Buy Wyze Lock Bolt Replacement Cover, Screws, Plate & Latch
Where to Buy Wyze Lock Bolt Replacement Parts: Cover, Screws, Plate, and Latch
If you own a Wyze Lock Bolt and need replacement parts such as the bolt replacement cover, screws, metal plate, or latch components, this guide will help you find exactly what you need. Wyze offers a range of genuine replacement parts designed specifically for the Wyze Lock Bolt, ensuring seamless compatibility and easy installation.
Wyze Lock Bolt Replacement Parts Overview
Wyze Lock Bolt is a smart deadbolt lock that combines convenience and security with features like a fingerprint sensor, backlit keypad, and auto-lock functionality. Over time, some parts like screws, battery covers, or interior assembly plates may need replacement due to wear or damage. Wyze provides these parts individually to keep your lock functioning perfectly without needing a full replacement.
Wyze Lock Bolt Interior Assembly Metal Plate
Secure Your Lock’s Interior Assembly
The Wyze Lock Bolt Interior Assembly Metal Plate is a crucial replacement part that anchors the interior assembly firmly to your door. This metal plate ensures the lock’s internal components stay stable and secure, maintaining the lock’s reliability and smooth operation.
  • Price: $4.99
  • Purpose: Anchors interior assembly to door
  • Available Quantities: 1 to 10 pieces
  • Return Policy: 30-day hassle-free returns
This metal plate is essential if you notice looseness or instability in your lock’s interior mechanism.
Wyze Lock Bolt Screws Replacement Set
Keep Your Lock Secure with Genuine Screws
For maintaining the structural integrity of your Wyze Lock Bolt, the Wyze Lock Bolt Screws replacement set is available. These screws are designed specifically for the Wyze Lock Bolt, ensuring perfect fit and durability.
  • Price: $2.99
  • Compatibility: Wyze Lock Bolt only
  • Includes: Set of screws for replacement
Replacing worn or missing screws can prevent your lock from becoming loose or malfunctioning.
Wyze Lock Bolt Interior Assembly Battery Cover
Protect Your Lock’s Power Source
The Wyze Lock Bolt Interior Assembly Battery Cover is a replacement cover designed to protect the battery compartment inside your lock. This cover keeps the batteries secure and prevents dust or moisture from entering.
  • Price: $9.99
  • Replacement Type: Interior battery cover
If your battery cover is cracked, lost, or damaged, this replacement ensures your lock remains powered and protected.
Why Choose Genuine Wyze Replacement Parts?
Using genuine Wyze replacement parts guarantees:
  • Perfect Fit: Designed specifically for Wyze Lock Bolt models.
  • Durability: Made with quality materials to last.
  • Easy Installation: Fits seamlessly without modification.
  • Warranty Support: Backed by Wyze’s return policies and customer support.
About the Wyze Lock Bolt Smart Lock
Before diving into replacement parts, here’s a quick overview of the Wyze Lock Bolt itself:
  • Type: Bluetooth smart deadbolt lock
  • Features: Ultra-fast fingerprint sensor, backlit keypad with anti-peep, auto-lock, built-in jam alarm, emergency one-time codes
  • Power Source: 4x AA batteries (included), lasting 10-12 months
  • Compatibility: Fits doors 1-3/8” to 1-3/4” thick, backset 2-3/8” or 2-3/4”
  • Weather Resistance: IPX5 rated keypad, suitable for outdoor use
  • Communication: Bluetooth 5.0 with 16 ft range
The Wyze Lock Bolt replaces your existing deadbolt, offering keyless convenience and enhanced security with smart features controlled via the Wyze app.
Wyze Lock Bolt Lifestyle Experience smart home security with Wyze Lock Bolt on your front door.
Enhance Your Home Security with Wyze Bundles
If you’re interested in a complete home security upgrade, consider the Essential Security Bundle or the Front Porch Security Bundle which include the Wyze Lock Bolt along with cameras and video doorbells for comprehensive protection.
Summary: Where to Buy Wyze Lock Bolt Replacement Parts
Replacement PartPriceDescription
Wyze Lock Bolt Interior Assembly Metal Plate$4.99Anchors interior assembly to door
Wyze Lock Bolt Screws$2.99Set of screws for lock assembly
Wyze Lock Bolt Interior Assembly Battery Cover$9.99Battery compartment cover
These parts are available individually to keep your Wyze Lock Bolt functioning smoothly and securely. Wyze Lock Bolt Keypad Wyze Lock Bolt keypad with backlit keys and fingerprint sensor.
