Buy Genuine Wyze Lock Bolt Replacement Parts Online
Order Genuine Wyze Lock Bolt Replacement Parts
If you own a Wyze Lock Bolt and need genuine replacement parts to keep your smart lock functioning flawlessly, you’ve come to the right place. Wyze offers authentic replacement components designed specifically for the Wyze Lock Bolt, ensuring seamless compatibility and reliable performance. Whether you need to replace the battery cover, screws, or the metal plate anchoring the interior assembly, these parts help maintain your lock’s security and convenience.
Wyze Lock Bolt: The Smart Deadbolt Replacement
The Wyze Lock Bolt is a cutting-edge Bluetooth smart lock that replaces your traditional deadbolt with advanced technology and sleek design. It features:
  • Ultra-Fast Fingerprint Sensor for quick, keyless entry
  • Backlit Keypad with Anti-Peep technology for secure code entry even in the dark
  • Auto-lock Function that secures your door automatically if you forget
  • Lock and Unlock History accessible via the Wyze app for peace of mind
  • Built-in Alarm for jam detection to alert you of tampering
  • Emergency One-Time Codes for guest access without sharing permanent codes
Available in Matte Black and Satin Nickel, the Wyze Lock Bolt fits doors with thickness from 1-3/8” to 1-3/4” and supports backsets of 2-3/8” or 2-3/4”. It operates on 4 AA batteries with a battery life of 10-12 months and communicates via Bluetooth 5.0 with a 16 ft range. The lock is weather-resistant with an IPX5 rating, making it suitable for various climates.
Experience the convenience of unlocking your door in less than a second with just a fingerprint or a tap on your phone app.
Wyze Lock Bolt Lifestyle Secure your home effortlessly with Wyze Lock Bolt
To keep your Wyze Lock Bolt operating at peak performance, Wyze offers the following genuine replacement parts:
Wyze Lock Bolt Interior Assembly Battery Cover
  • Designed specifically for the Wyze Lock Bolt interior assembly
  • Protects and secures the battery compartment
  • Easy to replace and install
  • Priced affordably at $9.99
  • Comes with a 30-day hassle-free return policy
Wyze Lock Bolt Screws
  • Complete set of screws compatible with the Wyze Lock Bolt
  • Ideal for replacing lost or damaged screws during installation or maintenance
  • Affordable at $2.99
  • Backed by a 30-day hassle-free return policy
Wyze Lock Bolt Interior Assembly Metal Plate
  • Metal plate anchors the interior assembly firmly to your door
  • Ensures stability and durability of the lock mechanism
  • Priced at $4.99
  • Genuine part designed for perfect fit and function
Using genuine Wyze replacement parts guarantees your lock’s integrity and maintains your home’s security.
Wyze Lock Bolt Keypad Wyze Lock Bolt’s backlit keypad and fingerprint sensor
Why Choose Genuine Wyze Replacement Parts?
  • Perfect Compatibility: Designed exclusively for Wyze Lock Bolt to ensure flawless fit and function.
  • Maintain Warranty: Using genuine parts helps keep your product warranty intact.
  • Reliable Quality: Manufactured to meet Wyze’s high standards for durability and performance.
  • Easy Installation: Replacement parts come with clear instructions for quick and hassle-free installation.
  • Peace of Mind: Keep your smart lock working smoothly to protect your home and loved ones.
Enhance Your Home Security with Wyze Bundles
For a comprehensive home security upgrade, consider the Essential Security Bundle or the Front Porch Security Bundle which include the Wyze Lock Bolt along with other smart devices like video doorbells and security cameras. These bundles offer:
  • Seamless integration with Wyze app for centralized control
  • High-definition video monitoring with two-way audio
  • Motion tracking and night vision capabilities
  • Remote lock/unlock and real-time alerts
Bundles provide an all-in-one solution to safeguard your home from every angle.
Secure your home with confidence by ordering genuine Wyze Lock Bolt replacement parts today. Keep your smart lock in top condition and enjoy the convenience and security that Wyze delivers.
