Buy Genuine Wyze Lock Bolt Battery Cover & Metal Plate Parts
Buy Genuine Wyze Lock Bolt Replacement Parts: Battery Cover & Metal Plate
When it comes to securing your home with smart technology, the Wyze Lock Bolt stands out as a top choice. If you need to maintain or repair your Wyze Lock Bolt, purchasing genuine replacement parts like the interior battery cover and metal plate ensures your lock continues to function flawlessly and securely. This page highlights the key features of the Wyze Lock Bolt and its essential replacement parts, helping you make an informed purchase.
Wyze Lock Bolt: The Smart Deadbolt Upgrade
The Wyze Lock Bolt is a Bluetooth-enabled smart lock designed to replace your traditional deadbolt with advanced security and convenience features.
Key Features:
  • Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a quick fingerprint scan.
  • Backlit Keypad with Anti-Peep: Enter your code discreetly even in low light.
  • Auto-Lock Function: Automatically locks your door if you forget, enhancing security.
  • Lock and Unlock History: Monitor access through the Wyze app.
  • Built-in Alarm: Detects jam attempts and alerts you immediately.
  • Emergency One-Time Codes: Provide temporary access to guests or service personnel.
  • Weather Resistance: Rated IPX5, suitable for various climates.
  • Battery Life: Powered by 4x AA batteries (included), lasting 10-12 months.
Specifications:
  • Colors Available: Matte Black, Satin Nickel
  • Weight: 2.75 lbs
  • Bluetooth 5.0 Communication: Reliable connection up to 16 ft.
  • Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick, with backset options of 2-3/8” or 2-3/4”.
  • Operating Temperature: Keypad works from -13°F to 122°F.
Experience the perfect blend of security and convenience with the Wyze Lock Bolt, designed for modern smart homes.
Wyze Lock Bolt Lifestyle Secure your front door with Wyze Lock Bolt’s smart technology.
Wyze Lock Bolt Interior Assembly Battery Cover
The Wyze Lock Bolt Interior Assembly Battery Cover is a genuine replacement part designed specifically for the Wyze Lock Bolt. This cover protects the battery compartment inside the lock, ensuring your batteries stay secure and the lock operates without interruption.
Why Choose the Genuine Battery Cover?
  • Perfect Fit: Made to match the original design for seamless installation.
  • Durability: Crafted to withstand daily use and protect internal components.
  • Compatibility: Exclusively compatible with Wyze Lock Bolt.
  • Affordable: Priced at $9.99 with a 30-day hassle-free return policy.
Replacing your battery cover with an authentic part helps maintain the lock’s integrity and prolongs its lifespan.
Wyze Lock Bolt Interior Assembly Metal Plate
The Wyze Lock Bolt Interior Assembly Metal Plate is a crucial replacement part that anchors the interior assembly securely to your door.
Features:
  • Strong Metal Construction: Provides sturdy support for the lock’s interior mechanism.
  • Easy Installation: Designed for quick replacement without professional help.
  • Compatibility: Made exclusively for the Wyze Lock Bolt.
  • Affordable Price: Available for $4.99.
Using the original metal plate replacement ensures your lock remains firmly attached and functions reliably.
Why Buy Genuine Wyze Lock Bolt Replacement Parts?
Using genuine replacement parts like the battery cover and metal plate guarantees compatibility, durability, and optimal performance of your Wyze Lock Bolt. Avoid the risks of third-party parts that may not fit properly or could compromise your home security.
Summary of Wyze Lock Bolt Replacement Parts
ProductPricePurpose
Wyze Lock Bolt Interior Battery Cover$9.99Protects battery compartment
Wyze Lock Bolt Interior Metal Plate$4.99Anchors interior assembly
Investing in these genuine parts keeps your smart lock working smoothly and your home secure.
Wyze Lock Bolt Keypad Wyze Lock Bolt’s backlit keypad and fingerprint sensor for quick access.
Final Thoughts
The Wyze Lock Bolt is a smart, reliable upgrade for your home security, and maintaining it with genuine replacement parts like the interior battery cover and metal plate is essential. These parts are designed to fit perfectly and keep your lock functioning at its best, ensuring your peace of mind. Upgrade your home security today with the Wyze Lock Bolt and its trusted replacement parts!
