Smart Locks for Remote Door Access and Entry History Review
When it comes to securing your home with convenience and advanced technology, smart locks that offer remote door access and detailed entry history are essential. Whether you want to unlock your door from anywhere or keep track of who enters and when, the right smart lock can transform your home security experience.
Wyze offers cutting-edge smart lock solutions designed to provide seamless remote access, robust security features, and easy integration with your smart home ecosystem.
Wyze Lock Bolt: Ultra-Fast, Secure, and Convenient
Key Features and Benefits
- Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a touch of your finger, eliminating the need for keys.
- Backlit Keypad with Anti-Peep: Enter your code discreetly even in low light, with a keypad designed to prevent prying eyes.
- Remote Lock/Unlock & History Tracking: Use the Wyze app to lock or unlock your door from anywhere and review detailed lock/unlock history for peace of mind.
- Auto-Lock Function: Never worry about forgetting to lock your door; the Wyze Lock Bolt automatically locks after a set time.
- Built-in Jam Detection Alarm: Alerts you if the lock is jammed or tampered with.
- Emergency One-Time Codes: Provide temporary access to guests or service providers without sharing permanent codes.
- Easy Installation: Replaces your existing deadbolt without complicated wiring.
Technical Specifications
- Communication: Bluetooth 5.0 with a 16 ft range.
- Power Source: 4x AA batteries included, lasting 10-12 months.
- Weather Resistance: Rated IPX5, suitable for various climates.
- Operating Temperature: Keypad works from -13°F to 122°F.
- Door Compatibility: Fits doors 1-3/8" to 1-3/4" thick with standard deadbolt dimensions.
Style Options
Experience the perfect blend of security and convenience with Wyze Lock Bolt, designed to keep your home safe while giving you effortless control.
Alt text: Smart lock on front door controlled remotely by smartphone
The Front Porch Security Bundle: Comprehensive Smart Home Access Management
What’s Included?
- Wyze Lock: Remote locking and unlocking with entry history.
- Wyze Video Doorbell: View your front porch in crisp 1080p HD with two-way audio.
- Wyze Chime: Hear doorbell alerts anywhere in your home.
Why Choose This Bundle?
- Complete Front Door Security: Monitor visitors and control access all from the Wyze app.
- Remote Access & Notifications: Unlock your door remotely and receive instant alerts when someone arrives or locks/unlocks the door.
- Works with Alexa and Google Assistant: Voice control your lock and doorbell for hands-free convenience.
- Weather-Resistant Devices: Designed to withstand outdoor conditions ensuring reliable performance.
Technical Highlights
- Wyze Lock Communication: Bluetooth and Zigbee with up to 50 ft range to gateway.
- Video Doorbell: 1080p HD video, night vision, 120° vertical and 88° horizontal field of view.
- Chime Sounds: Multiple customizable sounds including intruder alarm.
This bundle is ideal for those who want a fully integrated smart home entry system combining video surveillance and smart lock technology.
Alt text: Family greeting guests at front porch secured by smart lock and video doorbell
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning smoothly, Wyze offers essential replacement parts:
- Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly securely to your door.
- Wyze Lock Bolt Screws: Replacement screw set compatible with Wyze Lock Bolt.
- Wyze Lock Bolt Interior Assembly Battery Cover: Protects the battery compartment inside the lock.
- Wyze Lock Replacement Part Kit: Includes various components for maintenance and repair.
These parts ensure your smart lock remains reliable and easy to maintain over time.
Why Choose Wyze Smart Locks for Remote Access?
Wyze smart locks combine advanced biometric technology, app-based remote control, and detailed access logs to give you full control over your home’s entry points. With features like ultra-fast fingerprint recognition, auto-locking, and emergency codes, you can secure your home effortlessly while staying connected no matter where you are.
Wyze’s smart lock solutions are designed for easy installation, long battery life, and compatibility with popular smart home assistants, making them a top choice for modern homeowners seeking convenience and security.
Alt text: Backlit keypad and fingerprint sensor on Wyze Lock Bolt
Summary
- Wyze Lock Bolt: Fast fingerprint unlocking, remote access, auto-lock, and entry history.
- Front Porch Security Bundle: Combines Wyze Lock with video doorbell and chime for full front door security.
- Replacement Parts: Keep your Wyze Lock Bolt in top condition with official replacement components.
Upgrade your home security today with Wyze smart locks designed for remote door access and comprehensive entry history review.
What are the main benefits of using Wyze smart locks for remote door access?
Wyze smart locks offer convenient remote door access, allowing you to lock or unlock your door from anywhere using the Wyze app. They also provide detailed entry history, robust security features like ultra-fast fingerprint recognition, auto-locking, and emergency one-time codes for guests. These features help you monitor and control your home’s entry points with ease and peace of mind.How does the Wyze Lock Bolt enhance home security?
The Wyze Lock Bolt enhances home security with an ultra-fast fingerprint sensor for instant unlocking, a backlit anti-peep keypad for discreet code entry, auto-lock functionality, and a built-in jam detection alarm. It also allows you to review detailed lock and unlock history through the Wyze app, ensuring you always know who accessed your home and when.Can I control Wyze smart locks remotely?
Yes, Wyze smart locks can be controlled remotely via the Wyze app. You can lock or unlock your door from anywhere, provide temporary access codes to guests, and receive instant notifications about lock activity, making it easy to manage your home’s security even when you’re away.What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes a Wyze Lock for remote locking and unlocking with entry history, a Wyze Video Doorbell for 1080p HD video and two-way audio, and a Wyze Chime for customizable doorbell alerts. This bundle provides comprehensive front door security and seamless integration with the Wyze app.Are Wyze smart locks compatible with smart home assistants?
Yes, Wyze smart locks work with popular smart home assistants such as Alexa and Google Assistant. This allows you to control your lock and video doorbell using voice commands for added convenience.How easy is it to install the Wyze Lock Bolt?
The Wyze Lock Bolt is designed for easy installation and replaces your existing deadbolt without complicated wiring. It fits doors 1-3/8" to 1-3/4" thick with standard deadbolt dimensions, making it a straightforward upgrade for most homes.What replacement parts are available for the Wyze Lock Bolt?
Wyze offers several replacement parts for the Lock Bolt, including the interior assembly metal plate, replacement screw set, interior assembly battery cover, and a comprehensive replacement part kit. These parts help maintain and repair your smart lock for long-term reliability.How long do the batteries last in the Wyze Lock Bolt?
The Wyze Lock Bolt is powered by four AA batteries, which typically last between 10 to 12 months depending on usage. The lock is designed for energy efficiency to minimize maintenance.Is the Wyze Lock Bolt weather resistant?
Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance, making it suitable for various climates and outdoor conditions. The keypad operates in temperatures ranging from -13°F to 122°F.How does the entry history feature work on Wyze smart locks?
The entry history feature on Wyze smart locks allows you to review a detailed log of who has locked or unlocked your door and when. This information is accessible through the Wyze app, providing you with greater visibility and control over your home’s security.
