." – User Review
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt in top condition, replacement parts are available:
  • Wyze Lock Bolt Screws – Secure your lock firmly ($2.99)
  • Wyze Lock Bolt Interior Assembly Metal Plate – Anchors the interior assembly ($4.99)
  • Wyze Lock Bolt Interior Assembly Battery Cover – Protects battery compartment ($9.99)
These parts ensure your smart lock remains reliable and functional over time.
Wyze Lock Bolt Fingerprint Reader Fingerprint reader and backlit keypad for quick, secure access.
Upgrade your home security today with the Wyze Lock Bolt — the affordable matte black smart lock with encrypted access features that you can trust.
FeatureWyze Lock BoltWyze Lock
TypeBluetooth smart lock replacing deadboltSmart lock that attaches to existing deadbolt
Keyless EntryYes, fingerprint sensor and backlit keypadYes, app control and optional keypad
Fingerprint UnlockYesNo
App AccessLocal Bluetooth connection onlyRemote access via app anywhere
Auto-LockYes, basic auto-lock timerYes, advanced door position auto-lock
Auto-UnlockNoYes, unlocks as you approach
Voice Assistant SupportNoYes, supports Alexa, Google Assistant, Wyze Switch
Installation TimeAbout 20 minutesUnder 15 minutes
CompatibilityReplaces existing deadboltWorks with most single cylinder deadbolts
Max Fingerprints50N/A
Max Access Codes20Unlimited via app
Emergency One-Time CodesYesYes
Hardware EncryptionYesYes
Two-Factor AuthenticationYes (via app)Yes (via app)
Battery Type4x AA Batteries (up to 12 months)4x AA Batteries (5-6 months)
Weather ResistanceIPX5Indoor use only
Locking MethodFingerprint, keypad, app (Bluetooth)App, keypad (optional), voice
Price (Regular)$79.98$123.99
Keypad IncludedYesOptional accessory
Lock TypeReplaces deadboltAttaches to existing deadbolt
Lock/Unlock HistoryYes, in Wyze appYes, in Wyze app
Guest AccessCreate codes, fingerprints, emergency codesVirtual keys, codes via app
Auto-Lock Delay SettingYes, configurable in appYes, advanced settings
App FeaturesView lock/unlock history, failed attemptsRemote lock/unlock, notifications, automations
What is the Wyze Lock Bolt and what makes it unique?The Wyze Lock Bolt is an affordable matte black smart lock designed to replace your existing deadbolt. It features advanced encrypted access technology, ultra-fast fingerprint unlocking, a backlit keypad with anti-peep technology, and a stylish matte black finish. Its keyless design, hardware encryption, and weatherproof build make it a secure and convenient choice for modern homes.
How does the Wyze Lock Bolt provide secure access?Wyze Lock Bolt uses hardware encryption to protect your fingerprint and passcode data. It does not require a cloud connection for unlocking, ensuring your access information remains private. Additionally, two-factor authentication within the Wyze app adds an extra layer of security, allowing only authorized users to control the lock.
What access methods are available with the Wyze Lock Bolt?The Wyze Lock Bolt offers multiple access methods: ultra-fast fingerprint recognition, a backlit keypad with anti-peep technology for code entry, and app control via Bluetooth. You can store up to 50 fingerprints and create up to 20 unique access codes for family and guests.
Is the Wyze Lock Bolt weatherproof and suitable for outdoor use?Yes, the Wyze Lock Bolt is built with IPX5 weather resistance, making it suitable for outdoor installation. Its solid metal construction and keyless design also make it pick-proof and durable against the elements.
How long does the Wyze Lock Bolt battery last and what happens if it runs out?The Wyze Lock Bolt is powered by 4 AA batteries, providing up to 12 months of battery life. Low battery alerts notify you in advance, and if the batteries die, you can use the USB-C port for a quick emergency charge to regain entry.
How easy is it to install the Wyze Lock Bolt?Installation is simple and takes about 20 minutes. The Wyze Lock Bolt is designed to fit most exterior doors and comes with all necessary hardware for a hassle-free setup, making it easy to replace your existing deadbolt.
Can I control the Wyze Lock Bolt remotely?You can control the Wyze Lock Bolt remotely when within Bluetooth range using the Wyze app. The lock does not rely on cloud services, ensuring faster and more secure operation. You can also view access history and manage access codes and fingerprints through the app.
Does the Wyze Lock Bolt have an auto-lock feature?Yes, the Wyze Lock Bolt features a configurable auto-lock function. You can set a delay in the Wyze app, so the lock automatically secures your door after a specified period, providing peace of mind.
What is the price of the Wyze Lock Bolt?The Wyze Lock Bolt is priced at $79.98, offering premium smart lock features such as fingerprint access, hardware encryption, and weather resistance at an affordable cost.
Are replacement parts available for the Wyze Lock Bolt?Yes, replacement parts for the Wyze Lock Bolt are available, including screws ($2.99), the interior assembly metal plate ($4.99), and the interior assembly battery cover ($9.99). These parts help keep your smart lock reliable and functional over time.
How does the Wyze Lock Bolt compare to the Wyze Lock?The Wyze Lock Bolt is ideal for those seeking a matte black smart lock with encrypted local access and fingerprint unlocking. The Wyze Lock (not available in matte black) offers remote access and smart home integrations like Alexa and Google Assistant but does not have fingerprint unlocking and attaches to your existing deadbolt rather than replacing it.
What are the installation requirements for the Wyze Lock Bolt?Can the Wyze Lock Bolt be controlled remotely through an app?Are there any ongoing promotions or discounts for the Wyze Lock Bolt?
