Where to Buy Wyze Cam OG Stack Kit and Stacking Tips for OG Telephoto
If you're looking to enhance your Wyze Cam OG or Wyze Cam OG Telephoto setup, the
Wyze Cam OG Stack Kit and the
Wyze Cam OG Stack Kit Bundle are your go-to solutions. These products allow you to stack and power multiple cameras efficiently, giving you versatile viewing angles and a streamlined installation.
Wyze Cam OG Stack Kit: Power and Mount Two Cameras Seamlessly
The
Wyze Cam OG Stack Kit is designed specifically for Wyze Cam OG and OG Telephoto models. It includes everything you need to stack two cameras vertically while powering them from a single outlet.
Key Features:
- Stack Mount: Securely mounts two Wyze Cam OG or OG Telephoto cameras on top of each other.
- Dual Micro USB Power Cable (6ft): Powers both cameras simultaneously with one power source.
- 5V/1.5A Indoor Power Adapter: Reliable power supply for continuous operation.
- Matte White Finish: Sleek and unobtrusive design that blends with your home decor.
- Quick Start Guide: Easy setup instructions to get you started quickly.
This kit is perfect for users who want to combine a wide-angle view with a telephoto perspective without cluttering their space with multiple power cords.
Wyze Cam OG Stack Kit Bundle: Two Cameras, Two Views
For those who want an all-in-one package, the
Wyze Cam OG Stack Kit Bundle offers a complete solution with two cameras and the stack kit included.
Bundle Highlights:
- Includes:
- 1x Wyze Cam OG Standard (Wide-angle)
- 1x Wyze Cam OG Telephoto (3x zoom lens)
- 1x Wyze Cam OG Stack Kit (mount + power splitter)
- 1x 32GB MicroSD Card for local storage
- Power adapters, cables, mounting hardware, and quick start guides
- 1080p Full HD Video: Crisp, clear video quality for both cameras.
- Color Night Vision: See details even in low light with color illumination.
- Two-Way Audio: Communicate through the camera with built-in speaker and microphone.
- Fast Notifications: Receive alerts quickly for motion or sound detection.
- Alexa, Google Assistant, and IFTTT Integration: Smart home compatibility.
- Weather Resistant (IP65): Suitable for indoor and outdoor use.
- Stackable Design: Save space and create a multi-angle security setup.
This bundle is ideal for users who want to monitor a wide area and zoom in on specific details simultaneously, such as monitoring a front porch and zooming in on packages or visitors.
Wyze Cam OG Telephoto: Zoom In with Precision
The
Wyze Cam OG Telephoto is a powerful companion to the standard Wyze Cam OG, featuring a 3x telephoto lens that lets you zoom in on important details without losing image quality.
Telephoto Camera Specs:
- 3x Telephoto Lens: Narrow field of view (27° diagonal) for focused zoomed-in shots.
- 1080p HD Video: High-definition clarity for detailed monitoring.
- 4 IR LEDs for Night Vision: Clear images even in complete darkness.
- 8x Digital Zoom: Further zoom capabilities via the app.
- Built-in Speaker & Microphone: Two-way audio with noise and echo cancellation.
- Weather Resistant (IP65): Durable for outdoor use.
- Compact Size: 1.89in cube, easy to mount on walls or ceilings.
- Supports up to 256GB microSD: Local storage for extended recording.
- Fast Notification and Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT.
Stacking Tips for OG Telephoto:
- Use the Wyze Cam OG Stack Kit to mount the telephoto camera on top of a standard Wyze Cam OG for a dual-view setup.
- Position the telephoto camera higher to capture zoomed-in details while the wide-angle camera covers the broader scene.
- Ensure both cameras are powered using the included dual USB power cable to avoid cable clutter.
- Mount securely using the M4 screws included in the stack kit for stable and safe installation.
- Take advantage of the 6ft power cable length to place cameras optimally without worrying about outlet proximity.
Why Choose Wyze Cam OG Stack Kit and Bundle?
"Stack your Wyze cameras for comprehensive coverage with minimal hassle."
