Touch-Free Access with Wyze Lock Bolt
Experience the convenience of a
touch-free access Bluetooth smart lock designed to upgrade your door security effortlessly. The
Wyze Lock Bolt replaces your traditional deadbolt with a sleek, connected home device that offers ultra-fast fingerprint recognition and app-controlled unlocking. Say goodbye to fumbling for keys and hello to seamless entry.
Key Features of Wyze Lock Bolt
- Ultra-Fast Fingerprint Sensor: Unlock your door in less than a second with a simple touch.
- Backlit Keypad with Anti-Peep: Enter your code discreetly even in low light.
- Bluetooth 5.0 Connectivity: Reliable connection up to 16 feet.
- Auto-Lock Function: Automatically locks your door if you forget, enhancing security.
- Built-in Jam Detection Alarm: Alerts you if the lock is tampered with or jammed.
- Emergency One-Time Codes: Share temporary access securely via the Wyze app.
- Weather Resistance: Rated IPX5, suitable for various climates.
- Battery Life: Powered by 4 AA batteries included, lasting 10-12 months.
Specifications
- Colors Available: Matte Black, Satin Nickel
- Weight: 2.75 lbs
- Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick with backset options of 2-3/8” or 2-3/4”
- Operating Temperature: Keypad works from -13°F to 122°F, suitable for indoor assembly temperatures between 32°F and 122°F.
"Unlock your door with just a touch or a tap in the app — no keys needed."
Secure your home effortlessly with Wyze Lock Bolt.
Enhance Your Smart Lock Setup with Wyze Replacement Parts
To keep your Wyze Lock Bolt functioning perfectly, Wyze offers a range of replacement parts designed specifically for this model. These parts ensure your smart lock remains reliable and easy to maintain.
Available Replacement Parts
Wyze Lock Bolt Screws
Keep your lock securely mounted with a set of replacement screws compatible with the Wyze Lock Bolt.
Price: $2.99
Wyze Lock Bolt Interior Assembly Battery Cover
Replace the battery cover to maintain the lock’s sleek look and protect the battery compartment.
Price: $9.99
Wyze Lock Bolt Interior Assembly Metal Plate
A sturdy metal plate to anchor the interior assembly firmly to your door.
Price: $4.99
Wyze Lock Replacement Part Kit
A comprehensive kit including essential parts for quick repairs and replacements, ensuring your lock stays in top condition.
Price: $4.99 - $19.99 depending on kit style
These parts come with a 30-day hassle-free return policy, giving you peace of mind with your purchase.
Complete Your Home Security with The Front Porch Security Bundle
For those looking to elevate their home security beyond just the door lock, the
Front Porch Security Bundle offers an integrated solution combining smart locks and video surveillance.
Bundle Highlights
- Wyze Lock: Control your door lock remotely and monitor lock history via the Wyze app.
- Wyze Video Doorbell: View your front porch in crisp 1080p HD with two-way audio to greet visitors or deter unwanted guests.
- Wyze Chime: Hear doorbell alerts anywhere in your home with multiple sound options.
Why Choose This Bundle?
- Remote locking and unlocking from anywhere.
- Real-time video monitoring with motion detection.
- Works seamlessly with Alexa and Google Assistant.
- Weather-resistant components designed for outdoor use.
"Secure your front porch with smart technology that keeps you connected and in control."
Smart lock and video doorbell for ultimate front porch security.
Why Choose Wyze Touch-Free Bluetooth Smart Locks?
Wyze Lock Bolt stands out as a
refurbished Bluetooth smart lock option that combines affordability with premium features. Its touch-free fingerprint sensor and app integration make it ideal for modern homes seeking convenience and security without the hassle of keys.
- Easy installation replacing your existing deadbolt.
- Long-lasting battery life with included AA batteries.
- Compatible with both Android and iOS devices.
- Auto-lock and alarm features provide peace of mind.
- Stylish design available in Matte Black and Satin Nickel finishes.
Modern design meets smart technology for your door.
Summary
Upgrade your home security with the
Wyze Lock Bolt, a touch-free, Bluetooth-enabled smart lock that offers fast fingerprint access, app control, and robust security features. Complement your lock with genuine Wyze replacement parts for maintenance and consider the Front Porch Security Bundle for a comprehensive smart home security solution.
What is the Wyze Lock Bolt and how does it work?
The Wyze Lock Bolt is a Bluetooth-enabled smart lock that replaces your traditional deadbolt, offering touch-free access with ultra-fast fingerprint recognition and app-controlled unlocking. It allows you to unlock your door in less than a second using your fingerprint or the Wyze app, eliminating the need for keys.What are the key features of the Wyze Lock Bolt?
Key features of the Wyze Lock Bolt include an ultra-fast fingerprint sensor, backlit keypad with anti-peep technology, Bluetooth 5.0 connectivity up to 16 feet, auto-lock function, built-in jam detection alarm, emergency one-time codes, weather resistance (IPX5), and a battery life of 10-12 months using 4 AA batteries.Is the Wyze Lock Bolt compatible with my door?
The Wyze Lock Bolt fits doors that are 1-3/8” to 1-3/4” thick and supports backset options of 2-3/8” or 2-3/4”. It is designed to replace most standard deadbolts.How long does the Wyze Lock Bolt battery last and what type does it use?
The Wyze Lock Bolt is powered by 4 AA batteries, which are included with your purchase. The battery life typically lasts between 10 to 12 months, depending on usage.Can I control the Wyze Lock Bolt with my smartphone?
Yes, you can control the Wyze Lock Bolt using the Wyze app on both Android and iOS devices. The app allows you to unlock the door, share emergency one-time codes, and monitor lock activity.What replacement parts are available for the Wyze Lock Bolt?
Wyze offers several replacement parts for the Lock Bolt, including replacement screws, an interior assembly battery cover, an interior assembly metal plate, and a comprehensive replacement part kit. These parts are designed specifically for the Wyze Lock Bolt and come with a 30-day hassle-free return policy.Is the Wyze Lock Bolt weather resistant?
Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance, making it suitable for various climates. The keypad operates in temperatures from -13°F to 122°F, and the interior assembly is suitable for temperatures between 32°F and 122°F.What is included in the Front Porch Security Bundle?
The Front Porch Security Bundle includes the Wyze Lock for remote door control, the Wyze Video Doorbell for 1080p HD video monitoring with two-way audio, and the Wyze Chime for customizable doorbell alerts throughout your home.Does the Wyze Lock Bolt work with smart home assistants?
Yes, the Wyze Lock Bolt and the Front Porch Security Bundle work seamlessly with Alexa and Google Assistant, allowing for voice control and integration with your smart home ecosystem.How easy is it to install the Wyze Lock Bolt?
The Wyze Lock Bolt is designed for easy installation, replacing your existing deadbolt without the need for professional help. It comes with all necessary hardware and instructions for a straightforward setup.What colors are available for the Wyze Lock Bolt?
The Wyze Lock Bolt is available in two stylish finishes: Matte Black and Satin Nickel, allowing you to choose the best match for your home décor.What is the return policy for Wyze Lock Bolt replacement parts?
All Wyze Lock Bolt replacement parts come with a 30-day hassle-free return policy, ensuring peace of mind with your purchase.
