How to Install a Refurbished Smart Lock on an Existing Deadbolt
Upgrading your home security with a refurbished smart lock is a smart, eco-friendly choice that combines convenience and safety. If you have an existing deadbolt and want to install a smart lock without replacing your entire door hardware, the
Wyze Lock Bolt is an excellent option. This guide will walk you through the installation process and highlight the key features and compatible replacement parts to ensure a smooth setup.
Wyze Lock Bolt: The Ideal Smart Lock Replacement for Your Deadbolt
The
Wyze Lock Bolt is designed to replace your existing deadbolt easily, turning your traditional lock into a high-tech, connected home security device. It offers a seamless blend of security, convenience, and smart features.
Key Features:
- Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a touch of your finger.
- Backlit Keypad with Anti-Peep Technology: Enter your code discreetly, even in low light.
- Auto-Lock Function: Automatically locks your door if you forget, enhancing security.
- Bluetooth 5.0 Connectivity: Reliable wireless communication with a range of up to 16 feet.
- Weather Resistance (IPX5): Durable enough for various climates, operating between -13°F to 122°F.
- Compatible Door Specs: Fits doors 1-3/8” to 1-3/4” thick with a deadbolt diameter of 1”.
- Battery Life: Powered by 4 AA batteries included, lasting 10-12 months.
Installation Highlights:
- The Wyze Lock Bolt replaces your existing deadbolt without the need for complex rewiring.
- It fits standard deadbolt thru-hole diameters (2-1/8”) and backsets (2-3/8” or 2-3/4”).
- Comes in stylish Matte Black or Satin Nickel finishes to match your door hardware.
Installing the Wyze Lock Bolt is straightforward and designed for DIY enthusiasts, making it a perfect upgrade for your home security.
Experience smart home security with Wyze Lock Bolt on your front door.
Essential Replacement Parts for a Perfect Fit and Maintenance
When installing or maintaining your refurbished Wyze Lock Bolt, having the right replacement parts ensures longevity and optimal performance.
Wyze Lock Replacement Part Kit
- Purpose: Contains essential components compatible only with the Wyze Lock.
- Use Case: Ideal for replacing worn or lost parts during installation or repair.
- Affordable: Priced at $19.99 for the full kit or $4.99 for the adapter replacement kit.
- Return Policy: 30-day hassle-free returns for peace of mind.
Wyze Lock Bolt Screws
- Purpose: Replacement screws specifically designed for securing the Wyze Lock Bolt.
- Details: Sold as a set, perfect for installation or if original screws are lost.
- Price: $2.99 with a 30-day return policy.
Wyze Lock Bolt Interior Assembly Battery Cover
- Purpose: Replacement cover for the interior battery compartment.
- Compatibility: Fits only the Wyze Lock Bolt.
- Price: $9.99, ensuring your battery compartment stays protected.
Wyze Lock Bolt Interior Assembly Metal Plate
- Purpose: Metal plate anchors the interior assembly securely to the door.
- Quantity Options: Available in multiple quantities to suit your needs.
- Price: $4.99 with easy returns.
Having these replacement parts on hand can simplify installation and future maintenance, ensuring your smart lock functions flawlessly.
Step-by-Step Installation Guide for Wyze Lock Bolt on Existing Deadbolt
1.
Remove Your Existing Deadbolt
Unscrew and take off the current deadbolt hardware from your door.
2.
Check Door Specifications
Confirm your door thickness (1-3/8” to 1-3/4”) and deadbolt hole diameter (2-1/8”) match Wyze Lock Bolt requirements.
3.
Install the Mounting Plate and Adapter
Use the included mounting plate and adapter to fit the lock securely to your door.
4.
Attach the Wyze Lock Bolt Exterior Assembly
Position the exterior keypad and fingerprint sensor on the outside of your door.
5.
Secure the Interior Assembly
Attach the interior assembly with screws and the metal plate for stability.
6.
Insert Batteries and Cover
Place 4 AA batteries into the interior compartment and secure with the battery cover.
7.
Pair with Wyze App
Connect the lock to your smartphone via Bluetooth 5.0 using the Wyze app for remote control and monitoring.
8.
Test Lock Functionality
Verify fingerprint recognition, keypad entry, and auto-lock features work smoothly.
