Wyze Outdoor Cam Repair Kit: Screws, Cables & DIY Fixes
Wyze Outdoor Cam Repair Kit Essentials for Screws, Cables, and DIY Fixes
When it comes to maintaining your Wyze outdoor cameras, having the right repair kit for screws, cables, and other DIY fixes is essential. Whether you own the Wyze Cam v4 or the Wyze Cam OG Telephoto, ensuring your camera is securely mounted and properly connected will keep your home surveillance running smoothly. This guide highlights the key Wyze cameras that come with mounting screws and cables, perfect for your outdoor camera repair needs.
Wyze Cam v4: The Ideal Outdoor Camera with Repair-Ready Accessories
Key Features for Easy Repairs and Maintenance
  • Included Screw Kit: The Wyze Cam v4 comes with a comprehensive screw kit, making it easy to replace or tighten mounting screws during repairs.
  • 6-Foot Flat Micro USB Cable: This durable cable is perfect for replacing worn or damaged power cables, ensuring uninterrupted power supply.
  • Multiple Mounting Options: Stand, wall mount, ceiling mount, and magnetic wall mount with adhesive provide versatile installation and easy access for repairs.
  • Weather Resistance: Rated IP65, the camera withstands outdoor elements, but occasional maintenance with the right screws and cables keeps it secure.
  • Compact Size: Measuring 2in x 2in x 2 3/8in, it’s easy to handle during DIY fixes.
Why Choose Wyze Cam v4 for Your Outdoor Setup?
The Wyze Cam v4 offers 2.5K QHD video resolution, color night vision, and a built-in siren, making it a powerful security device. Its included accessories like the screw kit and power cable simplify repairs and replacements, saving you time and money.
Wyze Cam OG Telephoto: Durable and Repair-Friendly Outdoor Surveillance
Repair and Installation Highlights
  • Mounting with M4 Screws: The Wyze Cam OG Telephoto uses M4 screws for wall and ceiling mounts, which are standard and easy to replace if lost or damaged.
  • 6-Foot Power Cable: Comes with a 6 ft (1.8 m) power cable, ideal for replacement or extension during outdoor repairs.
  • Compact and Lightweight: At just 4.1 oz and 1.89in cube dimensions, it’s easy to handle for DIY fixes.
  • Weatherproof Design: IP65 rating ensures it can handle outdoor conditions, but proper screw tightening and cable checks are recommended for longevity.
  • Enhanced Telephoto Lens: With a 3x telephoto lens, it captures detailed footage, making it a great investment worth maintaining.
Benefits of Repairing Your Wyze Cam OG Telephoto
Maintaining your Wyze Cam OG Telephoto with the right screws and cables ensures consistent performance and security. Its standard mounting hardware and included power cable make DIY repairs straightforward.
Tips for DIY Repairs on Wyze Outdoor Cameras
Keeping your Wyze outdoor cameras in top shape involves regular checks of mounting screws and power cables. Loose screws can cause camera misalignment or detachment, while damaged cables may interrupt power and connectivity.
  • Always use the original or compatible M4 screws for mounting.
  • Replace frayed or damaged power cables promptly with the included 6-foot micro USB cables.
  • Use weather-resistant sealants around cable entry points to prevent moisture damage.
  • Regularly clean the camera lens and housing to maintain video clarity.
Conclusion
For Wyze outdoor camera owners, especially those with the Wyze Cam v4 and Wyze Cam OG Telephoto, having access to the right screws, cables, and repair accessories is crucial for DIY maintenance. Both cameras come equipped with mounting screws and power cables that simplify repairs, ensuring your home security system remains reliable and effective.
Outdoor Security Camera Installation Secure your Wyze outdoor camera with the right screws and cables for lasting protection.
