Where to Find Wyze Outdoor Cam Repair Kit with Replacement Parts for All Models
If you own a Wyze outdoor camera and are looking for a reliable repair kit or replacement parts compatible with all Wyze Cam models, this guide will help you find the best options available. Wyze offers versatile bundles and accessories designed to keep your outdoor security system running smoothly, no matter which model you have.
Wyze Outdoor Cam Repair and Replacement Solutions
Wyze does not offer a single universal "repair kit" for all outdoor cameras, but their product bundles and replacement parts cover a wide range of models, including the popular Wyze Cam Pan v3, Wyze Cam v4, and Wyze Cam OG. These kits and parts are designed to enhance functionality, replace worn components, and extend the life of your outdoor camera system.
Pan v3 + Lamp Socket v2 Bundle: Power and Convenience for Wyze Cam Pan v3
Key Features:
- Compatibility: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models.
- Power Source: The lamp socket allows you to power your Pan v3 camera without needing a traditional outlet.
- Materials & Build: Made from durable polycarbonate and plastic, designed for damp locations (not fully waterproof).
- Dimensions & Weight: Compact size (56.5mm x 56.5mm x 65mm) and lightweight (80g).
- Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth for seamless integration.
- Operating Temperature: Functions reliably between -4°F and 120°F (-20°C to 50°C).
- Certifications: FCC, IC, UL496, CA65, TSCA, RoHS certified.
- Warranty: 1-year warranty included.
- Important Note: Use CFL or LED bulbs under 20W; incandescent bulbs are not recommended due to thermal limitations.
This bundle is perfect for users who want to upgrade their outdoor lighting while powering their Wyze Cam Pan v3 efficiently.
Cam v4 + Lamp Socket v2 Bundle: Smart Lighting for Wyze Cam v4
Highlights:
- Device Compatibility: Supports Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
- Smart Features: Includes motion-activated lights, dusk-to-dawn scheduling, and unlimited linkability with other devices.
- Power Input: 120V~, 60Hz with a max lamp power of 20W.
- Materials & Dimensions: Polycarbonate and plastic construction, 56.5mm x 56.5mm x 65mm, weighing 80g.
- Connectivity: 802.11 b/g/n Wi-Fi (2.4GHz) and Bluetooth.
- Operating Conditions: Suitable for damp locations, operating between -4°F and 120°F (-20°C to 50°C).
- Certifications & Warranty: Same certifications as the Pan v3 bundle and a 1-year warranty.
- Usage Note: Recommended to use CFL or LED bulbs under 20W to avoid overheating.
This bundle is ideal for those with Wyze Cam v4 looking to integrate smart lighting and power solutions without the hassle of additional outlets.
Wyze Cam OG Telephoto: Enhanced Outdoor Surveillance
Product Overview:
- Camera Type: Wired outdoor camera with telephoto lens.
- Video Quality: 1080p HD resolution with 3x telephoto zoom and 8x digital zoom.
- Night Vision: Equipped with 4 IR LEDs for clear night-time footage.
- Connectivity: 2.4 GHz Wi-Fi (802.11 b/g/n).
- Compatibility: Works with Android 9.0+ and iOS 15.0+ devices.
- Weather Resistance: Rated IP65 for outdoor durability.
- Operating Temperature: -4°F to 131°F (-20°C to 55°C).
- Audio: Built-in speaker and microphone with noise and echo cancellation.
- Storage: Supports up to 256GB microSD card for local storage.
- Mounting Options: Stand, wall mount, or ceiling mount.
- Warranty: 1-year warranty.
The Wyze Cam OG Telephoto is a robust choice for outdoor security, offering enhanced zoom capabilities and weather resistance for reliable performance.
Summary: Finding the Right Replacement Parts and Repair Kits
While Wyze does not provide a dedicated "repair kit" for all outdoor camera models, the
Pan v3 + Lamp Socket v2 Bundle and
Cam v4 + Lamp Socket v2 Bundle serve as excellent replacement and upgrade options for powering and maintaining your cameras. For enhanced outdoor surveillance, the
Wyze Cam OG Telephoto offers advanced features and durability.
