Where to Buy Genuine Wyze Cam Pan Replacement Kit with Mount and Adapter Accessories
If you are looking to buy a genuine Wyze Cam Pan replacement kit along with essential mounting and adapter accessories, this guide covers the best authentic Wyze products designed specifically for Wyze Cam Pan models. Whether you need a spare mounting plate, a full mounting kit, or versatile mounts for your Wyze cameras, these genuine Wyze accessories ensure secure installation and reliable performance.
Wyze Cam Pan Mounting Kit: Perfect Fit for Wyze Cam Pan v1 & v2
Key Features:
- Compatibility: Designed exclusively for Wyze Cam Pan v1 and v2 models.
- Purpose: Acts as a spare mounting plate to replace worn or lost mounts.
- Ease of Use: Simple installation to securely hold your Wyze Cam Pan in place.
- Price: Affordable at $7.99, making it a cost-effective solution for mounting needs.
This mounting kit is essential if you want to maintain the flexibility and stability of your Wyze Cam Pan. It ensures your camera stays firmly attached to your preferred surface, whether indoors or outdoors.
Wyze Cam Mounting Kit: Comprehensive Mounting Solution for Wyze Cam v2, v3, and v3 Pro
What’s Included:
- Wall Plate x1
- USB Extension Cable (5 feet) x1
- Adhesive Tape x1
- Screw Set x1
Highlights:
- Compatibility: Works with Wyze Cam v2, v3, and v3 Pro.
- Extended Cable: Comes with a longer Micro USB cable for flexible placement.
- Mounting Options: Includes adhesive and screws for versatile mounting on walls or ceilings.
- Price: Available at $5.99, offering great value for a complete mounting kit.
This kit is ideal for users who want a reliable mounting solution with added cable length for easier camera positioning.
Wyze Universal Mount (Long): Durable and Adjustable Mount for Versatile Placement
Features:
- Heavy-Duty Metal Construction: Ensures durability and long-lasting use.
- Long Neck Design: Perfect for mounting on ceilings, patios, or other hard-to-reach areas.
- Compatibility: Supports Wyze Cam Pan v1, v2, v3, and v3 Pro, plus other Wyze cameras with a 1/4”-20 mount.
- Easy Installation: Comes with screws and drywall anchors for secure mounting.
- Price: Priced at $9.99, this mount offers premium build quality and flexibility.
This mount is perfect for users who want to position their Wyze Cam Pan in unique locations with a sturdy and adjustable mount.
Wyze Cam v3 Replacement Part Kit: Reliable Replacement for Wyze Cam v2 and v3
Overview:
- Compatibility: Suitable for Wyze Cam v2 and v3 models.
- Purpose: Replacement parts kit to keep your camera functioning optimally.
- Return Policy: Comes with a 30-day hassle-free return policy.
- Price: Available at $7.99, providing an affordable way to maintain your camera.
This replacement kit is a practical choice if you need genuine parts to repair or refresh your Wyze Cam.
Why Choose Genuine Wyze Accessories?
Using genuine Wyze replacement kits and mounting accessories guarantees compatibility, durability, and optimal performance. These products are designed specifically for Wyze cameras, ensuring easy installation and secure mounting, which is crucial for maintaining your home security system’s reliability.
Enhance Your Home Security Setup with Wyze Accessories
Secure your Wyze Cam Pan with genuine mounts for reliable home monitoring.
Summary of Genuine Wyze Cam Pan Replacement and Mounting Accessories
Product Name | Compatible Models | Key Features | Price |
Wyze Cam Pan Mounting Kit | Wyze Cam Pan v1, v2 | Spare mounting plate | $7.99 |
Wyze Cam Mounting Kit | Wyze Cam v2, v3, v3 Pro | Mounting bracket, adhesive, cable | $5.99 |
Wyze Universal Mount (Long) | Wyze Cam Pan v1, v2, v3, v3 Pro | Heavy-duty, adjustable, versatile | $9.99 |
Wyze Cam v3 Replacement Kit | Wyze Cam v2, v3 | Replacement parts | $7.99 |
Investing in genuine Wyze Cam Pan replacement kits and mounting accessories ensures your camera stays securely installed and fully functional, providing peace of mind for your home security needs.
Where can I buy genuine Wyze Cam Pan replacement kits and mounting accessories?
You can purchase genuine Wyze Cam Pan replacement kits and mounting accessories directly from authorized Wyze retailers or the official Wyze website. These authentic products are designed specifically for Wyze Cam Pan models to ensure compatibility and reliable performance.What is included in the Wyze Cam Pan Mounting Kit?
The Wyze Cam Pan Mounting Kit includes a spare mounting plate designed exclusively for Wyze Cam Pan v1 and v2 models. It provides a secure and stable way to mount your camera, making it easy to replace worn or lost mounts.Which Wyze cameras are compatible with the Wyze Cam Pan Mounting Kit?
The Wyze Cam Pan Mounting Kit is compatible with Wyze Cam Pan v1 and v2 models only.What does the Wyze Cam Mounting Kit offer for Wyze Cam v2, v3, and v3 Pro?
The Wyze Cam Mounting Kit for Wyze Cam v2, v3, and v3 Pro includes a wall plate, a 5-foot USB extension cable, adhesive tape, and a screw set. It provides flexible mounting options for walls or ceilings and allows for easier camera positioning with the extended cable.Is there a universal mount available for Wyze cameras?
Yes, the Wyze Universal Mount (Long) is a heavy-duty, adjustable mount compatible with Wyze Cam Pan v1, v2, v3, v3 Pro, and other Wyze cameras with a 1/4”-20 mount. It is ideal for mounting cameras on ceilings, patios, or hard-to-reach areas.What are the benefits of using genuine Wyze accessories for my Wyze Cam Pan?
Genuine Wyze accessories are designed for perfect compatibility, durability, and optimal performance. They ensure easy installation, secure mounting, and help maintain the reliability of your home security system.What is included in the Wyze Cam v3 Replacement Part Kit?
The Wyze Cam v3 Replacement Part Kit includes genuine replacement parts suitable for Wyze Cam v2 and v3 models. It helps keep your camera functioning optimally and comes with a 30-day hassle-free return policy.How much do Wyze Cam Pan replacement kits and mounting accessories cost?
Wyze Cam Pan Mounting Kit is priced at $7.99, Wyze Cam Mounting Kit at $5.99, Wyze Universal Mount (Long) at $9.99, and Wyze Cam v3 Replacement Kit at $7.99. These prices offer affordable solutions for maintaining and mounting your Wyze cameras.Why should I choose authentic Wyze Cam Pan replacement kits and mounts?
Choosing authentic Wyze Cam Pan replacement kits and mounts guarantees compatibility with your camera, ensures secure installation, and maintains the reliability and performance of your home security setup.
