Home Smart Lock with Built-In Alarm for Open Door Alerts
Home Smart Lock with Built-in Alarm for Open Door Alerts
Upgrade your home security with advanced smart locks that not only provide keyless convenience but also alert you instantly if your door is left open or tampered with. Discover the Wyze Lock Bolt, a cutting-edge connected home device designed to enhance your safety and peace of mind with built-in alarms and seamless app integration.
Wyze Lock Bolt: The Ultimate Smart Lock with Alarm Features
Keyless Convenience and Ultra-Fast Access
Say goodbye to fumbling for keys. The Wyze Lock Bolt replaces your traditional deadbolt with a sleek, Bluetooth-enabled smart lock featuring an ultra-fast fingerprint sensor and a backlit keypad with anti-peep technology. Unlock your door in less than a second using your fingerprint or a tap on the Wyze app.
Built-in Alarm for Enhanced Security
The Wyze Lock Bolt comes equipped with a built-in alarm that detects jam attempts and alerts you immediately. This feature ensures you are notified if someone tries to force the lock or if the door is left open, providing an extra layer of security for your home.
Smart Auto-Lock and Remote Monitoring
Never worry about forgetting to lock your door again. The auto-lock function secures your door automatically after a set time. Plus, with the Wyze app, you can view lock and unlock history, receive open door alerts, and control your lock remotely from anywhere.
Durable and Weather-Resistant Design
Available in Matte Black and Satin Nickel, the Wyze Lock Bolt is designed to fit standard door thicknesses and backsets. It is rated IPX5 for weather resistance, making it suitable for various climates. The lock operates efficiently in temperatures ranging from -13°F to 122°F.
Technical Specifications
  • Power Source: 4x AA Batteries (included) with 10-12 months battery life
  • Communication: Bluetooth 5.0 with a 16 ft range
  • Door Compatibility: Fits doors 1-3/8" to 1-3/4" thick
  • Features: Fingerprint sensor, backlit keypad, auto-lock, built-in alarm, emergency one-time codes
Wyze Lock Bolt Lifestyle Experience seamless home security with Wyze Lock Bolt on your front door.
Enhance Your Home Security with The Front Porch Security Bundle
Comprehensive Smart Home Protection
For those seeking an all-in-one security solution, the Front Porch Security Bundle combines the Wyze Lock Bolt with Wyze Video Doorbell and Chime. This bundle allows you to monitor your front porch in 1080p HD, communicate with visitors via two-way audio, and control your door lock remotely—all from the Wyze app.
Features of the Security Bundle
  • 1080p HD video with night vision and motion detection
  • Two-way audio to greet visitors or deter intruders
  • Remote lock/unlock and lock history tracking
  • Compatibility with Alexa and Google Assistant for voice control
  • Weather-resistant components designed for outdoor use
Technical Highlights
  • Wyze Lock Bolt: Bluetooth and Zigbee communication, 5-6 months battery life
  • Video Doorbell: IP65 weather resistance, 120° vertical x 88° horizontal field of view
  • Chime: Multiple sound options including intruder alarm
Wyze Lock Bolt with Video Doorbell Secure your home’s entryway with the Wyze Lock Bolt and Video Doorbell combo.
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning flawlessly, Wyze offers a range of replacement parts:
  • Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly securely to your door.
  • Wyze Lock Bolt Screws: Replacement screw sets compatible with the Wyze Lock Bolt.
  • Wyze Lock Bolt Interior Assembly Battery Cover: Replacement cover to protect the battery compartment.
  • Wyze Lock Replacement Part Kit: Includes essential components for maintenance and repair.
These parts ensure your smart lock remains reliable and easy to maintain over time.
Protect your home effortlessly with a smart lock that alerts you instantly to open doors or tampering attempts. The Wyze Lock Bolt and Front Porch Security Bundle offer a perfect blend of convenience, security, and smart home integration.