If you need specific replacement parts, such as filters or mic covers, those are generally available for other Wyze products like vacuums and headsets but not directly for outdoor cameras. For outdoor camera maintenance, these bundles and accessories are your best bet to keep your system running efficiently.
Keep your Wyze outdoor cameras powered and protected with these smart bundles designed for all major Wyze models.
Product Highlights
- Pan v3 + Lamp Socket v2 Bundle: Power your Pan v3 camera without an outlet.
- Cam v4 + Lamp Socket v2 Bundle: Smart lighting with motion activation for Cam v4.
- Wyze Cam OG Telephoto: Outdoor camera with 3x telephoto zoom and IP65 rating.
By choosing these Wyze bundles and accessories, you ensure your outdoor security cameras stay functional, smart, and ready to protect your home.
Where can I find Wyze outdoor cam repair kits and replacement parts for all models?
Wyze does not offer a single universal repair kit for all outdoor camera models. However, they provide versatile bundles and replacement parts compatible with popular models like Wyze Cam Pan v3, Wyze Cam v4, and Wyze Cam OG. These bundles, such as the Pan v3 + Lamp Socket v2 Bundle and Cam v4 + Lamp Socket v2 Bundle, are designed to power, upgrade, and maintain your Wyze outdoor cameras efficiently.Are there universal repair kits available for Wyze outdoor cameras?
No, Wyze does not offer a universal repair kit for all outdoor camera models. Instead, they provide specific bundles and replacement parts that cover a wide range of models, including the Wyze Cam Pan v3, Cam v4, and Cam OG. These solutions help replace worn components and extend the life of your outdoor camera system.What is included in the Pan v3 + Lamp Socket v2 Bundle for Wyze outdoor cameras?
The Pan v3 + Lamp Socket v2 Bundle includes a lamp socket that powers your Wyze Cam Pan v3 without the need for a traditional outlet. It is compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models. The bundle features durable materials, supports 2.4GHz Wi-Fi and Bluetooth, and is designed for damp locations. It comes with a 1-year warranty and is certified for safety and quality.Is the Cam v4 + Lamp Socket v2 Bundle compatible with other Wyze camera models?
Yes, the Cam v4 + Lamp Socket v2 Bundle is compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models. It offers smart lighting features such as motion-activated lights, dusk-to-dawn scheduling, and unlimited linkability with other devices, making it a versatile upgrade for your Wyze outdoor camera system.What are the key features of the Wyze Cam OG Telephoto for outdoor surveillance?
The Wyze Cam OG Telephoto is a wired outdoor camera featuring 1080p HD resolution, 3x telephoto zoom, 8x digital zoom, and 4 IR LEDs for night vision. It is IP65 rated for weather resistance, supports up to 256GB microSD card for local storage, and includes a built-in speaker and microphone with noise and echo cancellation. The camera is compatible with Android 9.0+ and iOS 15.0+ devices and comes with a 1-year warranty.Can I get specific replacement parts like filters or mic covers for Wyze outdoor cameras?
Specific replacement parts such as filters or mic covers are generally available for other Wyze products like vacuums and headsets, but not directly for outdoor cameras. For outdoor camera maintenance, the best options are the available bundles and accessories designed to power and protect your Wyze cameras.What is the recommended power source for Wyze outdoor cameras using the lamp socket bundles?
The lamp socket bundles for Wyze outdoor cameras are designed to be powered via a standard lamp socket, eliminating the need for a traditional outlet. It is recommended to use CFL or LED bulbs under 20W, as incandescent bulbs are not advised due to thermal limitations.Are Wyze outdoor camera accessories weatherproof?
Wyze outdoor camera accessories like the lamp socket bundles are made from durable polycarbonate and plastic and are designed for damp locations. However, they are not fully waterproof. The Wyze Cam OG Telephoto camera itself is IP65 rated for outdoor durability and weather resistance.What warranty is provided with Wyze outdoor camera bundles and accessories?
All major Wyze outdoor camera bundles and accessories, including the Pan v3 + Lamp Socket v2 Bundle, Cam v4 + Lamp Socket v2 Bundle, and Wyze Cam OG Telephoto, come with a 1-year warranty for added peace of mind.