This installation process is designed to be user-friendly, requiring only basic tools and minimal time.
Easy installation with Wyze Lock Bolt’s backlit keypad and fingerprint sensor.
Enhance Your Home Security with the Front Porch Security Bundle
For a comprehensive smart home security upgrade, consider the
Front Porch Security Bundle which includes the Wyze Lock Bolt along with Wyze Video Doorbell and Chime.
Bundle Features:
- 1080p HD Video Doorbell: Monitor your front porch with clear video and two-way audio.
- Remote Lock/Unlock: Control your door lock from anywhere via the Wyze app.
- Motion Detection & Lock History: Stay informed about visitors and lock activity.
- Smart Assistant Compatibility: Works with Alexa and Google Assistant for voice control.
This bundle offers a complete security solution, combining smart locking with video surveillance for peace of mind.
Conclusion
Installing a refurbished smart lock like the Wyze Lock Bolt on your existing deadbolt is a practical and efficient way to modernize your home security. With easy installation, reliable Bluetooth connectivity, and smart features like fingerprint access and auto-lock, it’s a perfect upgrade for any homeowner. Don’t forget to keep essential replacement parts handy to maintain your lock’s performance over time.
Upgrade your door security today with Wyze Lock Bolt and enjoy the convenience of keyless entry and smart home integration.
What is the Wyze Lock Bolt and how does it upgrade my existing deadbolt?
The Wyze Lock Bolt is a smart lock designed to replace your existing deadbolt, transforming your traditional lock into a high-tech, connected security device. It offers features like fingerprint access, a backlit keypad, auto-lock, and Bluetooth connectivity, making your home more secure and convenient without the need to replace your entire door hardware.Is the Wyze Lock Bolt compatible with my door?
The Wyze Lock Bolt fits doors that are 1-3/8” to 1-3/4” thick and have a deadbolt hole diameter of 2-1/8”. It is compatible with standard deadbolt thru-hole diameters and backsets of 2-3/8” or 2-3/4”.What are the key features of the Wyze Lock Bolt?
Key features of the Wyze Lock Bolt include an ultra-fast fingerprint sensor, a backlit keypad with anti-peep technology, auto-lock function, Bluetooth 5.0 connectivity, weather resistance (IPX5), and a battery life of 10-12 months powered by 4 AA batteries.How do I install the Wyze Lock Bolt on my existing deadbolt?
To install the Wyze Lock Bolt, remove your existing deadbolt, check your door specifications, install the mounting plate and adapter, attach the exterior assembly, secure the interior assembly with screws and the metal plate, insert the batteries and cover, pair the lock with the Wyze app via Bluetooth, and test all lock functions. The process is designed for easy DIY installation.What replacement parts are available for the Wyze Lock Bolt?
Available replacement parts for the Wyze Lock Bolt include the Wyze Lock Replacement Part Kit, Wyze Lock Bolt Screws, Wyze Lock Bolt Interior Assembly Battery Cover, and Wyze Lock Bolt Interior Assembly Metal Plate. These parts help with installation, maintenance, and repair, ensuring your smart lock functions optimally.How long do the Wyze Lock Bolt batteries last and what type do they use?
The Wyze Lock Bolt uses 4 AA batteries, which are included with the lock. The batteries typically last between 10 to 12 months, depending on usage.Can I control the Wyze Lock Bolt remotely?
Yes, you can control the Wyze Lock Bolt remotely via the Wyze app using Bluetooth 5.0 connectivity. For additional remote features, consider the Front Porch Security Bundle, which integrates the lock with the Wyze Video Doorbell and Chime for enhanced smart home control.What is included in the Front Porch Security Bundle?
The Front Porch Security Bundle includes the Wyze Lock Bolt, Wyze Video Doorbell, and Chime. It offers 1080p HD video monitoring, remote lock/unlock via the Wyze app, motion detection, lock history, and compatibility with Alexa and Google Assistant for voice control.What is the return policy for Wyze Lock Bolt replacement parts?
Wyze Lock Bolt replacement parts come with a 30-day hassle-free return policy, allowing you to return items within 30 days for peace of mind.Do I need professional help to install the Wyze Lock Bolt?
No, the Wyze Lock Bolt is designed for easy DIY installation. The process requires only basic tools and minimal time, making it accessible for most homeowners.