Summary of Products Mentioned
FeatureWyze Lock BoltThe Front Porch Security Bundle
Product TypeBluetooth Smart LockSecurity Bundle (Lock + Video Doorbell + Chime + Optional Cam)
Price$79.98$123.99 - $173.97 (varies by variant)
Lock TypeDeadbolt replacementIncludes Wyze Lock or Wyze Lock Bolt
Fingerprint SensorYes, ultra-fast fingerprint readerIncluded if Wyze Lock Bolt variant chosen
KeypadBacklit keypad with anti-peep technologyIncluded if Wyze Lock Bolt variant chosen
Auto-lock FeatureYesYes (via Wyze Lock or Lock Bolt)
App ControlYes, via Wyze app (Bluetooth connection)Yes, remote lock/unlock and lock history via Wyze app
Video Doorbell IncludedNoYes, Wyze Video Doorbell or Video Doorbell Pro included
Video Resolution (Doorbell)N/A1080p HD (Wyze Video Doorbell) or higher with Video Doorbell Pro
Two-way Audio (Doorbell)N/AYes
Additional Cameras IncludedNoOptional Wyze Cam V3 included in some variants
Installation Time~20 minutesVaries by components, Lock Bolt installs in ~20 minutes
Weather ResistanceIPX5Lock Bolt: IPX5; Doorbell: IP65
Battery Life (Lock)Up to 12 months (4 AA batteries)Same for Lock Bolt
Emergency One-Time CodesYesYes (via Wyze Lock Bolt)
Maximum Fingerprints Stored50Same for Lock Bolt
Maximum Access Codes20Same for Lock Bolt
Lock History & NotificationsYes, via Wyze appYes, via Wyze app
Auto-expiring CodesYesYes
Hardware EncryptionYesYes
Two-Factor AuthenticationYes (in app)Yes
Keyless EntryYesYes
Compatible Door TypesMost exterior doorsSame as Wyze Lock Bolt
Included AccessoriesLock Bolt unit, batteriesLock Bolt or Lock, Video Doorbell, Chime, optional Cam V3
What is the Wyze Lock Bolt and how does it enhance home security?The Wyze Lock Bolt is a Bluetooth-enabled smart lock that replaces your traditional deadbolt, offering keyless convenience and advanced security features. It includes a built-in alarm that alerts you instantly if your door is left open or tampered with, ensuring enhanced safety and peace of mind.
How does the built-in alarm on the Wyze Lock Bolt work?The Wyze Lock Bolt's built-in alarm detects jam attempts and notifies you immediately if someone tries to force the lock or if the door is left open. This feature provides an extra layer of security by keeping you informed of any unusual activity at your door.
What keyless entry options does the Wyze Lock Bolt offer?The Wyze Lock Bolt offers ultra-fast access with a fingerprint sensor and a backlit keypad featuring anti-peep technology. You can unlock your door in less than a second using your fingerprint or by tapping on the Wyze app.
Can I control the Wyze Lock Bolt remotely?Yes, you can control the Wyze Lock Bolt remotely using the Wyze app. The app allows you to view lock and unlock history, receive open door alerts, and manage your lock from anywhere.
Does the Wyze Lock Bolt have an auto-lock feature?Yes, the Wyze Lock Bolt includes a smart auto-lock function that automatically secures your door after a set period, so you never have to worry about forgetting to lock your door.
Is the Wyze Lock Bolt weather-resistant?The Wyze Lock Bolt is rated IPX5 for weather resistance and operates efficiently in temperatures ranging from -13°F to 122°F, making it suitable for various climates.
What are the technical specifications of the Wyze Lock Bolt?The Wyze Lock Bolt is powered by 4 AA batteries (included) with a battery life of 10-12 months. It uses Bluetooth 5.0 with a 16 ft range and fits doors 1-3/8" to 1-3/4" thick. Key features include a fingerprint sensor, backlit keypad, auto-lock, built-in alarm, and emergency one-time codes.
What is included in the Front Porch Security Bundle?The Front Porch Security Bundle includes the Wyze Lock Bolt, Wyze Video Doorbell, and Chime. This bundle provides comprehensive home protection with 1080p HD video, night vision, motion detection, two-way audio, remote lock/unlock, and compatibility with Alexa and Google Assistant.
Is the Wyze Lock Bolt compatible with smart home assistants?Yes, the Wyze Lock Bolt, when used as part of the Front Porch Security Bundle, is compatible with Alexa and Google Assistant for convenient voice control.
Are replacement parts available for the Wyze Lock Bolt?Yes, Wyze offers a range of replacement parts for the Wyze Lock Bolt, including the interior assembly metal plate, screw sets, battery cover, and a replacement part kit to ensure your smart lock remains reliable and easy to maintain.
How long does the battery last on the Wyze Lock Bolt?The Wyze Lock Bolt operates on 4 AA batteries, providing a battery life of 10-12 months under normal usage.
What door sizes are compatible with the Wyze Lock Bolt?The Wyze Lock Bolt is designed to fit standard doors with thicknesses ranging from 1-3/8 inches to 1-3/4 inches.
What features does the Wyze Lock Bolt offer for home security?Can you tell me more about the auto-lock function of the Wyze Lock Bolt?Do you have any ongoing sales or discounts for the Wyze Lock Bolt?
