Wired Doorbell Replacement for Wyze Duo Cam with Chime Support
Wired Doorbell Replacement Supporting Electronic Chime for Wyze Duo Cam Doorbell
If you're looking to replace your wired doorbell with a solution that supports electronic chime connection and works seamlessly with the Wyze Duo Cam Doorbell, Wyze offers the perfect combination of products designed for easy installation, smart features, and reliable performance. This guide highlights the best Wyze products tailored for your needs, focusing on compatibility, installation ease, and smart home integration.
Wyze Universal Wi-Fi Chime: The Ultimate Wireless Chime Solution
Effortless Setup Without Wiring Hassles
The Wyze Universal Wi-Fi Chime is designed to eliminate complicated wiring. Simply plug it in anywhere in your home and instantly receive doorbell alerts. This makes it an ideal replacement for traditional wired chimes, especially if you want to avoid rewiring or drilling.
Smart Automations for Enhanced Security
Beyond just ringing when someone presses your doorbell, this chime can be set to alert you when your Wyze cameras detect a person, even if they don’t press the doorbell. This feature is perfect for monitoring package deliveries or unexpected visitors.
Compatibility and Flexibility
  • Works with all Wyze cameras, including the Duo Cam Doorbell.
  • Supports smart automations via the Wyze app.
  • Portable and can be placed anywhere with a power outlet.
Never miss a ding-dong again with this convenient, fuss-free chime that keeps you connected to your home no matter where you are.
Family enjoying smart home security
Wyze Video Doorbell v2: Wired Doorbell with Advanced Features
Crisp 2K Video Quality and Wide Field of View
The Wyze Video Doorbell v2 offers a sharp 2K resolution (2048 x 1536) with a wide 135° horizontal and 103° vertical field of view, ensuring you capture every detail at your doorstep.
Wired Power with Local Storage
Powered by 16V-24V AC wiring, this doorbell supports local microSD storage up to 256GB, allowing you to save video footage without relying solely on cloud storage.
Essential Doorbell Features
  • Two-way audio for real-time communication.
  • Motion-activated voice deterrence to ward off unwanted visitors.
  • IP65 weather resistance for reliable outdoor use.
  • Compatible with the Wyze Chime Controller for mechanical chime integration.
What’s Included
  • Wyze Video Doorbell v2 unit.
  • Wyze Chime Controller.
  • Installation kit with screws, wire caps, and wall plate.
This wired doorbell is perfect for those who want a reliable, high-quality video doorbell that integrates with existing wiring and supports electronic chimes through the Wyze Chime Controller.
Wyze Chime Controller: Connect Your Wired Doorbell to Mechanical Chimes
Seamless Mechanical Chime Compatibility
The Wyze Chime Controller is a standalone unit designed to connect your Wyze Video Doorbell v2 or Duo Cam Doorbell to nearly any mechanical chime. This means you can keep your traditional chime sound while upgrading to a smart video doorbell.
Easy Installation
With a straightforward wiring process, the chime controller fits neatly inside your existing doorbell chime box, powering the chime and enabling it to ring when your Wyze doorbell is pressed.
Technical Highlights
  • Compatible with AC16V/AC24V power (≥10VA).
  • Compact size (47mm x 32mm x 15mm) fits most chime boxes.
  • Operates reliably in temperatures from -20°C to 50°C.
This controller is essential if you want to maintain your wired chime sound while upgrading to Wyze’s smart doorbell technology.
Why Choose Wyze for Your Wired Doorbell Replacement?
  • Smart Integration: Wyze products work together seamlessly, allowing you to customize alerts and automations through the Wyze app.
  • Flexible Power Options: Whether you prefer wired power or battery options, Wyze offers solutions that fit your home setup.
  • High-Quality Video: Capture clear, detailed video with 2K resolution and wide-angle lenses.
  • Easy Installation: From plug-and-play chimes to simple wiring kits, Wyze makes upgrading your doorbell hassle-free.
  • Reliable Notifications: Stay informed with real-time alerts, two-way audio, and smart detection features.
Summary of Recommended Products
Product NameKey FeatureCompatibilityPrice (Approx.)
Wyze Universal Wi-Fi ChimeWireless, no wiring neededAll Wyze cameras including Duo Cam$19.98
Wyze Video Doorbell v2Wired 2K video doorbell with local storageWorks with Wyze Chime Controller$44.98
Wyze Chime ControllerConnects wired doorbell to mechanical chimesCompatible with Duo Cam & Doorbell v2$17.99
Upgrade your home’s wired doorbell system with Wyze’s smart, compatible, and easy-to-install products. Whether you want a wireless chime or a wired video doorbell with mechanical chime support, Wyze has you covered.
Smart home doorbell in use
Frequently Asked Questions
Can the Wyze Universal Wi-Fi Chime replace my existing wired chime?
