Where to Buy Authentic Wyze Lock Bolt Replacement Screws and Metal Plates
If you own a Wyze Lock Bolt and need authentic replacement parts such as screws or metal plates, it’s essential to choose genuine Wyze components to ensure perfect compatibility and maintain your lock’s security and performance. Below, we highlight the key Wyze products that provide these replacement parts, along with the main Wyze Lock Bolt smart lock itself for context.
Wyze Lock Bolt: The Smart Deadbolt Replacement
The Wyze Lock Bolt is a cutting-edge Bluetooth smart lock designed to replace your existing deadbolt with advanced features for convenience and security.
Key Features:
- Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a quick fingerprint scan.
- Backlit Keypad with Anti-Peep: Enter your code discreetly even in low light.
- Auto-Lock Function: Automatically locks your door if you forget.
- Built-in Alarm: Detects jam attempts and alerts you.
- App Integration: View lock/unlock history and control remotely via the Wyze app.
- Weather Resistance: Rated IPX5, suitable for various climates.
- Battery Life: Powered by 4 AA batteries lasting 10-12 months.
Specifications:
- Available in Matte Black and Satin Nickel finishes.
- Fits doors with thickness from 1-3/8” to 1-3/4”.
- Compatible with backsets of 2-3/8” and 2-3/4”.
- Bluetooth 5.0 communication with a 16 ft range.
The Wyze Lock Bolt combines smart technology with ease of use, making it a top choice for modern home security.
Secure your home with Wyze Lock Bolt smart lock
Wyze Lock Bolt Screws: Genuine Replacement Set
If you need to replace the screws that secure your Wyze Lock Bolt, the
Wyze Lock Bolt Screws set is the authentic solution designed specifically for this smart lock.
Why Choose Wyze Lock Bolt Screws?
- Perfect Fit: Made to match the original screws for secure installation.
- Durability: Manufactured to maintain the lock’s integrity and safety.
- Affordable: Priced at $2.99 for a set.
- Hassle-Free Returns: 30-day return policy for peace of mind.
- Compatibility: Exclusively compatible with the Wyze Lock Bolt.
Replacing worn or lost screws with genuine Wyze parts ensures your lock remains firmly anchored and functions flawlessly.
Wyze Lock Bolt Interior Assembly Metal Plate
The
Wyze Lock Bolt Interior Assembly Metal Plate is a crucial replacement part that anchors the interior assembly of your lock to the door.
Features:
- Strong Anchor: Provides a stable base for the interior lock components.
- Easy Installation: Designed to fit seamlessly with the Wyze Lock Bolt.
- Affordable Price: Available for $4.99.
- Multiple Quantities: Purchase from 1 up to 10 plates as needed.
- 30-Day Returns: Buy with confidence thanks to hassle-free returns.
Using the authentic metal plate replacement guarantees your lock’s interior assembly remains secure and stable, preventing any operational issues.
Why Buy Authentic Wyze Replacement Parts?
Using genuine Wyze replacement screws and metal plates ensures your Wyze Lock Bolt maintains its high security standards and smooth operation. Non-authentic parts may not fit correctly or could compromise the lock’s durability and safety features.
Summary of Authentic Wyze Lock Bolt Replacement Parts
Product | Price | Purpose | Key Benefit |
Wyze Lock Bolt Screws | $2.99 | Replacement screws set | Perfect fit, durable |
Wyze Lock Bolt Interior Metal Plate | $4.99 | Anchors interior assembly | Secure and stable installation |
Enhance Your Home Security with Wyze
For a complete smart home security upgrade, consider the Wyze Lock Bolt along with other Wyze smart devices. Authentic replacement parts keep your system running smoothly and securely.
Wyze Lock Bolt keypad with smart app control
Final Thoughts
When searching for
authentic Wyze Lock Bolt replacement screws and metal plates, purchasing directly from authorized Wyze product collections guarantees genuine parts, compatibility, and quality. Keep your smart lock functioning at its best with these essential replacement components.
Where can I buy authentic Wyze Lock Bolt replacement screws and metal plates?
You can purchase authentic Wyze Lock Bolt replacement screws and metal plates directly from authorized Wyze product collections. Buying from official sources ensures you receive genuine parts that are fully compatible with your Wyze Lock Bolt, maintaining its security and performance.Why should I use genuine Wyze Lock Bolt replacement parts?
Using genuine Wyze Lock Bolt replacement screws and metal plates ensures your smart lock maintains its high security standards, durability, and smooth operation. Non-authentic parts may not fit correctly and could compromise the lock’s safety features.What are the features of the Wyze Lock Bolt Screws replacement set?
The Wyze Lock Bolt Screws replacement set is designed specifically for the Wyze Lock Bolt, offering a perfect fit and secure installation. The screws are durable, affordable at $2.99 per set, and come with a 30-day hassle-free return policy.What is the purpose of the Wyze Lock Bolt Interior Assembly Metal Plate?
The Wyze Lock Bolt Interior Assembly Metal Plate anchors the interior assembly of your lock to the door, providing a stable and secure base for the lock’s components. It is easy to install, available for $4.99, and can be purchased in quantities from 1 to 10 plates.Are Wyze Lock Bolt replacement screws and metal plates compatible with other locks?
No, Wyze Lock Bolt replacement screws and metal plates are exclusively designed for the Wyze Lock Bolt smart lock. Using them with other locks is not recommended, as they may not fit or function properly.What are the benefits of replacing worn or lost Wyze Lock Bolt screws with authentic parts?
Replacing worn or lost screws with authentic Wyze Lock Bolt screws ensures your lock remains firmly anchored, functions flawlessly, and maintains its intended security features.How do I ensure I am purchasing genuine Wyze Lock Bolt replacement parts?
To ensure you are purchasing genuine Wyze Lock Bolt replacement parts, buy directly from the official Wyze website or authorized Wyze retailers. This guarantees compatibility, quality, and access to customer support and return policies.What is the return policy for Wyze Lock Bolt replacement screws and metal plates?
Both the Wyze Lock Bolt Screws and the Interior Assembly Metal Plate come with a 30-day hassle-free return policy, allowing you to buy with confidence.How much do Wyze Lock Bolt replacement screws and metal plates cost?
Wyze Lock Bolt replacement screws are priced at $2.99 per set, while the Interior Assembly Metal Plate is available for $4.99 each. Multiple quantities of the metal plate can be purchased as needed.
