Bluetooth Smart Lock with Auto Unlock—No WiFi Needed
Bluetooth Smart Lock with Auto Unlock and No WiFi Required
Looking for a reliable Bluetooth smart lock that offers seamless auto unlock features without the need for WiFi? The Wyze Lock Bolt stands out as an excellent choice for modern homes seeking convenience, security, and smart technology without relying on cloud connectivity. This page highlights the key features and benefits of the Wyze Lock Bolt and its related accessories, designed to enhance your home security effortlessly.
Wyze Lock Bolt: The Ultimate Bluetooth Smart Lock
Key Features and Benefits
Bluetooth Connectivity Without WiFi The Wyze Lock Bolt operates primarily via Bluetooth, meaning it does not require a WiFi connection to function. This ensures your lock remains secure and accessible even if your home internet is down or unavailable. Ultra-Fast Fingerprint Reader Unlock your door in less than a second with a simple tap on the ultra-fast fingerprint sensor. Say goodbye to fumbling with keys or remembering complicated codes. Luxurious Backlit Keypad with Anti-Peep Technology The solid metal exterior features a backlit keypad for easy nighttime use. Anti-peep technology allows you to enter extra digits before or after your code, preventing onlookers from guessing your access code. Auto-Lock for Peace of Mind Never worry about leaving your door unlocked again. The Wyze Lock Bolt includes an auto-lock timer that you can customize in the Wyze app. After your set delay, the lock automatically secures your door. Long Battery Life with USB-C Emergency Charging Powered by 4 AA batteries, the lock can last up to 12 months. If the batteries run low or die, a USB-C port allows for a quick emergency charge so you can still enter your home. Pick-Proof and Weatherproof Design The lock is fully pick-proof by eliminating the need for physical keys and is rated IPX5 for weather resistance, making it durable for outdoor use. Local App Control with Strong Security Control and monitor your lock via the Wyze app using Bluetooth. The lock uses hardware encryption to protect your fingerprint and code data, and two-factor authentication ensures only authorized users can access it.
Specifications at a Glance
FeatureDetails
ConnectivityBluetooth only (No WiFi needed)
Fingerprint CapacityUp to 50 fingerprints
Access CodesUp to 20 codes
Battery LifeUp to 12 months (4 AA batteries)
Weather ResistanceIPX5
Auto-Lock TimerCustomizable via app
Emergency ChargingUSB-C port
Installation TimeApprox. 20 minutes
Finish OptionsMatte Black, Satin Nickel
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Wyze Lock Bolt Lifestyle Secure your front door with Wyze Lock Bolt’s sleek design and smart features.
Accessories and Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning perfectly or to customize your installation, consider these essential accessories:
Wyze Lock Bolt Screws
A replacement set of screws designed specifically for the Wyze Lock Bolt, ensuring a secure and stable installation.
Wyze Lock Bolt Interior Assembly Battery Cover
This replacement battery cover fits the interior assembly of the Wyze Lock Bolt, helping protect the batteries and internal components.
Wyze Lock Bolt Interior Assembly Metal Plate
A metal plate that anchors the interior assembly to your door, providing additional stability and security.
Wyze Lock Replacement Part Kit
Includes various replacement parts compatible with the Wyze Lock, ideal for repairs or upgrades.
Why Choose Wyze Lock Bolt for Your Smart Home?
  • No WiFi Dependency: Unlike many smart locks, Wyze Lock Bolt works locally via Bluetooth, so you don’t need to worry about internet outages or cloud security risks.
  • Fast and Secure Access: Fingerprint unlocking and keypad entry provide multiple secure ways to enter your home quickly.
  • Auto-Lock Convenience: Automatically locks your door after a set time, giving you peace of mind.
  • Durable and Weatherproof: Built to withstand outdoor conditions and resist tampering.
  • Easy Installation: Replaces your existing deadbolt in about 20 minutes with no complicated wiring.
Wyze Lock Bolt App Control Control your Wyze Lock Bolt effortlessly with the Wyze app via Bluetooth.
Enhance Your Home Security with Wyze Front Porch Security Bundle
For a comprehensive smart home security solution, consider pairing the Wyze Lock Bolt with the Wyze Video Doorbell and Wyze Chime in the Front Porch Security Bundle. This bundle offers:
  • 1080p HD video monitoring of your front porch
  • Two-way audio to greet visitors remotely
  • Remote lock/unlock and lock history viewing via the Wyze app
  • Compatibility with Alexa and Google Assistant for voice control
This combination ensures your home is secure, accessible, and monitored without relying on WiFi for the lock itself.