Yes, it works without any wiring and can be plugged into any outlet to provide doorbell alerts.
Does the Wyze Video Doorbell v2 support existing mechanical chimes?
Yes, when paired with the Wyze Chime Controller, it can trigger your existing mechanical chime.
Is the Wyze Chime Controller compatible with the Duo Cam Doorbell?
Absolutely, it supports both the Wyze Video Doorbell v2 and the Duo Cam Doorbell.
Enhance your home security and convenience today with Wyze’s wired doorbell replacement options that support electronic chime connections and smart home integration. Homeowner receiving doorbell alert
FeatureWyze Universal Wi-Fi ChimeWyze Video Doorbell v2Wyze Chime Controller
TypeAccessoryCameraAccessory
Price$19.98$44.98$17.99
Video ResolutionN/A2K (2048 x 1536)N/A
Video StorageN/ALocal microSD storage (up to 256GB)N/A
AudioChime alertsTwo-way audio, built-in speaker & microphoneN/A
PowerPlug-in (Wi-Fi enabled)Wired (AC 16-24V)Wired (AC16V/AC24V, ≥10VA)
InstallationPlug-in, no wiringWired installation, includes chime controllerEasy wiring installation
CompatibilityWorks with all Wyze cameras and doorbellsCompatible with Wyze Chime ControllerCompatible only with Wyze Video Doorbell v2 and Duo Cam Doorbell
Chime FunctionalityWireless chime alerts, smart automationsWorks with existing chime via included controllerCompatible with nearly every mechanical chime
Smart FeaturesAutomations to chime on person detectionMotion-activated voice deterrence, pre-roll recording, AI detections with Cam PlusN/A
Mounting OptionsAnywhereScrew mounting, 3M adhesiveN/A
Weather ResistanceIndoor useIP65 WeatherproofOperating temp: -20°C to 50°C
DimensionsNot specified4.3" x 1.7" x 0.9" (110mm x 44mm x 24mm)47mm x 32mm x 15mm
Included in Box1x Wi-Fi ChimeDoorbell + Chime Controller + accessories1x Chime controller unit
Special NotesNo complicated wiring, chimes from anywhereWired doorbell with local storage and two-way talkStandalone chime controller unit
Can the Wyze Universal Wi-Fi Chime replace my existing wired doorbell chime?Yes, the Wyze Universal Wi-Fi Chime is designed to replace traditional wired chimes. It requires no wiring—simply plug it into any power outlet in your home to receive doorbell alerts from your Wyze Duo Cam Doorbell or other Wyze cameras.
Does the Wyze Video Doorbell v2 support existing mechanical chimes?Yes, the Wyze Video Doorbell v2 can work with your existing mechanical chime when paired with the Wyze Chime Controller. This allows you to keep your traditional chime sound while upgrading to a smart video doorbell.
Is the Wyze Chime Controller compatible with the Wyze Duo Cam Doorbell?Absolutely. The Wyze Chime Controller is compatible with both the Wyze Video Doorbell v2 and the Wyze Duo Cam Doorbell, enabling them to trigger most mechanical chimes in your home.
What are the power requirements for the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 requires 16V-24V AC wiring with at least 10VA. This ensures reliable operation and supports features like local microSD storage and two-way audio.
Can I use the Wyze Universal Wi-Fi Chime with any Wyze camera?Yes, the Wyze Universal Wi-Fi Chime is compatible with all Wyze cameras, including the Duo Cam Doorbell. It can be set up to alert you for doorbell presses or when your cameras detect a person.
Does the Wyze Video Doorbell v2 offer local video storage?Yes, the Wyze Video Doorbell v2 supports local microSD storage up to 256GB, allowing you to save video footage without relying solely on cloud storage.
Is the Wyze Video Doorbell v2 weather resistant?Yes, the Wyze Video Doorbell v2 is IP65 weather resistant, making it suitable for reliable outdoor use in various weather conditions.
How easy is it to install the Wyze Chime Controller?The Wyze Chime Controller is designed for easy installation. It fits inside your existing doorbell chime box and connects with straightforward wiring, enabling your mechanical chime to work with Wyze smart doorbells.
What smart features does the Wyze Universal Wi-Fi Chime offer?The Wyze Universal Wi-Fi Chime not only alerts you when someone presses your doorbell but can also notify you when your Wyze cameras detect a person, enhancing your home security and monitoring capabilities.
Can I customize alerts and automations with Wyze doorbell products?Yes, all Wyze doorbell products integrate with the Wyze app, allowing you to customize alerts, set up smart automations, and manage notifications for enhanced home security and convenience.
Can the Wyze Universal Wi-Fi Chime be used with other Wyze cameras besides the Duo Cam Doorbell?What are the installation requirements for the Wyze Chime Controller?Are there any ongoing promotions or discounts available for Wyze products?
