Where to Buy a Replacement Wyze Cam Pan Mounting Kit for V1 and V2
If you are looking to replace the mounting kit for your Wyze Cam Pan V1 or V2, this guide will help you find the exact accessory you need. Wyze offers a dedicated
Wyze Cam Pan Mounting Kit designed specifically for these models, ensuring a perfect fit and secure installation.
Wyze Cam Pan Mounting Kit: Perfect Fit for V1 and V2
Key Features
- Compatibility: Exclusively made for Wyze Cam Pan V1 and V2 models.
- Purpose: A spare mounting plate to replace your original or damaged mounting kit.
- Price: Affordable at $7.99.
- Availability: Currently sold out but often restocked; keep an eye out for availability.
- Return Policy: Comes with a 30-day hassle-free return option.
This mounting kit is essential if you want to maintain the full functionality and stability of your Wyze Cam Pan. It ensures your camera stays securely mounted, allowing the 360° pan and 93° tilt features to work flawlessly.
The Wyze Cam Pan Mounting Kit is a simple yet vital accessory for anyone who owns a Wyze Cam Pan V1 or V2 and needs a reliable replacement part.
Alternative: Wyze Cam Mounting Kit for Multiple Models
Overview
If you have multiple Wyze cameras or are considering an upgrade, the
Wyze Cam Mounting Kit is a versatile option compatible with Wyze Cam V2, V3, and V3 Pro. While it does not specifically cater to the Pan models, it includes:
- A mounting bracket
- Adhesive for easy installation
- A longer Micro USB cable for flexible placement
Pricing and Availability
- Price: $5.99
- In stock and ready for immediate purchase
- 30-day hassle-free returns
This kit is ideal if you have a Wyze Cam V2 or newer and want a mounting solution that includes additional accessories like the longer cable.
Why Choose the Official Wyze Mounting Kits?
Using official Wyze mounting kits guarantees compatibility and durability. These kits are designed to fit perfectly with your camera models, ensuring:
- Secure mounting without risk of damage
- Easy installation with included hardware or adhesive
- Maintained camera functionality, including pan and tilt for Pan models
Additional Wyze Camera Accessories and Options
While searching for mounting kits, you might also consider other Wyze products that complement your security setup:
Wyze Cam Pan v3
- Redesigned with 360° pan and 180° tilt
- IP65 weather resistant for indoor/outdoor use
- Supports Alexa, Google Assistant, and IFTTT
- Price: Starting at $39.98 for multi-packs
Experience versatile security with the weather-resistant Wyze Cam Pan v3.
Wyze Cam v3 Replacement Part Kit
- Compatible with Wyze Cam V2 and V3
- Price: $7.99
- Useful for replacing worn or lost parts
Summary
For a replacement mounting kit specifically for Wyze Cam Pan V1 and V2, the
Wyze Cam Pan Mounting Kit is your best choice. It is designed to fit these models perfectly and maintain the camera’s full range of motion and stability. If you have other Wyze camera models, the
Wyze Cam Mounting Kit offers a versatile mounting solution with additional accessories.
Always opt for official Wyze accessories to ensure compatibility, durability, and peace of mind.
Where can I buy a replacement Wyze Cam Pan Mounting Kit for V1 and V2?
You can purchase the official Wyze Cam Pan Mounting Kit, designed specifically for Wyze Cam Pan V1 and V2, directly from the Wyze website. Please note that it is currently sold out but is often restocked, so check back regularly for availability.Is the Wyze Cam Pan Mounting Kit compatible with both V1 and V2 models?
Yes, the Wyze Cam Pan Mounting Kit is exclusively made for Wyze Cam Pan V1 and V2 models, ensuring a perfect fit and secure installation.How much does the Wyze Cam Pan Mounting Kit cost?
The Wyze Cam Pan Mounting Kit is affordably priced at $7.99.What is included in the Wyze Cam Pan Mounting Kit?
The Wyze Cam Pan Mounting Kit includes a spare mounting plate designed to replace your original or damaged mounting kit for Wyze Cam Pan V1 or V2.What is the return policy for the Wyze Cam Pan Mounting Kit?
The Wyze Cam Pan Mounting Kit comes with a 30-day hassle-free return option, allowing you to return the product if it does not meet your needs.Are there alternative mounting kits for other Wyze camera models?
Yes, the Wyze Cam Mounting Kit is compatible with Wyze Cam V2, V3, and V3 Pro. It includes a mounting bracket, adhesive for easy installation, and a longer Micro USB cable. However, it is not specifically designed for the Pan models.How much does the Wyze Cam Mounting Kit for V2, V3, and V3 Pro cost?
The Wyze Cam Mounting Kit for V2, V3, and V3 Pro is priced at $5.99 and is currently in stock for immediate purchase.Why should I choose official Wyze mounting kits for my cameras?
Official Wyze mounting kits guarantee compatibility and durability. They are designed to fit your camera models perfectly, ensuring secure mounting, easy installation, and maintained camera functionality, including pan and tilt features for Pan models.Are there replacement part kits available for Wyze Cam V2 and V3?
Yes, the Wyze Cam v3 Replacement Part Kit is compatible with Wyze Cam V2 and V3 and is available for $7.99. It is useful for replacing worn or lost parts.What are the features of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 features a redesigned 360° pan and 180° tilt, IP65 weather resistance for indoor and outdoor use, and supports Alexa, Google Assistant, and IFTTT. Prices start at $39.98 for multi-packs.