Conclusion
The Wyze Lock Bolt is the perfect Bluetooth smart lock for those who want fast, secure, and keyless entry without the need for WiFi. Its fingerprint sensor, auto-lock feature, and robust security make it a top choice for modern homes. With easy installation and durable design, it’s a smart investment in your home’s safety and convenience.
ProductTypePrice (USD)DescriptionKey Features / NotesCompatibilityReturn Policy
Wyze Lock BoltConnected Home79.98Bluetooth smart lock replacing deadbolt with fingerprint reader and backlit keypadAuto-lock, anti-peep tech, pick-proof, weatherproofReplaces existing deadbolt30-day hassle-free returns
Wyze Lock Bolt ScrewsReplacement Parts2.99Set of screws for Wyze Lock BoltReplacement screws setWyze Lock Bolt30-day hassle-free returns
Wyze Lock Bolt Interior Assembly Battery CoverReplacement Parts9.99Replacement interior battery coverBattery cover replacementWyze Lock Bolt30-day hassle-free returns
Wyze Lock Bolt Interior Assembly Metal PlateReplacement Parts4.99Metal plate to anchor the interior assembly to the doorAnchoring metal plateWyze Lock Bolt30-day hassle-free returns
Wyze Lock Replacement Part KitReplacement Parts4.99 - 19.99Replacement part kit (includes Adapter Replacement Kit option)Replacement parts kit only compatible with Wyze LockWyze Lock30-day hassle-free returns
Does the Wyze Lock Bolt require WiFi to operate?No, the Wyze Lock Bolt operates exclusively via Bluetooth and does not require a WiFi connection. This ensures your lock remains functional and secure even if your home internet is down.
How does the auto-unlock feature work on the Wyze Lock Bolt?The Wyze Lock Bolt features an ultra-fast fingerprint reader that unlocks your door in less than a second. You can also use the backlit keypad with anti-peep technology for secure code entry, all without needing WiFi.
What security features does the Wyze Lock Bolt offer?The Wyze Lock Bolt provides multiple security features, including a pick-proof design with no physical keyhole, anti-peep keypad technology, hardware encryption for fingerprint and code data, and two-factor authentication for app access.
How long does the battery last on the Wyze Lock Bolt, and what happens if it runs out?The Wyze Lock Bolt is powered by 4 AA batteries that can last up to 12 months. If the batteries run low or die, you can use the USB-C emergency charging port to quickly power the lock and regain access.
Is the Wyze Lock Bolt weatherproof and suitable for outdoor use?Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance, making it durable and suitable for outdoor installation on your front door.
How many fingerprints and access codes can the Wyze Lock Bolt store?The Wyze Lock Bolt can store up to 50 fingerprints and up to 20 unique access codes, allowing multiple users to access your home securely.
Can I control the Wyze Lock Bolt remotely?The Wyze Lock Bolt is controlled locally via Bluetooth using the Wyze app. Remote control features are available when paired with other Wyze devices, such as the Wyze Video Doorbell, but the lock itself does not require or use WiFi.
How easy is it to install the Wyze Lock Bolt?The Wyze Lock Bolt is designed for easy installation and can replace your existing deadbolt in approximately 20 minutes with no complicated wiring required.
What accessories and replacement parts are available for the Wyze Lock Bolt?Accessories and replacement parts for the Wyze Lock Bolt include replacement screws, an interior assembly battery cover, an interior assembly metal plate, and a Wyze Lock Replacement Part Kit for repairs or upgrades.
What is the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle combines the Wyze Lock Bolt with the Wyze Video Doorbell and Wyze Chime, offering 1080p HD video monitoring, two-way audio, remote lock/unlock, lock history viewing, and compatibility with Alexa and Google Assistant for a comprehensive smart home security solution.
What finish options are available for the Wyze Lock Bolt?The Wyze Lock Bolt is available in Matte Black and Satin Nickel finishes, allowing you to choose the style that best matches your home décor.
What are the installation requirements for the Wyze Lock Bolt?Can the Wyze Lock Bolt be controlled remotely through the Wyze app?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Lock Bolt?