Product Summary
Product NameTypePrice (USD)Key Features
Wyze Lock BoltConnected Home62.86Fingerprint sensor, backlit keypad, auto-lock, Bluetooth 5.0
Wyze Lock Bolt Interior Assembly Battery CoverReplacement Parts9.99Battery compartment cover, easy install
Wyze Lock Bolt ScrewsReplacement Parts2.99Complete screw set for lock assembly
Wyze Lock Bolt Interior Assembly Metal PlateReplacement Parts4.99Metal plate for interior assembly anchoring
FeatureWyze Lock BoltWyze Lock Bolt Interior Assembly Battery CoverWyze Lock Bolt ScrewsWyze Lock Bolt Interior Assembly Metal Plate
Product TypeConnected Home / Smart LockReplacement PartsReplacement PartsReplacement Parts
DescriptionBluetooth smart lock replacing deadbolt with fingerprint reader, backlit keypad, auto-lock, weatherproof, pick-proofReplacement interior battery coverSet of screws for Wyze Lock BoltMetal plate to anchor interior assembly to door
Price$62.86$9.99$2.99$4.99
Color / StyleMatte Black, Satin NickelDefaultDefaultDefault
CompatibilityReplaces existing deadbolt on exterior doorsCompatible with Wyze Lock BoltCompatible with Wyze Lock BoltCompatible with Wyze Lock Bolt
Key FeaturesFingerprint unlock, backlit keypad, auto-lock, Bluetooth app control, weatherproof (IPX5), pick-proof, 12-month battery lifeReplacement part for battery coverReplacement screws setReplacement metal plate for interior assembly
Warranty / Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns
Installation TimeAbout 20 minutesN/AN/AN/A
What are genuine Wyze Lock Bolt replacement parts?Genuine Wyze Lock Bolt replacement parts are authentic components designed specifically for the Wyze Lock Bolt smart deadbolt. These include the interior assembly battery cover, screws, and the interior assembly metal plate. Using these parts ensures seamless compatibility, reliable performance, and maintains your lock’s security.
Why should I use genuine Wyze replacement parts for my Lock Bolt?Using genuine Wyze replacement parts guarantees perfect compatibility, maintains your product warranty, and ensures reliable quality and durability. These parts are manufactured to Wyze’s high standards and come with easy installation instructions for hassle-free replacement.
Which replacement parts are available for the Wyze Lock Bolt?Wyze offers the following replacement parts for the Wyze Lock Bolt: the interior assembly battery cover, a complete set of screws, and the interior assembly metal plate. Each part is designed for a perfect fit and function with your Wyze Lock Bolt.
How much do Wyze Lock Bolt replacement parts cost?The Wyze Lock Bolt Interior Assembly Battery Cover is priced at $9.99, the complete set of screws is $2.99, and the Interior Assembly Metal Plate is $4.99. All parts come with a 30-day hassle-free return policy.
Are Wyze Lock Bolt replacement parts easy to install?Yes, all genuine Wyze Lock Bolt replacement parts are designed for easy installation. They come with clear instructions, making it simple to replace components and keep your smart lock functioning optimally.
Will using non-genuine parts affect my Wyze Lock Bolt warranty?Yes, using non-genuine parts may void your Wyze Lock Bolt warranty. To maintain your warranty and ensure the best performance, always use authentic Wyze replacement parts.
What features does the Wyze Lock Bolt offer?The Wyze Lock Bolt features an ultra-fast fingerprint sensor, backlit keypad with anti-peep technology, auto-lock function, lock and unlock history via the Wyze app, built-in alarm for jam detection, and emergency one-time codes for guest access. It is available in Matte Black and Satin Nickel finishes.
What is the battery life of the Wyze Lock Bolt?The Wyze Lock Bolt operates on 4 AA batteries, providing a battery life of 10-12 months under normal usage.
Is the Wyze Lock Bolt weather-resistant?Yes, the Wyze Lock Bolt is weather-resistant with an IPX5 rating, making it suitable for various climates and outdoor conditions.
Can I upgrade my home security with Wyze bundles?Yes, Wyze offers security bundles such as the Essential Security Bundle and the Front Porch Security Bundle. These include the Wyze Lock Bolt along with other smart devices like video doorbells and security cameras, providing comprehensive home security and seamless integration with the Wyze app.
What are the specific replacement parts available for the Wyze Lock Bolt?How do I install the Wyze Lock Bolt replacement parts?Can you tell me more about the warranty policy for the Wyze Lock Bolt?
