Buy Affordable Wyze Indoor & Outdoor Camera Replacement Kits
Affordable Replacement Kits for Wyze Indoor and Outdoor Cams
If you're searching for affordable replacement kits for your Wyze indoor and outdoor cameras, you're in the right place. Wyze offers a variety of cost-effective camera options and bundles designed to keep your home secure without breaking the bank. Whether you need a single camera replacement or a comprehensive security kit, Wyze has you covered with high-quality, feature-rich products at wallet-friendly prices.
Wyze Cam OG Telephoto: Affordable Indoor/Outdoor Security with Zoom
The Wyze Cam OG Telephoto is a budget-friendly option perfect for both indoor and outdoor use. Priced at just $25.98 for a single pack and $58.98 for a 2-pack, it offers excellent value for those looking to replace or upgrade their existing Wyze cameras.
Key Features:
  • 3x Telephoto Lens: Zoom in on distant subjects without losing image quality, ideal for detailed monitoring.
  • IP65 Weather Resistance: Durable enough to withstand harsh weather conditions, making it suitable for outdoor use.
  • Color Night Vision: See clear, colorful footage even in low-light environments.
  • 3x Faster Notifications: Stay informed instantly with rapid motion alerts.
  • Improved Two-Way Audio: Enhanced microphone and speaker for clear communication.
  • Local Storage Support: Compatible with Wyze microSD cards up to 256GB for continuous recording.
This camera is a great replacement choice if you want a reliable, affordable solution that works seamlessly indoors or outdoors.
Wyze Cam v4: The Best Value for Indoor and Outdoor Security
For those seeking a versatile and affordable replacement camera, the Wyze Cam v4 stands out as a top pick. Available for just $35.98 per single unit and discounted further in multi-packs, this camera offers advanced features typically found in higher-priced models.
Why Choose Wyze Cam v4?
  • 2.5K Quad HD Resolution: Crystal-clear video quality for detailed monitoring.
  • Enhanced Color Night Vision: Superior low-light performance reveals vibrant colors at night.
  • IP65 Weatherproof Rating: Perfect for outdoor installation without worry.
  • Motion-Activated Spotlight & 99 dB Siren: Deter intruders with bright light and loud alarms.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection.
  • Easy Setup: Bluetooth-enabled for hassle-free installation without QR codes.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
  • Local 24/7 Recording: Supports microSD cards up to 512GB with no subscription required.
This camera is ideal for anyone wanting a feature-rich, affordable replacement that works indoors or outdoors with smart home compatibility.
Whole Home Security Enhanced Kit: Comprehensive and Cost-Effective
If you're looking for a complete replacement solution, the Whole Home Security Enhanced Kit bundles the Wyze Cam v4 with the Wyze Cam Floodlight v2. Priced at $256.91, this kit offers a powerful combination of cameras and lighting to secure your entire property.
Kit Highlights:
  • Includes Wyze Cam v4 and Floodlight v2: Covers both video surveillance and powerful outdoor lighting.
  • Multiple Color Options: Choose from White, Grey, or Black to match your home’s aesthetic.
  • Weather-Resistant and Durable: Designed for all-season outdoor use.
  • Easy Installation: Comes with mounting options for flexible placement.
This kit is perfect for those who want to replace multiple cameras and upgrade their home security system affordably.
Wyze Bulb Cam: Dual-Purpose Outdoor Security and Lighting
For a unique replacement option, the Wyze Bulb Cam combines a smart LED light bulb with a 2K HD security camera. Priced at $49.98, it’s an affordable way to add security and lighting to your outdoor spaces. Wyze Bulb Cam Installed Outdoor Wyze Bulb Cam installed in an outdoor light fixture, providing security and illumination.
Features:
  • 2K HD Video with Color Night Vision: Clear footage day and night.
  • Instant Motion Alerts: Stay informed of any activity around your home.
  • Easy Installation: Fits most standard light fixtures.
