Renew Your Wyze Cam with the Latest Replacement Kits
If you're looking to upgrade or replace your Wyze Cam, there are several excellent options designed to fit your home security needs. Whether you want a standalone camera or a comprehensive security system, Wyze offers replacement kits and bundles that bring advanced features, easy installation, and smart home integration.
Wyze Cam v4: The Ultimate Replacement Camera
Crisp 2.5K QHD Video Quality
The Wyze Cam v4 delivers stunning 2.5K QHD resolution (2560x1440), providing crystal-clear video footage to keep your home safe and monitored with exceptional detail.
Advanced Night Vision and Spotlight
Equipped with 4 IR LEDs and 2 white spotlight LEDs, the Cam v4 offers enhanced color night vision, allowing you to see in full color even in low-light conditions. The built-in motion-activated spotlight adds an extra layer of security by illuminating suspicious activity.
Smart Features and Connectivity
- Wide 115.8° diagonal field of view captures more area.
- Two-way audio with a 99dB waterproof speaker and noise echo cancellation.
- Built-in siren to deter intruders.
- Supports Wi-Fi 6 and Bluetooth 5.2 for fast, reliable connections.
- Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
Durable and Weather-Resistant
Rated IP65, the Wyze Cam v4 is suitable for both indoor and outdoor use, operating in temperatures from -4ºF to 122ºF (-20ºC to 50ºC).
Easy Installation
Multiple mounting options including stand, wall, ceiling, and magnetic mounts make it simple to place your camera exactly where you need it.
Whole Home Security Starter Kit: All-in-One Protection
What’s Included?
- 1x Wyze Cam v4 (choose from Black, Grey, or White)
- 1x Wyze Video Doorbell v2 for front door monitoring
- 1x Wyze Home Monitoring Starter Kit for comprehensive home security
Why Choose This Kit?
This bundle is perfect if you want to renew your Wyze Cam and simultaneously upgrade your home security system. The doorbell offers crisp 1080p HD video and two-way audio, while the starter kit provides essential monitoring tools to keep your home safe.
This kit is ideal for those who want a seamless, integrated security solution with multiple devices working together.
Wyze Cam v4 Outdoor Bundle: Enhanced Outdoor Security
Designed for Outdoor Use
This bundle includes the Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card for 24/7 local recording. It’s tailored for outdoor environments, ensuring your camera stays powered and records continuously.
Key Features
- Enhanced color night vision and motion-activated spotlight for clear visibility day and night.
- Wi-Fi 6 support for faster and more stable connections outdoors.
- Smoke and CO alerts integration for added safety.
- Motion detection zones and sound detection to customize alerts.
Reliable and Convenient
With wired power and local storage, this bundle ensures you never miss a moment, even if your internet goes down.
Why Renew Your Wyze Cam with These Kits?
- Latest Technology: Get the newest Wyze Cam v4 with improved video quality, night vision, and smart features.
- Versatile Options: Choose from standalone cameras, bundles, or outdoor-specific kits to fit your unique needs.
- Smart Home Integration: All products work seamlessly with Alexa, Google Assistant, and IFTTT.
- Easy Setup: Multiple mounting options and included accessories make installation quick and hassle-free.
- Durability: Weather-resistant designs ensure your cameras perform reliably indoors and outdoors.
Alt text: Family monitoring home security with Wyze Cam in living room
Summary of Wyze Cam Replacement Options
Product Name | Key Features | Price (USD) | Ideal For |
Wyze Cam v4 | 2.5K QHD, color night vision, built-in siren | $100.00 | Standalone camera replacement |
Whole Home Security Starter Kit | Wyze Cam v4, Video Doorbell v2, Monitoring Kit | $155.95 | Complete home security upgrade |
Wyze Cam v4 Outdoor Bundle | Outdoor power adapter, 24/7 local recording | $69.99 | Outdoor camera replacement |
Renew your Wyze Cam today with these advanced replacement kits and enjoy peace of mind with smart, reliable home security.
What is included in the Wyze Cam v4 replacement kit?
The Wyze Cam v4 replacement kit includes the Wyze Cam v4 camera, which features 2.5K QHD video quality, advanced color night vision, a built-in siren, two-way audio, and multiple mounting options for easy installation. It is suitable for both indoor and outdoor use.What are the main features of the Wyze Cam v4?
The Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision with IR and spotlight LEDs, a wide 115.8° field of view, two-way audio with a waterproof speaker, a built-in siren, Wi-Fi 6 and Bluetooth 5.2 support, and compatibility with Alexa, Google Assistant, and IFTTT.Is the Wyze Cam v4 weather-resistant?
Yes, the Wyze Cam v4 is rated IP65, making it weather-resistant and suitable for both indoor and outdoor use. It operates in temperatures ranging from -4ºF to 122ºF (-20ºC to 50ºC).What is included in the Whole Home Security Starter Kit?
The Whole Home Security Starter Kit includes one Wyze Cam v4 (available in Black, Grey, or White), one Wyze Video Doorbell v2 for front door monitoring, and one Wyze Home Monitoring Starter Kit for comprehensive home security.What are the benefits of the Whole Home Security Starter Kit?
The Whole Home Security Starter Kit provides an integrated security solution with a Wyze Cam v4, a video doorbell with 1080p HD video and two-way audio, and a home monitoring kit. It is ideal for users seeking a complete home security upgrade with seamless device integration.What does the Wyze Cam v4 Outdoor Bundle include?
The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card for 24/7 local recording. It is designed specifically for outdoor use and continuous monitoring.What are the key features of the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle offers enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 support, smoke and CO alerts integration, motion detection zones, sound detection, and reliable wired power with local storage.Can Wyze Cam v4 be integrated with smart home systems?
Yes, the Wyze Cam v4 is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your smart home devices.How easy is it to install the Wyze Cam v4?
The Wyze Cam v4 offers multiple mounting options, including stand, wall, ceiling, and magnetic mounts, making installation quick and hassle-free.Why should I renew my Wyze Cam with the latest replacement kits?
Renewing your Wyze Cam with the latest replacement kits ensures you get the newest technology, improved video quality, advanced night vision, smart features, versatile options for different needs, easy setup, and durable, weather-resistant designs for reliable performance indoors and outdoors.What are the prices of the Wyze Cam replacement options?
The Wyze Cam v4 standalone camera is priced at $100.00, the Whole Home Security Starter Kit is $155.95, and the Wyze Cam v4 Outdoor Bundle is $69.99.
