Best Doorbell Chimes Compatible with Wyze Wired Video Doorbell
What Doorbell Chime Works with Wyze Wired Video Doorbell?
If you own a Wyze Wired Video Doorbell and are looking for the perfect doorbell chime to complement it, this guide will help you understand your options. Wyze offers several chime accessories designed to work seamlessly with their wired video doorbells, ensuring you never miss a visitor at your door.
Wyze Wired Video Doorbell Overview
The Wyze Video Doorbell (Wired) is a compact yet powerful smart doorbell camera that delivers full HD 1080p video quality with a 2K sensor (2048 x 1536). It features a wide 120° vertical by 88° horizontal field of view, allowing you to see your front porch clearly. Equipped with two-way audio, noise and echo cancellation, and night vision with infrared LEDs, it ensures you can communicate and monitor your doorstep day or night.
  • Video Quality: 1080p full HD with 8x digital zoom
  • Field of View: 120° vertical x 88° horizontal
  • Audio: Built-in speaker and microphone with two-way communication
  • Weather Resistance: IP65 rated for outdoor durability
  • Connectivity: Direct Wi-Fi 2.4 GHz (802.11 b/g/n)
  • Power: Hardwired (16V-24V AC)
  • Compatibility: Works with Alexa, Google Assistant, and IFTTT
Note: After installation, your existing mechanical chime will no longer work with this wired doorbell.
Compatible Doorbell Chimes for Wyze Wired Video Doorbell
Wyze Chime (Standalone)
The Wyze Chime is the dedicated chime accessory designed specifically for the Wyze Wired Video Doorbell. It is a standalone chime unit that plugs into a standard US power outlet and provides audible alerts when someone presses your doorbell.
  • Compatibility: Only works with Wyze Video Doorbell (Wired)
  • Incompatibility: Does NOT work with Wyze Video Doorbell Pro or Wyze Video Doorbell v2
  • Sounds: Offers a variety of chime tones including modern, classic, animal sounds, and automation alerts
  • Size & Weight: Compact and lightweight for easy placement
  • Power Source: Standard US power outlet (100V-240V, 0.1A, 50/60Hz)
This chime is ideal if you want a simple plug-and-play solution that pairs perfectly with your Wyze Wired Doorbell.
Wyze Universal Wi-Fi Chime
For a more versatile and wireless option, the Wyze Universal Wi-Fi Chime works with all Wyze Cams and doorbells, including the wired video doorbell. It connects over Wi-Fi, eliminating the need for complicated wiring.
  • Installation: Easy plug-in setup, no wiring required
  • Compatibility: Works with all Wyze cameras and doorbells
  • Tones: 17 different chime tones to choose from
  • Smart Automations: Can chime based on camera detections, not just doorbell presses
  • Connectivity: Wi-Fi (2.4 GHz), Bluetooth BLE 5.0
  • Power Input: 10-24V AC, 10VA 60Hz
  • Indoor Use: Designed for indoor placement
This chime is perfect if you want flexibility and smart home integration, including voice assistant compatibility with Alexa and Google Assistant.
Wyze Chime Controller (For Wyze Video Doorbell v2)
While the Wyze Chime Controller is not compatible with the Wyze Wired Video Doorbell, it is important to note it works exclusively with the Wyze Video Doorbell v2 and Duo Cam Doorbell. It acts as a bridge to connect your doorbell to nearly any mechanical chime.
  • Compatibility: Only with Wyze Video Doorbell v2 and Duo Cam Doorbell
  • Installation: Easy wiring installation
  • Power: AC16V/AC24V, ≥10VA
  • Size: Compact controller unit
If you have the Wyze Video Doorbell v2, this controller allows you to use your existing mechanical chime, but it is not suitable for the wired doorbell model.
Summary: Best Chime for Wyze Wired Video Doorbell
For the Wyze Wired Video Doorbell, the Wyze Chime (Standalone) is the recommended and compatible chime accessory. It is designed to work flawlessly with this doorbell model, providing clear and customizable chime sounds. If you prefer a wireless and smart-enabled chime, the Wyze Universal Wi-Fi Chime is also compatible and offers additional smart features and easy installation without wiring.
Enhance Your Home Security Setup
Pairing your Wyze Wired Video Doorbell with the right chime ensures you never miss a visitor or delivery. Whether you choose the dedicated Wyze Chime for a straightforward alert or the Universal Wi-Fi Chime for smart home integration, Wyze provides reliable and easy-to-install options tailored to your needs.
Experience peace of mind with Wyze’s smart doorbell and chime solutions that combine convenience, security, and smart technology.