FeatureWyze Lock BoltWyze Lock Bolt Interior Assembly Battery CoverWyze Lock Bolt Interior Assembly Metal Plate
TypeConnected Home Smart LockReplacement PartReplacement Part
DescriptionBluetooth smart lock replacing deadbolt with backlit keypad and fingerprint reader; auto-lock featureReplacement interior battery coverMetal plate to anchor the interior assembly to the door
Price$62.86$9.99$4.99
Color/Style VariantsMatte Black, Satin NickelDefault TitleDefault Title
CompatibilityReplaces existing deadbolt on most exterior doorsCompatible with Wyze Lock BoltCompatible with Wyze Lock Bolt
Key FeaturesFingerprint unlock, backlit keypad, auto-lock, pick-proof, weatherproof (IPX5), up to 12 months battery life, USB-C charging portReplacement part onlyReplacement part only
Installation TimeAbout 20 minutesN/AN/A
Warranty/Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns
Additional NotesBluetooth connection required for app featuresReplacement part to maintain lock functionalityAnchors interior assembly to door
What are the key features of the Wyze Lock Bolt smart deadbolt?The Wyze Lock Bolt offers advanced security and convenience features, including an ultra-fast fingerprint sensor, backlit keypad with anti-peep technology, auto-lock function, lock and unlock history via the Wyze app, built-in alarm for jam attempts, emergency one-time codes, weather resistance (IPX5), and a battery life of 10-12 months powered by 4x AA batteries.
Why should I buy genuine Wyze Lock Bolt replacement parts?Genuine Wyze Lock Bolt replacement parts, such as the interior battery cover and metal plate, ensure perfect compatibility, durability, and optimal performance. Using authentic parts helps maintain your lock’s integrity, prolongs its lifespan, and avoids the risks associated with third-party parts that may not fit properly or could compromise your home security.
What is the purpose of the Wyze Lock Bolt Interior Assembly Battery Cover?The Wyze Lock Bolt Interior Assembly Battery Cover is designed to protect the battery compartment inside your lock. It ensures your batteries stay secure and the lock operates without interruption. This genuine replacement part is made for a perfect fit, is durable, and is exclusively compatible with the Wyze Lock Bolt.
How much does the Wyze Lock Bolt Interior Assembly Battery Cover cost?The Wyze Lock Bolt Interior Assembly Battery Cover is priced at $9.99 and comes with a 30-day hassle-free return policy.
What is the function of the Wyze Lock Bolt Interior Assembly Metal Plate?The Wyze Lock Bolt Interior Assembly Metal Plate anchors the interior assembly securely to your door. Made from strong metal, it provides sturdy support for the lock’s interior mechanism and ensures reliable operation. This replacement part is designed exclusively for the Wyze Lock Bolt.
How much does the Wyze Lock Bolt Interior Assembly Metal Plate cost?The Wyze Lock Bolt Interior Assembly Metal Plate is available for $4.99.
Are the Wyze Lock Bolt replacement parts easy to install?Yes, both the Wyze Lock Bolt Interior Assembly Battery Cover and Metal Plate are designed for easy installation, allowing you to replace them quickly without professional help.
Are the Wyze Lock Bolt replacement parts compatible with other locks?No, the Wyze Lock Bolt Interior Assembly Battery Cover and Metal Plate are exclusively compatible with the Wyze Lock Bolt and are not designed for use with other locks.
What are the available colors and specifications for the Wyze Lock Bolt?The Wyze Lock Bolt is available in Matte Black and Satin Nickel. It weighs 2.75 lbs, uses Bluetooth 5.0 for communication up to 16 ft, fits doors 1-3/8” to 1-3/4” thick with backset options of 2-3/8” or 2-3/4”, and operates in temperatures from -13°F to 122°F.
Can you tell me more about the installation process for the Wyze Lock Bolt replacement parts?What are the benefits of using genuine replacement parts for the Wyze Lock Bolt?Are there any warranties or guarantees on the Wyze Lock Bolt replacement parts?
