Affordable Wyze Lock Replacement Kit with Parts Online
If you're searching for an affordable Wyze Lock replacement kit with all the essential parts, you've come to the right place. Whether you need to replace worn-out components or upgrade your smart lock system, Wyze offers a variety of replacement parts and kits designed specifically for the Wyze Lock Bolt. This page highlights the best options to keep your smart lock functioning smoothly without breaking the bank.
Wyze Lock Bolt: The Smart Lock You Can Trust
The Wyze Lock Bolt is a Bluetooth-enabled smart lock that replaces your traditional deadbolt with advanced features for convenience and security.
Key Features:
- Ultra-Fast Fingerprint Sensor for quick and secure access.
- Backlit Keypad with Anti-Peep technology to keep your code private.
- Auto-lock Function that secures your door automatically if you forget.
- Built-in Alarm for jam detection to alert you of tampering.
- Lock and Unlock History accessible via the Wyze app.
- Compatible with door thicknesses from 1-3/8” to 1-3/4” and backsets of 2-3/8” or 2-3/4”.
- Weather-resistant with an IPX5 rating, suitable for various climates.
- Powered by 4 AA batteries with a battery life of 10-12 months.
Available in
Matte Black and
Satin Nickel, the Wyze Lock Bolt combines sleek design with smart home integration, making it a top choice for modern homes.
Secure your home effortlessly with Wyze Lock Bolt.
Wyze Lock Replacement Part Kit: Affordable and Compatible
For those who need to replace specific parts of their Wyze Lock without purchasing a full lock, the
Wyze Lock Replacement Part Kit is an excellent budget-friendly option.
What You Get:
- Replacement parts designed exclusively for the Wyze Lock.
- Two styles available: Replacement Part Kit ($19.99) and Adapter Replacement Kit ($4.99).
- Hassle-free 30-day return policy for peace of mind.
This kit is perfect for fixing minor issues or replacing worn components, ensuring your lock continues to operate smoothly without the cost of a full replacement.
Essential Wyze Lock Bolt Replacement Parts
To maintain or repair your Wyze Lock Bolt, several individual replacement parts are available at affordable prices:
Wyze Lock Bolt Screws
- Price: $2.99
- A set of screws compatible with the Wyze Lock Bolt.
- Ideal for securing the lock firmly to your door.
- Comes with a 30-day hassle-free return policy.
Wyze Lock Bolt Interior Assembly Battery Cover
- Price: $9.99
- Replacement battery cover for the interior assembly.
- Ensures your batteries stay protected and your lock functions reliably.
- Compatible only with Wyze Lock Bolt.
Wyze Lock Bolt Interior Assembly Metal Plate
- Price: $4.99
- Metal plate used to anchor the interior assembly securely to the door.
- Available in quantities from 1 to 10, depending on your needs.
- 30-day hassle-free returns available.
These parts allow you to replace only what you need, saving money and extending the life of your Wyze Lock Bolt.
Why Choose Wyze Lock Replacement Kits and Parts?
"Affordable, reliable, and easy to install replacement parts keep your smart lock working like new."
Wyze replacement kits and parts are designed with compatibility and quality in mind. They provide a cost-effective way to maintain your smart lock system without compromising on security or convenience. With easy installation and a trusted return policy, you can confidently purchase the parts you need online.
Conclusion
For anyone looking to buy an affordable Wyze Lock replacement kit with parts online, Wyze offers a comprehensive selection tailored to your needs. From the full Wyze Lock Bolt smart lock to individual replacement parts like screws, battery covers, and metal plates, you can keep your smart home secure and functional without overspending.
Invest in genuine Wyze replacement parts today and enjoy the convenience and peace of mind that comes with a well-maintained smart lock system.
Wyze Lock Bolt keypad with smart app control.
Product Summary
Wyze Lock Bolt
Price: $79.98
Features: Fingerprint sensor, backlit keypad, auto-lock, alarm, Bluetooth 5.0, weather-resistant.
Price: $4.99 - $19.99
Includes adapter and replacement parts compatible with Wyze Lock.
Price: $2.99
Set of screws for secure installation.
Price: $9.99
Protects battery compartment.
Price: $4.99
Anchors interior assembly to door.
What is included in the Wyze Lock Replacement Part Kit?
The Wyze Lock Replacement Part Kit includes replacement parts designed exclusively for the Wyze Lock. There are two styles available: the Replacement Part Kit ($19.99) and the Adapter Replacement Kit ($4.99). These kits are ideal for fixing minor issues or replacing worn components, ensuring your lock continues to operate smoothly without the need for a full replacement.Are Wyze Lock replacement parts compatible with all Wyze Lock models?
Wyze Lock replacement parts and kits are specifically designed for the Wyze Lock and Wyze Lock Bolt models. Always check the product description to ensure compatibility with your specific lock model before purchasing.How much do Wyze Lock replacement parts cost?
Wyze Lock replacement parts are affordably priced. The Replacement Part Kit is $19.99, the Adapter Replacement Kit is $4.99, Wyze Lock Bolt Screws are $2.99, the Interior Assembly Battery Cover is $9.99, and the Interior Assembly Metal Plate is $4.99.Can I buy individual Wyze Lock Bolt replacement parts online?
Yes, you can purchase individual Wyze Lock Bolt replacement parts online, including screws, battery covers, and metal plates. This allows you to replace only the components you need, saving money and extending the life of your smart lock.What is the return policy for Wyze Lock replacement parts?
Wyze offers a hassle-free 30-day return policy on all replacement parts and kits. This gives you peace of mind when purchasing parts online.What features does the Wyze Lock Bolt offer?
The Wyze Lock Bolt features an ultra-fast fingerprint sensor, a backlit keypad with anti-peep technology, auto-lock function, built-in alarm for jam detection, lock and unlock history via the Wyze app, and weather resistance with an IPX5 rating. It is available in Matte Black and Satin Nickel finishes.How do I know which Wyze Lock replacement part I need?
To determine which Wyze Lock replacement part you need, identify the specific component that is worn or malfunctioning, such as screws, battery cover, or metal plate. Refer to your Wyze Lock model and check the compatibility listed in the product descriptions before purchasing.Are Wyze Lock replacement parts easy to install?
Yes, Wyze Lock replacement parts are designed for easy installation. Most users can replace components themselves without professional help, ensuring your smart lock is quickly restored to full functionality.Why should I choose genuine Wyze Lock replacement parts?
Genuine Wyze Lock replacement parts are specifically designed for compatibility and quality, ensuring your smart lock system remains secure and reliable. Using authentic parts helps maintain the performance and longevity of your Wyze Lock.Where can I buy affordable Wyze Lock replacement kits and parts online?
You can purchase affordable Wyze Lock replacement kits and parts directly from the Wyze website. They offer a comprehensive selection of kits and individual components tailored to your needs, all backed by a 30-day return policy.