Smart Home Doorbell Alert Alt text: Person receiving doorbell alert on smartphone inside home
FeatureWyze Universal Wi-Fi ChimeWyze Video Doorbell v2Wyze Chime ControllerWyze ChimeWyze Video Doorbell (Wired)
TypeAccessoryCameraAccessoryAccessoryCamera
Price$19.98$44.98$17.99$13.99$29.99 (Doorbell Only) / $34.99 (Doorbell + Chime)
Video ResolutionN/A2K (2048 x 1536)N/AN/A1080p Full HD (2048 x 1536 sensor)
AudioN/ATwo-way audioN/AN/ATwo-way audio with noise/echo cancellation
PowerPlug-in (Wi-Fi Chime)Wired (16V-24V AC, ≥10VA)Wired (AC16V/AC24V, ≥10VA)Wired (Standard US Power Outlet 100V-240V)Wired (Standard US Power Outlet 100V-240V)
InstallationPlug-in, no wiringWired installationEasy wiring installationWired installationWired installation
CompatibilityWorks with all Wyze Cams and DoorbellsCompatible with Wyze Chime ControllerOnly compatible with Wyze Video Doorbell v2 and Duo Cam DoorbellOnly works with Wyze Video Doorbell (Wired)Works with existing mechanical chime (existing chime will not work after installation)
Chime FunctionalityWi-Fi chime with smart automationsIncludes chime controller to use existing chimeMechanical chime controllerMechanical chimeMechanical chime (existing chime disabled)
Local StorageN/AmicroSD slot, up to 256GBN/AN/AmicroSD slot, up to 256GB
Motion DetectionYes (via camera integration)Yes, with pre-roll recordingN/AN/AYes
Weather ResistanceN/AIP65Operating temp -20°C to 50°CN/AIP65
DimensionsN/A4.3in x 1.7in x 0.9in (110mm x 44mm x 24mm)47mm x 32mm x 15mm2" x 2" x 1.4"N/A
WeightN/A1.7 oz / 49gN/A2.0 oz / 56gN/A
Special FeaturesNo wiring, smart automations, chimes on person detection2K video, two-way audio, motion-activated voice deterrence, pre-roll recording, Alexa/Google integrationCompatible with nearly every mechanical chimeStandalone mechanical chime1080p HD, two-way audio, night vision, Alexa/Google integration
Included Items1x Wyze Universal Wi-Fi ChimeDoorbell + Chime Controller, wall plate, wedge, wire caps, screws, quick start guide1x Chime controller unit1x Wyze ChimeDoorbell, wall plate, wedge, wire caps, screws, quick start guide
Compatible ProductsAll Wyze Cams and DoorbellsWorks with Wyze Chime ControllerWyze Video Doorbell v2, Duo Cam DoorbellWyze Video Doorbell (Wired) onlyN/A
What doorbell chime is compatible with the Wyze Wired Video Doorbell?The Wyze Chime (Standalone) and the Wyze Universal Wi-Fi Chime are both compatible with the Wyze Wired Video Doorbell. The Wyze Chime is a dedicated accessory designed specifically for this model, while the Universal Wi-Fi Chime offers wireless installation and smart home integration.
Can I use my existing mechanical chime with the Wyze Wired Video Doorbell?No, after installing the Wyze Wired Video Doorbell, your existing mechanical chime will no longer work. You will need to use a compatible chime accessory such as the Wyze Chime (Standalone) or the Wyze Universal Wi-Fi Chime.
What features does the Wyze Chime (Standalone) offer for the Wyze Wired Video Doorbell?The Wyze Chime (Standalone) plugs into a standard US power outlet and provides a variety of chime tones, including modern, classic, animal sounds, and automation alerts. It is compact, easy to install, and designed exclusively for the Wyze Wired Video Doorbell.
Is the Wyze Universal Wi-Fi Chime compatible with the Wyze Wired Video Doorbell?Yes, the Wyze Universal Wi-Fi Chime is compatible with the Wyze Wired Video Doorbell. It connects over Wi-Fi, offers 17 different chime tones, supports smart automations, and can be used with all Wyze cameras and doorbells.
Can I use the Wyze Chime Controller with the Wyze Wired Video Doorbell?No, the Wyze Chime Controller is not compatible with the Wyze Wired Video Doorbell. It is designed exclusively for the Wyze Video Doorbell v2 and Duo Cam Doorbell.
What are the power requirements for the Wyze Wired Video Doorbell?The Wyze Wired Video Doorbell requires a hardwired power source of 16V-24V AC. It is designed for direct connection to your existing doorbell wiring.
Does the Wyze Wired Video Doorbell work with Alexa or Google Assistant?Yes, the Wyze Wired Video Doorbell is compatible with Alexa, Google Assistant, and IFTTT, allowing for smart home integration and voice control.
What are the main features of the Wyze Wired Video Doorbell?The Wyze Wired Video Doorbell offers 1080p full HD video with a 2K sensor, a 120° vertical by 88° horizontal field of view, two-way audio with noise and echo cancellation, night vision, IP65 weather resistance, and direct Wi-Fi connectivity.
Is the Wyze Chime (Standalone) compatible with Wyze Video Doorbell Pro or Wyze Video Doorbell v2?No, the Wyze Chime (Standalone) is only compatible with the Wyze Wired Video Doorbell and does not work with the Wyze Video Doorbell Pro or Wyze Video Doorbell v2.
How do I install a chime for the Wyze Wired Video Doorbell?To install a chime for the Wyze Wired Video Doorbell, simply plug the Wyze Chime (Standalone) or Wyze Universal Wi-Fi Chime into a standard power outlet, pair it with your doorbell through the Wyze app, and select your preferred chime tone.
What are the different chime tones available for the Wyze Chime?Can the Wyze Universal Wi-Fi Chime be used outdoors?Do you have any deals, ongoing sales, discounts, or promotions?