  • Local Video Storage: No subscription needed for storing footage.
  • IP65 Weatherproof: Built to withstand outdoor conditions.
This camera is perfect for replacing outdoor lighting fixtures with a smart security upgrade. Wyze Bulb Cam Motion Detection Motion detection in action with Wyze Bulb Cam, ideal for garages and outdoor areas.
Where to Buy Affordable Wyze Replacement Kits
Wyze replacement kits and cameras are widely available at competitive prices. The products listed here offer some of the most affordable options for indoor and outdoor security cameras with advanced features. Whether you want a single camera replacement or a full home security bundle, Wyze provides reliable, budget-friendly solutions.
Pro Tip: When choosing your replacement kit, consider the environment where the camera will be installed. For outdoor use, ensure the camera has an IP65 weatherproof rating like the Wyze Cam OG Telephoto or Wyze Cam v4. For indoor use, any Wyze Cam model will provide excellent coverage and features.
Summary of Affordable Wyze Replacement Kits
Product NamePrice RangeKey FeaturesIndoor/Outdoor Use
Wyze Cam OG Telephoto$25.98 - $58.983x Telephoto, Color Night VisionIndoor & Outdoor
Wyze Cam v4$35.98 - $107.942.5K QHD, Spotlight, Siren, Wi-Fi 6Indoor & Outdoor
Whole Home Security Kit$256.91Cam v4 + Floodlight v2 BundleOutdoor
Wyze Bulb Cam$49.982K HD Video, Light Bulb, Motion AlertsOutdoor
By choosing any of these affordable Wyze replacement kits, you can maintain or upgrade your home security system with ease and confidence.
FeatureWyze Cam OG TelephotoWyze Cam v4Whole Home Security Enhanced KitWyze Bulb Cam
TypeWired Security CameraWired Security CameraBundle: Wyze Cam v4 + Wyze Cam Floodlight v2Outdoor Security Camera + Smart LED Bulb
Video ResolutionNot specified (improved live HD)2.5K QHD (2560x1440)2.5K QHD (Wyze Cam v4)2K HD (2304 x 1296)
Field of View27° (3x Telephoto lens)115.8° (DFOV), 98.5° (HFOV), 53.1° (VFOV)Same as Wyze Cam v4160° (diagonal 166°)
Zoom3x Telephoto zoom8x Digital Zoom8x Digital Zoom (Wyze Cam v4)Digital Zoom
Night VisionColor Night VisionEnhanced Color Night VisionEnhanced Color Night Vision (Wyze Cam v4)Color Night Vision + IR Night Vision
AudioImproved 2-way audioEnhanced Two-Way TalkImproved 2-way audio (Wyze Cam v4)Two-Way Audio
Siren Volume90 dB user-activated siren99 dB built-in siren99 dB built-in siren (Wyze Cam v4)95 dB siren at 4 in
Weather ResistanceIP65IP65IP65 (Wyze Cam v4)IP65
Indoor/Outdoor UseIndoor/OutdoorIndoor/OutdoorIndoor/Outdoor (Wyze Cam v4)Outdoor
ConnectivityWiredWired, Wi-Fi 6 supportWired, Wi-Fi 6 (Wyze Cam v4)Wi-Fi 2.4 GHz
Smart Features3x faster notifications, Custom Detection Zones, Smoke & CO AlertsMotion & Sound Detection, Motion Detection Zones, Smoke & CO Alerts, Alexa/Google Assistant, IFTTTSame as Wyze Cam v4Motion Alerts, Wyze Automations
Local Storage SupportmicroSD up to 256GBmicroSD up to 512GBmicroSD 128GB included (Wyze Cam v4)microSD up to 256GB (exFAT format)
Cloud StorageCam Plus subscription availableCam Plus subscription availableCam Plus subscription availableCloud storage via AWS
Power SourceWiredWiredWired (Wyze Cam v4)120V AC (standard bulb socket)
Included in BoxCamera(s) (1 or 2 pack), cables, mountsCamera, power adapter, mounts, cablesWyze Cam v4 + Wyze Cam Floodlight v2Bulb Cam (smart bulb + camera)
Price (Single Unit)$25.98$35.98$256.91 (bundle)$49.98
Additional Features3x Telephoto lens, 3x faster notifications, 50% faster live streamingMotion-activated spotlight, Wi-Fi 6, AI Auto-Zoom, Wide Dynamic Range (WDR)Floodlight included, enhanced bundle features2-in-1 camera and smart LED light bulb, 800 lumens brightness, motion-activated light
Mounting OptionsStand, wall, ceiling, magnetic mountStand, wall, ceiling, magnetic mountSame as Wyze Cam v4Fits standard E26 socket
What are the most affordable Wyze replacement kits for indoor and outdoor cameras?Wyze offers several affordable replacement kits for both indoor and outdoor cameras, including the Wyze Cam OG Telephoto, Wyze Cam v4, Whole Home Security Enhanced Kit, and Wyze Bulb Cam. These options provide high-quality security features at budget-friendly prices.
