Remote Smart Lock with Temporary Key Sharing – Wyze Lock Bolt
Remote Door Access Smart Lock with Temporary Key Sharing
Upgrade your home security and convenience with the latest in smart lock technology. If you're searching for a remote door access smart lock with temporary key sharing feature, the Wyze Lock Bolt stands out as a top choice. Designed to replace your existing deadbolt, this smart lock offers seamless keyless entry, ultra-fast fingerprint recognition, and the ability to share temporary access codes remotely — perfect for guests, service providers, or short-term visitors.
Wyze Lock Bolt: Key Features & Benefits
Ultra-Fast Fingerprint & Keypad Access
Forget fumbling for keys. The Wyze Lock Bolt features an ultra-fast fingerprint reader that unlocks your door in less than a second. For added convenience, it also includes a luxurious backlit keypad with anti-peep technology, allowing you to enter your code securely even if someone is watching. You can add extra digits before or after your code, and the lock will still open, protecting your access code privacy.
Remote Access & Temporary Key Sharing
Using the Wyze app, you can remotely generate emergency one-time access codes for guests or service personnel. These codes are single-use and expire within 4 hours, ensuring secure, temporary access without handing over physical keys. You can create up to 16 such codes every 4 hours, and also set auto-expiring codes with specific schedules, so you never have to worry about unauthorized entry.
Auto-Lock & Security Features
Never worry about leaving your door unlocked again. The Wyze Lock Bolt includes an auto-lock timer that you can customize via the app. After your set delay, the lock automatically secures your door. The lock is fully pick-proof, weatherproof (IPX5 rating), and built from solid metal for maximum durability and security.
Long Battery Life & Emergency Power
Powered by 4 AA batteries, the Wyze Lock Bolt lasts up to 12 months on a single set. If the batteries run low or die while you're away, a USB-C port allows for a quick emergency charge so you can still enter your access code and get inside.
Easy Installation & Design
The Wyze Lock Bolt replaces your existing deadbolt in about 20 minutes and fits almost all exterior doors. Its sleek, solid metal design with a backlit keypad complements any home exterior, blending security with style.
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Wyze Lock Bolt lifestyle front door Secure your home with Wyze Lock Bolt’s smart fingerprint access.
Comprehensive Home Security with the Essential Security Bundle
For those looking to enhance their home security ecosystem, the Essential Security Bundle offers a complete solution. This bundle includes the Wyze Lock Bolt along with other advanced security devices:
  • Wyze Video Doorbell v2: Monitor your front door with crisp 1080p HD video and two-way audio, so you can see and speak to visitors from anywhere.
  • Wyze Cam Pan v3: Covers large areas with 360° horizontal and 180° vertical motion tracking, color night vision, and two-way audio.
  • Two Wyze Cam OGs: Versatile plug-in cameras with motion-activated spotlights and color night vision for indoor or outdoor use.
This bundle ensures your home is protected from every angle, with smart devices that integrate seamlessly for remote monitoring and control. Wyze Plug-in Cam outdoor security Complete your home security with Wyze smart cameras and locks.
Why Choose Wyze Lock Bolt for Remote Access & Temporary Sharing?
  • Bluetooth Smart Lock: Local Bluetooth connection ensures your data stays private without relying on cloud services.
  • Encrypted Security: Hardware encryption protects your fingerprint and access code data.
  • Two-Factor Authentication: Only authorized users can control the lock via the Wyze app.
  • Multiple User Support: Store up to 20 access codes and 50 fingerprints for family, friends, and frequent visitors.
  • Emergency Access Codes: Generate temporary, one-time codes remotely for trusted guests.
  • Auto-Expiring Codes: Set schedules for access codes to automatically expire, perfect for short-term visitors.
Wyze Lock Bolt app control lifestyle Control your Wyze Lock Bolt remotely with the Wyze app.
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning perfectly, Wyze offers essential replacement parts:
  • Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly securely to your door.
  • Wyze Lock Bolt Screws: Replacement screw set compatible with the lock.
  • Wyze Lock Bolt Interior Assembly Battery Cover: Replacement cover for the battery compartment.
These parts ensure your smart lock remains durable and reliable over time.
Conclusion
The Wyze Lock Bolt is an excellent choice for anyone seeking a remote door access smart lock with temporary key sharing. Its combination of fingerprint unlocking, backlit keypad, remote app control, and temporary access codes makes it a versatile and secure solution for modern homes. Paired with the Essential Security Bundle, it offers comprehensive protection and peace of mind. Upgrade your home security today with Wyze Lock Bolt — smart, secure, and designed for your convenience.