FeatureWyze Cam v4Wyze Cam OG Telephoto
Price$100.00 (Default Title) / $35.98 - $107.94 (varies by bundle/color)$25.98 (1 Pack), $58.98 (2 Pack)
Resolution2.5K QHD (2560x1440)1920 x 1080 (1080p)
SensorCMOS Starlight SensorCMOS-Starlight Sensor (1920 x 1080)
Field of View (DFOV / HFOV / VFOV)115.8° / 98.5° / 53.1°27° / 23.6° / 13.6°
Video FPSDaytime 20 FPS / Nighttime 15 FPSDaytime 20 FPS / Nighttime 10 FPS
Digital Zoom8x8x
Night Vision4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens), Color Night Vision4 IR LEDs (850 nm)
Wide Dynamic RangeYesNot specified
Audio Speaker99dB, waterproofBuilt-in Speaker & Microphone; Noise & Echo Cancellation
Two-Way TalkYesYes
Built-in SirenYesNot specified
Noise/Echo CancellationYesYes
Bluetooth Version5.2Not specified
Wi-Fi Support2.4 GHz Wi-Fi, Wi-Fi 6802.11 b/g/n, 2.4 GHz Wi-Fi
Phone CompatibilityAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+
IntegrationsAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Local StoragemicroSD card up to 512 GBSupports up to 256 GB microSD in exFAT format
Cloud StorageWith subscription planNot specified
Weather ResistanceIP65IP65
Operating Temperature-4°F to 122°F (-20°C to 50°C)-4°F to 131°F (-20°C to 55°C)
Storage Temperature-40°F to 158°F (-40°C to 70°C)-40°F to 158°F (-40°C to 70°C)
Dimensions2in x 2in x 2 3/8in1.89in x 1.89in x 1.89in (48mm x 48mm x 48mm)
Weight0.49 lb (222 g)4.1 oz (116 g)
Mounting OptionsStand, Wall mount, Ceiling mount, Magnetic wall mount (adhesive)Stand, Wall mount (M4 screw), Ceiling mount (M4 screw)
Power Adapter Input110-240 V (AC/DC)110-240V (AC/DC)
Power Adapter OutputIndoor 5V/1A5V/1A
Cable Length6-Foot Flat micro USB to USB-A6 ft (1.8 m)
Warranty1 Year1 Year
What is included in a Wyze Outdoor Cam repair kit?A Wyze Outdoor Cam repair kit typically includes essential items such as mounting screws (like M4 screws), a 6-foot flat micro USB power cable, and accessories for DIY fixes. These components help with replacing or tightening screws and swapping out damaged power cables to keep your Wyze outdoor cameras functioning properly.
Which Wyze cameras come with mounting screws and power cables for repairs?Both the Wyze Cam v4 and Wyze Cam OG Telephoto come with mounting screws and 6-foot power cables. These accessories make it easy to perform repairs, replacements, and secure installations for your outdoor surveillance setup.
How do I replace the mounting screws on my Wyze Cam OG Telephoto?To replace the mounting screws on your Wyze Cam OG Telephoto, use standard M4 screws, which are included with the camera. Simply unscrew the damaged or missing screws and replace them with new M4 screws to ensure a secure wall or ceiling mount.
What type of power cable is compatible with Wyze outdoor cameras?Wyze outdoor cameras, such as the Wyze Cam v4 and Wyze Cam OG Telephoto, use a 6-foot flat micro USB power cable. Always use the original or a compatible replacement cable to ensure reliable power and connectivity.
How can I maintain my Wyze outdoor camera for long-lasting performance?To maintain your Wyze outdoor camera, regularly check and tighten mounting screws, replace frayed or damaged power cables, use weather-resistant sealants around cable entry points, and clean the camera lens and housing. These steps help prevent misalignment, power interruptions, and moisture damage.
Are Wyze outdoor cameras weatherproof?Yes, both the Wyze Cam v4 and Wyze Cam OG Telephoto are rated IP65 for weather resistance. This means they can withstand outdoor elements, but regular maintenance of screws and cables is recommended to ensure continued protection and performance.
Why is it important to use the correct screws and cables for Wyze camera repairs?Using the correct screws and cables, such as M4 mounting screws and the 6-foot micro USB power cable, ensures your Wyze camera is securely installed and receives uninterrupted power. This helps maintain optimal video quality and reliable home security.
Can I perform DIY repairs on my Wyze outdoor camera?Yes, Wyze outdoor cameras are designed for easy DIY repairs. With included screw kits and power cables, you can quickly replace or tighten screws, swap out damaged cables, and perform routine maintenance to keep your camera in top condition.
What are the key features of the Wyze Cam v4 that make it suitable for outdoor use?Can you explain how to properly maintain the Wyze Cam OG Telephoto for optimal performance?Do you have any ongoing sales or discounts for Wyze outdoor camera accessories?