The Wyze Cam OG Stack Kit and Bundle provide a smart, space-saving solution for users who want to maximize their home security setup. Whether you want to monitor wide areas or zoom in on specific spots, stacking your Wyze Cam OG and OG Telephoto cameras gives you the flexibility and power you need.
Summary of Products for Your Wyze Cam OG Setup
Product Name | Price (USD) | Key Features |
Wyze Cam OG Stack Kit | $9.99 | Stack mount, dual USB power cable, power adapter |
Wyze Cam OG Stack Kit Bundle | $89.99 | Includes 2 cameras, stack kit, 32GB microSD, full HD, night vision |
Wyze Cam OG Telephoto | $25.98+ | 3x telephoto lens, 1080p HD, night vision, weather resistant |
Optimize your home security with the Wyze Cam OG Stack Kit and Telephoto camera today, and enjoy a versatile, powerful, and neat surveillance system.
Where can I buy the Wyze Cam OG Stack Kit and Stack Kit Bundle?
You can purchase the Wyze Cam OG Stack Kit and the Wyze Cam OG Stack Kit Bundle directly from the official Wyze website or authorized retailers. These kits are designed specifically for Wyze Cam OG and Wyze Cam OG Telephoto models, providing a seamless stacking and power solution.What is included in the Wyze Cam OG Stack Kit?
The Wyze Cam OG Stack Kit includes a stack mount for securely mounting two Wyze Cam OG or OG Telephoto cameras, a 6ft dual micro USB power cable to power both cameras from a single outlet, a 5V/1.5A indoor power adapter, a matte white finish for a sleek look, and a quick start guide for easy installation.What comes with the Wyze Cam OG Stack Kit Bundle?
The Wyze Cam OG Stack Kit Bundle includes one Wyze Cam OG Standard (wide-angle), one Wyze Cam OG Telephoto (3x zoom lens), one Wyze Cam OG Stack Kit (mount and power splitter), a 32GB microSD card for local storage, power adapters, cables, mounting hardware, and quick start guides.How does the Wyze Cam OG Stack Kit improve my home security setup?
The Wyze Cam OG Stack Kit allows you to stack and power two cameras from a single outlet, reducing cable clutter and saving space. This setup enables you to combine wide-angle and telephoto views for comprehensive coverage, making it easier to monitor large areas and zoom in on specific details.Can I use the Wyze Cam OG Stack Kit outdoors?
Yes, both the Wyze Cam OG and Wyze Cam OG Telephoto cameras are weather resistant with an IP65 rating, making them suitable for both indoor and outdoor use when used with the Stack Kit.What are the key features of the Wyze Cam OG Telephoto camera?
The Wyze Cam OG Telephoto features a 3x telephoto lens with a 27° diagonal field of view, 1080p HD video, 4 IR LEDs for night vision, 8x digital zoom via the app, built-in speaker and microphone for two-way audio, weather resistance (IP65), compact size, support for up to 256GB microSD cards, and smart home integration with Alexa, Google Assistant, and IFTTT.How do I stack the Wyze Cam OG and OG Telephoto cameras for optimal coverage?
To stack the Wyze Cam OG and OG Telephoto cameras, use the Wyze Cam OG Stack Kit to mount the telephoto camera on top of the standard Wyze Cam OG. Position the telephoto camera higher to capture zoomed-in details while the wide-angle camera covers the broader scene. Use the included dual USB power cable and M4 screws for secure and clutter-free installation.Does the Wyze Cam OG Stack Kit support local video storage?
Yes, the Wyze Cam OG Stack Kit Bundle includes a 32GB microSD card for local storage. The Wyze Cam OG Telephoto camera also supports microSD cards up to 256GB for extended recording.Are the Wyze Cam OG Stack Kit and Bundle compatible with smart home systems?
Yes, both the Wyze Cam OG Stack Kit and the cameras included in the bundle are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration into your smart home setup.What are the benefits of stacking Wyze Cam OG and OG Telephoto cameras?
Stacking Wyze Cam OG and OG Telephoto cameras provides dual viewing angles—wide and zoomed-in—using minimal space and a single power source. This setup is ideal for monitoring large areas while focusing on specific details, such as packages or visitors at your front door.