Product NameTypePrice (USD)DescriptionKey FeaturesCompatibilityReturn Policy
Wyze Lock BoltConnected Home79.98Bluetooth smart lock replacing deadbolt with fingerprint sensor and backlit keypad.Fingerprint unlock, backlit keypad, auto-lock, pick-proof, weatherproof, up to 12 months battery lifeReplaces existing deadbolt30-day hassle-free returns
Essential Security BundleBundle199.99Security bundle including Wyze Lock Bolt, Video Doorbell v2, Cam Pan v3, and 2× Wyze Cam OG.Comprehensive home protection, multiple cameras, smart lock with fingerprint sensorIncludes Wyze Lock Bolt30-day hassle-free returns
Wyze Lock Bolt Interior Assembly Metal PlateReplacement Parts4.99Metal plate to anchor the interior assembly to the door.Replacement part for interior assembly anchoringWyze Lock Bolt30-day hassle-free returns
Wyze Lock Bolt ScrewsReplacement Parts2.99Set of screws for Wyze Lock Bolt.Replacement screwsWyze Lock Bolt30-day hassle-free returns
Wyze Lock Bolt Interior Assembly Battery CoverReplacement Parts9.99Replacement interior battery cover for Wyze Lock Bolt.Battery cover replacementWyze Lock Bolt30-day hassle-free returns
Wyze Lock Replacement Part KitReplacement Parts4.99 - 19.99Replacement part kit compatible only with Wyze Lock (not Lock Bolt).Replacement parts kit (two styles: Replacement Part Kit and Adapter Replacement Kit)Wyze Lock (not Lock Bolt)30-day hassle-free returns
What is the Wyze Lock Bolt and how does it enhance home security?The Wyze Lock Bolt is a smart lock designed to replace your existing deadbolt, offering advanced security features such as ultra-fast fingerprint recognition, a backlit keypad with anti-peep technology, and remote temporary key sharing. It enhances home security by providing keyless entry, customizable auto-lock, and encrypted access control, making it a convenient and secure solution for modern homes.
How does the temporary key sharing feature work on the Wyze Lock Bolt?With the Wyze Lock Bolt, you can use the Wyze app to remotely generate emergency one-time access codes for guests, service providers, or short-term visitors. These codes are single-use, expire within 4 hours, and you can create up to 16 codes every 4 hours. You can also set auto-expiring codes with specific schedules, ensuring secure and temporary access without handing over physical keys.
Can I unlock my door with my fingerprint using the Wyze Lock Bolt?Yes, the Wyze Lock Bolt features an ultra-fast fingerprint reader that unlocks your door in less than a second. It can store up to 50 fingerprints, allowing multiple users to enjoy quick and secure access.
What is anti-peep technology on the Wyze Lock Bolt keypad?Anti-peep technology allows you to enter extra digits before or after your actual access code on the backlit keypad. The lock will still recognize your code and unlock the door, protecting your access code privacy even if someone is watching.
Does the Wyze Lock Bolt support remote access and control?Yes, you can control the Wyze Lock Bolt remotely via the Wyze app. This includes generating temporary access codes, setting auto-lock timers, and managing user access, all from your smartphone.
How secure is the Wyze Lock Bolt?The Wyze Lock Bolt is highly secure, featuring hardware encryption for fingerprint and access code data, two-factor authentication for app control, and a pick-proof, weatherproof (IPX5 rated) solid metal construction. It also uses a local Bluetooth connection to keep your data private.
What is the battery life of the Wyze Lock Bolt and what happens if the battery dies?The Wyze Lock Bolt is powered by 4 AA batteries and lasts up to 12 months on a single set. If the batteries run low or die, you can use the built-in USB-C port for a quick emergency charge, allowing you to enter your access code and unlock the door.
Is the Wyze Lock Bolt easy to install?Yes, the Wyze Lock Bolt is designed for easy installation, replacing your existing deadbolt in about 20 minutes. It fits most exterior doors and comes with a sleek, solid metal design that complements any home.
What is included in the Essential Security Bundle with the Wyze Lock Bolt?The Essential Security Bundle includes the Wyze Lock Bolt, Wyze Video Doorbell v2 (with 1080p HD video and two-way audio), Wyze Cam Pan v3 (with 360° motion tracking and color night vision), and two Wyze Cam OGs (versatile plug-in cameras with spotlights and night vision). This bundle provides comprehensive home security with seamless device integration.
Are replacement parts available for the Wyze Lock Bolt?Yes, Wyze offers essential replacement parts for the Lock Bolt, including the interior assembly metal plate, replacement screw set, and interior assembly battery cover. These parts help maintain the durability and reliability of your smart lock.
How many users can access the Wyze Lock Bolt?The Wyze Lock Bolt supports up to 20 access codes and 50 fingerprints, making it ideal for families, friends, and frequent visitors who need secure and convenient access.
Does the Wyze Lock Bolt require Wi-Fi to operate?No, the Wyze Lock Bolt uses a local Bluetooth connection for operation, ensuring your data remains private and does not rely on cloud services for basic functionality.
What are the installation requirements for the Wyze Lock Bolt?How does the auto-lock feature work on the Wyze Lock Bolt?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Lock Bolt?