Final Tips for Replacement and Maintenance
  • Always use genuine Wyze parts for best performance.
  • Follow Wyze’s installation instructions carefully.
  • Regularly check screws and covers for wear or damage.
  • Replace batteries promptly to avoid lockouts.
With these replacement parts, your Wyze Lock Bolt will continue to provide secure, keyless access for years to come.
FeatureWyze Lock BoltWyze Lock Bolt Interior Assembly Metal PlateWyze Lock Bolt ScrewsWyze Lock Bolt Interior Assembly Battery Cover
Product TypeConnected Home / Smart LockReplacement PartsReplacement PartsReplacement Parts
DescriptionBluetooth smart lock replacing deadbolt with fingerprint reader, backlit keypad, auto-lock, weatherproof, pick-proofMetal plate to anchor the interior assembly to the doorSet of screws for Wyze Lock BoltInterior battery cover replacement for Wyze Lock Bolt
Price$79.98$4.99$2.99$9.99
CompatibilityReplaces existing deadboltCompatible with Wyze Lock BoltCompatible with Wyze Lock BoltCompatible with Wyze Lock Bolt
Key FeaturesFingerprint unlock, backlit keypad, auto-lock, weatherproof (IPX5), pick-proof, up to 12 months battery life, USB-C charging portAnchors interior assembly to doorReplacement screws setReplacement battery cover
Installation TimeAbout 20 minutesN/AN/AN/A
Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns
Where can I buy genuine Wyze Lock Bolt replacement parts?You can purchase genuine Wyze Lock Bolt replacement parts, such as the interior assembly metal plate, screws, and battery cover, directly from Wyze. These parts are designed specifically for the Wyze Lock Bolt to ensure perfect fit and easy installation.
What replacement parts are available for the Wyze Lock Bolt?Wyze offers several replacement parts for the Wyze Lock Bolt, including the interior assembly metal plate, screws replacement set, and interior assembly battery cover. Each part is sold individually to help you maintain your lock’s performance.
Why should I use genuine Wyze replacement parts for my Lock Bolt?Genuine Wyze replacement parts are designed for perfect compatibility with the Wyze Lock Bolt, ensuring durability, easy installation, and continued warranty support. Using authentic parts helps maintain your lock’s security and functionality.
How much do Wyze Lock Bolt replacement parts cost?The Wyze Lock Bolt Interior Assembly Metal Plate costs $4.99, the Screws Replacement Set is $2.99, and the Interior Assembly Battery Cover is $9.99. All prices are for individual parts and are subject to Wyze’s 30-day hassle-free return policy.
What is the purpose of the Wyze Lock Bolt Interior Assembly Metal Plate?The Wyze Lock Bolt Interior Assembly Metal Plate anchors the lock’s interior assembly to your door, ensuring stability and reliable operation. It is essential if you notice looseness or instability in your lock’s interior mechanism.
What does the Wyze Lock Bolt Screws Replacement Set include?The Wyze Lock Bolt Screws Replacement Set includes a set of screws specifically designed for the Wyze Lock Bolt. These screws help maintain the structural integrity of your lock and prevent it from becoming loose or malfunctioning.
What is the function of the Wyze Lock Bolt Interior Assembly Battery Cover?The Wyze Lock Bolt Interior Assembly Battery Cover protects the battery compartment inside your lock, keeping the batteries secure and preventing dust or moisture from entering. It is a direct replacement if your original cover is lost or damaged.
Are Wyze Lock Bolt replacement parts easy to install?Yes, all genuine Wyze Lock Bolt replacement parts are designed for easy installation and seamless compatibility with your existing lock. No modifications are needed.
What is the return policy for Wyze Lock Bolt replacement parts?Wyze offers a 30-day hassle-free return policy on all Lock Bolt replacement parts, allowing you to shop with confidence.
How do I maintain my Wyze Lock Bolt for long-lasting performance?To keep your Wyze Lock Bolt functioning smoothly, always use genuine Wyze replacement parts, follow installation instructions, regularly check screws and covers for wear, and replace batteries promptly to avoid lockouts.
What are the benefits of using genuine Wyze replacement parts for my lock?Can you explain the installation process for the Wyze Lock Bolt replacement parts?What is the return policy for Wyze Lock Bolt replacement parts?