What features does the Wyze Cam OG Telephoto offer for indoor and outdoor security?The Wyze Cam OG Telephoto features a 3x telephoto lens for detailed monitoring, IP65 weather resistance for outdoor durability, color night vision, 3x faster notifications, improved two-way audio, and local storage support for microSD cards up to 256GB.
Is the Wyze Cam v4 suitable for both indoor and outdoor use?Yes, the Wyze Cam v4 is designed for both indoor and outdoor use. It features 2.5K Quad HD resolution, enhanced color night vision, IP65 weatherproof rating, motion-activated spotlight, 99 dB siren, Wi-Fi 6 support, easy Bluetooth setup, smart home integration, and local 24/7 recording.
What is included in the Whole Home Security Enhanced Kit from Wyze?The Whole Home Security Enhanced Kit includes the Wyze Cam v4 and the Wyze Cam Floodlight v2. This bundle provides comprehensive video surveillance and powerful outdoor lighting, with multiple color options and weather-resistant design for all-season use.
How does the Wyze Bulb Cam combine security and lighting for outdoor areas?The Wyze Bulb Cam is a dual-purpose device that combines a smart LED light bulb with a 2K HD security camera. It offers color night vision, instant motion alerts, easy installation in standard light fixtures, local video storage without a subscription, and IP65 weatherproofing for outdoor use.
Do Wyze replacement cameras require a subscription for video storage?No, Wyze replacement cameras such as the Wyze Cam OG Telephoto, Wyze Cam v4, and Wyze Bulb Cam support local video storage via microSD cards, so you can record and store footage without a subscription.
Where can I buy affordable Wyze replacement kits and cameras?Affordable Wyze replacement kits and cameras are available directly from the Wyze website and other major retailers. These products offer competitive pricing for both single camera replacements and comprehensive security bundles.
What should I consider when choosing a Wyze replacement kit for outdoor use?When selecting a Wyze replacement kit for outdoor use, ensure the camera has an IP65 weatherproof rating, such as the Wyze Cam OG Telephoto or Wyze Cam v4, to withstand harsh weather conditions and provide reliable security.
Are Wyze replacement cameras compatible with smart home systems?Yes, Wyze replacement cameras like the Wyze Cam v4 are compatible with popular smart home systems, including Alexa, Google Assistant, and IFTTT, allowing for seamless integration and control.
What is the price range for Wyze replacement kits and cameras?Wyze replacement kits and cameras range in price from $25.98 for the Wyze Cam OG Telephoto single pack to $256.91 for the Whole Home Security Enhanced Kit. Multi-pack discounts and bundles are also available for greater savings.
What are the key features of the Wyze Cam OG Telephoto?Can you tell me more about the Whole Home Security Enhanced Kit?What is the warranty policy for Wyze products?
